  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 499.3k Aufrufe 137 Beobachtet
    tritanium
    #441
    @copystring
    So, hier gehts los.... nach 3h dauerhafte re-connects....
    Vorher keine Logs zum Roborock Adapter....:
    roborock.0
       2024-01-17 21:07:21.291	warn	MQTT connection reconnect.
    roborock.0
       2024-01-17 21:07:20.291	warn	MQTT connection close.
    roborock.0
       2024-01-17 21:07:20.124	warn	MQTT connection reconnect.
    roborock.0
       2024-01-17 21:07:19.123	warn	MQTT connection close.
    roborock.0
       2024-01-17 21:07:18.974	warn	MQTT connection reconnect.
    roborock.0
       2024-01-17 21:07:17.974	warn	MQTT connection close.
    roborock.0
       2024-01-17 21:07:17.737	warn	MQTT connection reconnect.
    roborock.0
       2024-01-17 21:07:17.734	warn	MQTT connection close.
    roborock.0
       2024-01-17 21:07:17.695	warn	Reconnecting mqtt client!
    linux-control.0
       2024-01-17 21:05:50.014	info	successful received data from ioBroker (192.168.50.5:22)
    linux-control.0
       2024-01-17 21:05:36.041	info	getting data from ioBroker (192.168.50.5:22)
    tr-064.0
       2024-01-17 21:05:04.878	info	starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.17.0, js-controller: 5.0.17
    host.iobroker
       2024-01-17 21:05:02.170	info	instance system.adapter.tr-064.0 started with pid 2476245
    host.iobroker
       2024-01-17 21:05:00.932	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.iobroker
       2024-01-17 21:05:00.931	info	instance system.adapter.tr-064.0 scheduled normal terminated and will be restarted on schedule.
    tr-064.0
       2024-01-17 21:05:00.595	info	terminating
    tr-064.0
       2024-01-17 21:05:00.229	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    tr-064.0
       2024-01-17 21:05:00.225	info	terminating
    Jede Sekunde disconnect & reconnect...
    Thomas BraunT copystringC 2 Antworten Letzte Antwort
    • T tritanium
      @copystring
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      linux-control.0
      linux-control.0
      tr-064.0
      host.iobroker
      host.iobroker
      host.iobroker
      tr-064.0
      tr-064.0
      tr-064.0
      #442
      @tritanium sagte in Neuer Adapter für Roborock-Staubsauger:
      node: v18.17.0
      Aktualisieren...
      iob nodejs-update
      da_WoodyD T 2 Antworten Letzte Antwort
        node: v18.17.0
        Aktualisieren...
        iob nodejs-update
        da_WoodyD Online
        da_WoodyD Online
        da_Woody
        #443
        @thomas-braun und wie erklärt sich dann das?
        Node.js v18.19.0 (Es gibt eine neuere Version: v18.17.1)
        gruß vom Woody
          node: v18.17.0
          Aktualisieren...
          iob nodejs-update
          tritanium
          #444
          Hallo Thomas,
          hat denn die Version Auswirkungen aus die MQTT re-connects ?? :-\
          • da_WoodyD da_Woody
            #445
            @da_woody
            Das erklärt sich durch Caching.
            • T tritanium
              Hallo Thomas,
              #446
              NodeJS ist das 'Betriebssystem' für den ioBroker, das wirkt sich natürlich auf alles aus.
              Heute Nachmittag war eine alte nodeJS-Version der Grund für gescheiterte Logins bei DHL. Aktuelles nodeJS installiert, schon funktionierte es. Da war zuvor auch die Notwendigkeit eines Updates als komplett unnötig angesehen worden.
              Nein, ein aktuelles, konsistent aufgesetztes nodeJS ist essentiell wichtig.
                tritanium
                #447
                Danke für die Info 🐶
                ...dann werde ich mal die/das Update "eben" machen.....
                • T tritanium
                  #448
                  Dauert 2 Minuten.
