  4. Neuinstallation: Esp-Home kann nicht installiert werden
31 Beiträge 4 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • WagnerW Wagner
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ras-ssd
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     17:08:05 up 3 days, 14:02,  2 users,  load average: 0.56, 0.67, 0.62
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-15 17:08:05 CET
               Universal time: Mon 2024-01-15 16:08:05 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.9G        237M        4.0M        1.7G        1.7G
    Swap:           99M         56M         43M
    Total:         3.9G        2.0G        281M
             3837 M total memory
             1941 M used memory
             1007 M active memory
             2466 M inactive memory
              237 M free memory
              142 M buffer memory
             1515 M swap cache
               99 M total swap
               56 M used swap
               43 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      235G   19G  207G   9% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Jan 12 03:05:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:58:F2:29 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=38fd7d31-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Jan 12 03:05:36 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 12 03:05:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Jan 12 03:05:38 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.0G    /var/
    1.8G    /var/cache/apt/archives
    1.8G    /var/cache/apt
    1.8G    /var/cache
    1.1G    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    425M    /opt/iobroker/iobroker-data/files
    262M    /opt/iobroker/iobroker-data/history
    104M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    426M    /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ras-ssd                                  -  enabled
    + system.adapter.admin.0                  : admin                 : ras-ssd                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ras-ssd                                  -  enabled
      system.adapter.daswetter.0              : daswetter             : ras-ssd                                  -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ras-ssd                                  -  enabled
      system.adapter.devices.0                : devices               : ras-ssd                                  - disabled
    + system.adapter.discovery.0              : discovery             : ras-ssd                                  -  enabled
      system.adapter.dwd.0                    : dwd                   : ras-ssd                                  -  enabled
      system.adapter.esphome.0                : esphome               : ras-ssd                                  -  enabled
      system.adapter.flot.0                   : flot                  : ras-ssd                                  - disabled
    + system.adapter.history.0                : history               : ras-ssd                                  -  enabled
    + system.adapter.hmip.0                   : hmip                  : ras-ssd                                  -  enabled
      system.adapter.ical.0                   : ical                  : ras-ssd                                  -  enabled
      system.adapter.ical.1                   : ical                  : ras-ssd                                  -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ras-ssd                                  - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ras-ssd                                  - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ras-ssd                                  - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ras-ssd                                  - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ras-ssd                                  - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ras-ssd                                  - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ras-ssd                                  - disabled
    + system.adapter.info.0                   : info                  : ras-ssd                                  -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : ras-ssd                                  -  enabled
    + system.adapter.javascript.0             : javascript            : ras-ssd                                  -  enabled
    + system.adapter.lovelace.0               : lovelace              : ras-ssd                                  -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : ras-ssd                                  -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : ras-ssd                                  -  enabled
      system.adapter.schoolfree.0             : schoolfree            : ras-ssd                                  -  enabled
    + system.adapter.shelly.0                 : shelly                : ras-ssd                                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : ras-ssd                                  -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : ras-ssd                                  -  enabled, port: 0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ras-ssd                                  -  enabled
    + system.adapter.telegram.0               : telegram              : ras-ssd                                  -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ras-ssd                                  - disabled
    + system.adapter.tr-064.0                 : tr-064                : ras-ssd                                  -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ras-ssd                                  - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ras-ssd                                  - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ras-ssd                                  - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ras-ssd                                  -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ras-ssd                                  - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ras-ssd                                  - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ras-ssd                                  - disabled
      system.adapter.vis-material.0           : vis-material          : ras-ssd                                  - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ras-ssd                                  - disabled
      system.adapter.vis-metro.0              : vis-metro             : ras-ssd                                  - disabled
      system.adapter.vis-players.0            : vis-players           : ras-ssd                                  - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ras-ssd                                  - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ras-ssd                                  - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ras-ssd                                  - disabled
      system.adapter.vis-weather.0            : vis-weather           : ras-ssd                                  - disabled
      system.adapter.vis.0                    : vis                   : ras-ssd                                  -  enabled
    + system.adapter.web.0                    : web                   : ras-ssd                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
    Adapter    "daswetter"    : 3.1.12   , installed 3.1.11 [Updatable]
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hmip"         : 1.21.0   , installed 1.20.0 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
    Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        12363
    States:         11547
    W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not resolve 'dl.yarnpkg.co'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Err:1 https://dl.yarnpkg.co m/debian InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15873      494/sshd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19224      974/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19245      989/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       17731      944/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       17732      944/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17304      478/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16282      478/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17624      814/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       617402     27727/io.web.0
    tcp6       0      0 :::21                   :::*                    LISTEN      111        833028     3853/proftpd: (acce
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15875      494/sshd
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       25633      1675/io.lovelace.0
    tcp6       0      0 :::3306                 :::*                    LISTEN      109        17089      573/mysqld
    udp        0      0 0.0.0.0:56231           0.0.0.0:*                           108        14940      382/avahi-daemon: r
    udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       1579807    1092/io.discovery.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18505      414/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14938      382/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16250      414/dhcpcd
    udp6       0      0 :::48713                :::*                                108        14941      382/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14939      382/avahi-daemon: r
    2024-01-15 16:59:08.631  - info: javascript.0 (848) script.js.common.FensterOffen: TürHaustür wurde geschlossen.
