  4. Zigbee Probleme mit tradfri und eine Frage zum Adapter
    5.1k
32 Beiträge 5 Kommentatoren 5.5k Aufrufe 5 Beobachtet
  • arteckA arteck
    @stefan_nk doch hat es..
    einz nach dem anderen ..
    der adapter knallt nicht mehr..
    der configure ist jetzt das problem...
    geht den die andere Birne ??? kannst du die steuern ??
    Stefan_NK
    @arteck Bei der zweiten Lampe bekomme ich den gleichen Fehler
    2023-11-15 08:17:04.234 - info: admin.0 (1049) ==> Connected system.user.admin from ::ffff:192.168.179.35
    2023-11-15 08:17:04.630 - info: zigbee.0 (157474) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2469688","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469688-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
    2023-11-15 08:17:13.631 - info: zigbee.0 (157474) Zigbee: allowing new devices to join.
    2023-11-15 08:17:38.001 - info: zigbee.0 (157474) Starting interview of '0xb43522fffe9b547b'
    2023-11-15 08:17:38.046 - info: zigbee.0 (157474) Device '0xb43522fffe9b547b' announced itself
    2023-11-15 08:17:39.775 - info: zigbee.0 (157474) Successfully interviewed '0xb43522fffe9b547b', device has successfully been paired
    2023-11-15 08:17:39.775 - info: zigbee.0 (157474) Device '0xb43522fffe9b547b' is supported, identified as: IKEA TRADFRI LED bulb E27 1055 lumen, dimmable, white spectrum (LED2201G8)
    2023-11-15 08:17:39.777 - info: zigbee.0 (157474) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
    2023-11-15 08:17:39.787 - error: zigbee.0 (157474) DeviceConfigure:Failed to DeviceConfigure.configure 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm (TypeError: Cannot read properties of undefined (reading 'configure')
    at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:37)
    at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:113:21))
    2023-11-15 08:18:14.900 - info: zigbee.0 (157474) Zigbee: stop joining
    2023-11-15 08:18:28.317 - info: admin.0 (1049) <== Disconnect system.user.admin from ::ffff:192.168.179.35
    Ich habe schon länger eine LED1836G9 eingebunden, die funktioniert einwandfrei.
    • S Stefan_NK
      arteckA Offline
      arteckA Offline
      arteck
      @stefan_nk installiere mal die GIT version ..jetzt
      nochmal.. es ist egal ob die Birne gleich aussieht oder die gleiche Bezeichnung auf der Verpakung steht..
      wenn die Birne sich anders meldet dann hat Ikea die interne Modellnummer geändert..
      • arteckA arteck
        Stefan_NK
        @arteck
        Super 👍 👍 Vielen, vielen Dank. Wirklich spitze, dass das jetzt doch so schnell geklappt hat. Bist ein Wahnsinn.
        Beide Lampen konnten gepairt werden. Die E14 hat zwar kein Symbol, aber das it ja egal. Beide lassen sich steuern.
        Soll ich bei der nächsten offiziellen Version von der Github Installation wieder weg? Wie kann ich dann zurück zur "normalen" Version?
        Thomas BraunT arteckA 2 Antworten Letzte Antwort
        • S Stefan_NK
          @arteck
          @stefan_nk sagte in Zigbee Probleme mit tradfri und eine Frage zum Adapter:
          Einfach weiter Updates wie gewohnt einspielen, wenn Sie angeboten werden.
          Eine 1.8.25 kommt dann darüber rein.
          • S Stefan_NK
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            @stefan_nk erstmal so lassen.. ausser du brauchst was . sonst sind die Änderungen im /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js weg
            da muss ich noch jemanden überzeugen das da ein Bug ist
            • arteckA arteck
              Stefan_NK
              @arteck Einmal bin ich es noch... Es scheint dank Euch alles zu funktionieren. Die Steuerung über VIS und Blockly funktioniert wie geplant.
              Im LOG bekomme ich immer einen info-Eintrag. Etwa alle 5 Minuten, aber nur über die beiden Lampen. Die anderen Zigbee Geräte machen das nicht. Nur... falls es wichtig wäre....
              2023-11-15 18:31:52.238 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:31:52.757 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
              2023-11-15 18:36:52.343 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:36:52.864 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
              2023-11-15 18:41:52.454 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:41:52.975 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
              2023-11-15 18:46:52.566 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:46:53.082 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
              2023-11-15 18:51:52.680 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:51:53.185 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
              2023-11-15 18:56:52.787 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
              2023-11-15 18:56:53.296 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                TomComm27
                ich habe gerade viel ausprobiert mit Externe Konverter und Co aber es funktioniert einfach nicht dass das Gerät richtig erkannt wird!
