  4. Adapterwarnungen / web stürzt ab
    2.9k
    4.9k
    4.1k
63 Beiträge 6 Kommentatoren 8.7k Aufrufe 5 Beobachtet
  • MichaelFM MichaelF
    @thomas-braun said in Adapterwarnungen / web stürzt ab:
    @michaelf
    Die fehlen aus Sicht von npm.
    Ich weiß aber nicht wie der ham-Adapter das handhabt.
    Mal neu trüber installieren ?
    #41
    @michaelf
    Vermutlich nur die ham-Module nochmal reinjubeln.
    MichaelFM 1 Antwort Letzte Antwort
      @michaelf
      MichaelFM Offline
      MichaelFM Offline
      MichaelF
      #42
      @michaelf
      In Arbeit
      • MichaelFM Offline
        MichaelFM Offline
        MichaelF
        #43
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.25-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         22:15:39 up  2:30,  1 user,  load average: 1.57, 1.65, 1.71
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-11-08 22:15:40 CET
                   Universal time: Wed 2023-11-08 21:15:40 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        3.0G        3.3G        1.0M        1.6G        4.7G
        Swap:            99M          0B         99M
        Total:          7.9G        3.0G        3.4G
                 7811 M total memory
                 2968 M used memory
                 3133 M active memory
                  984 M inactive memory
                 3258 M free memory
                  318 M buffer memory
                 1266 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   17G   95G  15% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems \(real ones only\):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime,stripe=8191
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        4.4G    /var/
        3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
        3.6G    /var/log
        574M    /var/cache
        Archived and active journals take up 3.5G in the file system.
        /opt/iobroker/backups:
        826M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.0G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/sqlite
        659M    /opt/iobroker/iobroker-data/files
        132M    /opt/iobroker/iobroker-data/backup-objects
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
        49M     /opt/iobroker/iobroker-data/states.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
        npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
        npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
        npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
        npm ERR! extraneous: tslib@2.4.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
        npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.4
        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T21_15_50_546Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   9
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
        + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
        + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
          system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
        + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
        + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
        + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
        + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
        + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
        + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
        + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
        + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
        + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "device-watcher": 2.9.4   , installed 2.9.4
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hekr"         : 0.0.6    , installed 0.0.6
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "midea"        : 0.0.7    , installed 0.1.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "psa"          : 0.0.11   , installed 0.0.11
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "s7"           : 1.3.15   , installed 1.3.15
        Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        28839
        States:         24330
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
        tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
        tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
        tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
        tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
        tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
        tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
        tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
        tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
        udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
        udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
        udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
        udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
        udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
        2023-11-08 22:13:47.920  - info: host.iobroker stopInstance system.adapter.ham.0 send kill signal
        2023-11-08 22:13:48.530  - info: host.iobroker instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-08 22:13:51.656  - info: host.iobroker instance system.adapter.ham.0 started with pid 9182
        2023-11-08 22:13:59.930  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 22:14:00.117  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9213
        2023-11-08 22:14:02.468  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478042468_9572
        2023-11-08 22:14:07.867  - info: luftdaten.0 (9213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 22:14:08.618  - info: luftdaten.0 (9213) Terminated (NO_ERROR): Without reason
        2023-11-08 22:14:09.228  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-11-08 22:14:41.287  - info: admin.0 (17298) ==> Connected system.user.admin from ::ffff:192.168.178.52
        2023-11-08 22:14:53.476  - info: admin.0 (17298) <== Disconnect system.user.admin from ::ffff:192.168.178.52 ham
        2023-11-08 22:15:00.071  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9336
        2023-11-08 22:15:00.709  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 22:15:01.255  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478101254_3328
        2023-11-08 22:15:08.139  - info: dwd.0 (9336) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 22:15:11.054  - info: dwd.0 (9336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-08 22:15:11.882  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-08 22:15:59.500  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 22:16:00.460  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9883
        2023-11-08 22:16:02.080  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478162080_8235
        2023-11-08 22:16:09.485  - info: luftdaten.0 (9883) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 22:16:11.630  - info: luftdaten.0 (9883) Terminated (NO_ERROR): Without reason
        2023-11-08 22:16:12.196  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-11-08 22:17:00.326  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 22:17:00.872  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478220871_7431
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7811 M total memory
                   2968 M used memory
                   3258 M free memory
                    318 M buffer memory
                   1266 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          4.4G    /var/
          3.6G    /var/log
          574M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        28839
          States:         24330
          Pending Updates: 0
          #44
          @michaelf sagte in Adapterwarnungen / web stürzt ab:
          Da wird im javascript-Adapter das Modul fehlen. Brauchst du das überhaupt?
            MichaelFM Offline
            MichaelFM Offline
            MichaelF
            #45
            Ja auch grade gesehen, und neu eingetragen seit dem läuft der Adapter wieder.
