  4. [gelöst] JS-Controller update schlägt fehl
    5.3k
js-controller update
51 Beiträge 6 Kommentatoren 5.6k Aufrufe 4 Beobachtet
  • da_WoodyD da_Woody
    @thomas-braun sagte in [gelöst] JS-Controller update schlägt fehl:
    iob diag
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 12 (bookworm)
    Kernel:                 6.1.0-10-amd64
    Installation:           kvm
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     38
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/node           v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            6.2G        3.6G        1.9G        528K        993M        2.6G
    Swap:           1.0G          0B        1.0G
    Total:          7.2G        3.6G        2.9G
    Active iob-Instances:   36
    Active repo(s): Beta (latest)
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.7.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                23431
    States:                 17588
    Size of iob-Database:
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/objects.json.bak
    14M     /opt/iobroker/iobroker-data/states.jsonl
    3.0M    /opt/iobroker/iobroker-data/states.json.bak
    @da_woody sagte in [gelöst] JS-Controller update schlägt fehl:
    Und dann bitte die Langfassung.
      da_WoodyD Offline
      da_WoodyD Offline
      @thomas-braun büddescheen:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
      NAME="Debian GNU/Linux"
      VERSION_ID="12"
      VERSION="12 (bookworm)"
      VERSION_CODENAME=bookworm
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       19:18:32 up 1 min,  2 users,  load average: 1.20, 0.35, 0.12
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Thu 2023-08-03 19:18:32 CEST
                 Universal time: Thu 2023-08-03 17:18:32 UTC
                       RTC time: Thu 2023-08-03 17:18:32
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      woody
      /home/woody
      woody cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            6.2G        2.0G        4.0G        499K        456M        4.2G
      Swap:           1.0G          0B        1.0G
      Total:          7.2G        2.0G        5.0G
               5925 M total memory
               1907 M used memory
                141 M active memory
               1798 M inactive memory
               3808 M free memory
                 50 M buffer memory
                384 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs          tmpfs     593M  492K  593M   1% /run
      /dev/sda1      ext4       97G   14G   79G  15% /
      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
      [Thu Aug  3 19:17:31 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Aug  3 19:17:32 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      3.9G    /var/
      3.4G    /var/log/journal/6285e535af59466aa3856f0d231ada92
      3.4G    /var/log
      331M    /var/cache
      Archived and active journals take up 743.3M in the file system.
      /opt/iobroker/backups:
      487M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      513M    /opt/iobroker/iobroker-data/
      297M    /opt/iobroker/iobroker-data/files
      120M    /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
      20M     /opt/iobroker/iobroker-data/states.jsonl
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.0
      /usr/bin/node           v18.17.0
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
       *** 18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.11
      admin:          6.7.0
      javascript:     7.1.1
      Adapters from github:   4
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
        system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
        system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
        system.adapter.gruenbeck.0              : gruenbeck             : ioBroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        system.adapter.influxdb.1               : influxdb              : ioBroker                                 - disabled, port: 8086
        system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
        system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.octoprint.0              : octoprint             : ioBroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
        system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: woody
      + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
        system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
        system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.0.250
        system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 4001
        system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
        system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.7.0    , installed 6.7.0
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.1.1    , installed 7.1.1
      Controller "js-controller": 5.0.11   , installed 5.0.11
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
      Adapter    "openweathermap": 0.3.11  , installed 0.3.11
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
      Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
      Adapter    "socketio"     : 6.5.2    , installed 6.5.2
      Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 6.1.0    , installed 6.1.0
      Adapter    "wled"         : 0.7.0    , installed 0.7.0
      Adapter    "ws"           : 2.5.3    , installed 2.5.3
      Objects and States
      Objects:        23431
      States:         17605
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.0.250:1883      0.0.0.0:*               LISTEN      1001       20705      953/io.sonoff.0
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       17179      639/sshd: woody@pts
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22029      1107/io.shelly.1
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       18644      731/io.mqtt.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13296      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15879      480/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14942      458/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15913      458/iobroker.js-con
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       17178      639/sshd: woody@pts
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13298      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15881      480/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15997      515/io.admin.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       19555      766/io.radar2.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14729      408/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13297      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18280      716/io.mihome-vacuu
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19940      825/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          13299      1/init
      2023-08-03 19:18:58.364  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_send_email_attachment" has to be type "string" but received type "boolean"
      2023-08-03 19:18:58.440  - info: host.ioBroker instance system.adapter.backitup.0 started with pid 1130
      2023-08-03 19:18:58.468  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_view_google" has to be type "string" but received type "boolean"
      2023-08-03 19:18:58.502  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_send_email_attachment" has to be type "string" but received type "boolean"
      2023-08-03 19:18:58.542  - info: synology.0 (996) State value to set for "synology.0.FileStation.info.enable_view_microsoft" has to be type "string" but received type "boolean"
      2023-08-03 19:18:58.581  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_view_google" has to be type "string" but received type "boolean"
      2023-08-03 19:18:58.810  - info: synology.1 (1022) State value to set for "synology.1.FileStation.info.enable_view_microsoft" has to be type "string" but received type "boolean"
      2023-08-03 19:19:02.272  - info: host.ioBroker instance scheduled system.adapter.birthdays.0 0 0 * * *
      2023-08-03 19:19:02.288  - info: host.ioBroker instance system.adapter.birthdays.0 started with pid 1158
      2023-08-03 19:19:05.643  - info: backitup.0 (1130) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.0, js-controller: 5.0.11
      2023-08-03 19:19:05.837  - info: backitup.0 (1130) [iobroker] backup will be activated at 03:30 every 1 day(s)
