  4. [gelöst] JS-Controller update schlägt fehl
    5.3k
js-controller update
51 Beiträge 6 Kommentatoren 5.6k Aufrufe 4 Beobachtet
  • da_WoodyD da_Woody
    @thomas-braun büddescheen:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 12 (bookworm)
    Release:        12
    Codename:       bookworm
    PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
    NAME="Debian GNU/Linux"
    VERSION_ID="12"
    VERSION="12 (bookworm)"
    VERSION_CODENAME=bookworm
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:18:32 up 1 min,  2 users,  load average: 1.20, 0.35, 0.12
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-03 19:18:32 CEST
               Universal time: Thu 2023-08-03 17:18:32 UTC
                     RTC time: Thu 2023-08-03 17:18:32
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    woody
    /home/woody
    woody cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            6.2G        2.0G        4.0G        499K        456M        4.2G
    Swap:           1.0G          0B        1.0G
    Total:          7.2G        2.0G        5.0G
             5925 M total memory
             1907 M used memory
              141 M active memory
             1798 M inactive memory
             3808 M free memory
               50 M buffer memory
              384 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs          tmpfs     593M  492K  593M   1% /run
    /dev/sda1      ext4       97G   14G   79G  15% /
    tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
    [Thu Aug  3 19:17:31 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Aug  3 19:17:32 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    3.9G    /var/
    3.4G    /var/log/journal/6285e535af59466aa3856f0d231ada92
    3.4G    /var/log
    331M    /var/cache
    Archived and active journals take up 743.3M in the file system.
    /opt/iobroker/backups:
    487M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    513M    /opt/iobroker/iobroker-data/
    297M    /opt/iobroker/iobroker-data/files
    120M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    20M     /opt/iobroker/iobroker-data/states.jsonl
    20M     /opt/iobroker/iobroker-data/objects.json.bak
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
            100 /var/lib/dpkg/status
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.7.0
    javascript:     7.1.1
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
      system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
      system.adapter.gruenbeck.0              : gruenbeck             : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : ioBroker                                 - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
      system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
      system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: woody
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
      system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.0.250
      system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
    + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 4001
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.7.0    , installed 6.7.0
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
    Adapter    "openweathermap": 0.3.11  , installed 0.3.11
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "wled"         : 0.7.0    , installed 0.7.0
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Objects and States
    Objects:        23431
    States:         17605
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.0.250:1883      0.0.0.0:*               LISTEN      1001       20705      953/io.sonoff.0
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       17179      639/sshd: woody@pts
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22029      1107/io.shelly.1
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       18644      731/io.mqtt.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13296      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15879      480/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      458/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15913      458/iobroker.js-con
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       17178      639/sshd: woody@pts
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13298      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15881      480/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15997      515/io.admin.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       19555      766/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14729      408/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13297      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18280      716/io.mihome-vacuu
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19940      825/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          13299      1/init
    2023-08-03 19:18:58.364  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_send_email_attachment" has to be type "string" but received type "boolean"
    2023-08-03 19:18:58.440  - info: host.ioBroker instance system.adapter.backitup.0 started with pid 1130
    2023-08-03 19:18:58.468  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_view_google" has to be type "string" but received type "boolean"
    2023-08-03 19:18:58.502  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_send_email_attachment" has to be type "string" but received type "boolean"
    2023-08-03 19:18:58.542  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_view_microsoft" has to be type "string" but received type "boolean"
    2023-08-03 19:18:58.581  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_view_google" has to be type "string" but received type "boolean"
    2023-08-03 19:18:58.810  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_view_microsoft" has to be type "string" but received type "boolean"
    2023-08-03 19:19:02.272  - info: host.ioBroker instance scheduled system.adapter.birthdays.0 0 0 * * *
    2023-08-03 19:19:02.288  - info: host.ioBroker instance system.adapter.birthdays.0 started with pid 1158
