  5. [gelöst] Error: Cannot read properties of undefined abfangen
javascript
6 Beiträge 2 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • F Offline
    Farmer-cb
    schrieb am zuletzt editiert von Farmer-cb
    Hallo
    habe ein Script, welche per request eine API (Ultimaker 3) abfragt und ein Json erhält.
    Die Abfrage an sich funktioniert, ich bekomme Daten zurück.
        "id": 954,
        "uuid": "99496274-a9f4-431e-9fc3-8287c0fe2861",
        "name": "UM3_Batterie_Halter_2_2021-11-03_08_31_32",
        "owner": "Buechner",
        "created_at": "2023-10-30T12:56:18.596537",
        "deleted_at": "2023-10-30T12:57:16.342311",
        "status": "queued",
        "job_material_1_guid": "506c9f0d-e3aa-4bd4-b2d2-23e2425b1aa9",
        "job_printcore_1": "AA 0.4",
        "job_material_amount_1": 38909,
        "job_material_2_guid": null,
        "job_printcore_2": null,
        "job_material_amount_2": null,
        "job_buildplate": "glass",
        "estimated_time_total": 13780,
        "force": false,
        "machine_variant": "Ultimaker 3",
        "printer_uuid": "",
        "time_total": null,
        "print_start_time": null,
        "print_end_time": null,
        "printer_material_1_guid": null,
        "printer_printcore_1": null,
        "printer_material_2_guid": null,
        "printer_printcore_2": null,
        "printer_buildplate": "glass",
        "compatible_machine_families": "",
        "require_printer_name": "",
        "cloud_job_id": null
        "id": 955,
        "uuid": "4c9c40bf-7df9-4747-b64c-b8128dd91962",
        "created_at": "2023-10-30T13:01:41.003291",
        "deleted_at": "2023-10-30T13:09:15.273831",
        "status": "aborted",
        "job_printcore_1": "AA 0.8",
        "job_material_amount_1": 0,
        "job_material_2_guid": "506c9f0d-e3aa-4bd4-b2d2-23e2425b1aa9",
        "job_printcore_2": "AA 0.4",
        "job_material_amount_2": 38909,
        "estimated_time_total": 13787,
        "force": false,
        "printer_uuid": "be15f44e-a9aa-4cd5-908f-bdc869f2ca7f",
        "time_total": 286,
        "print_start_time": "2023-10-30T13:01:42.749989",
        "print_end_time": "2023-10-30T13:06:28.811234",
        "printer_material_1_guid": "506c9f0d-e3aa-4bd4-b2d2-23e2425b1aa9",
        "printer_printcore_1": "AA 0.8",
        "printer_material_2_guid": "506c9f0d-e3aa-4bd4-b2d2-23e2425b1aa9",
        "printer_printcore_2": "AA 0.4",
        "id": 956,
        "uuid": "fadb4f30-0ce2-4a03-a31b-95bf6ef85edf",
        "created_at": "2023-10-30T13:08:54.228739",
        "deleted_at": "2023-10-31T05:15:45.773095",
        "force": false,
        "time_total": 154,
        "print_start_time": "2023-10-30T13:09:16.254341",
        "print_end_time": "2023-10-30T13:11:50.544407",
    Jetzt will ich nur die Array's auslesen bei denen "printer_uuid" nicht leer ist
    hab dazu ganz simpel eine If-abfrage in meine For-schleife eingebaut
    ist nur ein teil der Abfrage:
    for (let i=0;i<=array_laenge;i++)
                                if (werte[i].printer_uuid!='')
                                        LOG(printer_uuid);
    diese Abfrage funktioniert zwar aber bringt mir jetzt ein error zurück:
    Error in request callback: TypeError: Cannot read properties of undefined
    wie kann ich diese Fehlermeldung abfrage
    nfg Christian
    smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
    J 1 Antwort Letzte Antwort
    • F Farmer-cb
      Hallo
          "id": 954,
          "status": "queued",
          "force": false,
          "printer_uuid": "",
          "time_total": null,
          "id": 955,
          "force": false,
          "time_total": 286,
          "id": 956,
          "force": false,
          "time_total": 154,
                                          LOG(printer_uuid);
      nfg Christian
      Jaksa
      schrieb am zuletzt editiert von Jaksa
      @farmer-cb
      Änder die for Schleife in:
      for (let i=0;i<array_laenge;i++)
      Edit: Zum Hintergrund.
      Wenn du 1 Ergebnis im Array hast würde die Schleife einmal mit "0" und einmal mit "1" laufen weil du in deiner Programmierung sagst das i auch gleich der array Länge sein darf.
      werte[0] gibt es in dem Fall aber werte[1] halt nicht mehr.
      Sorry bin kein großartiger Erklärbär ich hoffe du verstehst wo der Fehler liegt :-)
      F 1 Antwort Letzte Antwort
      • J Jaksa
        @farmer-cb
        Farmer-cb
        @jaksa
        kann ich machen, hat aber leider mit meinen eigentlichen Problem nix zu tun
        Wie man in der Beschreibung sieht, bekomme ich ja Array 0-3 zurück (id 954,955,956)
        vielleicht hilft das zum verständnis
        request(urlpfad, function(error, response, body)
                        //log('FehlerNr: '+body.error_code)
                    if (error)
                            log('auf Fehler reagieren');
                        else
                            var werte=JSON.parse(body);
                            let array_laenge=werte.length;
                                            LOG(printer_uuid);
        mfg
        Christian
        • F Farmer-cb
          @jaksa
                      if (error)
                          else
                                              LOG(printer_uuid);
          mfg
          Christian
          Jaksa
          @farmer-cb
          Genau da ist ja das Problem. Du hast nicht Array 0-3 sondern nur Array 0-2... [0] ist schon der erste, [1] der zweite und [2] der dritte.
          Und du läufst danach noch über [3] den es nicht gibt weil das der vierte wäre.
          Edit:
          i(0) <= 0 ist true (id 954)
          i(1) <= 1 ist true (id 955)
          i(2) <= 2 ist true (id 956)
          i(3) <= 3 ist true (id gibt es nicht Ergebnis ist dann: Error in request callback: TypeError: Cannot read properties of undefined)
          Wenn du das "=" weg nimmst ist das letzte false und somit stimmt deine Schleife dann auch mit den 3 Einträgen.
          • J Jaksa
            @farmer-cb
            Edit:
            Farmer-cb
            @jaksa
            habs getestet und muss dir leider mitteilen DAS DU VOLLKOMMEN RECHT HAST 😖
            da bin ich doch total auf dem falschen pfad gewesen 🤦 , dachte immer ich müsste den irgenwie abfangen , danke für den wink mit dem Zaunpfahl 🔨
            DANKE
            • F Farmer-cb
              @jaksa
              DANKE
              Jaksa
              @farmer-cb
              Super das es jetzt läuft. Gerne :-)
              Ich hoffe du verstehst wo dein Denkfehler ist/war. Ist der absolute "Klassiker" wenn man noch nicht so viel programmiert hat.
              Den Fehler macht man ein mal und evtl. ein zweites mal danach hat man es meist verinnerlicht. Da muss nur ein mal der Groschen fallen :-D
