  3. Einsteigerfragen
  4. Gelöst: radar2 Adapter läuft seit einiger Zeit auf Fehler
16 Beiträge 4 Kommentatoren 1.2k Aufrufe 5 Beobachtet
  • crepp1967C Offline
    crepp1967C Offline
    crepp1967
    schrieb am zuletzt editiert von crepp1967
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 10 (buster)
    Kernel:                 4.19.0-25-amd64
    Installation:           kvm
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            11G        4.7G        4.7G         11M        2.3G        6.7G
    Swap:          974M          0B        974M
    Total:          12G        4.7G        5.6G
    Active iob-Instances:   41
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.7.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
    Objects:                26800
    States:                 24777
    Size of iob-Database:
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    16M     /opt/iobroker/iobroker-data/objects.json.broken
    111M    /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/states.json.migrated
    11M     /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Seit einiger Zeit startet der Adapter alle paar Minuten neu u. wirft diesen Fehler ins Protokoll:
    host.iob-test1-proxmox
    2023-08-10 12:47:16.184	warn	Do not restart adapter system.adapter.radar2.0 because restart loop detected
    2023-08-10 12:47:16.183	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    radar2.0
    2023-08-10 12:47:14.586	warn	Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
    radar2.0
    2023-08-10 12:47:14.572	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    radar2.0
    2023-08-10 12:47:14.566	warn	Uncaught Exception: bind EACCES 0.0.0.0:67
    radar2.0
    2023-08-10 12:47:14.565	error	Exception-Code: EACCES: bind EACCES 0.0.0.0:67
    radar2.0
    2023-08-10 12:47:14.564	error	Error: bind EACCES 0.0.0.0:67 at node:dgram:362:20 at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
    radar2.0
    2023-08-10 12:47:14.562	error	uncaught exception: bind EACCES 0.0.0.0:67
    Ich habe die hier empfohlenen Befehle ausgeführt.
    Manche bringen aber diesen Fehler bei der Ausführung:
    z.B.
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which arp-scan)
    readlink: fehlender Operand
    „readlink --help“ liefert weitere Informationen.
    [sudo] Passwort für pi:
    usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
     Note <filename> must be a regular (non-symlink) file.
    pi@iob-test1-proxmox:~$
    Da ich kein Linux Profi bin stehe ich auf dem Schlauch, irgend jemand eine Idee oder sehe ich den Wald vor lauter Bäumen nicht?
    Torsten
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • crepp1967C crepp1967
                           v.2023-04-16
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:          974M          0B        974M
                              admin                   6.7.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                26800
      States:                 24777
      radar2.0
      radar2.0
      radar2.0
      radar2.0
      radar2.0
      radar2.0
      z.B.
      Torsten
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @crepp1967 sagte in radar2 Adapter läuft seit einiger Zeit auf Fehler:
      eine Idee
      Vielleicht hängt es ja mit Deiner BetatesterVersion vom AdminAdapter zusammen ?!
      Lehrling seit 1975 !!!
      crepp1967C 1 Antwort Letzte Antwort
                             v.2023-04-16
        Installation:           kvm
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:          974M          0B        974M
                                admin                   6.7.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                26800
        States:                 24777
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        z.B.
        Torsten
        @crepp1967
        sudo -Hu iobroker which readlink arp-scan
        sagt?
        • DJMarc75D DJMarc75
          eine Idee
          crepp1967C Offline
          crepp1967C Offline
          crepp1967
          @djmarc75
          Das Problem war schon vorher.
            @crepp1967
            sagt?
            crepp1967C Offline
            crepp1967C Offline
            crepp1967
            /usr/bin/readlink
            /usr/sbin/arp-scan
              /usr/bin/readlink
              /usr/sbin/arp-scan
              @crepp1967
              Bitte vollständig Ein- wie Ausgaben inkl. Login prompts.
              sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f /usr/sbin/arp-scan)
              Und dein 'Buster / Debian 10' ist auch abgekündigt, installier da was lebendiges.
                @crepp1967
                crepp1967C Offline
                crepp1967C Offline
                crepp1967
                @thomas-braun sagte in radar2 Adapter läuft seit einiger Zeit auf Fehler:
                ok - mach ich
                Hier die Ein- u. Ausgaben:
                pi@iob-test1-proxmox:~$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f /usr/sbin/arp-scan)
                seltsam, jetzt kommt plötzlich kein Fehler mehr...
                  ok - mach ich
                  Der Befehl wurde ja auch leicht abgeändert... ;-)
                  crepp1967C 3 Antworten Letzte Antwort
                    crepp1967C Offline
                    crepp1967C Offline
                    crepp1967
                    OK, das ist mir nicht aufgefallen - jetzt kommt jedenfalls kein Fehler mehr.