                    Dauert 2 Minuten.
                    da_WoodyD Online
                    da_WoodyD Online
                    da_Woody
                    #449
                    @thomas-braun klar gehts schnell.
                    ioBroker nodejs updater 2023-10-13
                    Recommended nodejs-version is: 18.19.0
                    Checking your installation now. Please be patient!
                    Your current setup is:
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    We found these nodejs versions available for installation:
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                    Node.js v18.19.0 nur ist halt die meldung über eine angeblich neuere weg.
                    gruß vom Woody
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                      #450
                      @da_woody sagte in Neuer Adapter für Roborock-Staubsauger:
                      Ja, und? Die war ja eh falsch. War die Anzeige im Admin, oder?
                        da_WoodyD Online
                        da_WoodyD Online
                        da_Woody
                        #451
                        @thomas-braun im info
                        gruß vom Woody
                          #452
                          @da_woody
                          Ja, ist bekannt das da schon mal falsche Versionen gemeldet werden.
                          Auf die Anzeige an der Stelle kannst du nix geben.
                            @da_woody
                            da_WoodyD Online
                            da_WoodyD Online
                            da_Woody
                            #453
                            @thomas-braun ok, soweit, so gut.
                            allerdings ist es bei mir auch wieder zu den MQTT warnings gekommen. wie bei @tritanium
                            muss doch auch was im adapter klemmen @copystring
                            gruß vom Woody
                              #454
                              Ich hab ja auch nicht behauptet, dass ein aktuelles nodejs die Lösung für das konkrete Problem sei. Lediglich das eine aktuelle Version die Basis für alles weitere sein soll.
                                @da_woody
                                tritanium
                                schrieb am zuletzt editiert von tritanium
                                #455
                                vSooooo :-D
                                ...bin wieder online... alles aktualisiert.... hach, das war ein wenig mehr...inkl. komplettem System update ...
                                => Dann starte ich mal wieder den Roborock Adapter und schau mal was passiert....
                                Ich will hoffen das das entweder läuft, oder bitte nicht wieder 3h dauert 🤤
                                roborock.0
                                	2024-01-17 22:06:44.899	info	MQTT initialized
                                roborock.0
                                	2024-01-17 22:06:38.735	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                roborock.0
                                	2024-01-17 22:06:38.696	info	starting. Version 0.5.1 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.19.0, js-controller: 5.0.17
                                host.iobroker
                                	2024-01-17 22:06:32.567	info	instance system.adapter.roborock.0 started with pid 8416
                                host.iobroker
                                	2024-01-17 22:06:32.031	info	"system.adapter.roborock.0" enabled
                                • T tritanium
                                  @copystring
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  linux-control.0
                                  linux-control.0
                                  tr-064.0
                                  host.iobroker
                                  host.iobroker
                                  host.iobroker
                                  tr-064.0
                                  tr-064.0
                                  tr-064.0
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #456
                                  @tritanium said in Neuer Adapter für Roborock-Staubsauger:
                                  @copystring
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  linux-control.0
                                  linux-control.0
                                  tr-064.0
                                  host.iobroker
                                  host.iobroker
                                  host.iobroker
                                  tr-064.0
                                  tr-064.0
                                  tr-064.0
                                  Dann hast du nicht die aktuellste dev von gestern Abend.
                                  Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                                  https://paypal.me/copystring
                                  • T tritanium
                                    @copystring Moin :-)
                                    Kurze Review: Neue /dev heute morgen installiert, Adapter crasht nicht mehr!
                                    Beim verlassen des Hauses, starteten beide Robis auch normal (durch Blockly).
                                    Gefahren sind sie ganz normal und in der App konnte ich logischerweise sehen was die machen.
                                    AAAABER:
                                    Derzeit wird mir das Logging vom ioBroker zugespammt :-)
                                    Die Datenpunkte für die CleaningInfo scheint nicht aktualisiert zu werden. Die steh noch auf dem Datum von gestern .... auch während der Reinigungsvorgänge kommen die ganze Zeit diese Logeinträge.....
