  4. Installation des Adapters awtrix-light schlägt fehl
3 Beiträge 2 Kommentatoren 519 Aufrufe 2 Beobachtet
    trackersos
    die Installation des Adapter awtrix-light schlägt fehl:
    $ iobroker add awtrix-light --host Biobroker
    Installing iobroker.awtrix-light@0.8.0... (System call)
    added 4 packages in 6s111 packages are looking for funding run `npm fund` for details
    host.Biobroker install adapter awtrix-light
    upload [13] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/awtrix-light.png awtrix-light.png image/png
    upload [10] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [8] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [5] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [2] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [0] awtrix-light.admin /opt/iobroker/node_modules/iobroker.awtrix-light/admin/jsonConfig.json jsonConfig.json application/json
    host.Biobroker Invalid version of "admin". Installed "6.3.6", required ">=6.6.0"
    ERROR: Process exited with code 32
    Das System ist aktuell. Admin ist in Version 6.10.8 installiert.
    folgendes ist durchgeführt:
    iob stop
    iob fix
    iob start
    Die Diagnostik ergibt:
    iob diag
    Zusammenfassung:
    			v.2023-10-10
       Static hostname: Biobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.203-1-pve
          Architecture: x86-64
    Installation: 		lxc
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.1
    			/usr/bin/node 		v18.18.1
    			/usr/bin/npm 		9.8.1
    			/usr/bin/npx 		9.8.1
    			/usr/bin/corepack 	0.19.0
    Recommended versions are nodejs 18.18.1 and npm 9.8.1
    MEMORY:
    Mem:           6.0G        1.3G        4.1G        0.0K        652M        4.7G
    Swap:          8.2G          0B        8.2G
    Total:          14G        1.3G         12G
    Active iob-Instances: 	16
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.12
    			admin 			6.10.8
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : Biobroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : Biobroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		2856
    States: 		2100
    Size of iob-Database:
    6.1M	/opt/iobroker/iobroker-data/objects.jsonl
    8.4M	/opt/iobroker/iobroker-data/states.jsonl
    Gesamter Log:
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
    model name	: Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:17:19 up 34 min,  1 user,  load average: 0.86, 0.92, 0.97
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-13 18:17:19 CEST
               Universal time: Fri 2023-10-13 16:17:19 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    alex
    /home/alex
    alex sudo iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:           6.0G        1.2G        4.1G        0.0K        647M        4.8G
    Swap:          8.2G          0B        8.2G
    Total:          14G        1.2G         12G
             6000 M total memory
             1249 M used memory
             1486 M active memory
              233 M inactive memory
             4103 M free memory
                0 M buffer memory
              647 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--104--disk--0 ext4       83G   12G   68G  16% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  132K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /sys/fs/cgroup
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Fri Oct 13 14:37:37 2023] EXT4-fs warning (device dm-13): ext4_end_bio:317: I/O error 10 writing to inode 139783 (offset 0 size 4096 starting block 1656224)
    [Fri Oct 13 14:42:05 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 14:44:22 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 14:56:39 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 15:12:40 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 15:55:19 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 17:18:22 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 17:26:00 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 13 17:39:42 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET                           SOURCE                                FSTYPE     OPTIONS
    /                                /dev/mapper/pve-vm--104--disk--0      ext4       rw,relatime,stripe=16
    |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    2.6G	/var/
    1.9G	/var/log/journal/b354c482f7cc342776f020ee5ea440c3
    1.9G	/var/log
    375M	/var/cache
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    6.3G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    174M	/opt/iobroker/iobroker-data/
    151M	/opt/iobroker/iobroker-data/files
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    33M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/npm 		9.8.1
    /usr/bin/npx 		9.8.1
    nodejs:
      Installed: 18.18.1-1nodesource1
      Candidate: 18.18.1-1nodesource1
      Version table:
     *** 18.18.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         16.20.2-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x nodistro/main amd64 Packages