    2024-01-15 17:00:00.084  - info: host.ras-ssd instance system.adapter.dwd.0 started with pid 6178
    2024-01-15 17:00:02.968  - info: dwd.0 (6178) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
    2024-01-15 17:00:04.106  - info: host.ras-ssd instance system.adapter.daswetter.0 started with pid 6193
    2024-01-15 17:00:06.820  - info: daswetter.0 (6193) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.17
    2024-01-15 17:00:06.856  - info: daswetter.0 (6193) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-01-15 17:00:07.376  - info: daswetter.0 (6193) cleaned everything up...
    2024-01-15 17:00:07.390  - info: host.ras-ssd instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-15 17:00:08.131  - info: host.ras-ssd instance system.adapter.ical.0 started with pid 6208
    2024-01-15 17:00:10.586  - info: dwd.0 (6178) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-15 17:00:11.146  - info: host.ras-ssd instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-15 17:00:11.288  - info: ical.0 (6208) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2024-01-15 17:00:11.811  - info: ical.0 (6208) processing URL: Müll http://www.sbazv.de/entsorgungstermine/klein.ics?city=N
    2024-01-15 17:00:12.144  - info: host.ras-ssd instance system.adapter.ical.1 started with pid 6223
    2024-01-15 17:00:12.269  - info: ical.0 (6208) processing URL: GerdPrivat h
    2024-01-15 17:00:18.099  - info: ical.0 (6208) Terminated (NO_ERROR): Without reason
    2024-01-15 17:00:18.184  - info: ical.1 (6223) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2024-01-15 17:00:18.640  - info: host.ras-ssd instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-01-15 17:00:19.510  - info: ical.1 (6223) processing URL: Mondphasen http://mooncal.ch/mooncal.ics?lang=de&phases[full]=true&phases[new]=false&phases[quarter]=false&phases[daily]=true&events[lunareclipse]=true&events[solareclipse]=true&events[moonlanding]=false&before=P6M&after=P2Y&zone=CET
    2024-01-15 17:00:25.474  - info: ical.1 (6223) Terminated (NO_ERROR): Without reason
    2024-01-15 17:00:26.031  - info: host.ras-ssd instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2024-01-15 17:05:00.825  - info: host.ras-ssd instance system.adapter.dwd.0 started with pid 6241
    2024-01-15 17:05:03.827  - info: dwd.0 (6241) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
    2024-01-15 17:05:07.652  - info: dwd.0 (6241) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-15 17:05:08.214  - info: host.ras-ssd instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    MOD-EDIT: private Daten entfernt!
    Press any key for a summary
    @wagner
    Vermutlich ist deine Python-Version zu alt.
    Da du aber ohnehin das ganze Ding am besten als 64Bit Raspberry OS 12 'Bookworm' Lite aufsetzen wirst gar kein Problem. Backup einspielen, fertig
    WagnerW 1 Antwort Letzte Antwort
      @wagner
      WagnerW Offline
      WagnerW Offline
      Wagner
      schrieb am zuletzt editiert von Wagner
      Python 2.7.16 (default, Sep 20 2023, 07:59:17)
      pi@ras-ssd:~ $ python3
      Python 3.7.3 (default, Oct 11 2023, 09:51:27)
      [GCC 8.3.0] on linux
      • WagnerW Wagner
        @wagner
        Und aktuell sind wir bei Python 3.11/3.12
        Und Debian/Raspberry OS 12.
