  4. Adapterwarnungen / web stürzt ab
    2.9k
    4.9k
    4.1k
63 Beiträge 6 Kommentatoren 8.7k Aufrufe 5 Beobachtet
  • MichaelFM Offline
    MichaelFM Offline
    MichaelF
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.25-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     21:56:14 up  2:11,  1 user,  load average: 1.59, 1.63, 1.82
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-11-08 21:56:15 CET
               Universal time: Wed 2023-11-08 20:56:15 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.9G        3.3G        1.0M        1.6G        4.7G
    Swap:            99M          0B         99M
    Total:          7.9G        2.9G        3.4G
             7811 M total memory
             2933 M used memory
             3096 M active memory
              963 M inactive memory
             3317 M free memory
              302 M buffer memory
             1258 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   95G  15% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,stripe=8191
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.4G    /var/
    3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    3.6G    /var/log
    574M    /var/cache
    Archived and active journals take up 3.5G in the file system.
    /opt/iobroker/backups:
    826M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/sqlite
    671M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    26M     /opt/iobroker/iobroker-data/states.jsonl
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: typescript@5.1.6 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
    npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
    npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
    npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
    npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
    npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
    npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
    npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
    npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
    npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
    npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
    npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
    npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
    npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
    npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
    npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
    npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
    npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
    npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
    npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
    npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
    npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
    npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
    npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
    npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
    npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
    npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
    npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
    npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
    npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
    npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
    npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
    npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
    npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
    npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
    npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
    npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
    npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
    npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
    npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
    npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
    npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
    npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
    npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
    npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
    npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
    npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
    npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
    npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
    npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
    npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
    npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
    npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
    npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
    npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
    npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
    npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
    npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
    npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
    npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
    npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
    npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
    npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
    npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
    npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
    npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
    npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
    npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
    npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
    npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
    npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
    npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
    npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
    npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
    npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
    npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
    npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
    npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
    npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
    npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
    npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
    npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
    npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
    npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
    npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
    npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
    npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
    npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
    npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
    npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
    npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
    npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
    npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
    npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
    npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
    npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
    npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
    npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
    npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
    npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
    npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
    npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
    npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
    npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
    npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
    npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
    npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
    npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
    npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
    npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
    npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
    npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
    npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
    npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
    npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
    npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
    npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
    npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
    npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
    npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
    npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
    npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
    npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
    npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
    npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
    npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
    npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
    npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
    npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
    npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
    npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
    npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
    npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
    npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
    npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
    npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
    npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
    npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
    npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
    npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
    npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
    npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
    npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
    npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
    npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
    npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
    npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
    npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
    npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
    npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
    npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
    npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
    npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
    npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
    npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
    npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
    npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
    npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
    npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
    npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
    npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
    npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
    npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
    npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
    npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
    npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
    npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
    npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
    npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
    npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
    npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
    npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
    npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
    npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
    npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
    npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
    npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
    npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
    npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
    npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
    npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
    npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
    npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
    npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
    npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
    npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
    npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
    npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
    npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
    npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
    npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
    npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
    npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
    npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
    npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
    npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path
    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
    npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
    npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
    npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
    npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
    npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
    npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
    npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
    npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
    npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
    npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
    npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
    npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
    npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
    npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
    npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
    npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
    npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
    npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents
    npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
    npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
    npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
    npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
    npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
    npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
    npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
    npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
    npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
    npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
    npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
    npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
    npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
    npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
    npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
    npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
    npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd
    npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
    npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
    npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
    npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
    npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
    npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
    npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
    npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
    npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors
    npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto
    npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
    npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
    npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
    npm ERR! extraneous: has@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
    npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
    npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
    npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
    npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
    npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
    npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
    • MichaelFM Offline
      MichaelFM Offline
      MichaelF
      npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
      npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
      npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
      npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
      npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
      npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
      npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
      npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
      npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
      npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
      npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
      npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
      npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
      npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
      npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
      npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
      npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
      npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
      npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
      npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
      npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
      npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
      npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
      npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
      npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
      npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
      npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
      npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
      npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
      npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
      npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
      npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
      npm ERR! extraneous: istextorbinary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
      npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
      npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
      npm ERR! extraneous: json-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
      npm ERR! extraneous: json-stable-stringify-without-jsonify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
      npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
      npm ERR! extraneous: just-debounce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
      npm ERR! extraneous: just-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
      npm ERR! extraneous: keyv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
      npm ERR! extraneous: last-run@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
      npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
      npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
      npm ERR! extraneous: lead@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
      npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
      npm ERR! extraneous: liftoff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
      npm ERR! extraneous: limiter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
      npm ERR! extraneous: load-json-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
      npm ERR! extraneous: localtunnel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
      npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
      npm ERR! extraneous: lodash.get@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
      npm ERR! extraneous: lodash.isfinite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
      npm ERR! extraneous: lodash.merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
      npm ERR! extraneous: lodash.truncate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
      npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
      npm ERR! extraneous: log-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
      npm ERR! extraneous: loupe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
      npm ERR! extraneous: make-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
      npm ERR! extraneous: map-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
      npm ERR! extraneous: map-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
      npm ERR! extraneous: map-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
      npm ERR! extraneous: matchdep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
      npm ERR! extraneous: media-typer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
      npm ERR! extraneous: merge-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
      npm ERR! extraneous: merge-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
      npm ERR! extraneous: merge2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
      npm ERR! extraneous: methods@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
      npm ERR! extraneous: mimic-fn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
      npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
      npm ERR! extraneous: mitt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
      npm ERR! extraneous: mixin-deep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
      npm ERR! extraneous: mocha@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
      npm ERR! extraneous: mute-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
      npm ERR! extraneous: nanoid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
      npm ERR! extraneous: nanomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
      npm ERR! extraneous: natural-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
      npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
      npm ERR! extraneous: next-tick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
      npm ERR! extraneous: nise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
      npm ERR! extraneous: nodemon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
      npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
      npm ERR! extraneous: normalize-package-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
      npm ERR! extraneous: now-and-later@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
      npm ERR! extraneous: npm-run-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
      npm ERR! extraneous: number-is-nan@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
      npm ERR! extraneous: nwmatcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
      npm ERR! extraneous: object-assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
      npm ERR! extraneous: object-copy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
      npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
      npm ERR! extraneous: object-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
      npm ERR! extraneous: object-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
      npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
      npm ERR! extraneous: object.defaults@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
      npm ERR! extraneous: object.map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
      npm ERR! extraneous: object.pick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
      npm ERR! extraneous: object.reduce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
      npm ERR! extraneous: once@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
      npm ERR! extraneous: onetime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
      npm ERR! extraneous: openurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
      npm ERR! extraneous: opn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
      npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
      npm ERR! extraneous: ordered-read-streams@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
      npm ERR! extraneous: os-locale@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
      npm ERR! extraneous: p-limit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
      npm ERR! extraneous: p-locate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
      npm ERR! extraneous: parent-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
      npm ERR! extraneous: parse-filepath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
      npm ERR! extraneous: parse-json@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
      npm ERR! extraneous: parse-node-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
      npm ERR! extraneous: parse-passwd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
      npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
      npm ERR! extraneous: parseurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
      npm ERR! extraneous: pascalcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
      npm ERR! extraneous: path-dirname@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
      npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
      npm ERR! extraneous: path-is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
      npm ERR! extraneous: path-key@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
      npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
      npm ERR! extraneous: path-root-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
      npm ERR! extraneous: path-root@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
      npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
      npm ERR! extraneous: path-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
      npm ERR! extraneous: pathval@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
      npm ERR! extraneous: pause-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
      npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
      npm ERR! extraneous: pify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
      npm ERR! extraneous: pinkie-promise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
      npm ERR! extraneous: pinkie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
      npm ERR! extraneous: portscanner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
      npm ERR! extraneous: posix-character-classes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
      npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
      npm ERR! extraneous: pretty-hrtime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
      npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
      npm ERR! extraneous: ps-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
      npm ERR! extraneous: pstree.remy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
      npm ERR! extraneous: pump@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
      npm ERR! extraneous: pumpify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
      npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
      npm ERR! extraneous: queue-microtask@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
      npm ERR! extraneous: randombytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
      npm ERR! extraneous: range-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
      npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
      npm ERR! extraneous: read-pkg-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
      npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
      npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
      npm ERR! extraneous: rechoir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
      npm ERR! extraneous: regex-not@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
      npm ERR! extraneous: remove-bom-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
      npm ERR! extraneous: remove-bom-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
      npm ERR! extraneous: remove-trailing-separator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
      npm ERR! extraneous: repeat-element@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
      npm ERR! extraneous: repeat-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
      npm ERR! extraneous: replace-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
      npm ERR! extraneous: replace-homedir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
      npm ERR! extraneous: replacestream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
      npm ERR! extraneous: require-directory@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
      npm ERR! extraneous: require-from-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
      npm ERR! extraneous: require-main-filename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
      npm ERR! extraneous: requires-port@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
      npm ERR! extraneous: resolve-dir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
      npm ERR! extraneous: resolve-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
      npm ERR! extraneous: resolve-options@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
      npm ERR! extraneous: resolve-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
      npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
      npm ERR! extraneous: resp-modifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
      npm ERR! extraneous: ret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
      npm ERR! extraneous: reusify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
      npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
      npm ERR! extraneous: run-parallel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
      npm ERR! extraneous: rx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
      npm ERR! extraneous: safe-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
      npm ERR! extraneous: semver-greatest-satisfied-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
      npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
      npm ERR! extraneous: serialize-javascript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
      npm ERR! extraneous: serve-index@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
      npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
