  4. Probleme bei Buster 32bit auf Bullseye 64bit Upgrade
    6.4k
39 Beiträge 7 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • RaspiUserR Online
    RaspiUserR Online
    RaspiUser
    ich habe eine neue SD Karte mit dem Raspian Bullseye 64bit lite Image beschrieben, den ioBroker installiert und das alte Buster Backitup aufgespielt (Raspberry Pi4 2GB). Fast alle Adapter "GRÜN", bis auf diese 2 "GELB"en ...
    mqtt.0
    	2023-07-22 11:12:02.938	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:12:02.931	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:52.941	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017112935,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:52.938	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017112934,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017112934}
    mqtt.0
    	2023-07-22 11:11:52.929	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:52.928	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:52.923	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:42.932	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017102926,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:42.929	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017102925,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017102925}
    mqtt.0
    	2023-07-22 11:11:42.919	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:42.918	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:42.912	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:32.930	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017092918,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:32.923	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017092917,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017092917}
    mqtt.0
    	2023-07-22 11:11:32.908	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:32.907	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:32.896	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:22.908	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017082901,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:22.906	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017082900,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017082900}
    mqtt.0
    	2023-07-22 11:11:22.893	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:22.893	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:22.886	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:12.882	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:12.749	info	Try to connect to mqtt://localhost:1883 with clientId=ioBroker-Raspi.mqtt.0and credentials Nutzer:*******************
    mqtt.0
    	2023-07-22 11:11:12.187	info	starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.16.1, js-controller: 4.0.24
    mqtt.0
    	2023-07-22 11:11:11.669	debug	Plugin sentry Initialize Plugin (enabled=true)
    mqtt.0
    	2023-07-22 11:11:11.426	debug	States connected to redis: 0.0.0.0:9000
    mqtt.0
    	2023-07-22 11:11:11.335	debug	States create User PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.334	debug	States create System PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.303	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    mqtt.0
    	2023-07-22 11:11:11.249	debug	Objects connected to redis: 0.0.0.0:9001
    mqtt.0
    	2023-07-22 11:11:11.240	debug	Objects client initialize lua scripts
    mqtt.0
    	2023-07-22 11:11:11.136	debug	Objects create User PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.134	debug	Objects create System PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.132	debug	Objects client ready ... initialize now
    mqtt.0
    	2023-07-22 11:11:11.065	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    mqtt.0
    	2023-07-22 11:11:06.819	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mqtt.0
    	2023-07-22 11:11:06.819	debug	Plugin sentry destroyed
    mqtt.0
    	2023-07-22 11:11:06.817	info	terminating
    mqtt.0
    	2023-07-22 11:11:06.313	info	Got terminate signal TERMINATE_YOURSELF
    	2023-07-22 11:18:04.246	debug	create/update parser 180.02
    canbus.0
    	2023-07-22 11:18:04.190	debug	create/update message id: 180, uuid: 1a56e754-7bd5-40f9-a1e5-5ba65c5ac578
    canbus.0
    	2023-07-22 11:18:04.150	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.16.1, js-controller: 4.0.24
    canbus.0
    	2023-07-22 11:18:03.534	debug	Plugin sentry Initialize Plugin (enabled=true)
    canbus.0
    	2023-07-22 11:18:03.209	debug	States create User PubSub Client
    canbus.0
    	2023-07-22 11:18:03.207	debug	States create System PubSub Client
    canbus.0
    	2023-07-22 11:18:03.177	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    canbus.0
    	2023-07-22 11:18:03.121	debug	Objects connected to redis: 0.0.0.0:9001
    canbus.0
    	2023-07-22 11:18:03.111	debug	Objects client initialize lua scripts
    canbus.0
    	2023-07-22 11:18:03.020	debug	Objects create User PubSub Client
    canbus.0
    	2023-07-22 11:18:03.017	debug	Objects create System PubSub Client
    canbus.0
    	2023-07-22 11:18:03.015	debug	Objects client ready ... initialize now
    canbus.0
    	2023-07-22 11:18:02.939	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    canbus.0
    	2023-07-22 11:17:58.046	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    canbus.0
    	2023-07-22 11:17:58.045	debug	Plugin sentry destroyed
    canbus.0
    	2023-07-22 11:17:58.043	info	terminating
    canbus.0
    	2023-07-22 11:17:58.042	debug	cleaned everything up...
    canbus.0
    	2023-07-22 11:17:58.040	info	Got terminate signal TERMINATE_YOURSELF
    Kann ein Fachmann etwas im Log erkennen bzw. mir sagen an welcher Schraube ich drehen muss ?