      2023-08-03 19:19:06.549  - info: host.ioBroker instance scheduled system.adapter.daswetter.0 */30 * * * *
      2023-08-03 19:19:06.590  - info: host.ioBroker instance system.adapter.daswetter.0 started with pid 1229
      2023-08-03 19:19:06.783  - error: backitup.0 (1130) Error: Command failed: sudo mount -t cifs -o username=simon,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/sharename/backupDir /opt/iobroker/backups
      mount error(2): No such file or directory
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      2023-08-03 19:19:11.010  - info: host.ioBroker instance system.adapter.device-reminder.0 started with pid 1260
      2023-08-03 19:19:14.862  - info: host.ioBroker instance system.adapter.fronius.0 started with pid 1291
      2023-08-03 19:19:18.853  - info: host.ioBroker instance system.adapter.gruenbeck.0 started with pid 1307
      2023-08-03 19:19:21.112  - info: device-reminder.0 (1260) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.17.0, js-controller: 5.0.11
      2023-08-03 19:19:22.228  - info: device-reminder.0 (1260) Device "Waschmaschine" was successfully created
      2023-08-03 19:19:23.109  - info: host.ioBroker instance system.adapter.info.0 started with pid 1330
      2023-08-03 19:19:24.986  - info: device-reminder.0 (1260) Device "Trockner" was successfully created
      2023-08-03 19:19:27.490  - info: host.ioBroker instance system.adapter.iot.0 started with pid 2001
      summary:
                           v.2023-04-16
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.0
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Mem:            6.2G        3.5G        2.1G        503K        799M        2.7G
      Swap:           1.0G          0B        1.0G
      Total:          7.2G        3.5G        3.2G
                              admin                   6.7.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                23431
      States:                 17605
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/states.jsonl
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        12
        Codename:       bookworm
        VERSION_ID="12"
        ID=debian
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        woody
        /home/woody
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 5925 M total memory
                 1907 M used memory
                  141 M active memory
                 3808 M free memory
                   50 M buffer memory
                  384 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        3.9G    /var/
        3.4G    /var/log
        331M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.7.0
        javascript:     7.1.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        23431
        States:         17605
        Pending Updates: 0
        summary:
                             v.2023-04-16
        Installation:           kvm
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:           1.0G          0B        1.0G
                                admin                   6.7.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                23431
        States:                 17605
        crunchipC Offline
        crunchipC Offline
        @da_woody irgend etwas stimmt aber teilweise nicht mit deinen Instanzen
        z.b
        wo ist das +?
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        12
          Codename:       bookworm
          VERSION_ID="12"
          ID=debian
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          woody
          /home/woody
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
                   5925 M total memory
                   1907 M used memory
                    141 M active memory
                   3808 M free memory
                     50 M buffer memory
                    384 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          3.9G    /var/
          3.4G    /var/log
          331M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.7.0
          javascript:     7.1.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        23431
          States:         17605
          Pending Updates: 0
          summary:
                               v.2023-04-16
          Installation:           kvm
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:           1.0G          0B        1.0G
                                  admin                   6.7.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                23431
          States:                 17605
          @da_woody
          Setz den woody noch in die Gruppe adm rein.
          Dann kann der ohne root Rechte auch logs lesen.
            @da_woody
            da_WoodyD Offline
            da_WoodyD Offline
            @thomas-braun /usr/sbin/usermod -a -G adm woody ?
            @crunchip was für ein + ?
              crunchipC Offline
              crunchipC Offline
              + instance is alive
                @da_woody
                sudo /usr/sbin/usermod -a -G adm woody
                müsste ja jetzt funktionieren, root wird nicht mehr verwendet.
                  + instance is alive
                  da_WoodyD Offline
                  da_WoodyD Offline
                  @crunchip
                  alles lebt...
                    @da_woody
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @thomas-braun 👍
                      @crunchip
                      alles lebt...
                      crunchipC Offline
                      crunchipC Offline
                      alles lebt...
                      laut deiner Ausgabe oben aber nicht
                        alles lebt...
                        da_WoodyD Offline
                        da_WoodyD Offline
                        @crunchip tjo, wer lügt da? :)
                        witziger weise waren beide synology instanzen grad mit orangenem dreieck versehn, in der liste war aber das + drinnen...
                        nochmal laufen lassen, jetzt stehn da mehr +...
                        Adapter State
                        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                        + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                        + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
                        + system.adapter.gruenbeck.0              : gruenbeck             : ioBroker                                 -  enabled
                        + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                        + system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 -  enabled
                        + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                        + system.adapter.octoprint.0              : octoprint             : ioBroker                                 -  enabled
                        + system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
                        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                        + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: woody
                        + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
                        + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                        + instance is alive
                          Adapter State
                          + instance is alive
                          crunchipC Offline
                          crunchipC Offline
                          @da_woody jetzt passt`s
                            da_WoodyD Offline
                            da_WoodyD Offline
                            @crunchip sültsam... vllt war nach dem reboot noch nicht alles da? (js-controller update)
                            ich geb für heute ein over and out.
                            die birne raucht. (schachtel kippen auch verblasen)
                            da das problem, nebenbei in sketchup war konstruieren fürn 3d-drucker, gleichzeitig den drucker füttern, seit 06:00 auf den hufen, frau wau bespaßen, ...
                            ich werd alt. :D
                            rückzug in die furzmulde...
                              ich werd alt. :D
                              crunchipC Offline
                              crunchipC Offline
                              wäre ne Erklärung
                              da war ich schon wieder müde😜