      npm ERR! extraneous: server-destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
      npm ERR! extraneous: set-blocking@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
      npm ERR! extraneous: set-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
      npm ERR! extraneous: shebang-command@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
      npm ERR! extraneous: shebang-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
      npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
      npm ERR! extraneous: signal-exit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
      npm ERR! extraneous: simple-update-notifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
      npm ERR! extraneous: sinon-chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
      npm ERR! extraneous: sinon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
      npm ERR! extraneous: slice-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
      npm ERR! extraneous: snapdragon-node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
      npm ERR! extraneous: snapdragon-util@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
      npm ERR! extraneous: snapdragon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
      npm ERR! extraneous: socket.io-adapter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
      npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
      npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
      npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
      npm ERR! extraneous: source-map-resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
      npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
      npm ERR! extraneous: source-map-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
      npm ERR! extraneous: sparkles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
      npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
      npm ERR! extraneous: spdx-exceptions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
      npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
      npm ERR! extraneous: spdx-license-ids@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
      npm ERR! extraneous: split-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
      npm ERR! extraneous: split@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
      npm ERR! extraneous: stack-trace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
      npm ERR! extraneous: static-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
      npm ERR! extraneous: stream-combiner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
      npm ERR! extraneous: stream-exhaust@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
      npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
      npm ERR! extraneous: stream-throttle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
      npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
      npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
      npm ERR! extraneous: strip-bom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
      npm ERR! extraneous: strip-final-newline@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
      npm ERR! extraneous: strip-json-comments@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
      npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
      npm ERR! extraneous: sver-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
      npm ERR! extraneous: symbol-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
      npm ERR! extraneous: table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
      npm ERR! extraneous: text-table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
      npm ERR! extraneous: textextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
      npm ERR! extraneous: through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
      npm ERR! extraneous: through2-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
      npm ERR! extraneous: through2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
      npm ERR! extraneous: time-stamp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
      npm ERR! extraneous: timekeeper@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
      npm ERR! extraneous: tiny-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
      npm ERR! extraneous: to-absolute-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
      npm ERR! extraneous: to-object-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
      npm ERR! extraneous: to-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
      npm ERR! extraneous: to-through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
      npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
      npm ERR! extraneous: touch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
      npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
      npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
      npm ERR! extraneous: type-detect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
      npm ERR! extraneous: type-fest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
      npm ERR! extraneous: type-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
      npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
      npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
      npm ERR! extraneous: ua-parser-js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
      npm ERR! extraneous: unc-path-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
      npm ERR! extraneous: undefsafe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
      npm ERR! extraneous: undertaker-registry@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
      npm ERR! extraneous: undertaker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
      npm ERR! extraneous: union-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
      npm ERR! extraneous: unique-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
      npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
      npm ERR! extraneous: unpipe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
      npm ERR! extraneous: unset-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
      npm ERR! extraneous: upath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
      npm ERR! extraneous: urix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
      npm ERR! extraneous: use@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
      npm ERR! extraneous: utils-merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
      npm ERR! extraneous: v8flags@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
      npm ERR! extraneous: validate-npm-package-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
      npm ERR! extraneous: value-or-function@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
      npm ERR! extraneous: vary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
      npm ERR! extraneous: vinyl-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
      npm ERR! extraneous: vinyl-sourcemap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
      npm ERR! extraneous: vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
      npm ERR! extraneous: whatwg-url-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
      npm ERR! extraneous: which-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
      npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
      npm ERR! extraneous: widest-line@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
      npm ERR! extraneous: word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
      npm ERR! extraneous: workerpool@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
      npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
      npm ERR! extraneous: wrappy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
      npm ERR! extraneous: xml-name-validator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
      npm ERR! extraneous: xmldom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
      npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
      npm ERR! extraneous: xmlhttprequest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
      npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
      npm ERR! extraneous: yargs-unparser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
      npm ERR! extraneous: yocto-queue@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/axios
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script/node_modules/axios
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
      npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
      npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
      npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
      npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
      npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
      npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
      npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
      npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
      npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
      npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
      npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
      npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
      npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
      npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
      npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
      npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
      npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
      npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
      npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
      npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fsevents
      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
      npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
      npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
      npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
      npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
      npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
      npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
      npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
      npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
      npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
      npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
      npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
      npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
      npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
      npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor/node_modules/kind-of
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
      npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
      npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
      npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
      npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
      npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
      npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/isarray
      npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
      npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
      npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
      npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
      npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
      npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
      npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
      npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
      npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
      npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
      npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
      npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
      npm ERR! extraneous: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
      npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
      npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
      npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
      npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor/node_modules/kind-of
      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
      npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
      npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T20_56_24_842Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.12.0
      javascript:     7.1.4
      Adapters from github:   9
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
      + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
      + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
        system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
      + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
      + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
      + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
      + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
      + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "device-watcher": 2.9.4   , installed 2.9.4
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
      Adapter    "evcc"         : 0.0.10   , installed 0.0.10
      Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hekr"         : 0.0.6    , installed 0.0.6
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
      Adapter    "midea"        : 0.0.7    , installed 0.1.0
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "psa"          : 0.0.11   , installed 0.0.11
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "s7"           : 1.3.15   , installed 1.3.15
      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Objects and States
      Objects:        28839
      States:         24330
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
      tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
      tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
      tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
      tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
      tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
      tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
      tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
      udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
      udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
      udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
      udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
      udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
      2023-11-08 21:52:08.090  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2023-11-08 21:53:00.347  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
      2023-11-08 21:53:00.888  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476780888_7107
      2023-11-08 21:53:58.129  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
      2023-11-08 21:54:00.072  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 3554
      2023-11-08 21:54:01.670  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476841669_4609
      2023-11-08 21:54:07.965  - info: luftdaten.0 (3554) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 21:54:08.604  - info: luftdaten.0 (3554) Terminated (NO_ERROR): Without reason
      2023-11-08 21:54:09.169  - warn: luftdaten.0 (3554) get state error: Connection is closed.