            Moment neuer Diag
            • MichaelFM Offline
              MichaelFM Offline
              MichaelF
              #46
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : armhf
               22:25:47 up  2:40,  1 user,  load average: 2.07, 2.07, 1.94
              CPU threads: 4
              Current issues:
                             Local time: Wed 2023-11-08 22:25:47 CET
                         Universal time: Wed 2023-11-08 21:25:47 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.8G        3.3G        2.8G        1.0M        1.7G        4.4G
              Swap:            99M          0B         99M
              Total:          7.9G        3.3G        2.9G
                       7811 M total memory
                       3290 M used memory
                       3449 M active memory
                       1073 M inactive memory
                       2841 M free memory
                        326 M buffer memory
                       1352 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              4.4G    /var/
              3.6G    /var/log
              574M    /var/cache
              61M     /opt/iobroker/iobroker-data/states.jsonl
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        28839
              States:         24407
              Pending Updates: 0
              2023-11-08 22:25:39.551  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
              2023-11-08 22:25:39.552  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
              2023-11-08 22:25:40.711  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
              2023-11-08 22:25:59.446  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
              2023-11-08 22:26:00.445  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 13249
              2023-11-08 22:26:02.012  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478762011_8296
              2023-11-08 22:26:12.328  - info: luftdaten.0 (13249) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
              2023-11-08 22:26:14.168  - info: luftdaten.0 (13249) Terminated (NO_ERROR): Without reason
              2023-11-08 22:26:15.000  - warn: luftdaten.0 (13249) get state error: Connection is closed.
              2023-11-08 22:26:15.340  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
              2023-11-08 22:27:00.253  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
              2023-11-08 22:27:00.796  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478820795_8708
              Alle Fehler Weg............
              Mega, Riesen Dank
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7811 M total memory
                         3290 M used memory
                         2841 M free memory
                          326 M buffer memory
                         1352 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                4.4G    /var/
                3.6G    /var/log
                574M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        28839
                States:         24407
                Pending Updates: 0
                Mega, Riesen Dank
                #47
                auch alle extraneous im npm tree??
                wie kommt man suf soooo viele Adapter aus Github?
                MichaelFM 2 Antworten Letzte Antwort
                • MichaelFM Offline
                  MichaelFM Offline
                  MichaelF
                  #48
                  Ich lasse heute Nacht ein Backup laufen und versuche morgen Abend nochmal das Update des Web Adapters.
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    #49
                    @homoran said in Adapterwarnungen / web stürzt ab:
                    Ich Schaue, Moment
                    • MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      #50
                      pi@iobroker:~ $ npm ls
                      pi@ /home/pi
                      └── canvas@2.9.3
                      pi@iobroker:~ $
                        MichaelFM Offline
                        MichaelFM Offline
                        MichaelF
                        #51
                        Mmh, mit den Adaptern ist halt irgendwie so gewachsen. Also da war jetzt nicht irgendwie Absicht dahinter
                          #52
                          immer wieder ins normale Repo überführen wenn vorhanden
                            pi@ /home/pi
                            └── canvas@2.9.3
                            pi@iobroker:~ $
                            #53
                            @michaelf
                            cd /opt/iobroker
                            npm ls
                            canvas haste mal daneben geworfen... ;-)
                              MichaelFM Offline
                              MichaelFM Offline
                              MichaelF
                              #54
                              Das hatte ich nie gemacht, aber in Zukunft.............
                                @michaelf
                                cd /opt/iobroker
                                npm ls
                                MichaelFM Offline
                                MichaelFM Offline
                                MichaelF
                                #55
                                @michaelf
                                cd /opt/iobroker
                                npm ls
                                Das erklärt einiges...........
