  4. Adapterwarnungen / web stürzt ab
    2.9k
    4.9k
    4.1k
63 Beiträge 6 Kommentatoren 8.7k Aufrufe 5 Beobachtet
  • MichaelFM Offline
    MichaelFM Offline
    MichaelF
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.25-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     22:15:39 up  2:30,  1 user,  load average: 1.57, 1.65, 1.71
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-11-08 22:15:40 CET
               Universal time: Wed 2023-11-08 21:15:40 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.0G        3.3G        1.0M        1.6G        4.7G
    Swap:            99M          0B         99M
    Total:          7.9G        3.0G        3.4G
             7811 M total memory
             2968 M used memory
             3133 M active memory
              984 M inactive memory
             3258 M free memory
              318 M buffer memory
             1266 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   95G  15% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,stripe=8191
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.4G    /var/
    3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    3.6G    /var/log
    574M    /var/cache
    Archived and active journals take up 3.5G in the file system.
    /opt/iobroker/backups:
    826M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/sqlite
    659M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    49M     /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
    npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
    npm ERR! extraneous: tslib@2.4.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
    npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.4
    npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
    npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T21_15_50_546Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   9
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
      system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
    + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
    + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
    + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hekr"         : 0.0.6    , installed 0.0.6
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "midea"        : 0.0.7    , installed 0.1.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "psa"          : 0.0.11   , installed 0.0.11
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "s7"           : 1.3.15   , installed 1.3.15
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        28839
    States:         24330
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
    tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
    tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
    tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
    tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
    tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
    tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
    tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
    udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
    udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
    udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
    udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
    udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
    2023-11-08 22:13:47.920  - info: host.iobroker stopInstance system.adapter.ham.0 send kill signal
    2023-11-08 22:13:48.530  - info: host.iobroker instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-08 22:13:51.656  - info: host.iobroker instance system.adapter.ham.0 started with pid 9182
    2023-11-08 22:13:59.930  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
    2023-11-08 22:14:00.117  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9213
    2023-11-08 22:14:02.468  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478042468_9572
    2023-11-08 22:14:07.867  - info: luftdaten.0 (9213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
    2023-11-08 22:14:08.618  - info: luftdaten.0 (9213) Terminated (NO_ERROR): Without reason
    2023-11-08 22:14:09.228  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-11-08 22:14:41.287  - info: admin.0 (17298) ==> Connected system.user.admin from ::ffff:192.168.178.52
    2023-11-08 22:14:53.476  - info: admin.0 (17298) <== Disconnect system.user.admin from ::ffff:192.168.178.52 ham
    2023-11-08 22:15:00.071  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9336
    2023-11-08 22:15:00.709  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
    2023-11-08 22:15:01.255  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478101254_3328
    2023-11-08 22:15:08.139  - info: dwd.0 (9336) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
    2023-11-08 22:15:11.054  - info: dwd.0 (9336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-08 22:15:11.882  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-08 22:15:59.500  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
    2023-11-08 22:16:00.460  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 9883
    2023-11-08 22:16:02.080  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478162080_8235
    2023-11-08 22:16:09.485  - info: luftdaten.0 (9883) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
    2023-11-08 22:16:11.630  - info: luftdaten.0 (9883) Terminated (NO_ERROR): Without reason
    2023-11-08 22:16:12.196  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-11-08 22:17:00.326  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
    2023-11-08 22:17:00.872  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478220871_7431
    • MichaelFM MichaelF
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               2968 M used memory
               3258 M free memory
                318 M buffer memory
               1266 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.4G    /var/
      3.6G    /var/log
      574M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        28839
      States:         24330
      Pending Updates: 0
      @michaelf sagte in Adapterwarnungen / web stürzt ab:
      Da wird im javascript-Adapter das Modul fehlen. Brauchst du das überhaupt?
      MichaelFM 1 Antwort Letzte Antwort
        MichaelFM Offline
        MichaelFM Offline
        MichaelF
        @thomas-braun said in Adapterwarnungen / web stürzt ab:
        Ja auch grade gesehen, und neu eingetragen seit dem läuft der Adapter wieder.