    Die alte Buster SD Karte funktioniert einwandfrei.
    • RaspiUserR RaspiUser
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      canbus.0
      TT-Tom
      @raspiuser
      Poste mal zusätzlich die volle Ausgabe von
      iob diag
      Damit gibt es noch mehr Informationen zu deinem System.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      RaspiUserR 1 Antwort Letzte Antwort
      • T TT-Tom
        @raspiuser
        iob diag
        RaspiUserR Online
        RaspiUserR Online
        RaspiUser
        schrieb am zuletzt editiert von RaspiUser
        @tt-tom
        Hallo und Guten Tag ...
        Das hier ? Oder den ewig langen Log davor ?
                             v.2023-04-16
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 6.1.21-v8+
        Installation:           Native
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     3
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                /usr/bin/node           v18.16.1
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            1.8G        1.5G        144M        0.0K        227M        304M
        Swap:            99M         99M        0.0K
        Total:          1.9G        1.6G        144M
        Active iob-Instances:   25
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : ioBroker-Raspi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : ioBroker-Raspi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                9586
        States:                 8161
        Size of iob-Database:
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/states.jsonl
        T DJMarc75D 2 Antworten Letzte Antwort
          @tt-tom
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          MEMORY:
          Swap:            99M         99M        0.0K
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                9586
          States:                 8161
          TT-Tom
          @raspiuser das Lange sagt mehr
          Gruß Tom
          Public Transport
            @tt-tom
                                 v.2023-04-16
            Kernel:                 6.1.21-v8+
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Swap:            99M         99M        0.0K
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                9586
            States:                 8161
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @raspiuser Dir geht der RAM aus
            Lehrling seit 1975 !!!
            • T TT-Tom
              RaspiUserR Online
              RaspiUserR Online
              RaspiUser
              @tt-tom said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
              das Lange sagt mehr
              Bitte sehr ...
              ======== Start marking the full check here =========
              Skript v.2023-04-16
              BASE SYSTEM
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Architecture    : aarch64
              Docker          : false
              Virtualization  : none
              Distributor ID: Debian
              Description:    Debian GNU/Linux 11 (bullseye)
              Release:        11
              Codename:       bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               11:57:49 up  1:24,  1 user,  load average: 0.37, 0.28, 0.28
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=55.5'C
              volt=0.8625V
              Time and Time Zones
                             Local time: Sat 2023-07-22 11:57:50 CEST
                         Universal time: Sat 2023-07-22 09:57:50 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              User and Groups
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              X-Server-Setup
              X-Server:       false
              Desktop:
              Terminal:       tty
              MEMORY
              Mem:            1.8G        1.5G        147M        0.0K        235M        315M
              Swap:            99M         99M        0.0K
              Total:          1.9G        1.6G        148M
                       1849 M total memory
                       1466 M used memory
                        860 M active memory
                        713 M inactive memory
                        147 M free memory
                          4 M buffer memory
                        230 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              lifetime oom required: 0 Mbytes
              total time in oom handler: 0 ms
              max time spent in oom handler: 0 ms
              FILESYSTEM
              /dev/root      ext4       14G  3.4G   10G  25% /
              devtmpfs       devtmpfs  667M     0  667M   0% /dev
              tmpfs          tmpfs     925M     0  925M   0% /dev/shm
              tmpfs          tmpfs     370M  1.1M  369M   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
              [Sat Jul 22 10:33:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:B4:C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=228a697b-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Jul 22 10:33:27 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Sat Jul 22 10:33:27 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Sat Jul 22 10:33:28 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Sat Jul 22 10:33:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sat Jul 22 10:33:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sat Jul 22 10:33:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              502M    /var/
              190M    /var/cache
              185M    /var/cache/apt
              147M    /var/lib
              123M    /var/lib/apt/lists
              Archived and active journals take up 64.0M in the file system.
