  4. BackItUp erstellt keine backups mehr
31 Beiträge 6 Kommentatoren 3.6k Aufrufe 5 Beobachtet
    @ronk
    Üblicherweise ist es Port 22.
    ronk
    schrieb am zuletzt editiert von ronk
    @thomas-braun said in BackItUp erstellt keine backups mehr:
    @ronk
    so. bin jetzt drauf. musste ssh starten.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     18:03:16 up 13 min,  2 users,  load average: 1.04, 1.36, 1.08
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-04 18:03:16 CET
               Universal time: Mon 2023-12-04 17:03:16 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ronny
    /home/ronny
    ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.5G        660M        128M        1.6G        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.5G        760M
             3794 M total memory
             1520 M used memory
             2271 M active memory
              428 M inactive memory
              660 M free memory
              138 M buffer memory
             1474 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * rc-local.service loaded failed failed /etc/rc.local Compatibility
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   15G   13G  55% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  3.4M  756M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Mon Dec  4 17:49:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1680x1050M@60 smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Dec  4 17:49:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Dec  4 17:50:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    10G     /var/
    7.6G    /var/lib
    7.4G    /var/lib/docker
    6.9G    /var/lib/docker/overlay2
    1.2G    /var/log/journal/55f00fb070744f2da4bf0d8a099975a6
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    196M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    205M    /opt/iobroker/iobroker-data/
    155M    /opt/iobroker/iobroker-data/files
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solax"        : 0.8.0    , installed 0.8.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        3135
    States:         3111
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://download.docker.com/linux/debian bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       20354      3429/io.mqtt.0
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15448      951/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23613      3593/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15447      951/smbd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11746      547/cupsd
    tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          18017      1552/docker-proxy
    tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17908      1369/docker-proxy
    tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          17964      1465/docker-proxy
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       15968      733/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       16007      733/iobroker.js-con
    tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          17067      1514/docker-proxy
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          11130      577/vncserver-x11-c
    tcp6       0      0 :::139                  :::*                    LISTEN      0          15446      951/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          23615      3593/sshd: /usr/sbi
    tcp6       0      0 :::445                  :::*                    LISTEN      0          13274      951/smbd
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        16296      732/grafana
    tcp6       0      0 :::7190                 :::*                    LISTEN      0          18545      1559/docker-proxy
    tcp6       0      0 :::7194                 :::*                    LISTEN      0          17911      1376/docker-proxy
    tcp6       0      0 :::3100                 :::*                    LISTEN      0          17967      1471/docker-proxy
    tcp6       0      0 :::4000                 :::*                    LISTEN      0          17072      1522/docker-proxy
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       22110      3489/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       22130      3535/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15368      564/influxd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11745      547/cupsd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          11129      577/vncserver-x11-c
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15318      480/dhcpcd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23297      550/nmbd
    udp        0      0 169.254.251.49:137      0.0.0.0:*                           0          23296      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23293      550/nmbd
    udp        0      0 169.254.224.59:137      0.0.0.0:*                           0          23292      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23289      550/nmbd
    udp        0      0 169.254.176.113:137     0.0.0.0:*                           0          23288      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23285      550/nmbd
    udp        0      0 169.254.166.163:137     0.0.0.0:*                           0          23284      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23281      550/nmbd
    udp        0      0 169.254.137.51:137      0.0.0.0:*                           0          23280      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23277      550/nmbd
    udp        0      0 169.254.124.18:137      0.0.0.0:*                           0          23276      550/nmbd
    udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23273      550/nmbd
    udp        0      0 169.254.88.37:137       0.0.0.0:*                           0          23272      550/nmbd
    udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          17877      550/nmbd
    udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          17876      550/nmbd
    udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          17873      550/nmbd
    udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          17872      550/nmbd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13186      550/nmbd
    udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          13185      550/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12987      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23299      550/nmbd
    udp        0      0 169.254.251.49:138      0.0.0.0:*                           0          23298      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23295      550/nmbd
    udp        0      0 169.254.224.59:138      0.0.0.0:*                           0          23294      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23291      550/nmbd
    udp        0      0 169.254.176.113:138     0.0.0.0:*                           0          23290      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23287      550/nmbd
    udp        0      0 169.254.166.163:138     0.0.0.0:*                           0          23286      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23283      550/nmbd