      2023-11-08 21:54:09.400  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2023-11-08 21:54:32.528  - info: fritzdect.0 (18158) DECT ID: 087610101442 identified for command (state) : false
      2023-11-08 21:54:59.917  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
      2023-11-08 21:55:00.201  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3669
      2023-11-08 21:55:02.467  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476902467_6802
      2023-11-08 21:55:07.827  - info: dwd.0 (3669) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 21:55:09.345  - info: dwd.0 (3669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-11-08 21:55:09.893  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-11-08 21:56:00.181  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 4091
      2023-11-08 21:56:00.710  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
      2023-11-08 21:56:01.245  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476961244_1751
      2023-11-08 21:56:07.469  - info: luftdaten.0 (4091) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
      2023-11-08 21:56:08.624  - info: luftdaten.0 (4091) Terminated (NO_ERROR): Without reason
      2023-11-08 21:56:09.211  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2023-11-08 21:56:59.486  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
      2023-11-08 21:57:02.037  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699477022036_8863
      • MichaelFM MichaelF
        npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
        npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
        npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
        npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
        npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
        npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
        npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
        npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
        npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
        npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
        npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
        npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
        npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
        npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
        npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
        npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
        npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
        npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
        npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
        npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
        npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
        npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
        npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
        npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
        npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
        npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
        npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
        npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
        npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
        npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
        npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
        npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
        npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
        npm ERR! extraneous: istextorbinary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
        npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
        npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
        npm ERR! extraneous: json-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
        npm ERR! extraneous: json-stable-stringify-without-jsonify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
        npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
        npm ERR! extraneous: just-debounce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
        npm ERR! extraneous: just-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
        npm ERR! extraneous: keyv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
        npm ERR! extraneous: last-run@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
        npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
        npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
        npm ERR! extraneous: lead@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
        npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
        npm ERR! extraneous: liftoff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
        npm ERR! extraneous: limiter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
        npm ERR! extraneous: load-json-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
        npm ERR! extraneous: localtunnel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
        npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
        npm ERR! extraneous: lodash.get@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
        npm ERR! extraneous: lodash.isfinite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
        npm ERR! extraneous: lodash.merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
        npm ERR! extraneous: lodash.truncate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
        npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
        npm ERR! extraneous: log-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
        npm ERR! extraneous: loupe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
        npm ERR! extraneous: make-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
        npm ERR! extraneous: map-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
        npm ERR! extraneous: map-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
        npm ERR! extraneous: map-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
        npm ERR! extraneous: matchdep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
        npm ERR! extraneous: media-typer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
        npm ERR! extraneous: merge-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
        npm ERR! extraneous: merge-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
        npm ERR! extraneous: merge2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
        npm ERR! extraneous: methods@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
        npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
        npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
        npm ERR! extraneous: mimic-fn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
        npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
        npm ERR! extraneous: mitt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
        npm ERR! extraneous: mixin-deep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
        npm ERR! extraneous: mocha@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
        npm ERR! extraneous: mute-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
        npm ERR! extraneous: nanoid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
        npm ERR! extraneous: nanomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
        npm ERR! extraneous: natural-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
        npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
        npm ERR! extraneous: next-tick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
        npm ERR! extraneous: nise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
        npm ERR! extraneous: nodemon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
        npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
        npm ERR! extraneous: normalize-package-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
        npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
        npm ERR! extraneous: now-and-later@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
        npm ERR! extraneous: npm-run-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
        npm ERR! extraneous: number-is-nan@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
        npm ERR! extraneous: nwmatcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
        npm ERR! extraneous: object-assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
        npm ERR! extraneous: object-copy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
        npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
        npm ERR! extraneous: object-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
        npm ERR! extraneous: object-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
        npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
        npm ERR! extraneous: object.defaults@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
        npm ERR! extraneous: object.map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
        npm ERR! extraneous: object.pick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
        npm ERR! extraneous: object.reduce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
        npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
        npm ERR! extraneous: once@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
        npm ERR! extraneous: onetime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
        npm ERR! extraneous: openurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
        npm ERR! extraneous: opn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
        npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
        npm ERR! extraneous: ordered-read-streams@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
        npm ERR! extraneous: os-locale@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
        npm ERR! extraneous: p-limit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
        npm ERR! extraneous: p-locate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
        npm ERR! extraneous: parent-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
        npm ERR! extraneous: parse-filepath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
        npm ERR! extraneous: parse-json@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
        npm ERR! extraneous: parse-node-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
        npm ERR! extraneous: parse-passwd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
        npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
        npm ERR! extraneous: parseurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
        npm ERR! extraneous: pascalcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
        npm ERR! extraneous: path-dirname@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
        npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
        npm ERR! extraneous: path-is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
        npm ERR! extraneous: path-key@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
        npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
        npm ERR! extraneous: path-root-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
        npm ERR! extraneous: path-root@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
        npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
        npm ERR! extraneous: path-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
        npm ERR! extraneous: pathval@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
        npm ERR! extraneous: pause-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
        npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
        npm ERR! extraneous: pify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
        npm ERR! extraneous: pinkie-promise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
        npm ERR! extraneous: pinkie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
        npm ERR! extraneous: portscanner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
        npm ERR! extraneous: posix-character-classes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
        npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
        npm ERR! extraneous: pretty-hrtime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
        npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