         16.20.1-1nodesource1 500
         16.20.0-1nodesource1 500
         16.19.1-1nodesource1 500
         16.19.0-1nodesource1 500
         16.18.1-1nodesource1 500
         16.18.0-1nodesource1 500
         16.17.1-1nodesource1 500
         16.17.0-1nodesource1 500
         16.16.0-1nodesource1 500
         16.15.1-1nodesource1 500
         16.15.0-1nodesource1 500
         16.14.2-1nodesource1 500
         16.14.1-1nodesource1 500
         16.14.0-1nodesource1 500
         16.13.2-1nodesource1 500
         16.13.1-1nodesource1 500
         16.13.0-1nodesource1 500
         16.12.0-1nodesource1 500
         16.11.1-1nodesource1 500
         16.11.0-1nodesource1 500
         16.10.0-1nodesource1 500
         16.9.1-1nodesource1 500
         16.9.0-1nodesource1 500
         16.8.0-1nodesource1 500
         16.7.0-1nodesource1 500
         16.6.2-1nodesource1 500
         16.6.1-1nodesource1 500
         16.6.0-1nodesource1 500
         16.5.0-1nodesource1 500
         16.4.2-1nodesource1 500
         16.4.1-1nodesource1 500
         16.4.0-1nodesource1 500
         16.3.0-1nodesource1 500
         16.2.0-1nodesource1 500
         16.1.0-1nodesource1 500
         16.0.0-1nodesource1 500
         10.19.0~dfsg-3ubuntu1.2 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: http@^0.0.1-security, required by iobroker.javascript@7.1.4
    npm ERR! missing: url@^0.11.3, required by iobroker.javascript@7.1.4
    npm ERR! A complete log of this run can be found in: /home/alex/.npm/_logs/2023-10-13T16_17_21_186Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		6.10.8
    javascript: 	7.1.4
    Adapters from github: 	0
    Adapter State
    + system.adapter.backitup.0               : backitup              : Biobroker                                -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : Biobroker                                -  enabled
    + system.adapter.discovery.0              : discovery             : Biobroker                                -  enabled
      system.adapter.fahrplan.0               : fahrplan              : Biobroker                                - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : Biobroker                                -  enabled
    + system.adapter.hue.0                    : hue                   : Biobroker                                -  enabled, port: 443
      system.adapter.icons-material-png.0     : icons-material-png    : Biobroker                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Biobroker                                -  enabled
    + system.adapter.javascript.0             : javascript            : Biobroker                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Biobroker                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.pi-hole.0                : pi-hole               : Biobroker                                -  enabled
    + system.adapter.pushover.0               : pushover              : Biobroker                                -  enabled
    + system.adapter.shelly.0                 : shelly                : Biobroker                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : Biobroker                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.spotify-premium.0        : spotify-premium       : Biobroker                                - disabled
    + system.adapter.sql.1                    : sql                   : Biobroker                                -  enabled, port: 3306
    + system.adapter.sql.2                    : sql                   : Biobroker                                -  enabled, port: 3306
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Biobroker                                -  enabled
      system.adapter.vis-metro.0              : vis-metro             : Biobroker                                -  enabled
      system.adapter.vis.0                    : vis                   : Biobroker                                -  enabled
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.8
    Adapter    "awtrix-light" : 0.8.0    , installed 0.8.0
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.10.0   , installed 3.10.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects: 	2856
    States: 	2100
    Hit:1 https://deb.nodesource.com/node_16.x nodistro InRelease
    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        777727527  103/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          777727595  144/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          777727676  297/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       777756680  2697/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       777756673  2697/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          777725627  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          777727597  144/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       777757392  2993/io.simple-api.