    udp        0      0 169.254.137.51:138      0.0.0.0:*                           0          23282      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23279      550/nmbd
    udp        0      0 169.254.124.18:138      0.0.0.0:*                           0          23278      550/nmbd
    udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23275      550/nmbd
    udp        0      0 169.254.88.37:138       0.0.0.0:*                           0          23274      550/nmbd
    udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          17879      550/nmbd
    udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          17878      550/nmbd
    udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          17875      550/nmbd
    udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          17874      550/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13188      550/nmbd
    udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          13187      550/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12988      550/nmbd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11761      620/cups-browsed
    udp        0      0 0.0.0.0:33728           0.0.0.0:*                           108        12911      414/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12909      414/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13087      480/dhcpcd
    udp6       0      0 :::41701                :::*                                108        12912      414/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12910      414/avahi-daemon: r
    2023-12-04 17:51:54.035  - info: tesla-motors.0 (3601) Session loaded
    2023-12-04 17:51:54.036  - info: tesla-motors.0 (3601) Refresh session
    2023-12-04 17:51:54.991  - info: tesla-motors.0 (3601) Receive device list
    2023-12-04 17:51:55.323  - info: tesla-motors.0 (3601) Found 1 devices
    2023-12-04 17:51:56.689  - info: accuweather.0 (3616) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.16
    2023-12-04 17:51:56.876  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.energy_cost_breakdown.home.raw_value" has to be type "number" but received type "string"
    2023-12-04 17:51:57.252  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values05.raw_value" has to be type "number" but received type "string"
    2023-12-04 17:51:57.253  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values06.raw_value" has to be type "number" but received type "string"
    2023-12-04 17:51:57.279  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values05.raw_value" has to be type "string" but received type "number"
    2023-12-04 17:51:57.283  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values06.raw_value" has to be type "string" but received type "number"
    2023-12-04 17:51:58.296  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 3633
    2023-12-04 17:52:00.793  - info: vis-inventwo.0 (3633) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.19.0, js-controller: 5.0.16
    2023-12-04 17:52:03.015  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJ3xxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
    2023-12-04 17:52:03.411  - info: host.raspberrypi instance system.adapter.solax.0 started with pid 3649
    2023-12-04 17:52:05.781  - info: solax.0 (3649) starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.solax, node: v18.19.0, js-controller: 5.0.16
    2023-12-04 17:52:06.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3665
    2023-12-04 17:52:09.178  - info: backitup.0 (3665) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.16
    2023-12-04 17:52:09.278  - info: backitup.0 (3665) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-12-04 17:52:09.683  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2023-12-04 17:53:56.485  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
    2023-12-04 17:54:38.261  - info: admin.0 (3489) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2023-12-04 17:57:09.577  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2023-12-04 18:01:56.126  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
    2023-12-04 18:02:09.564  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2023-12-04 18:03:02.529  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
    • R ronk
      @ronk
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ronny
      /home/ronny
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
               1520 M used memory
                660 M free memory
                138 M buffer memory
               1474 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      10G     /var/
      7.6G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3135
      States:         3111
      Pending Updates: 0
      @ronk
      Immer sauber rebooten, nie einfach vom Strom reißen.
        ronk
        nochmal booten?
        • R ronk
          nochmal booten?
          @ronk
          War eigentlich ein allgemeiner Hinweis zum Umgang mit einem Betriebssystem. Die mögen das alle nicht.
            ronk
                                    v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            MEMORY:
            Mem:            3.8G        1.6G        485M        129M        1.7G        1.9G
            Swap:            99M          0B         99M
            Total:          3.9G        1.6G        585M
            Active iob-Instances:   14
            ioBroker Core:          js-controller           5.0.16
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                3135
            States:                 3110
            Size of iob-Database:
            1.1M    /opt/iobroker/iobroker-data/states.jsonl
              ronk
              Influx db Sicherung läuft nun. Richtiger Token hilft. In Grafana finde ich keinen Token. Wo kann ich einen erstellen?
              • R ronk
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                @ronk sagte in BackItUp erstellt keine backups mehr:
                Service Accounts --> Add service account (Role "Admin") --> Token
                R 1 Antwort Letzte Antwort
                • Marc BergM Marc Berg
                  ronk
                  @marc-berg
                  Danke. Display name auch admin? Oder ist das egal?
                  • R ronk
                    @marc-berg
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    Oder ist das egal?
                    Egal ...
                      Oder ist das egal?
                      Egal ...
                      ronk
                      @marc-berg
                      Danke. Das wars. Sicherung läuft durch. Token...
                      Ich danke euch.
                      Viele Grüße.
                        @homoran sagte in BackItUp erstellt keine backups mehr:
                        @eulo
                        @simatec
                        passt das zusammen?
                        https://forum.iobroker.net/topic/68975/backitup-arbeit-einfach-nicht-mehr/8
                        Ne, die Fehlermeldung ist aus meiner Sicht eindeutig, der Mount mountet nicht. Auch wenn @Eulo sagt, dass es daran nicht liegen kann.
                        @Eulo kannst du denn manuell mounten?
                        EuloE Offline
                        EuloE Offline
                        Eulo
                        @marc-berg wie mounte ich denn manuell?
