  5. Material design calendar widget ical konvertierung
1 Beiträge 1 Kommentatoren 233 Aufrufe 1 Beobachtet
  • G Offline
    grazer2500
    Ich habe das material design widget und den ical Adapter installiert.
    Und auch soweit konfiguriert.
    Im ical Adapter werden alle Termine angezeigt. Aber bei der Visualisierung im material design calendar widget mit dem Script werden mir nicht alle Termine angezeigt.
    Welche Informationen braucht ihr um das nachzuvollziehen?
    // momentjs is required as dependecies in javascript adapter
    const moment = require("moment");
    var instances = $(`[id=ical.*.data.table]`);
    instances.on(ical2CalendarWidget);
    // remove this, if you know to use your own datapoint
    let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
    createState(datapointId, "[]", {
      read: true,
      write: false,
      desc: "JSON String for Calendar Widget",
      type: "string",
      def: "[]"
    function ical2CalendarWidget() {
        try {
            let calList = [];
            for (var inst = 0; inst <= instances.length - 1; inst++) {
                let icalObj = getState(instances[inst]).val;
                if (icalObj) {
                    for (var i = 0; i <= icalObj.length - 1; i++) {
                        let item = icalObj[i];
                        // extract calendar color
                        let calendarName = item._class.split(' ')[0].replace('ical_', '');
                        let startTime = moment(item._date);
                        let endTime = moment(item._end);
                        let start = startTime.format("YYYY-MM-DD HH:mm");
                        let end = endTime.format("YYYY-MM-DD HH:mm");
                        if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                            // is full-day event
                            if (endTime.diff(startTime, 'hours') === 24) {
                                // full-day event, one day
                                start = startTime.format("YYYY-MM-DD");
                                end = startTime.format("YYYY-MM-DD");
                            } else {
                                // full-day event, multiple days
                                end = endTime.format("YYYY-MM-DD");
                        // create object for calendar widget
                        calList.push({
                            color: getMyCalendarColor(calendarName),
                            colorText: getMyCalendarTextColor(calendarName),
                            start: start,
                            end: end
                    function getMyCalendarColor(calendarName) {
                        // assign colors via the calendar names, use calendar name as set in ical
                        if (calendarName === 'calendar1') {
                            return '#FF0000';
                        } else if (calendarName === 'calendar2') {
                            return '#44739e'
                        } else if (calendarName === 'calendar3') {
                            return '#32a852'
                    function getMyCalendarTextColor(calendarName) {
                            return '#FFFFFF';
                            return '#FFFFFF'
                            return '#FFFFFF'
                // Enter the destination data point that is to be used as object ID in the widget
                setState(datapointId, JSON.stringify(calList), true);
        } catch (e) {
            console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
    ical2CalendarWidget();
    Habe alle Termine zensiert, sollte aber erkennbar sein das viele fehlen
    Bildschirmfoto vom 2023-11-29 10-06-54.png Bildschirmfoto vom 2023-11-29 10-07-21.png Bildschirmfoto vom 2023-11-29 10-07-08.png