          @wagner
          WagnerW Offline
          WagnerW Offline
          Wagner
          bei mir sehe ist ein "Python" 2.7.16 UND ein "Python3" 3.7.3. was mache ich damit?
          • WagnerW Wagner
            @wagner sagte in Neuinstallation: Esp-Home kann nicht installiert werden:
            Nix. Du installierst da ein aktuell unterstütztes Betriebssystem neu.
              WagnerW Offline
              WagnerW Offline
              Wagner
              😢 🤧 aber danke 👏
              • WagnerW Wagner
                😢 🤧 aber danke 👏
                @thomas-braun 😢 🤧 aber danke 👏
                Das ist keine einzige Schweißperle wert!
                • Backup erstellen
                • extern sichern
                • Betriebssystem neu aufsetzen
                • ioBroker mit dem Einzeiler incl. node und npm installieren
                • Backup zurückspielen
                feddisch!
                  • Backup erstellen
                  • extern sichern
                  feddisch!
                  WagnerW Offline
                  WagnerW Offline
                  Wagner
                  etwas so: ==========================================================================
                  ioBroker was installed successfully
                  Open http://192.168.178.96:8081 in a browser and start configuring!
                  You need to re-login before doing anything else on the console!
                  m2loft@ras4ssd:~ $ node -v
                  v18.19.0
                  m2loft@ras4ssd:~ $ npm -v
                  10.2.3
                  m2loft@ras4ssd:~ $
                  • WagnerW Wagner
                    v18.19.0
                    10.2.3
                    m2loft@ras4ssd:~ $
                    @wagner
                    Ausloggen, wieder einloggen.
                    Dann
                    iob diag
                    anschauen.
                      @wagner
                      Dann
                      iob diag
                      anschauen.
                      WagnerW Offline
                      WagnerW Offline
                      Wagner
                      mein backup habe ich schon geladen ohne die inst. zu aktivieren...
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                       Static hostname: ras4ssd
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi7-rpi-v8
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       23:09:11 up  1:56,  4 users,  load average: 1.36, 1.51, 1.24
                      CPU threads: 4
                      Current issues:
                                     Local time: Mon 2024-01-15 23:09:11 CET
                                 Universal time: Mon 2024-01-15 22:09:11 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      m2loft
                      /home/m2loft
                      m2loft adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.2G        1.1G        2.6G         19M        4.7G        7.1G
                      Swap:           104M          0B        104M
                      Total:          8.3G        1.1G        2.7G
                               7810 M total memory
                               1010 M used memory
                               1753 M active memory
                               3141 M inactive memory
                               2431 M free memory
                                165 M buffer memory
                               4343 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.6G     0  3.6G   0% /dev
                      tmpfs          tmpfs     782M  1.3M  780M   1% /run
                      /dev/sda2      ext4      110G  6.8G   98G   7% /
                      tmpfs          tmpfs     3.9G  148K  3.9G   1% /dev/shm
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/sda1      vfat      510M   73M  438M  15% /boot/firmware
                      tmpfs          tmpfs     782M   40K  781M   1% /run/user/1000
                      [Mon Jan 15 21:12:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D6:E2:01 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a6d2155b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                      [Mon Jan 15 21:12:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Mon Jan 15 21:12:28 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                      `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      520M    /var/
                      191M    /var/lib
                      188M    /var/cache
                      181M    /var/cache/apt
                      132M    /var/lib/apt/lists
                      Archived and active journals take up 39.9M in the file system.
