  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.5k Aufrufe 9 Beobachtet
  • S Schneider_Helmut
    @trixx
    I really appreciate your support. Your adapter will be very useful to Solis as people increasingly want to network systems. I can't understand why manufacturers don't make an effort to open up to common automation solutions and offer adapters themselves. For example, I have been looking for a wallbox for months where the manufacturer offers an IoBroker adapter with which I can start charging via IO-Broker and specify the charging current for the car myself.
    And I still did not find one.
    TrixxT Offline
    TrixxT Offline
    Trixx
    schrieb am zuletzt editiert von Trixx
    The latest version on github is broken, I broke it while trying to fix something else...
    I'll try fixing this tonight.
    Edit; small fix. Already ok again
    L 1 Antwort Letzte Antwort
    • TrixxT Trixx
      Luapsi
      @trixx
      I am also interested in the “Soliscloud” adapter.
      The installation was successful, unfortunately I can't get any further with the settings so that access to the SolisCloud is possible.
      No SolisCloud is displayed in the instances, but that's okay in the objects?
      I have already activated the Solis API.
      I have only recently started using ioBroker.
      Thk Sven
      TrixxT HomoranH 2 Antworten Letzte Antwort
      • L Luapsi
        @trixx
        Thk Sven
        TrixxT Offline
        TrixxT Offline
        Trixx
        @luapsi
        Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
        From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
        • L Luapsi
          @trixx
          Thk Sven
          @luapsi sagte in New Adapter - Soliscloud:
          that is the regular behavior by installing via github.
          The instance has to be added manually
            Luapsi
            Hello, I just found it in the documentation.
            Thank you very much:)
            • TrixxT Trixx
              I've created an adapter to read data from the API of soliscloud.com.
              The adapter can be installed in the expert settings / Custom.
              https://github.com/Trixx34/ioBroker.soliscloud
              At the moment it reads and stores the following values:
              • battery_current_usage
              • battery_percent
              • bought_Today
              • consumption_Today
              • current_Consumption
              • current_From_Net
              • current_Power
              • generated_Today
              • sold_Today
                More values can be added if people are interested. I'll link the documentation to what's available.
                Edit; The api information with all values is available >HERE<
              To use the API, you do need to request access trough suppport (service@ginlong.com).
              Once API access is enabled:
              • Go to https://www.soliscloud.com/#/apiManage.
              • Activate API management and agree with the usage conditions.
              • After activation, click on view key tot get a pop-up window asking for the verification code.
              • First click on "Verification code" after which you get an image with 2 puzzle pieces, which you need to overlap each other using the slider below.
              • After that, you will receive an email with the verification code you need to enter (within 60 seconds).
              • Once confirmed, you get the API ID, secret and API URL
              The configuration needs the API ID / API secret / PlantID to work, a polling interval also needs to be configured.
              All comments and feedback welcome.
              Luapsi
              @trixx sagte in New Adapter - Soliscloud:
              hi @trixx,
              The SolisCloud adapter also works for me. Thank you for your implementation.
              As you requested, it would be great if these values ​​could be added:
              from the Power Station List:
              1. batteryTodayDischargeEnergy
              2. batteryTodayChargeEnergy
              3. homeLoadTodayEnergy
              4. state
              5. oneSelf
              from the Inverter List:
              1. eToday
              2. etodayStr
              3. state
              Gerne teste ich für Dich!
              TrixxT 1 Antwort Letzte Antwort
              • L Luapsi
                hi @trixx,
                4. state
                5. oneSelf
                1. eToday
                2. etodayStr
                3. state
                TrixxT Offline
                TrixxT Offline
                Trixx
                @luapsi said in New Adapter - Soliscloud:
                hi @trixx,
                4. state
                5. oneSelf
                1. eToday
                2. etodayStr
                3. state
                Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
                I'll let you know once I have an update on this.
                L 2 Antworten Letzte Antwort
                • TrixxT Trixx
                  hi @trixx,
                  4. state
                  5. oneSelf
                  1. eToday
                  2. etodayStr
                  3. state
                  Luapsi
                  @trixx
                  hi @Trixx
                  thank you for taking the suggestions!
                  Here's a little addition!
                  In ioBroker, instances are assigned a category!
                  Would you be so kind as to put your instance in the “Energy” category?
                  Here is an excerpt from instances in this category
                  Thx Sven
                  • TrixxT Offline
                    TrixxT Offline
                    Trixx
                    @luapsi
                    I've just pushed a new version to github, I think it should include all requested additions :)
                    Regards,
                    Trixx
                    • TrixxT Trixx
                      @luapsi
                      Regards,
                      Trixx
                      Luapsi
                      @trixx
                      Your performance is great, thank you very much.
                      I will test extensively and give you feedback.
                      I wish you a pleasant day
                      • TrixxT Trixx
                        hi @trixx,
                        4. state
                        5. oneSelf
                        1. eToday
                        2. etodayStr
                        3. state
                        Luapsi
                        schrieb am zuletzt editiert von Luapsi
                        Hi @trixx,
                        all data fields are correct.
                        Thanks for the quick and professional work.
