  4. Test Adapter device-reminder V 3.x
390 Beiträge 48 Kommentatoren 114.3k Aufrufe 57 Beobachtet
  • Rene55R Rene55
    @xenon Ja natürlich gern:
      "linkedDevice": {
         "ids": [
             "enabled": true,
             "name": "Trockner",
             "telegram": [
               "1"
             "autoOff": false,
             "timer": "0",
             "abort": false,
             "id": "1"
             "enabled": true,
             "name": "Waschen",
             "telegram": [
               "1"
             "autoOff": false,
             "timer": "0",
             "abort": false,
             "id": "2"
             "enabled": true,
             "name": "Geschirr",
             "telegram": [
               "1"
             "autoOff": false,
             "timer": "0",
             "abort": false,
             "id": "3"
         "finalIds": {
           "1": {
             "type": "custom1",
             "pathConsumption": "sonoff.0.DVES_DE4DE7.ENERGY_Power",
             "pathSwitch": "sonoff.0.DVES_DE4DE7.POWER",
             "startText": "Trockner läuft",
             "endText": "Trockner ist fertig",
             "enabled": true,
             "name": "Trockner",
             "alexa": [],
             "sayit": [],
             "telegram": [
               "1"
             "whatsapp": [],
             "pushover": [],
             "signal": [],
             "email": [],
             "matrix": [],
             "timer": "0",
             "autoOff": false,
             "abort": false,
             "id": "1"
           "2": {
             "type": "custom2",
             "pathConsumption": "sonoff.0.DVES_DE6C60.ENERGY_Power",
             "pathSwitch": "sonoff.0.DVES_DE6C60.POWER",
             "startText": "Waschmaschine läuft",
             "endText": "Waschmaschine ist fertig",
             "enabled": true,
             "name": "Waschen",
             "alexa": [],
             "sayit": [],
             "telegram": [
               "1"
             "whatsapp": [],
             "pushover": [],
             "signal": [],
             "email": [],
             "matrix": [],
             "timer": "0",
             "autoOff": false,
             "abort": false,
             "id": "2"
    XenonX Offline
    XenonX Offline
    Xenon
    Forum Testing Developer
    #41
    @rene55 danke, ich schaue heute Abend mal danach :)
    wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
    Rene55R 1 Antwort Letzte Antwort
    • XenonX Xenon
      Rene55R Offline
      Rene55R Offline
      Rene55
      #42
      @xenon Ich hatte jetzt nur "linkedDevice" geschickt. Brauchst du noch die "devices"?
      Und wie krieg ich das in den schwarzen Kasten?
      Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
      ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
      Wetterstation: Froggit WH3000SE V1.6.6
      XenonX 1 Antwort Letzte Antwort
      • Rene55R Rene55
        XenonX Offline
        XenonX Offline
        Xenon
        #43
        @rene55
        nein, dass reicht ;)
        code_text
        • XenonX Xenon
          @rene55
          code_text
          Rene55R Offline
          Rene55R Offline
          Rene55
          #44
          @xenon Danke. Jetzt hats funktioniert. Habe ich eben auch so gemacht - hat aber nicht geklappt. So siehts schön aus.
          • Rene55R Rene55
            XenonX Offline
            XenonX Offline
            Xenon
            #45
            @rene55 habe im Admin nochmals einfach auf Speichern geklickt, aufmal ist auch der Trockner angelegt worden. Merkwürdiges Verhalten, ich versuche es mal irgendwie zu reproduzieren :/
            • XenonX Xenon
              Rene55R Offline
              Rene55R Offline
              Rene55
              #46
              @xenon Um nochmal speichern zu können muss man erstmal was verändern. Ich hab einfach ein 4. Gerät hinzugefügt und schon ist das dritte Gerät im Objektbaum. Was ich auch festgestellt habe, der Neustart danach dauert (nach meinem Gefühl) recht lang.
              • Rene55R Rene55
                XenonX Offline
                XenonX Offline
                Xenon
                #47
                @rene55 sagte in Test Adapter device-reminder V 2.x:
                Aber das neue wurde nicht angelegt? Das wäre ein Ansatz....