                      407M    /opt/iobroker/iobroker-data/
                      367M    /opt/iobroker/iobroker-data/files
                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                      32M     /opt/iobroker/iobroker-data/objects.jsonl
                      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                      8.9M    /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                        system.adapter.accuweather.0            : accuweather           : ras4ssd                                  - disabled
                      + system.adapter.admin.0                  : admin                 : ras4ssd                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : ras4ssd                                  -  enabled
                        system.adapter.daswetter.0              : daswetter             : ras4ssd                                  - disabled
                        system.adapter.device-reminder.0        : device-reminder       : ras4ssd                                  - disabled
                        system.adapter.devices.0                : devices               : ras4ssd                                  - disabled
                        system.adapter.discovery.0              : discovery             : ras4ssd                                  - disabled
                        system.adapter.dwd.0                    : dwd                   : ras4ssd                                  - disabled
                        system.adapter.esphome.0                : esphome               : ras4ssd                                  -  enabled
                        system.adapter.flot.0                   : flot                  : ras4ssd                                  - disabled
                        system.adapter.history.0                : history               : ras4ssd                                  - disabled
                        system.adapter.hmip.0                   : hmip                  : ras4ssd                                  - disabled
                        system.adapter.ical.0                   : ical                  : ras4ssd                                  - disabled
                        system.adapter.ical.1                   : ical                  : ras4ssd                                  - disabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ras4ssd                                  - disabled
                        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ras4ssd                                  - disabled
                        system.adapter.icons-icons8.0           : icons-icons8          : ras4ssd                                  - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ras4ssd                                  - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ras4ssd                                  - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ras4ssd                                  - disabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ras4ssd                                  - disabled
                        system.adapter.info.0                   : info                  : ras4ssd                                  - disabled
                        system.adapter.iqontrol.0               : iqontrol              : ras4ssd                                  - disabled
                        system.adapter.javascript.0             : javascript            : ras4ssd                                  - disabled
                        system.adapter.lovelace.0               : lovelace              : ras4ssd                                  - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                        system.adapter.mqtt.0                   : mqtt                  : ras4ssd                                  - disabled, port: 1886, bind: 0.0.0.0
                        system.adapter.openweathermap.0         : openweathermap        : ras4ssd                                  - disabled
                        system.adapter.schoolfree.0             : schoolfree            : ras4ssd                                  - disabled
                        system.adapter.shelly.0                 : shelly                : ras4ssd                                  - disabled, port: 1882, bind: 0.0.0.0
                        system.adapter.sonoff.0                 : sonoff                : ras4ssd                                  - disabled, port: 1883, bind: 0.0.0.0
                        system.adapter.sql.0                    : sql                   : ras4ssd                                  - disabled, port: 0
                        system.adapter.tankerkoenig.0           : tankerkoenig          : ras4ssd                                  - disabled
                        system.adapter.telegram.0               : telegram              : ras4ssd                                  - disabled, port: 8443, bind: 0.0.0.0
                        system.adapter.text2command.0           : text2command          : ras4ssd                                  - disabled
                        system.adapter.tr-064.0                 : tr-064                : ras4ssd                                  - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ras4ssd                                  - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ras4ssd                                  - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : ras4ssd                                  - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : ras4ssd                                  - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ras4ssd                                  - disabled
                        system.adapter.vis-keyboard.0           : vis-keyboard          : ras4ssd                                  - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : ras4ssd                                  - disabled
                        system.adapter.vis-material.0           : vis-material          : ras4ssd                                  - disabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ras4ssd                                  - disabled
                        system.adapter.vis-metro.0              : vis-metro             : ras4ssd                                  - disabled
                        system.adapter.vis-players.0            : vis-players           : ras4ssd                                  - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : ras4ssd                                  - disabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : ras4ssd                                  - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ras4ssd                                  - disabled
                        system.adapter.vis-weather.0            : vis-weather           : ras4ssd                                  - disabled
                        system.adapter.vis.0                    : vis                   : ras4ssd                                  - disabled
                        system.adapter.web.0                    : web                   : ras4ssd                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Objects and States
                      Objects:        12374
                      States:         11357
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 85
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17581      782/cupsd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62025      20856/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61080      20856/iobroker.js-c
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17589      794/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62064      20881/io.admin.0
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17580      782/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          17591      794/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:41069           0.0.0.0:*                           104        16407      558/avahi-daemon: r
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19626      1330/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16405      558/avahi-daemon: r
                      udp6       0      0 fe80::53d5:5df9:71e:546 :::*                                0          34476      700/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        16406      558/avahi-daemon: r
                      udp6       0      0 :::55258                :::*                                104        16408      558/avahi-daemon: r
                      2024-01-15 23:09:39.163  - info: host.ras4ssd iobroker npm-install: Installing iobroker.vis-keyboard@0.0.2... (System call)
                      2024-01-15 23:09:55.686  - info: host.ras4ssd iobroker npm-install:
                      2024-01-15 23:09:55.688  - info: host.ras4ssd iobroker npm-install: added 1 package in 16s276 packages are looking for funding  run `npm fund` for details
                      2024-01-15 23:09:55.742  - info: host.ras4ssd iobroker npm-install: host.ras4ssd install adapter vis-keyboard@0.0.2
                      2024-01-15 23:09:55.856  - info: host.ras4ssd iobroker npm-install: upload [1] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/index.html index.html text/html
                      2024-01-15 23:09:55.990  - info: host.ras4ssd iobroker npm-install: upload [0] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/keyboard.png keyboard.png image/png
                      2024-01-15 23:09:56.021  - info: host.ras4ssd iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-keyboard/www" was not found! Nothing was uploaded or deleted.