                        from the v1/api/InverterDetail:
                        1. familyLoadPower
                        2. familyLoadPowerStr
                        3. id inverter id
                        4. sn inverter sn
                        5. iAc1 AC current R
                        6. iAc2 AC current S
                        7. iAc3 AC current T
                        8. uAc1 AC voltage R
                        9. uAc2 AC voltage S
                        10. uAc3 AC voltage T
                        11. inverterTemperature
                        12. batteryPower
                        13. batterypowerStr
                        14. batteryPowerPec
                        15. batteryTodayChargeEnergy
                        16. batteryTodayChargeEnergyStr
                        17. batteryMonthChargeEnergy
                        18. batteryMonthChargeEnergyStr
                        19. batteryYearChargeEnergy
                        20. batteryYearChargeEnergyStr
                        21. batteryTotalChargeEnergy
                        22. batteryTotalChargeEnergyStr
                        23. batteryTodayDischargeEnergy
                        24. batteryTodayDischargeEnergyStr
                        25. batteryMonthDischargeEnergy
                        26. batteryMonthDischargeEnergyStr
                        27. batteryYearDischargeEnergy
                        28. batteryYearDischargeEnergyStr
                        29. batteryTotalDischargeEnergy
                        30. batteryTotalDischargeEnergyStr
                        another note about the data structure:
                        Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
                        • Power Station List (v1/api/userStationList)
                        • Power Station Detail (v1/api/stationDetail)
                        • Datalogger List (v1/api/collectorList)
                        • Data logger details (v1/api/collectorDetail)
                        Inverter List (v1/api/inverterList)
                        • Inverter details (v1/api/inverterDetail)
                          possible!
                        If I can support you here, please let me know.
                        Greetings from Saxony
                        PS: the app currently available from Solis cannot be used in this way.
                        • L Luapsi
                          Hi @trixx,
                          1. familyLoadPower
                          3. id inverter id
                          4. sn inverter sn
                          12. batteryPower
                          13. batterypowerStr
                          14. batteryPowerPec
                            possible!
                          TrixxT Offline
                          TrixxT Offline
                          Trixx
                          @luapsi
                          I've pushed another version to github.
                          The values are split up between the inverter & station details, for the values I did have to switch some things.
                          The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
                          I still have a few more to add and need to adjust some units .
                          I'll try to get to those later today or later this week.
                          Regards,
                          Trixx
                          • TrixxT Trixx
                            @luapsi
                            Regards,
                            Trixx
                            Luapsi
                            @trixx
                            Thank you for your enthusiasm and commitment!
                            For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
                            Let me know if there is any news.
                            Greetings Sven
                            • L Luapsi
                              @trixx
                              Greetings Sven
                              Luapsi
                              @Trixx
                              The problem with the API is solved.
                              An additional group is still needed :)
                              Is it possible for you to integrate these?
                              is needed to calculate data!
                              Thank you very much in advance!
                              from v1/api/epmDetail:
                              1. state
                              2. iAc1 Current U
                              3. iAc2 Current V
                              4. iAc3 Current W
                              5. uAc1 Voltage U
                              6. uAc2 Voltage V
                              7. uAc3 Voltage W
                              8. pAc1 Power U
                              9. pAc2 Power V
                              10. pAc3 Power W
                              11. facMeter
                              12. pEpmTotal
                              13. pEpmTotalStr
                              14. eTotalBuy
                              15. eTotalBayStr
                              16. eTotalSell
                              17. etotalSellStr
                              Thanks
                              TrixxT 2 Antworten Letzte Antwort
                              • L Luapsi
                                @Trixx
                                1. state
                                2. iAc1 Current U
                                3. iAc2 Current V
                                4. iAc3 Current W
                                5. uAc1 Voltage U
                                6. uAc2 Voltage V
                                7. uAc3 Voltage W
                                8. pAc1 Power U
                                9. pAc2 Power V
                                10. pAc3 Power W
                                11. facMeter
                                12. pEpmTotal
                                13. pEpmTotalStr
                                14. eTotalBuy
                                15. eTotalBayStr
                                16. eTotalSell
                                17. etotalSellStr
                                Thanks
                                TrixxT Offline
                                TrixxT Offline
                                Trixx
                                @luapsi
                                I'll see what I can do !
                                • L Luapsi
                                  @Trixx
                                  1. state
                                  2. iAc1 Current U
                                  3. iAc2 Current V
                                  4. iAc3 Current W
                                  5. uAc1 Voltage U
                                  6. uAc2 Voltage V
                                  7. uAc3 Voltage W
                                  8. pAc1 Power U
                                  9. pAc2 Power V
                                  10. pAc3 Power W
                                  11. facMeter
                                  12. pEpmTotal
                                  13. pEpmTotalStr
                                  14. eTotalBuy
                                  15. eTotalBayStr
                                  16. eTotalSell
                                  17. etotalSellStr
                                  Thanks
                                  TrixxT Offline
                                  TrixxT Offline
                                  Trixx
                                  @luapsi
                                  Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
                                  I do have some IRL things to take care of this week, so it might be a few days before I get to this.
                                  Regards,
                                  Trixx
                                  • TrixxT Offline
                                    TrixxT Offline
                                    Trixx
                                    @luapsi
                                    Hi !
                                    Sorry for the long delay. I had some stuff going on that I needed to handle first...
                                    I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                                    Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                                    With that I should be able to map the values you requested.
                                    Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                                    Happy holidays !
                                    Regards,
                                    Trixx
                                      @trixx
                                      Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                                      Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                                      M TM Offline
                                      M TM Offline
                                      M T
                                      Hallo
                                      Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                                      @schneider_helmut said in New Adapter - Soliscloud:
                                      @trixx
                                      mcm1957M M TM 2 Antworten Letzte Antwort
                                      • M TM M T
                                        Hallo
                                        @trixx
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        @m-t said in New Adapter - Soliscloud:
                                        Hallo
                                        Können sie bitte einen Bild hochladen .........
                                        This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        M TM 1 Antwort Letzte Antwort
                                        • mcm1957M mcm1957
                                          Hallo
                                          M TM Offline
                                          M TM Offline
                                          M T
                                          Can you give me a screenshot of the app settings? how to enter the data
                                          @mcm57 said in New Adapter - Soliscloud:
                                          Hallo