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          777727677  297/master
    tcp6       0      0 :::1884                 :::*                    LISTEN      1001       777754348  2757/io.javascript.
    tcp6       0      0 :::111                  :::*                    LISTEN      0          777725629  1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       777753594  2715/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       777761063  2923/io.web.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       777754587  2878/io.shelly.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        777727526  103/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          777725628  1/init
    udp6       0      0 :::111                  :::*                                0          777725630  1/init
    2023-10-13 18:17:00.009  - info: javascript.0 (2757) script.js.SQL.Herd_AVG: 0
    2023-10-13 18:17:00.009  - info: javascript.0 (2757) script.js.SQL.NAS-Status: 0
    2023-10-13 18:17:00.011  - info: javascript.0 (2757) script.js.SQL.GetSensorData: {"sensor_temp":20.68}
    2023-10-13 18:17:00.011  - info: javascript.0 (2757) script.js.SQL.GetSensorData: 20.68
    2023-10-13 18:17:00.013  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: requestSonosAPI URL: http://192.168.17.25:5005/favorites
    2023-10-13 18:17:00.014  - info: javascript.0 (2757) script.js.SQL.GetSensorData: 28.25
    2023-10-13 18:17:03.548  - info: javascript.0 (2757) script.js.Wohnungstür: Tür geschlossen
    2023-10-13 18:17:10.004  - info: javascript.0 (2757) script.js.SQL.WaschmaschineAVG: 0
    2023-10-13 18:17:10.004  - info: javascript.0 (2757) script.js.SQL.Herd_AVG: 0
    2023-10-13 18:17:10.006  - info: javascript.0 (2757) script.js.SQL.TrocknerAVG: 0
    2023-10-13 18:17:13.003  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: requestSonosAPI URL: http://192.168.17.25:5005/playlists
    2023-10-13 18:17:17.386  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: Received Post
    2023-10-13 18:17:17.386  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: Result: {"type":"transport-state","data":{"uuid":"RINCON_38420B1BDE9001400","coordinator":"RINCON_38420B1BDE9001400","roomName":"Küche","state":{"volume":18,"mute":true,"equalizer":{"bass":0,"treble":0,"loudness":true},"currentTrack":{"artist":"rbb24 Inforadio","title":"NDR 2 - NDR 2 - ndr.de/ndr2","albumArtUri":"/getaa?s=1&u=x-sonosapi-stream%3atunein%253a5593%3fsid%3d303%26flags%3d8232%26sn%3d1","duration":0,"uri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","trackUri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","type":"radio","stationName":"rbb24 Inforadio","absoluteAlbumArtUri":"http://192.168.17.132:1400/getaa?s=1&u=x-sonosapi-stream%3atunein%253a5593%3fsid%3d303%26flags%3d8232%26sn%3d1"},"nextTrack":{"artist":"","title":"","album":"","albumArtUri":"","duration":0,"uri":""},"trackNo":1,"elapsedTime":0,"elapsedTimeFormatted":"00:00:00","playbackState":"PLAYING","playMode":{"repeat":"none","shuffle":false,"crossfade":false}},"groupState":{"volume":18,"mute":true},"avTransportUri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","avTransportUriMetadata":"<DIDL-Lite xmlns:dc=\"http://purl.org/dc/elements/1.1/\" xmlns:upnp=\"urn:schemas-upnp-org:metadata-1-0/upnp/\" xmlns:r=\"urn:schemas-rinconnetworks-com:metadata-1-0/\" xmlns=\"urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/\"><item id=\"-1\" parentID=\"-1\" restricted=\"true\"><dc:title>rbb24 Inforadio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><desc id=\"cdudn\" nameSpace=\"urn:schemas-rinconnetworks-com:metadata-1-0/\">SA_RINCON77575_X_#Svc77575-0-Token</desc></item></DIDL-Lite>"}}
    2023-10-13 18:17:17.419  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: Received Post