        Moment neuer Diag
        • MichaelFM Offline
          MichaelFM Offline
          MichaelF
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
           22:25:47 up  2:40,  1 user,  load average: 2.07, 2.07, 1.94
          CPU threads: 4
          Current issues:
                         Local time: Wed 2023-11-08 22:25:47 CET
                     Universal time: Wed 2023-11-08 21:25:47 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        3.3G        2.8G        1.0M        1.7G        4.4G
          Swap:            99M          0B         99M
          Total:          7.9G        3.3G        2.9G
                   7811 M total memory
                   3290 M used memory
                   3449 M active memory
                   1073 M inactive memory
                   2841 M free memory
                    326 M buffer memory
                   1352 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          4.4G    /var/
          3.6G    /var/log
          574M    /var/cache
          61M     /opt/iobroker/iobroker-data/states.jsonl
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        28839
          States:         24407
          Pending Updates: 0
          2023-11-08 22:25:39.551  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
          2023-11-08 22:25:39.552  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
          2023-11-08 22:25:40.711  - info: javascript.0 (11921) script.js.Licht_Wohnung: true
          2023-11-08 22:25:59.446  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:26:00.445  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 13249
          2023-11-08 22:26:02.012  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478762011_8296
          2023-11-08 22:26:12.328  - info: luftdaten.0 (13249) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
          2023-11-08 22:26:14.168  - info: luftdaten.0 (13249) Terminated (NO_ERROR): Without reason
          2023-11-08 22:26:15.000  - warn: luftdaten.0 (13249) get state error: Connection is closed.
          2023-11-08 22:26:15.340  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-11-08 22:27:00.253  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
          2023-11-08 22:27:00.796  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699478820795_8708
          Alle Fehler Weg............
          Mega, Riesen Dank
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     3290 M used memory
                     2841 M free memory
                      326 M buffer memory
                     1352 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            4.4G    /var/
            3.6G    /var/log
            574M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        28839
            States:         24407
            Pending Updates: 0
            Mega, Riesen Dank
            auch alle extraneous im npm tree??
            wie kommt man suf soooo viele Adapter aus Github?
            MichaelFM 2 Antworten Letzte Antwort
            • MichaelFM Offline
              MichaelFM Offline
              MichaelF
              Ich lasse heute Nacht ein Backup laufen und versuche morgen Abend nochmal das Update des Web Adapters.
                MichaelFM Offline
                MichaelFM Offline
                MichaelF
                @homoran said in Adapterwarnungen / web stürzt ab:
                Ich Schaue, Moment
                • MichaelFM Offline
                  MichaelFM Offline
                  MichaelF
                  pi@iobroker:~ $ npm ls
                  pi@ /home/pi
                  └── canvas@2.9.3
                  pi@iobroker:~ $
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    Mmh, mit den Adaptern ist halt irgendwie so gewachsen. Also da war jetzt nicht irgendwie Absicht dahinter
                      immer wieder ins normale Repo überführen wenn vorhanden
                        pi@ /home/pi
                        └── canvas@2.9.3
                        pi@iobroker:~ $
                        @michaelf
                        cd /opt/iobroker
                        npm ls
                        canvas haste mal daneben geworfen... ;-)
                          MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          Das hatte ich nie gemacht, aber in Zukunft.............
                            @michaelf
                            cd /opt/iobroker
                            npm ls
                            MichaelFM Offline
                            MichaelFM Offline
                            MichaelF
                            @michaelf
                            cd /opt/iobroker
                            npm ls
                            Das erklärt einiges...........
                            pi@iobroker:/opt/iobroker $ npm ls
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├── @types/caseless@0.12.2 extraneous
                            ├── @types/request@2.48.8 extraneous
                            ├── @types/tough-cookie@4.0.2 extraneous
                            ├── buffer-shims@1.0.0 extraneous
                            ├── coffeescript@1.12.7 extraneous
                            ├── futoin-hkdf@1.4.3 extraneous
                            ├── homebridge-plugin-wrapper@3.2.0 extraneous
                            ├── iobroker.accuweather@1.3.1
                            ├── iobroker.admin@6.12.0
                            ├── iobroker.alexa2@3.25.5
                            ├── iobroker.backitup@2.8.7
                            ├── iobroker.bosesoundtouch@0.10.3
                            ├── iobroker.broadlink2@2.1.5
                            ├── iobroker.device-reminder@3.0.0
                            ├── iobroker.device-watcher@2.9.4
                            ├── iobroker.devices@1.1.5
                            ├── iobroker.discovery@3.1.0
                            ├── iobroker.dwd@2.8.5
                            ├── iobroker.echarts@1.5.1
                            ├── iobroker.energiefluss-erweitert@0.0.2-alpha.20 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#07858bd9e4cbb8e005a3585cf5a480650fc47296)
                            ├── iobroker.envertech-pv@1.0.2
                            ├── iobroker.evcc@0.0.10
                            ├── iobroker.eventlist@1.2.3
                            ├── iobroker.fb-checkpresence@1.2.2
                            ├── iobroker.fritzdect@2.3.1