        npm ERR! extraneous: ps-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
        npm ERR! extraneous: pstree.remy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
        npm ERR! extraneous: pump@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
        npm ERR! extraneous: pumpify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
        npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
        npm ERR! extraneous: queue-microtask@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
        npm ERR! extraneous: randombytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
        npm ERR! extraneous: range-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
        npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
        npm ERR! extraneous: read-pkg-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
        npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
        npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
        npm ERR! extraneous: rechoir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
        npm ERR! extraneous: regex-not@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
        npm ERR! extraneous: remove-bom-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
        npm ERR! extraneous: remove-bom-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
        npm ERR! extraneous: remove-trailing-separator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
        npm ERR! extraneous: repeat-element@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
        npm ERR! extraneous: repeat-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
        npm ERR! extraneous: replace-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
        npm ERR! extraneous: replace-homedir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
        npm ERR! extraneous: replacestream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
        npm ERR! extraneous: require-directory@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
        npm ERR! extraneous: require-from-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
        npm ERR! extraneous: require-main-filename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
        npm ERR! extraneous: requires-port@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
        npm ERR! extraneous: resolve-dir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
        npm ERR! extraneous: resolve-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
        npm ERR! extraneous: resolve-options@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
        npm ERR! extraneous: resolve-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
        npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
        npm ERR! extraneous: resp-modifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
        npm ERR! extraneous: ret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
        npm ERR! extraneous: reusify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
        npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
        npm ERR! extraneous: run-parallel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
        npm ERR! extraneous: rx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
        npm ERR! extraneous: safe-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
        npm ERR! extraneous: semver-greatest-satisfied-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
        npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
        npm ERR! extraneous: serialize-javascript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
        npm ERR! extraneous: serve-index@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
        npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
        npm ERR! extraneous: server-destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
        npm ERR! extraneous: set-blocking@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
        npm ERR! extraneous: set-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
        npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
        npm ERR! extraneous: shebang-command@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
        npm ERR! extraneous: shebang-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
        npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
        npm ERR! extraneous: signal-exit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
        npm ERR! extraneous: simple-update-notifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
        npm ERR! extraneous: sinon-chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
        npm ERR! extraneous: sinon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
        npm ERR! extraneous: slice-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
        npm ERR! extraneous: snapdragon-node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
        npm ERR! extraneous: snapdragon-util@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
        npm ERR! extraneous: snapdragon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
        npm ERR! extraneous: socket.io-adapter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
        npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
        npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
        npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
        npm ERR! extraneous: source-map-resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
        npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
        npm ERR! extraneous: source-map-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
        npm ERR! extraneous: sparkles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
        npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
        npm ERR! extraneous: spdx-exceptions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
        npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
        npm ERR! extraneous: spdx-license-ids@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
        npm ERR! extraneous: split-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
        npm ERR! extraneous: split@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
        npm ERR! extraneous: stack-trace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
        npm ERR! extraneous: static-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
        npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
        npm ERR! extraneous: stream-combiner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
        npm ERR! extraneous: stream-exhaust@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
        npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
        npm ERR! extraneous: stream-throttle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
        npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
        npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
        npm ERR! extraneous: strip-bom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
        npm ERR! extraneous: strip-final-newline@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
        npm ERR! extraneous: strip-json-comments@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
        npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
        npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
        npm ERR! extraneous: sver-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
        npm ERR! extraneous: symbol-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
        npm ERR! extraneous: table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
        npm ERR! extraneous: text-table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
        npm ERR! extraneous: textextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
        npm ERR! extraneous: through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
        npm ERR! extraneous: through2-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
        npm ERR! extraneous: through2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
        npm ERR! extraneous: time-stamp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
        npm ERR! extraneous: timekeeper@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
        npm ERR! extraneous: tiny-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
        npm ERR! extraneous: to-absolute-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
        npm ERR! extraneous: to-object-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
        npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
        npm ERR! extraneous: to-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
        npm ERR! extraneous: to-through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
        npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
        npm ERR! extraneous: touch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
        npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
        npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
        npm ERR! extraneous: type-detect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
        npm ERR! extraneous: type-fest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
        npm ERR! extraneous: type-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
        npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
        npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
        npm ERR! extraneous: ua-parser-js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
        npm ERR! extraneous: unc-path-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
        npm ERR! extraneous: undefsafe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
        npm ERR! extraneous: undertaker-registry@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
        npm ERR! extraneous: undertaker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
        npm ERR! extraneous: union-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
        npm ERR! extraneous: unique-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
        npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
        npm ERR! extraneous: unpipe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
        npm ERR! extraneous: unset-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
        npm ERR! extraneous: upath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
        npm ERR! extraneous: urix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
        npm ERR! extraneous: use@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
        npm ERR! extraneous: utils-merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
        npm ERR! extraneous: v8flags@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
        npm ERR! extraneous: validate-npm-package-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
        npm ERR! extraneous: value-or-function@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
        npm ERR! extraneous: vary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
        npm ERR! extraneous: vinyl-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
        npm ERR! extraneous: vinyl-sourcemap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
        npm ERR! extraneous: vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
        npm ERR! extraneous: whatwg-url-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
        npm ERR! extraneous: which-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
        npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
        npm ERR! extraneous: widest-line@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
        npm ERR! extraneous: word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
        npm ERR! extraneous: workerpool@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
        npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
        npm ERR! extraneous: wrappy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
        npm ERR! extraneous: xml-name-validator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
        npm ERR! extraneous: xmldom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
        npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
        npm ERR! extraneous: xmlhttprequest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
        npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
        npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
