  4. Alexa2 Version 3.24.+
    6.6k
alexa2
157 Beiträge 32 Kommentatoren 36.5k Aufrufe 37 Beobachtet
  • J Offline
    JohnnyBahama
    schrieb am zuletzt editiert von JohnnyBahama
    @apollon77
    Die History funktioniert wieder mit dem manuellem fix von GitHub, aber ich wollte mir das update offiziell über den Adapter installieren.
    Das Update steigt allerdings aus.
    v6.3.5
    Log-Größe: 42.6 KB
    Zeit
    debug
    Nachricht
    host.raspberrypi4
    2023-08-11 15:55:59.941	info	iobroker exit 25
    host.raspberrypi4
    2023-08-11 15:55:58.909	error	iobroker host.raspberrypi4 Cannot install iobroker.alexa2@3.24.1: 217
    host.raspberrypi4
    2023-08-11 15:55:58.879	info	iobroker npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/enquirer' -> '/opt/iobroker/node_modules/.enquirer-mkjbX5s3'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-08-11T13_55_49_224Z-debug-0.log
    host.raspberrypi4
    2023-08-11 15:55:58.869	info	iobroker npm ERR! path /opt/iobroker/node_modules/enquirernpm ERR! dest /opt/iobroker/node_modules/.enquirer-mkjbX5s3npm ERR! errno -39
    host.raspberrypi4
    2023-08-11 15:55:58.867	info	iobroker npm ERR! syscall rename
    host.raspberrypi4
    2023-08-11 15:55:58.860	info	iobroker npm ERR! code ENOTEMPTY
    host.raspberrypi4
    2023-08-11 15:55:48.004	info	iobroker Installing iobroker.alexa2@3.24.1... (System call)
    host.raspberrypi4
    2023-08-11 15:55:48.002	info	iobroker NPM version: 8.19.2
    host.raspberrypi4
    2023-08-11 15:55:46.696	info	iobroker Update alexa2 from @3.23.2 to @3.24.1
    host.raspberrypi4
    2023-08-11 15:55:43.817	info	iobroker upgrade alexa2@3.24.1 --debug
    Ro75R F Thomas BraunT A 4 Antworten Letzte Antwort
    • J JohnnyBahama
      @apollon77
      v6.3.5
      Log-Größe: 42.6 KB
      Zeit
      debug
      Nachricht
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      Ro75R Offline
      Ro75R Offline
      Ro75
      @johnnybahama Schaue mal bitte hier
      • J JohnnyBahama
        @apollon77
        v6.3.5
        Log-Größe: 42.6 KB
        Zeit
        debug
        Nachricht
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        host.raspberrypi4
        Frank579
        schrieb am zuletzt editiert von Frank579
        @johnnybahama sagte in Alexa2 Version 3.24.+:
        Schau mal in den angepinnten Beitrag ....
        • J JohnnyBahama
          @apollon77
          v6.3.5
          Log-Größe: 42.6 KB
          Zeit
          debug
          Nachricht
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          host.raspberrypi4
          @johnnybahama
          Insgesamt das Thema nodejs auf Stand bringen.
          Mit aktuellen, ordentlich installierten Versionen passiert das soweit ich das sehe gar nicht mehr.
          Ringo-66R 1 Antwort Letzte Antwort
            @johnnybahama
            Ringo-66R Offline
            Ringo-66R Offline
            Ringo-66
            schrieb am zuletzt editiert von Ringo-66
            @apollon77
            Hallo, ich versuche gerade den ALexa2 Adapter im ioBroker ans Laufen zu bringen... Das gelingt mir leider (noch) nicht...
            Ich habe nach der Installation der Version 3.24.1 in der Instanz des Adapters den Link aufgerufen, um den Adapter mit Alexa zu verknüpfen.
            Es wird eine lokale Seite mit Port "56208" geöffnet, nach Eingabe meiner Logindaten kommt die 2fa über die Codeeingabe.
            Diese verlinkt zur USA-Seite: xxx:56208/www.amazon.com/ap/cvf/transactionapproval?arbxxx
            Muss das dorthin verlinken?
            Die Codeeingabe dort ist sehr schwierig, nach Eingabe von 2..3 Zeichen erfolgt scheinbar ein Seitenreload und das Inputfeld wird wieder gelöscht... (mit c&p klappt es dann)...
            Nach Bestätigung des Codes kommt dann aber ein 404'er (xxx:56208/www.amazon.com/404)
            Was mache ich falsch?
            ...ach ja, bin auf einem Windowssystem, alle Komponenten sind auf dem neuesten Stand...
            Vielen Dank für Deine / Eure Hilfe!
            • Ringo-66R Ringo-66
              @apollon77
              @ringo-66 einfach bei Amazon das „alte“ 2fa was du hast auf das neue über die App oder sowas aktualisieren. Dann gehts wieder.
              • apollon77A Offline
                Ansonsten so als Vorwarnung: es häufen sich gerade erste Meldungen das auch der vor kurzem gefundene und eingebaute fix was die history Themen angeht (also ändern auf den alten Weg) jetzt von Amazon auch deaktiviert wurde.
                Wie ist es bei euch? Geht noch alles?
                Ich bin gerade noch im Urlaub und kann so nichts testen.