                                pi@iobroker:/opt/iobroker $ npm ls
                                iobroker.inst@3.0.0 /opt/iobroker
                                ├── @types/caseless@0.12.2 extraneous
                                ├── @types/request@2.48.8 extraneous
                                ├── @types/tough-cookie@4.0.2 extraneous
                                ├── buffer-shims@1.0.0 extraneous
                                ├── coffeescript@1.12.7 extraneous
                                ├── futoin-hkdf@1.4.3 extraneous
                                ├── homebridge-plugin-wrapper@3.2.0 extraneous
                                ├── iobroker.accuweather@1.3.1
                                ├── iobroker.admin@6.12.0
                                ├── iobroker.alexa2@3.25.5
                                ├── iobroker.backitup@2.8.7
                                ├── iobroker.bosesoundtouch@0.10.3
                                ├── iobroker.broadlink2@2.1.5
                                ├── iobroker.device-reminder@3.0.0
                                ├── iobroker.device-watcher@2.9.4
                                ├── iobroker.devices@1.1.5
                                ├── iobroker.discovery@3.1.0
                                ├── iobroker.dwd@2.8.5
                                ├── iobroker.echarts@1.5.1
                                ├── iobroker.energiefluss-erweitert@0.0.2-alpha.20 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#07858bd9e4cbb8e005a3585cf5a480650fc47296)
                                ├── iobroker.envertech-pv@1.0.2
                                ├── iobroker.evcc@0.0.10
                                ├── iobroker.eventlist@1.2.3
                                ├── iobroker.fb-checkpresence@1.2.2
                                ├── iobroker.fritzdect@2.3.1
                                ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#f7d8e7ac363adbe19b99c060d77895097228d7ca)
                                ├── iobroker.ham@5.3.1
                                ├── iobroker.hekr@0.0.6
                                ├── iobroker.history@3.0.1
                                ├── iobroker.hm-rega@3.0.47
                                ├── iobroker.hm-rpc@1.15.19
                                ├── iobroker.ical@1.13.3
                                ├── iobroker.icons-material-png@0.1.0
                                ├── iobroker.icons-mfd-png@1.1.0
                                ├── iobroker.icons-mfd-svg@1.1.0
                                ├── iobroker.icons-open-icon-library-png@0.1.2
                                ├── iobroker.influxdb@3.2.0
                                ├── iobroker.info@2.0.0
                                ├── iobroker.iot@1.14.5
                                ├── iobroker.javascript@7.1.4
                                ├── iobroker.js-controller@5.0.12
                                ├── iobroker.logparser@2.2.0
                                ├── iobroker.luftdaten@3.1.0
                                ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#262717eed55656f1c79056eccd8c209666015421)
                                ├── iobroker.mqtt-client@1.6.5
                                ├── iobroker.mqtt@4.1.1
                                ├── iobroker.nuki@1.6.0
                                ├── iobroker.nut@1.6.0
                                ├── iobroker.octoprint@5.1.0
                                ├── iobroker.parcel@0.0.27
                                ├── iobroker.pi-hole@1.3.6
                                ├── iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#6902280218c6709de322058c19704839f241c069)
                                ├── iobroker.psa@0.0.11
                                ├── iobroker.pvforecast@2.9.0
                                ├── iobroker.rpi2@1.3.2
                                ├── iobroker.s7@1.3.15
                                ├── iobroker.sainlogic@0.10.5
                                ├── iobroker.shelly@6.6.1
                                ├── iobroker.simple-api@2.7.2
                                ├── iobroker.socketio@6.5.5
                                ├── iobroker.sonoff@2.5.3
                                ├── iobroker.sql@2.2.0
                                ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                                ├── iobroker.synology@3.0.1
                                ├── iobroker.tankerkoenig@3.3.7
                                ├── iobroker.telegram@2.0.1
                                ├── iobroker.tr-064@4.2.18
                                ├── iobroker.trashschedule@2.3.0
                                ├── iobroker.tuya@3.14.2
                                ├── iobroker.upnp@1.0.21
                                ├── iobroker.vis-bars@0.1.4
                                ├── iobroker.vis-canvas-gauges@1.0.1
                                ├── iobroker.vis-colorpicker@2.0.3
                                ├── iobroker.vis-google-fonts@1.0.4
                                ├── iobroker.vis-history@1.0.0
                                ├── iobroker.vis-hqwidgets@1.4.0
                                ├── iobroker.vis-icontwo@0.96.0
                                ├── iobroker.vis-inventwo@3.3.3
                                ├── iobroker.vis-jqui-mfd@1.0.12
                                ├── iobroker.vis-justgage@1.0.2
                                ├── iobroker.vis-material@0.1.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-material.git#0384950a1e05ec2fa6b6c4bb774afa5e97a13b6c)
                                ├── iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
                                ├── iobroker.vis-metro@1.2.0
                                ├── iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                ├── iobroker.vis-players@0.1.6
                                ├── iobroker.vis-rgraph@0.0.2
                                ├── iobroker.vis-timeandweather@1.2.2
                                ├── iobroker.vis@1.4.16
                                ├── iobroker.web@6.1.2
                                ├── iobroker.worx@2.3.4
                                ├── iobroker.ws@2.5.5
                                ├── mock-require@3.0.3 extraneous
                                ├── node-inspect@2.0.0 extraneous
                                ├── node-persist@0.0.11 extraneous
                                ├── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                                ├── q@1.1.2 extraneous
                                ├── string-argv@0.3.1 extraneous
                                ├── typescript@5.1.6 extraneous
                                ├── virtual-tsc@0.6.2 extraneous
                                └── wake_on_lan@1.0.0 extraneous
                                  @michaelf
                                  cd /opt/iobroker
                                  npm ls
                                  #56
                                  @michaelf
                                  cd /opt/iobroker
                                  npm prune
                                  Danach könnte es sauber sein.
                                  • MichaelFM Offline
                                    MichaelFM Offline
                                    MichaelF
                                    #57
                                    └── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                                      #58
                                      @michaelf geht doch 😀
                                      hattest du beim letzten prune 7m falschen Verzeichnis gestanden?
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        #59
                                        Riesen Dank !!!!!
                                          #60
                                          pioneer-avr
                                          Der gehört aber eigentlich auch nicht in die erste Ebene.
                                          Aber lass das jetzt so.