        npm ERR! extraneous: yargs-unparser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
        npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
        npm ERR! extraneous: yocto-queue@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/axios
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script/node_modules/axios
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
        npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
        npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
        npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
        npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
        npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
        npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
        npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
        npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
        npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
        npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
        npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
        npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
        npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
        npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
        npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
        npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
        npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
        npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
        npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
        npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
        npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
        npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
        npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
        npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
        npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
        npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
        npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
        npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
        npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
        npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
        npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
        npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
        npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
        npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
        npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fsevents
        npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
        npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
        npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
        npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
        npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
        npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
        npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
        npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
        npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
        npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
        npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
        npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
        npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
        npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
        npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
        npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
        npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
        npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
        npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
        npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor/node_modules/kind-of
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
        npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
        npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
        npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
        npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
        npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
        npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
        npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
        npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
        npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
        npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
        npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
        npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
        npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
        npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
        npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
        npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
        npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
        npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
        npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
        npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/isarray
        npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
        npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
        npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
        npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
        npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
        npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
        npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
        npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
        npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
        npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
        npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
        npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
        npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
        npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
        npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
        npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
        npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
        npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
        npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
        npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
        npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
        npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
        npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
        npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
        npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
        npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
        npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
        npm ERR! extraneous: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
        npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
        npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
        npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
        npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
        npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
        npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
        npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
        npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T20_56_24_842Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   9
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
        + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
        + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
          system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
        + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
        + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
        + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
        + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
        + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
        + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
        + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
        + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
        + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "device-watcher": 2.9.4   , installed 2.9.4
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hekr"         : 0.0.6    , installed 0.0.6
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "midea"        : 0.0.7    , installed 0.1.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "psa"          : 0.0.11   , installed 0.0.11
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "s7"           : 1.3.15   , installed 1.3.15
        Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        28839
        States:         24330
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
        tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
        tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
        tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
        tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
        tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
        tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
        tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
        tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
        udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
        udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
        udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
        udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
        udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
        2023-11-08 21:52:08.090  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-11-08 21:53:00.347  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 21:53:00.888  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476780888_7107
        2023-11-08 21:53:58.129  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 21:54:00.072  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 3554
        2023-11-08 21:54:01.670  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476841669_4609
        2023-11-08 21:54:07.965  - info: luftdaten.0 (3554) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 21:54:08.604  - info: luftdaten.0 (3554) Terminated (NO_ERROR): Without reason
        2023-11-08 21:54:09.169  - warn: luftdaten.0 (3554) get state error: Connection is closed.
        2023-11-08 21:54:09.400  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-11-08 21:54:32.528  - info: fritzdect.0 (18158) DECT ID: 087610101442 identified for command (state) : false
        2023-11-08 21:54:59.917  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 21:55:00.201  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3669
        2023-11-08 21:55:02.467  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476902467_6802
        2023-11-08 21:55:07.827  - info: dwd.0 (3669) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 21:55:09.345  - info: dwd.0 (3669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-08 21:55:09.893  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-08 21:56:00.181  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 4091
        2023-11-08 21:56:00.710  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 21:56:01.245  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476961244_1751
        2023-11-08 21:56:07.469  - info: luftdaten.0 (4091) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
        2023-11-08 21:56:08.624  - info: luftdaten.0 (4091) Terminated (NO_ERROR): Without reason
        2023-11-08 21:56:09.211  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-11-08 21:56:59.486  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
        2023-11-08 21:57:02.037  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699477022036_8863
        @michaelf
        Räum das auf:
        npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
        npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        MichaelFM 1 Antwort Letzte Antwort
          @michaelf
          Räum das auf:
          MichaelFM Offline
          MichaelFM Offline
          MichaelF
          schrieb am zuletzt editiert von MichaelF
          @thomas-braun said in Adapterwarnungen / web stürzt ab:
          @michaelf
          Räum das auf:
          Aufräumen ?
