  2. English
  3. Development
  4. New Adapter - Soliscloud
    6.1k
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.5k Aufrufe 9 Beobachtet
  • M TM M T
    Hallo
    Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
    @schneider_helmut said in New Adapter - Soliscloud:
    @trixx
    Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
    Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
    M TM Offline
    M TM Offline
    M T
    #41
    Can you tell me what data I need to enter??
    @m-t said in New Adapter - Soliscloud:
    Hallo
    @trixx
    • M TM M T
      Hallo
      @trixx
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #42
      @m-t
      Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
      What information do you miss in detail?
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      M TM 1 Antwort Letzte Antwort
      • mcm1957M mcm1957
        @m-t
        M TM Offline
        M TM Offline
        M T
        #43
        I'm concerned about which data and where should I enter it?
        IMG_4452.jpeg @mcm57 said in New Adapter - Soliscloud:
        @m-t
        • M TM M T
          @m-t
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #44
          @m-t
          As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
          Did you try to enter them there?
          Or did I misunderstand your question.
          What cocerns do you have?
          • mcm1957M mcm1957
            @m-t
            M TM Offline
            M TM Offline
            M T
            #45
            @m-t
            I use iobroker which data I have to enter where so that I can establish a connection
            TrixxT 1 Antwort Letzte Antwort
            • M TM M T
              @m-t
              TrixxT Offline
              TrixxT Offline
              Trixx
              #46
              @m-t
              Hi!
              What you show in your screenshot should work.
              You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
              Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
              Regards,
              T
              • TrixxT Trixx
                @m-t
                Hi!
                Regards,
                T
                M TM Offline
                M TM Offline
                M T
                #47
                @trixx said in New Adapter - Soliscloud:
                @m-t
                Hi!
                Regards,
                T
                The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
                • M TM M T
                  @m-t
                  Hi!
                  Regards,
                  T
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #48
                  @m-t
                  Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
                  G 1 Antwort Letzte Antwort
                  • TrixxT Trixx
                    @luapsi
                    Hi !
                    Sorry for the long delay. I had some stuff going on that I needed to handle first...
                    I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                    Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                    With that I should be able to map the values you requested.
                    Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                    Happy holidays !
                    Regards,
                    Trixx
                    Luapsi
                    #49
                    @trixx
                    Thank you for the implementation and your commitment.
                    Update carried out.
                    My adapter version is 1.4.0.
                    What settings can I make to support you?
                    greeting
                    Luapsi
                    • mcm1957M mcm1957
                      @m-t
                      gabylein
                      #50
                      Hy
                      installed it V1.4.1 - but getting no value from the cloud.
                      get this error
                      Instance:
                      Objects:
                      What is the right way to get the Information from the Cloud ?
                      greatings
                      gabylein
                      • G gabylein
                        Hy
                        get this error
                        Instance:
                        Objects:
                        greatings
                        gabylein
                        TrixxT Offline
                        TrixxT Offline
                        Trixx
                        #51
                        @gabylein
                        Hi !
                        Do you see more info if you set the logging level to debug ? The configuration seems right.
                        It should show what is returned from the different api calls.
                        • TrixxT Trixx
                          @gabylein
                          Hi !
                          gabylein
                          schrieb am zuletzt editiert von gabylein
                          #52
                          Its running
                          all the time I call directly this link ..
                          https://www.soliscloud.com/#/station/inverter/inverterdetail?id=xxxxxxxxxxxxxxxxxxxxxxxx&stationId=xxxxxxxxxxxxxxxxxxx
                          there is a mistake * Station ID is not Inverter ID :-)
                          running now
                          gabylein
                            meikel
                            #53
                            First of all, great work 👍 . The adapter works perfectly and provides reliable data.
                            If adjustments are made to the data points in the future, I would find the "total yield" value very interesting for further evaluations.
                            Regards
                              Mirtl
                              #54
                              @Trixx
                              Is it possible for you to integrate these?
                              • iDC1 Current
                              • iDC2 Current
                              • iDC3 Current
                              • iCD4 Current
                              • uDC1 Voltage
                              • uDC2 Voltage
                              • uDC3 Voltage
                              • uDC4 Voltage
                              • pDC1 Power
                              • pDC2 Power
                              • pDC3 Power
                              • pDC4 Power
                              Thank you very much in advance!
                              Mirtl
                              • M Mirtl
                                @Trixx
                                • iDC1 Current
                                • iDC2 Current
                                • iDC3 Current
                                • iCD4 Current
                                • uDC1 Voltage
                                • uDC2 Voltage
                                • uDC3 Voltage
                                • uDC4 Voltage
                                • pDC1 Power
                                • pDC2 Power
                                • pDC3 Power
                                • pDC4 Power
                                Mirtl
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #55
                                @trixx
                                You archived the repo ioBroker.soliscloud.
                                Please let us lnow if hhe adapter is nonlonger worki g due tp some cganges at the solis website or if you just do not have time or interrest to makntain it any further.
                                If the later is valud please consider movi g itvinto iobroker-community-adapters.This wpukd ne only a few clicks for you. Transfer ownership of repo to me (mcm1957) would be sufficient. I can do the rest.
                                Thanks for your feedback
                                Mcm1956
                                Edit
                                https://github.com/iobroker-community-adapters/info?tab=readme-ov-file#ask-to-move-your-repository-to-iobroker-community-adapters
                                des ribes the steps to initiate a transfer
                                • H Offline
                                  Honnkoponko
                                  #56
                                  @Trixx
                                  Is it possible to implement Inverter Control as on Home Assistant?
                                  Energy Storage Control Switch
                                  Overdischarge SOC
                                  Force Charge SOC
                                  Backup SOC
                                  Or does anyone knows how to control and monitor those values via Iobroker?
                                  • H Honnkoponko
                                    @Trixx
                                    Overdischarge SOC
                                    Force Charge SOC
                                    Backup SOC
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #57
                                    @honnkoponko
                                    This adapter is no longer maintained. I do not have any information WHY it was archived.
                                    IF the adpater is still working (and change by solis cloud etc.) is the reason to stop maintaining this adapter we could move it to iobroker-community-area so that at least base maintainance can be provided. Adding new features is always possible but depends on available developers.
                                    Please let me know if adapter is still working and if you eventually would help testing after migration to iobroker-community-area.
                                    (Please ping me again if I miss any answer)