    2023-08-03 19:19:05.643  - info: backitup.0 (1130) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.0, js-controller: 5.0.11
    2023-08-03 19:19:05.837  - info: backitup.0 (1130) [iobroker] backup will be activated at 03:30 every 1 day(s)
    2023-08-03 19:19:06.549  - info: host.ioBroker instance scheduled system.adapter.daswetter.0 */30 * * * *
    2023-08-03 19:19:06.590  - info: host.ioBroker instance system.adapter.daswetter.0 started with pid 1229
    2023-08-03 19:19:06.783  - error: backitup.0 (1130) Error: Command failed: sudo mount -t cifs -o username=simon,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/sharename/backupDir /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    2023-08-03 19:19:11.010  - info: host.ioBroker instance system.adapter.device-reminder.0 started with pid 1260
    2023-08-03 19:19:14.862  - info: host.ioBroker instance system.adapter.fronius.0 started with pid 1291
    2023-08-03 19:19:18.853  - info: host.ioBroker instance system.adapter.gruenbeck.0 started with pid 1307
    2023-08-03 19:19:21.112  - info: device-reminder.0 (1260) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.17.0, js-controller: 5.0.11
    2023-08-03 19:19:22.228  - info: device-reminder.0 (1260) Device "Waschmaschine" was successfully created
    2023-08-03 19:19:23.109  - info: host.ioBroker instance system.adapter.info.0 started with pid 1330
    2023-08-03 19:19:24.986  - info: device-reminder.0 (1260) Device "Trockner" was successfully created
    2023-08-03 19:19:27.490  - info: host.ioBroker instance system.adapter.iot.0 started with pid 2001
    summary:
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 12 (bookworm)
    Kernel:                 6.1.0-10-amd64
    Installation:           kvm
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.0
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            6.2G        3.5G        2.1G        503K        799M        2.7G
    Swap:           1.0G          0B        1.0G
    Total:          7.2G        3.5G        3.2G
    Active iob-Instances:   36
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.7.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                23431
    States:                 17605
    Size of iob-Database:
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/states.jsonl
    3.0M    /opt/iobroker/iobroker-data/states.json.bak
    #41
    @da_woody
    Setz den woody noch in die Gruppe adm rein.
    Dann kann der ohne root Rechte auch logs lesen.
      @da_woody
      da_WoodyD Offline
      da_WoodyD Offline
      da_Woody
      #42
      @thomas-braun /usr/sbin/usermod -a -G adm woody ?
      @crunchip was für ein + ?
      gruß vom Woody
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
        crunchipC Offline
        crunchipC Offline
        #43
        + instance is alive
          #44
          @da_woody
          sudo /usr/sbin/usermod -a -G adm woody
          müsste ja jetzt funktionieren, root wird nicht mehr verwendet.
            + instance is alive
            da_WoodyD Offline
            da_WoodyD Offline
            da_Woody
            #45
            @crunchip
            alles lebt...
            gruß vom Woody
              @da_woody
              da_WoodyD Offline
              da_WoodyD Offline
              da_Woody
              #46
              @thomas-braun 👍
              gruß vom Woody
                @crunchip
                alles lebt...
                crunchipC Offline
                crunchipC Offline
                #47
                @da_woody sagte in [gelöst] JS-Controller update schlägt fehl:
                alles lebt...
                laut deiner Ausgabe oben aber nicht
                  alles lebt...
                  da_WoodyD Offline
                  da_WoodyD Offline
                  da_Woody
                  #48
                  @crunchip tjo, wer lügt da? :)
                  witziger weise waren beide synology instanzen grad mit orangenem dreieck versehn, in der liste war aber das + drinnen...
                  nochmal laufen lassen, jetzt stehn da mehr +...
                  Adapter State
                  + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                  + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
                  + system.adapter.gruenbeck.0              : gruenbeck             : ioBroker                                 -  enabled
                  + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 -  enabled
                  + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                  + system.adapter.octoprint.0              : octoprint             : ioBroker                                 -  enabled
                  + system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: woody
                  + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
                  + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  + instance is alive
                  gruß vom Woody
                    Adapter State
                    + instance is alive
                    crunchipC Offline
                    crunchipC Offline
                    #49
                    @da_woody jetzt passt`s
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      #50
                      @crunchip sültsam... vllt war nach dem reboot noch nicht alles da? (js-controller update)
                      ich geb für heute ein over and out.
                      die birne raucht. (schachtel kippen auch verblasen)
                      da das problem, nebenbei in sketchup war konstruieren fürn 3d-drucker, gleichzeitig den drucker füttern, seit 06:00 auf den hufen, frau wau bespaßen, ...
                      ich werd alt. :D
                      rückzug in die furzmulde...
                      gruß vom Woody
                        ich werd alt. :D
                        crunchipC Offline
                        crunchipC Offline
                        #51
                        wäre ne Erklärung
                        da war ich schon wieder müde😜