          Das müsste das hier sein ?
          • MichaelFM MichaelF
            @michaelf
            Räum das auf:
            Aufräumen ?
            @michaelf
            Die fehlen aus Sicht von npm.
            Ich weiß aber nicht wie der ham-Adapter das handhabt.
              @michaelf
              MichaelFM Offline
              MichaelFM Offline
              MichaelF
              @michaelf
              Mal neu trüber installieren ?
                @michaelf
                @michaelf
                Vermutlich nur die ham-Module nochmal reinjubeln.
                  @michaelf
                  MichaelFM Offline
                  MichaelFM Offline
                  MichaelF
                  @michaelf
                  In Arbeit
                  • MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.25-v8+
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : armhf
                    Systemuptime and Load:
                     22:15:39 up  2:30,  1 user,  load average: 1.57, 1.65, 1.71
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Wed 2023-11-08 22:15:40 CET
                               Universal time: Wed 2023-11-08 21:15:40 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            7.8G        3.0G        3.3G        1.0M        1.6G        4.7G
                    Swap:            99M          0B         99M
                    Total:          7.9G        3.0G        3.4G
                             7811 M total memory
                             2968 M used memory
                             3133 M active memory
                              984 M inactive memory
                             3258 M free memory
                              318 M buffer memory
                             1266 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4      117G   17G   95G  15% /
                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
                    /dev/sda1      vfat      253M   51M  202M  20% /boot
                    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
                    [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    TARGET  SOURCE    FSTYPE OPTIONS
                    /       /dev/sda2 ext4   rw,noatime,stripe=8191
                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                    /var:
                    4.4G    /var/
                    3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
                    3.6G    /var/log
                    574M    /var/cache
                    Archived and active journals take up 3.5G in the file system.
                    /opt/iobroker/backups:
                    826M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    2.0G    /opt/iobroker/iobroker-data/
                    1.1G    /opt/iobroker/iobroker-data/sqlite
                    659M    /opt/iobroker/iobroker-data/files
                    132M    /opt/iobroker/iobroker-data/backup-objects
                    88M     /opt/iobroker/iobroker-data/files/echarts.admin
                    1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
                    49M     /opt/iobroker/iobroker-data/states.jsonl
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    25M     /opt/iobroker/iobroker-data/objects.jsonl
                    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.18.2
                    /usr/bin/node           v18.18.2
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.2-1nodesource1
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                     *** 18.18.2-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.18.1-1nodesource1 500
                         18.18.0-1nodesource1 500
                         18.17.1-1nodesource1 500
                         18.17.0-1nodesource1 500
                         18.16.1-1nodesource1 500
                         18.16.0-1nodesource1 500
                         18.15.0-1nodesource1 500
                         18.14.2-1nodesource1 500
                         18.14.1-1nodesource1 500
                         18.14.0-1nodesource1 500
                         18.13.0-1nodesource1 500
                         18.12.0-1nodesource1 500
                         18.11.0-1nodesource1 500
                         18.10.0-1nodesource1 500
                         18.9.1-1nodesource1 500
                         18.9.0-1nodesource1 500
                         18.8.0-1nodesource1 500
                         18.7.0-1nodesource1 500
                         18.6.0-1nodesource1 500
                         18.5.0-1nodesource1 500
                         18.4.0-1nodesource1 500
                         18.3.0-1nodesource1 500
                         18.2.0-1nodesource1 500
                         18.1.0-1nodesource1 500
                         18.0.0-1nodesource1 500
                         12.22.12~dfsg-1~deb11u4 500
                    No problems detected
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                    npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                    npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                    npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                    npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                    npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                    npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
                    npm ERR! extraneous: tslib@2.4.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
                    npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.4
                    npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
                    npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
                    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T21_15_50_546Z-debug-0.log
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        28839
                    States:         24330
                    Pending Updates: 0
                    2023-11-08 22:13:47.920  - info: host.iobroker stopInstance system.adapter.ham.0 send kill signal
                    2023-11-08 22:13:48.530  - info: host.iobroker instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-11-08 22:13:51.656  - info: host.iobroker instance system.adapter.ham.0 started with pid 9182
                    2023-11-08 22:13:59.930  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                    2023-11-08 22:14:00.117  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9213
                    2023-11-08 22:14:02.468  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478042468_9572
                    2023-11-08 22:14:07.867  - info: luftdaten.0 (9213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                    2023-11-08 22:14:08.618  - info: luftdaten.0 (9213) Terminated (NO_ERROR): Without reason
                    2023-11-08 22:14:09.228  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-11-08 22:14:41.287  - info: admin.0 (17298) ==> Connected system.user.admin from ::ffff:192.168.178.52
                    2023-11-08 22:14:53.476  - info: admin.0 (17298) <== Disconnect system.user.admin from ::ffff:192.168.178.52 ham
                    2023-11-08 22:15:00.071  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9336
                    2023-11-08 22:15:00.709  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                    2023-11-08 22:15:01.255  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478101254_3328
                    2023-11-08 22:15:08.139  - info: dwd.0 (9336) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                    2023-11-08 22:15:11.054  - info: dwd.0 (9336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-11-08 22:15:11.882  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-11-08 22:15:59.500  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                    2023-11-08 22:16:00.460  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9883
                    2023-11-08 22:16:02.080  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478162080_8235
                    2023-11-08 22:16:09.485  - info: luftdaten.0 (9883) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                    2023-11-08 22:16:11.630  - info: luftdaten.0 (9883) Terminated (NO_ERROR): Without reason
                    2023-11-08 22:16:12.196  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                    2023-11-08 22:17:00.326  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                    2023-11-08 22:17:00.872  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478220871_7431
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               7811 M total memory
                               2968 M used memory
                               3258 M free memory
                                318 M buffer memory
                               1266 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      4.4G    /var/
                      3.6G    /var/log
                      574M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        28839
                      States:         24330
                      Pending Updates: 0
                      @michaelf sagte in Adapterwarnungen / web stürzt ab:
                      Da wird im javascript-Adapter das Modul fehlen. Brauchst du das überhaupt?