                                    Hier mal ein kurzer Auszug:
                                    roborock.0
                                       2024-01-16 08:37:10.420	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:10.325	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:09.324	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:09.233	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:08.232	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:08.136	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:07.135	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:07.038	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:06.377	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with id 28705 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:37:06.038	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:05.951	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:05.746	warn	Failed to execute get_map_v1 on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with id 28704 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:37:04.951	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:04.854	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:03.854	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:03.743	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:02.742	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:02.655	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:01.655	warn	MQTT connection close.
                                    linux-control.0
                                       2024-01-16 08:37:01.566	info	getting data from ioBroker (192.168.50.5:22)
                                    roborock.0
                                       2024-01-16 08:37:01.553	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:37:01.430	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with id 28696 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:37:00.740	warn	Failed to execute get_map_v1 on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with id 28692 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:37:00.553	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:37:00.446	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:59.445	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:59.338	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:58.337	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:58.232	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:57.232	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:57.125	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:56.337	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with id 28691 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:56.126	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:56.018	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:55.792	warn	Failed to execute get_map_v1 on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with id 28685 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:55.018	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:54.912	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:53.910	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:53.809	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:52.809	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:52.700	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:51.699	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:51.592	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:51.393	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with id 28679 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:50.748	warn	Failed to execute get_map_v1 on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with id 28678 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:50.591	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:50.487	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:49.486	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:49.379	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:48.378	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:48.272	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:47.270	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:47.160	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:46.373	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with id 28670 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:46.160	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:46.053	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:45.785	warn	Failed to execute get_map_v1 on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with id 28666 with method get_map_v1 timed out after 10 seconds for response.102
                                    roborock.0
                                       2024-01-16 08:36:45.053	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:44.946	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:43.946	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:43.840	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:42.840	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:42.735	warn	MQTT connection reconnect.
                                    roborock.0
                                       2024-01-16 08:36:41.735	warn	MQTT connection close.
                                    roborock.0
                                       2024-01-16 08:36:41.625	warn	MQTT connection reconnect.
                                    Ich würde jetzt mal den Adapter neu starten um zu beobachten, was passiert ....
                                    EDIT:
                                    Adapter normal neu gestartet:
                                    Keine verdächtigen Logs, oder sonstiges "negatives".....
                                    Nach ca. 7 Minuten:
                                    Lediglich die WARNINGS für get_status bzw. get_network_info waren mal angezeigt.
                                    Auch die Cleaning_Infos wurden "nach aktualisiert", die stimmen nun auch wieder....
                                    Ich behalte es im Auge und sage bis später..... aber bis dato: TOP Version :-)
                                    -> danke für dein Engagement :-)
                                    tritanium
                                    #457
                                    AAAABER:
                                    Öhm, ich hoffe doch :-D ...die Nachricht war ja von heute morgen .....
                                    => Soll ich einfach nochmal JETZT die /dev aktualisieren ??
                                    copystringC 1 Antwort Letzte Antwort
                                    • T tritanium
                                      AAAABER:
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #458
                                      @tritanium Weiß ich nicht. Aber die aktuelle dev sollte dich nach 1 Stunde anstatt 3 Stunden rauswerfen.
                                      • T tritanium
                                        vSooooo :-D
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        host.iobroker
                                        host.iobroker
                                        #459
                                        Dann war es auch dringend erforderlich...
                                        Künftig regelmäßig die Kiste in Gänze auf Stand halten.
                                        • copystringC copystring
                                          tritanium
                                          #460
                                          @copystring
                                          ich mach mal eben .... kann ja nur besser werden :-D
                                          Moment....
                                          So, fertig... keine besonderen Vorkommnisse (würde man beim Bund sagen) :-D
                                          Ich warte jetzt wieder ab ...