                Ingo
                Chris76eC Ro75R DJMarc75D E padrinoP 7 Antworten Letzte Antwort
                • apollon77A apollon77
                  Ingo
                  Chris76eC Offline
                  Chris76eC Offline
                  Chris76e
                  @apollon77 sagte in Alexa2 Version 3.24.+:
                  Bei mir funktioniert es noch einwandfrei
                  Chris76eC 1 Antwort Letzte Antwort
                    Ingo
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    Hier auch alles OK.
                      Ingo
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @apollon77 naja, Spotify und Alexa harmonieren nicht mehr. Mal klappts, mal nicht, ... ist aber kein Beinbruch 👍
                      Lehrling seit 1975 !!!
                        Ingo
                        Eggs
                        @apollon77
                        @apollon77 said in Alexa2 Version 3.24.+:
                        Nööö - History wird hier nicht mehr befüllt - da hat Amazon mal wieder ganze Arbeit geleistet. Ich frage mich so langsam, ob dort nur Amateure rumsitzen, die aus Langeweile irgendwas verbocken oder ob da ne Absicht dahintersteckt und wenn ja: welche? Was haben die davon, ein funktionierendes System (basierend auf IHREN Geräten) zu sabotieren?
                        Zumindest sinkt der WAF in letzter Zeit abgrundtief. Bin vor 2 Wochen nachts aus dem Urlaub gekommen - nix ging. Da hatte Ingo aber zum Glück schon den o.g. Fix bereit - vielen Dank dafür!
                        Ich lese eigentlich nur die summery aus und reagiere mit Skripten darauf - mein Datenverkehr hält sich also in Grenzen...
                        kopfschüttelnde Grüße nach Amazonien und nochmals Dank an @apollon77 für seine Ausdauer
                        Dirk
                        • E Eggs
                          @apollon77
                          Dirk
                          @eggs Du musst das anders sehen. Ggf sind das einfach Funktionen und Datentraffic den SIe nicht mehr in der Alexa APp brauchen als nehmen Sie es raus. Bedenkt bitte das wir uns da "inoffizieller Weise" an APIs und Daten dranklemmen die halt da waren ... naja jetzt halt nicht mehr
                          padrinoP 1 Antwort Letzte Antwort
                          • Chris76eC Chris76e
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            @chris76e sagte in Alexa2 Version 3.24.+:
                            Jetzt funktioniert es bei mir auch nicht mehr.....
                              Ringo-66R Offline
                              Ringo-66R Offline
                              Ringo-66
                              @apollon77 Danke Dir! (kaum macht man es richtig... schon geht's ;) )
                                Ingo
                                padrinoP Offline
                                padrinoP Offline
                                padrino
                                @apollon77
                                Also, wie bereits auf Github geschrieben, hier klappt es noch.
                                Stand jetzt wird history noch brav befüllt.
                                Die Frage bleibt, wie lange noch...
                                • padrinoP padrino
                                  @apollon77
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  @padrino sagte in Alexa2 Version 3.24.+:
                                  Spätestens wenn der Adapter neu gestartet wird :(
                                  • DJMarc75D DJMarc75
                                    padrinoP Offline
                                    padrinoP Offline
                                    padrino
                                    @djmarc75 sagte in Alexa2 Version 3.24.+:
                                    Hmm, auf mich (als Laien) wirkt das doch alles sehr seltsam...
                                    Denn wenn Amazon "ein Signal" abgeschaltet hätte, dann dürften doch alle nix mehr empfangen...
                                    Wenn es nach einem Neustart scheitern, klingt es für mich so, als wäre alles noch da, nur Berechtigungen gingen verloren. 🤷
                                    F 1 Antwort Letzte Antwort
                                    • padrinoP padrino
                                      flitzpiepe
                                      ich klinke mich hier mal ein, da der Adapter bei mir (3.24.1) seit gestern die History auch nicht mehr füllt und jetzt diverse Sprachkommandos nicht mehr funktionieren, die auf der Auswertung des Datenpunktes basieren. der Adapter an sich wird als "grün" dargestellt.
                                      Jetzt nicht als Kritik verstehen, sondern mich würde nur interessieren, ob es regelmäßig vorkommt, dass Amazon etwas "spontan" an der Schnittstelle ändert und die Entwickler vom Adapter dann natürlich auf Ursachenforschung gehen müssen, um das Ganze wieder zum Laufen zu bringen? Und kann es sein, dass Amazon irgendwann generell einen Riegel davor schiebt, weil es nicht erwünscht ist, Alexa in externe Systeme integrieren zu können?
                                      Wie gesagt ist rein aus Interesse gefragt und danke an die Entwickler, die so viel Zeit und Mühe in das Projekt investieren.
                                      Grüße...
                                        padrinoP Offline
                                        padrinoP Offline
                                        padrino
                                        Ja, hab mir auch schon in der Vergangenheit gedacht, wieso es diese ganzen push Infos gibt. Wüsste nicht, dass ich mir was erklären könnte, wo due App das braucht...
                                        Dennoch schön, dass sie da waren. 😌
                                        • padrinoP padrino
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          Hm, bei mir lüppt das .
                                          Summary wird nach 1sek befüllt.
                                          Hab noch ne ältere Version und die Einstellungen
                                          DJMarc75D padrinoP 2 Antworten Letzte Antwort