                        MichaelFM Offline
                        MichaelFM Offline
                        MichaelF
                        Ja auch grade gesehen, und neu eingetragen seit dem läuft der Adapter wieder.
                        Moment neuer Diag
                        • MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           22:25:47 up  2:40,  1 user,  load average: 2.07, 2.07, 1.94
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2023-11-08 22:25:47 CET
                                     Universal time: Wed 2023-11-08 21:25:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            7.8G        3.3G        2.8G        1.0M        1.7G        4.4G
                          Swap:            99M          0B         99M
                          Total:          7.9G        3.3G        2.9G
                                   7811 M total memory
                                   3290 M used memory
                                   3449 M active memory
                                   1073 M inactive memory
                                   2841 M free memory
                                    326 M buffer memory
                                   1352 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          4.4G    /var/
                          3.6G    /var/log
                          574M    /var/cache
                          61M     /opt/iobroker/iobroker-data/states.jsonl
                          29M     /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        28839
                          States:         24407
                          Pending Updates: 0
                          2023-11-08 22:25:39.551  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                          2023-11-08 22:25:39.552  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                          2023-11-08 22:25:40.711  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
                          2023-11-08 22:25:59.446  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                          2023-11-08 22:26:00.445  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 13249
                          2023-11-08 22:26:02.012  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478762011_8296
                          2023-11-08 22:26:12.328  - info: luftdaten.0 (13249) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                          2023-11-08 22:26:14.168  - info: luftdaten.0 (13249) Terminated (NO_ERROR): Without reason
                          2023-11-08 22:26:15.000  - warn: luftdaten.0 (13249) get state error: Connection is closed.
                          2023-11-08 22:26:15.340  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                          2023-11-08 22:27:00.253  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                          2023-11-08 22:27:00.796  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478820795_8708
                          Alle Fehler Weg............
                          Mega, Riesen Dank
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     7811 M total memory
                                     3290 M used memory
                                     2841 M free memory
                                      326 M buffer memory
                                     1352 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            4.4G    /var/
                            3.6G    /var/log
                            574M    /var/cache
                            USB-Devices by-id:
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        28839
                            States:         24407
                            Pending Updates: 0
                            Mega, Riesen Dank
                            auch alle extraneous im npm tree??
                            wie kommt man suf soooo viele Adapter aus Github?
                            MichaelFM 2 Antworten Letzte Antwort
                            • MichaelFM Offline
                              MichaelFM Offline
                              MichaelF
                              Ich lasse heute Nacht ein Backup laufen und versuche morgen Abend nochmal das Update des Web Adapters.
                                MichaelFM Offline
                                MichaelFM Offline
                                MichaelF
                                @homoran said in Adapterwarnungen / web stürzt ab:
                                Ich Schaue, Moment
                                • MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  pi@iobroker:~ $ npm ls
                                  pi@ /home/pi
                                  └── canvas@2.9.3
                                  pi@iobroker:~ $
                                    MichaelFM Offline
                                    MichaelFM Offline
                                    MichaelF
                                    Mmh, mit den Adaptern ist halt irgendwie so gewachsen. Also da war jetzt nicht irgendwie Absicht dahinter
                                      immer wieder ins normale Repo überführen wenn vorhanden
                                        pi@ /home/pi
                                        └── canvas@2.9.3
                                        pi@iobroker:~ $
                                        @michaelf
                                        cd /opt/iobroker
                                        npm ls
                                        canvas haste mal daneben geworfen... ;-)
                                          MichaelFM Offline
                                          MichaelFM Offline
                                          MichaelF
                                          Das hatte ich nie gemacht, aber in Zukunft.............