    2023-10-13 18:17:17.419  - info: javascript.0 (2757) script.js.Sonos.Sonos-webhook: Result: {"type":"transport-state","data":{"uuid":"RINCON_38420B1BDE9001400","coordinator":"RINCON_38420B1BDE9001400","roomName":"Küche","state":{"volume":18,"mute":true,"equalizer":{"bass":0,"treble":0,"loudness":true},"currentTrack":{"artist":"rbb24 Inforadio","title":"NDR 2 - NDR 2 - ndr.de/ndr2","albumArtUri":"/getaa?s=1&u=x-sonosapi-stream%3atunein%253a5593%3fsid%3d303%26flags%3d8232%26sn%3d1","duration":0,"uri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","trackUri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","type":"radio","stationName":"rbb24 Inforadio","absoluteAlbumArtUri":"http://192.168.17.132:1400/getaa?s=1&u=x-sonosapi-stream%3atunein%253a5593%3fsid%3d303%26flags%3d8232%26sn%3d1"},"nextTrack":{"artist":"","title":"","album":"","albumArtUri":"","duration":0,"uri":""},"trackNo":1,"elapsedTime":0,"elapsedTimeFormatted":"00:00:00","playbackState":"PLAYING","playMode":{"repeat":"none","shuffle":false,"crossfade":false}},"groupState":{"volume":18,"mute":true},"avTransportUri":"x-sonosapi-stream:tunein%3a5593?sid=303&flags=8232&sn=1","avTransportUriMetadata":"<DIDL-Lite xmlns:dc=\"http://purl.org/dc/elements/1.1/\" xmlns:upnp=\"urn:schemas-upnp-org:metadata-1-0/upnp/\" xmlns:r=\"urn:schemas-rinconnetworks-com:metadata-1-0/\" xmlns=\"urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/\"><item id=\"-1\" parentID=\"-1\" restricted=\"true\"><dc:title>rbb24 Inforadio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><desc id=\"cdudn\" nameSpace=\"urn:schemas-rinconnetworks-com:metadata-1-0/\">SA_RINCON77575_X_#Svc77575-0-Token</desc></item></DIDL-Lite>"}}
    2023-10-13 18:17:20.005  - info: javascript.0 (2757) script.js.SQL.TrocknerAVG: 0
    2023-10-13 18:17:20.005  - info: javascript.0 (2757) script.js.SQL.WaschmaschineAVG: 0
    2023-10-13 18:17:20.007  - info: javascript.0 (2757) script.js.SQL.Herd_AVG: 0
    2023-10-13 18:17:30.005  - info: javascript.0 (2757) script.js.SQL.WaschmaschineAVG: 0
    2023-10-13 18:17:30.005  - info: javascript.0 (2757) script.js.SQL.Herd_AVG: 0
    2023-10-13 18:17:30.007  - info: javascript.0 (2757) script.js.SQL.TrocknerAVG: 0
    2023-10-13 18:17:30.008  - info: javascript.0 (2757) script.js.SQL.NAS-Status: 0
    2023-10-13 18:17:40.005  - info: javascript.0 (2757) script.js.SQL.TrocknerAVG: 0
    2023-10-13 18:17:40.007  - info: javascript.0 (2757) script.js.SQL.WaschmaschineAVG: 0
    2023-10-13 18:17:40.008  - info: javascript.0 (2757) script.js.SQL.Herd_AVG: 0
    Hat jemand einen Tipp für mich?
    Herzlichen Dank
    • T trackersos
      iob stop
      iob fix
      iob start
      iob diag
      Zusammenfassung:
      			v.2023-10-10
                 Chassis: container
          Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		amd64
      User-ID: 		1000
      X-Server: 		false
      			/usr/bin/npm 		9.8.1
      			/usr/bin/npx 		9.8.1
      MEMORY:
      Swap:          8.2G          0B        8.2G
      Total:          14G        1.3G         12G
      			admin 			6.10.8
      Objects type: jsonl
      States  type: jsonl
      Objects: 		2856
      States: 		2100
      Gesamter Log:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      alex
      /home/alex
      alex sudo iobroker
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:          8.2G          0B        8.2G
      Total:          14G        1.2G         12G
               6000 M total memory
               1249 M used memory
               4103 M free memory
                  0 M buffer memory
                647 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G	/var/
      1.9G	/var/log
      375M	/var/cache
      USB-Devices by-id:
      /usr/bin/npm 		9.8.1
      /usr/bin/npx 		9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.10.8
      javascript: 	7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	2856
      States: 	2100
      Pending Updates: 0
      Herzlichen Dank
      @trackersos
      iob upload all
        @trackersos
        iob upload all
        trackersos
        @thomas-braun said in Installation des Adapters awtrix-light schlägt fehl:
        @trackersos
        iob upload all
        Wow Danke!