                    Ich hoffe dass sich das Prob damit erledigt hat.
                    Vielen Dank für Eure Hilfe.
                    Wenn alles funktioniert werde ich den Thread auf gelöst setzen...
                      crepp1967C Offline
                      crepp1967C Offline
                      crepp1967
                      Leider zu früh gefreut.
                      Nach dem Neustart des Servers kommt diese Protokollmeldung:
                      radar2.0
                      2023-08-10 14:23:00.882	warn	Promise failed @ 'main in /opt/iobroker/node_modules/iobroker.radar2/radar2.js @744:13; onReady in /opt/iobroker/node_modules/iobroker.radar2/fjadapter-core.js @212:3' error: Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2663:37) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2709:33) at process.processImmediate (node:internal/timers:478:21) { [stack]: 'Error: DB closed\n' + ' at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)\n' + ' at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)\n' + ' at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2663:37)\n' + ' at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2709:33)\n' + ' at process.processImmediate (node:internal/timers:478:21)', [message]: 'DB closed'}
                      Aber ich benutze Redis gar nicht.
                        crepp1967C Offline
                        crepp1967C Offline
                        crepp1967
                        Bei jedem Scan (alle 60s) kommen diese Fehlermeldungen:
                        radar2.0
                        2023-08-10 14:33:00.555	warn	redis get radar2.0.ping_AVM_ENYA._here, error - Connection is closed.
                        radar2.0
                        2023-08-10 14:33:00.554	warn	Error {} is setState for ping_AVM_ENYA._here with {"val":true,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2023-08-10 14:33:00.554	warn	get state error: Connection is closed.
                        radar2.0
                        2023-08-10 14:33:00.553	warn	Could not perform strict object check of state radar2.0.ping_AVM_ENYA._here: DB closed
                        radar2.0
                        2023-08-10 14:33:00.552	warn	redis get radar2.0.ping_AVM_ENYA._here, error - Connection is closed.
                        radar2.0
                        2023-08-10 14:33:00.551	warn	redis get radar2.0.ping_AVM_ENYA, error - Connection is closed.
                        radar2.0
                        2023-08-10 14:33:00.550	warn	Error {} is setState for ping_AVM_ENYA with {"val":true,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                        radar2.0
                        2023-08-10 14:33:00.548	warn	get state error: Connection is closed.
                        radar2.0
                        2023-08-10 14:33:00.533	warn	redis get radar2.0.ping_AVM_ENYA, error - Connection is closed.
                        radar2.0
                        2023-08-10 14:32:00.651	warn	error {} extend object radar2.0.ping_SamsungHD._whatHere
                        radar2.0
                        2023-08-10 14:32:00.645	warn	error {} extend object radar2.0.ping_SamsungHD._nHere
                        radar2.0
                        2023-08-10 14:29:00.586	warn	error {} extend object radar2.0._uIPs.192-168-1-25
                        radar2.0
                        2023-08-10 14:29:00.582	warn	redis get radar2.0._uIPs.192-168-1-24, error - Connection is closed.
                        radar2.0
                        2023-08-10 14:29:00.581	warn	Error {} is setState for radar2.0._uIPs.192-168-1-24 with {"val":"{ ipAddress: '192.168.1.24', macAddress: '98:d8:63:31:5b:46', by: 'arp', hosts: [], getMacVendor: 'Shanghai High-Flying Electronics Tech Co, Ltd'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                          radar2.0
                          crunchipC Abwesend
                          crunchipC Abwesend
                          bezieht sich wohl aufs interne redis was iobroker nutzt
                          eigentlich sollten die "cups" im fixer inbegriffen sein, also normal nur ein iob fix ausführen
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            radar2.0
                            Kommen alle vom Adapter. Kann ich aber nix zu sagen.
                              crepp1967C Offline
                              crepp1967C Offline
                              crepp1967
                              Habe nun den Adapter deinstalliert u nach Reboot neu installiert.
                              Seitdem ohne Fehler...
                              Torsten
                                Torsten
                                @crepp1967 sagte in Gelöst: radar2 Adapter läuft seit einiger Zeit auf Fehler:
                                Hast du auch in Zuge des Reboots dein Betriebssystem aktualisiert?
                                  crepp1967C Offline
                                  crepp1967C Offline
                                  crepp1967
                                  Ja, ich habe gleich im Anschluss auf bullseye hochgezogen.
                                  Torsten