                • XenonX Xenon
                  Rene55R Offline
                  Rene55R Offline
                  Rene55
                  schrieb am zuletzt editiert von Rene55
                  #48
                  @xenon So ist es.
                  ERGÄNZUNG: In der Config ist es drin. Womöglich ein Darstellungsproblem, dass irgendwo ein Index nicht sauber mitläuft.
                  • Rene55R Rene55
                    @xenon So ist es.
                    XenonX Offline
                    XenonX Offline
                    Xenon
                    #49
                    @xenon So ist es.
                    Aber unter "finalIds" wirds fehlen. Und genau da stehen die Daten, aus denen der Adapter das Objekt erstellt. Aber immerhin habe ich dann nachher eine Möglichkeit, das Ganze zu reproduzieren. Danke dir !
                    • XenonX Xenon
                      @xenon So ist es.
                      Rene55R Offline
                      Rene55R Offline
                      Rene55
                      #50
                      @xenon Ja korrekt. Device 1 - 3 sind da, 4 fehlt. Frohes schaffen
                      • XenonX Offline
                        XenonX Offline
                        Xenon
                        schrieb am zuletzt editiert von Xenon
                        #51
                        Neue Version auf github (3.0.0)
                        Achtung: Alle die nicht die Version 2.1.2 installiert hatten (das sind die wenigsten), müssen den Adapter zwingend neu installieren!
                        Alle bekannten Bugs sollten behoben sein, inklusive fehlender Buttons für die Config
                        Sollte es keine großen Probleme mehr geben, kommt die Version am Wochenende in die latest. Vorher passe ich natürlich die readme noch an, da ja einige Neuerungen dazu gekommen sind. Schönen abend ;)
                        F KnallochseK 2 Antworten Letzte Antwort
                        • XenonX Xenon
                          flotux
                          #52
                          @Xenon
                          Folgende Warnung bekomme ich im ioBroker Log noch:
                          Ansonsten teste ich die Tage jetzt mal, ob alles soweit funktioniert und gebe Feedback.
                          • F flotux
                            @Xenon
                            XenonX Offline
                            XenonX Offline
                            Xenon
                            #53
                            @flotux sagte in Test Adapter device-reminder V 3.x:
                            @Xenon
                            Obwohl du den Adapter neu installiert hast?
                            F 1 Antwort Letzte Antwort
                            • XenonX Xenon
                              @Xenon
                              flotux
                              #54
                              @xenon
                              Exakt! Ich habe den Adapter vollständig entfernt und dann neu über die GitHub Adresse aktualisiert.
                              • F flotux
                                @xenon
                                XenonX Offline
                                XenonX Offline
                                Xenon
                                #55
                                @flotux okay, das ist das Objekt welches den Adapter in den Instanzen gelb anzeigt. Brauchst du erstmal nicht weiter beachten
                                • XenonX Xenon
                                  Rene55R Offline
                                  Rene55R Offline
                                  Rene55
                                  #56
                                  @xenon Version 3.0.0 drübergebügelt. Sieht gut aus: 4.Gerät ist da und Export funktioniert auch. Jetzt muss nur noch gewaschen werden.
                                  • H Offline
                                    Hakemann
                                    #57
                                    Hallo xenon, erstmal vielen Dank für deine Arbeit und gute Besserung.
                                    Bisher scheint es bei mir zu funktionieren. Was mir aufgefallen ist, dass sich der Pfad von Alexa geändert hat. "Speak" findet sich nicht mehr unter "Announcements", sondern unter "Commands".
                                    Wo du gerade schon dran arbeitest kannst du das vielleicht auch anpassen.
                                    • H Hakemann
                                      XenonX Offline
                                      XenonX Offline
                                      Xenon
                                      #58
                                      @hakemann das ist nur ein beispiel dafür, dass man entweder announcement oder speak auswählen muss
                                      H 1 Antwort Letzte Antwort
                                      • XenonX Xenon
                                        Hakemann
                                        #59
                                        @xenon 👍
                                        • XenonX Xenon
                                          KnallochseK Offline
                                          KnallochseK Offline
                                          Knallochse
                                          schrieb am zuletzt editiert von Knallochse
                                          #60
                                          am Smartphone verdrückt
                                          HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