                            ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#f7d8e7ac363adbe19b99c060d77895097228d7ca)
                            ├── iobroker.ham@5.3.1
                            ├── iobroker.hekr@0.0.6
                            ├── iobroker.history@3.0.1
                            ├── iobroker.hm-rega@3.0.47
                            ├── iobroker.hm-rpc@1.15.19
                            ├── iobroker.ical@1.13.3
                            ├── iobroker.icons-material-png@0.1.0
                            ├── iobroker.icons-mfd-png@1.1.0
                            ├── iobroker.icons-mfd-svg@1.1.0
                            ├── iobroker.icons-open-icon-library-png@0.1.2
                            ├── iobroker.influxdb@3.2.0
                            ├── iobroker.info@2.0.0
                            ├── iobroker.iot@1.14.5
                            ├── iobroker.javascript@7.1.4
                            ├── iobroker.js-controller@5.0.12
                            ├── iobroker.logparser@2.2.0
                            ├── iobroker.luftdaten@3.1.0
                            ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#262717eed55656f1c79056eccd8c209666015421)
                            ├── iobroker.mqtt-client@1.6.5
                            ├── iobroker.mqtt@4.1.1
                            ├── iobroker.nuki@1.6.0
                            ├── iobroker.nut@1.6.0
                            ├── iobroker.octoprint@5.1.0
                            ├── iobroker.parcel@0.0.27
                            ├── iobroker.pi-hole@1.3.6
                            ├── iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#6902280218c6709de322058c19704839f241c069)
                            ├── iobroker.psa@0.0.11
                            ├── iobroker.pvforecast@2.9.0
                            ├── iobroker.rpi2@1.3.2
                            ├── iobroker.s7@1.3.15
                            ├── iobroker.sainlogic@0.10.5
                            ├── iobroker.shelly@6.6.1
                            ├── iobroker.simple-api@2.7.2
                            ├── iobroker.socketio@6.5.5
                            ├── iobroker.sonoff@2.5.3
                            ├── iobroker.sql@2.2.0
                            ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                            ├── iobroker.synology@3.0.1
                            ├── iobroker.tankerkoenig@3.3.7
                            ├── iobroker.telegram@2.0.1
                            ├── iobroker.tr-064@4.2.18
                            ├── iobroker.trashschedule@2.3.0
                            ├── iobroker.tuya@3.14.2
                            ├── iobroker.upnp@1.0.21
                            ├── iobroker.vis-bars@0.1.4
                            ├── iobroker.vis-canvas-gauges@1.0.1
                            ├── iobroker.vis-colorpicker@2.0.3
                            ├── iobroker.vis-google-fonts@1.0.4
                            ├── iobroker.vis-history@1.0.0
                            ├── iobroker.vis-hqwidgets@1.4.0
                            ├── iobroker.vis-icontwo@0.96.0
                            ├── iobroker.vis-inventwo@3.3.3
                            ├── iobroker.vis-jqui-mfd@1.0.12
                            ├── iobroker.vis-justgage@1.0.2
                            ├── iobroker.vis-material@0.1.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-material.git#0384950a1e05ec2fa6b6c4bb774afa5e97a13b6c)
                            ├── iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
                            ├── iobroker.vis-metro@1.2.0
                            ├── iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                            ├── iobroker.vis-players@0.1.6
                            ├── iobroker.vis-rgraph@0.0.2
                            ├── iobroker.vis-timeandweather@1.2.2
                            ├── iobroker.vis@1.4.16
                            ├── iobroker.web@6.1.2
                            ├── iobroker.worx@2.3.4
                            ├── iobroker.ws@2.5.5
                            ├── mock-require@3.0.3 extraneous
                            ├── node-inspect@2.0.0 extraneous
                            ├── node-persist@0.0.11 extraneous
                            ├── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                            ├── q@1.1.2 extraneous
                            ├── string-argv@0.3.1 extraneous
                            ├── typescript@5.1.6 extraneous
                            ├── virtual-tsc@0.6.2 extraneous
                            └── wake_on_lan@1.0.0 extraneous
                              @michaelf
                              cd /opt/iobroker
                              npm ls
                              @michaelf
                              cd /opt/iobroker
                              npm prune
                              Danach könnte es sauber sein.
                              • MichaelFM Offline
                                MichaelFM Offline
                                MichaelF
                                └── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
                                  @michaelf geht doch 😀
                                  hattest du beim letzten prune 7m falschen Verzeichnis gestanden?
                                    MichaelFM Offline
                                    MichaelFM Offline
                                    MichaelF
                                    Riesen Dank !!!!!
                                      pioneer-avr
                                      Der gehört aber eigentlich auch nicht in die erste Ebene.
                                      Aber lass das jetzt so.
                                        pioneer-avr
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        pioneer-avr
                                        Ja bleibt so :-), morgen nochmal der versuch den Web zu aktualisieren und dann ist wieder alles tutti.
                                        Danke nochmal !
                                          pioneer-avr
                                          Danke nochmal !
                                          @michaelf
                                          iob update
                                          iob upgrade
                                          fertig.