                Ich verwende den zigbee2mqtt Adapter deswegen bin ich mir nicht sicher ob ich es genauso machen muss/kann mit der Github version? Und wenn ja wie geht das?😨
                Hier meine Infos:
                /opt/zigbee2mqtt/data/configuration.yaml
                homeassistant: false
                permit_join: true
                frontend:
                  port: 80xx
                  host: 192.xxx.xxx.xxx
                mqtt:
                  base_topic: zigbee2mqtt
                  server: mqtt://192.xxx.xxx.xxx:xxxx
                  user: xxx
                  password: xxxxxxxxxxx
                  keepalive: 60
                  reject_unauthorized: true
                  version: 4
                  client_id:
                serial:
                  port: /dev/ttyACM0
                advanced:
                  pan_id: 10328
                  ext_pan_id:
                    - 221
                    - xxx
                    - xxx
                    - xxx
                    - xxx
                    - xxx
                    - xxx
                    - xxx
                  channel: 11
                  network_key:
                    - 38
                    - 73
                    - 42
                    - 108
                    - 105
                    - 179
                    - 130
                    - 245
                    - xxx
                    - xx
                    - xxx
                    - xx
                    - xxx
                    - xxx
                    - xxx
                    - xxx
                  last_seen: ISO_8601_local
                  legacy_api: false
                  legacy_availability_payload: false
                  homeassistant_legacy_entity_attributes: false
                  cache_state: false
                  output: json
                  log_level: info
                device_options:
                  legacy: false
                availability: true
                devices: devices.yaml
                Hier die Log Meldung:
                2023-11-29 14:12:40Zigbee: allowing new devices to join.
                Info 2023-11-29 14:12:42MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"udfh5-8"}'
                Info 2023-11-29 14:13:10Device '0xb43522fffe814999' joined
                Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999"},"type":"device_joined"}'
                Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:09+01:00"}'
                Info 2023-11-29 14:13:10Starting interview of '0xb43522fffe814999'
                Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999","status":"started"},"type":"device_interview"}'
                Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:10+01:00","linkquality":255}'
                Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:10+01:00","linkquality":255}'
                Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:11+01:00","linkquality":255}'
                Info 2023-11-29 14:13:11Successfully interviewed '0xb43522fffe814999', device has successfully been paired
                Warning 2023-11-29 14:13:11Device '0xb43522fffe814999' with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":null,"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999","status":"successful","supported":false},"type":"device_interview"}'
                Warning 2023-11-29 14:13:35Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                Warning 2023-11-29 14:13:35Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Info 2023-11-29 14:13:35MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:34+01:00","linkquality":255}'
                Warning 2023-11-29 14:13:38Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                Warning 2023-11-29 14:13:38Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Info 2023-11-29 14:13:38MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:37+01:00","linkquality":255}'
                Warning 2023-11-29 14:13:41Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                Warning 2023-11-29 14:13:41Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Info 2023-11-29 14:13:41MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:40+01:00","linkquality":255}'
                Warning 2023-11-29 14:13:43Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                Warning 2023-11-29 14:13:44Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Info 2023-11-29 14:13:44MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:43+01:00","linkquality":255}'
                Warning 2023-11-29 14:13:46Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                Warning 2023-11-29 14:13:46Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                Ich hoffe die Lösung ist genauso easy wie bei Stefan :)
                Fg Tomas
                • T TomComm27
                  Hier meine Infos:
                  permit_join: true
                  frontend:
                    port: 80xx
                  mqtt:
                    user: xxx
                    keepalive: 60
                    version: 4
                    client_id:
                  serial:
                    port: /dev/ttyACM0
                  advanced:
                    pan_id: 10328
                    ext_pan_id:
                      - 221
                      - xxx
                      - xxx
                      - xxx
                      - xxx
                      - xxx
                      - xxx
                      - xxx
                    channel: 11
                    network_key:
                      - 38
                      - 73
                      - 42
                      - 108
                      - 105
                      - 179
                      - 130
                      - 245
                      - xxx
                      - xx
                      - xxx
                      - xx
                      - xxx
                      - xxx
                      - xxx
                      - xxx
                    legacy_api: false
                    cache_state: false
                    output: json
                    log_level: info
                  device_options:
                    legacy: false
                  availability: true
                  Fg Tomas
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @tomcomm27 einfach ist alles wenn man weiss wie es zu machen ist..
                  leider ist im zigbee2mqtt project es eben nicht SO einfach... da musst du auf ne neue Version warten..sonst musst du den branch wechseln.was wiedderum mit Problem her kommt da du dann auf DEV Version bist und diese nicht immer funktioniert..
                  also abwarten
                  @stefan_nk installier mal die GIT version des adapter.. dann sollte die Meldung weg sein
                  • arteckA arteck
                    also abwarten
                    TomComm27
                    @arteck danke schon mal für die Info!
                    Das ich es richtig verstehe...falls mein Ikea Licht wirklich die 2107C4 ist und das zigbee2mqtt projekt diese schon auf ihrer Homepage als Unterstütztes Gerät drinnen haben heißt das noch nicht das dies in der derzeit aktuellsten zigbee2mqtt Version schon deinnen ist?🤪
                    • T TomComm27
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @tomcomm27 ja es ist gelistet weil es in DEV unterstützt wird.
                      die 1.34 ist draussen
                      • arteckA arteck
                        TomComm27
                        @arteck beim iobroker zigbee2mqtt Adapter hat sich ja die Cersion von 2.13.3 nich geändert🤔
                        Wie bekomme ich die neue Version aktualisiert?
                        Muss ich das im Terminal machen nicht im iobroker?
                        Danke!
                        • T TomComm27
                          Danke!
                          TomComm27
                          @tomcomm27 hab es schon selber hinbekommen!
                          Im Raspberry im Terminal folgendes ausführen:
                          cd /opt/zigbee2mqtt
                          ./update.sh
                          Lampe wird jetzt komplett erkannt👍