                      2024-01-15 23:09:56.289  - info: host.ras4ssd iobroker npm-install: host.ras4ssd object system.adapter.vis-keyboard created/updated
                      2024-01-15 23:09:57.393  - info: host.ras4ssd iobroker npm-install: exit 0
                      2024-01-15 23:09:58.393  - warn: host.ras4ssd startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
                      2024-01-15 23:09:58.394  - info: host.ras4ssd iobroker install vis-material-advanced@1.7.4 using installedFrom
                      2024-01-15 23:10:02.592  - info: host.ras4ssd iobroker npm-install: NPM version: 10.2.3
                      2024-01-15 23:10:02.596  - info: host.ras4ssd iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
                      2024-01-15 23:10:19.190  - info: host.ras4ssd iobroker npm-install:
                      2024-01-15 23:10:19.191  - info: host.ras4ssd iobroker npm-install: added 1 package in 16s276 packages are looking for funding  run `npm fund` for details
                      2024-01-15 23:10:19.237  - info: host.ras4ssd iobroker npm-install: host.ras4ssd install adapter vis-material-advanced@1.7.4
                      2024-01-15 23:10:19.331  - info: host.ras4ssd iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
                      2024-01-15 23:10:19.348  - info: host.ras4ssd iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
                      2024-01-15 23:10:19.359  - info: host.ras4ssd iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
                      2024-01-15 23:10:19.543  - info: host.ras4ssd iobroker npm-install: host.ras4ssd object system.adapter.vis-material-advanced created/updated
                      2024-01-15 23:10:20.673  - info: host.ras4ssd iobroker npm-install: exit 0
                      2024-01-15 23:10:21.673  - warn: host.ras4ssd startInstance cannot find adapter "vis-material@0.1.3". Try to install it... 1 attempt
                      2024-01-15 23:10:21.674  - info: host.ras4ssd iobroker install vis-material@0.1.3 using installedFrom
                      2024-01-15 23:10:25.903  - info: host.ras4ssd iobroker npm-install: NPM version: 10.2.3
                      2024-01-15 23:10:25.907  - info: host.ras4ssd iobroker npm-install: Installing iobroker.vis-material@0.1.3... (System call)
                      Copy text starting here:
                                              v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Installation:           native
                      Kernel:                 aarch64
                      Userland:               arm64
                      Timezone:               Europe/Berlin (CET, +0100)
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     85
                      Pending iob updates:    3
                      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                              /usr/bin/npm            10.2.3
                                              /usr/bin/npx            10.2.3
                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                      MEMORY:
                      Mem:            8.2G        1.1G        2.5G         19M        4.8G        7.1G
                      Swap:           104M          0B        104M
                      Total:          8.3G        1.1G        2.6G
                      Active iob-Instances:   3
                      ioBroker Core:          js-controller           5.0.17
                                              admin                   6.12.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                12374
                      States:                 11357
                      Size of iob-Database:
                      === Mark text until here for copying ===
                      m2loft@ras4ssd:~ $
                      • WagnerW Wagner
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        m2loft
                        /home/m2loft
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 7810 M total memory
                                 1010 M used memory
                                 2431 M free memory
                                  165 M buffer memory
                                 4343 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        520M    /var/
                        191M    /var/lib
                        188M    /var/cache
                        181M    /var/cache/apt
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        12374
                        States:         11357
                        Pending Updates: 85
                                                v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            10.2.3
                                                /usr/bin/npx            10.2.3
                        MEMORY:
                        Swap:           104M          0B        104M
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                12374
                        States:                 11357
                        m2loft@ras4ssd:~ $
                        boot.target auf multi-user setzen:
                        sudo systemctl set-default multi-user.target
                        Pending Updates: 85
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                        Und die drei Adapter Updates auch einspielen.