              /opt/iobroker/backups:
              4.0K    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              232M    /opt/iobroker/iobroker-data/
              193M    /opt/iobroker/iobroker-data/files
              52M     /opt/iobroker/iobroker-data/files/javascript.admin
              34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
              9.8M    /opt/iobroker/iobroker-data/states.jsonl
              8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
              8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
              NodeJS-Installation
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Installed: 18.16.1-deb-1nodesource1
                Candidate: 18.17.0-deb-1nodesource1
                Version table:
                   18.17.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   18.16.1-deb-1nodesource1 100
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              ioBroker-Installation
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              MULTIHOSTSERVICE/enabled: false
              Core adapters versions
              admin:          6.3.5
              javascript:     7.0.3
              Adapters from github:   1
              Adapter State
              + system.adapter.backitup.0               : backitup              : ioBroker-Raspi                           -  enabled
              + system.adapter.canbus.0                 : canbus                : ioBroker-Raspi                           -  enabled
              + system.adapter.cloud.0                  : cloud                 : ioBroker-Raspi                           -  enabled
                system.adapter.discovery.0              : discovery             : ioBroker-Raspi                           - disabled
                system.adapter.email.0                  : email                 : ioBroker-Raspi                           - disabled
                system.adapter.feiertage.0              : feiertage             : ioBroker-Raspi                           -  enabled
              + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-Raspi                           -  enabled
                system.adapter.go-e.0                   : go-e                  : ioBroker-Raspi                           - disabled
                system.adapter.habpanel.0               : habpanel              : ioBroker-Raspi                           - disabled
              + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Raspi                           -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
                system.adapter.influxdb.0               : influxdb              : ioBroker-Raspi                           - disabled, port: 8086
                system.adapter.info.0                   : info                  : ioBroker-Raspi                           - disabled
              + system.adapter.iqontrol.0               : iqontrol              : ioBroker-Raspi                           -  enabled
              + system.adapter.javascript.0             : javascript            : ioBroker-Raspi                           -  enabled
              + system.adapter.lgtv.0                   : lgtv                  : ioBroker-Raspi                           -  enabled
                system.adapter.luftdaten.0              : luftdaten             : ioBroker-Raspi                           -  enabled
              + system.adapter.modbus.0                 : modbus                : ioBroker-Raspi                           -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Raspi                           -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.onkyo.0                  : onkyo                 : ioBroker-Raspi                           - disabled
                system.adapter.psa.0                    : psa                   : ioBroker-Raspi                           - disabled
              + system.adapter.sainlogic.1              : sainlogic             : ioBroker-Raspi                           -  enabled, port: 1030, bind: 192.168.178.36
              + system.adapter.scenes.0                 : scenes                : ioBroker-Raspi                           -  enabled
              + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Raspi                           -  enabled
              + system.adapter.simple-api.0             : simple-api            : ioBroker-Raspi                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.socketio.0               : socketio              : ioBroker-Raspi                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : ioBroker-Raspi                           -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-Raspi                           -  enabled
              + system.adapter.telegram.0               : telegram              : ioBroker-Raspi                           -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : ioBroker-Raspi                           - disabled
              + system.adapter.tr-064.0                 : tr-064                : ioBroker-Raspi                           -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Raspi                           - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Raspi                           - disabled
                system.adapter.vis-metro.0              : vis-metro             : ioBroker-Raspi                           - disabled
                system.adapter.vis.0                    : vis                   : ioBroker-Raspi                           - disabled
                system.adapter.vw-connect.0             : vw-connect            : ioBroker-Raspi                           - disabled
                system.adapter.wled.0                   : wled                  : ioBroker-Raspi                           - disabled
              + system.adapter.zigbee.0                 : zigbee                : ioBroker-Raspi                           -  enabled, port: /dev/ttyUSB0
              + instance is alive
              ioBroker-Repositories
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.3.5    , installed 6.3.5
              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
              Adapter    "canbus"       : 1.3.1    , installed 1.3.1
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "frontier_silicon": 0.0.11, installed 0.0.11
              Adapter    "go-e"         : 1.0.27   , installed 1.0.27
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
              Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "info"         : 1.9.26   , installed 1.9.26
              Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
              Adapter    "javascript"   : 7.0.3    , installed 7.0.3
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
              Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
              Adapter    "psa"          : 0.0.11   , installed 0.0.11
              Adapter    "sainlogic"    : 0.10.3   , installed 0.10.3
              Adapter    "scenes"       : 2.3.9    , installed 2.3.9
              Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
              Adapter    "socketio"     : 4.2.0    , installed 4.2.0
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
              Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
              Adapter    "web"          : 4.3.0    , installed 4.3.0
              Adapter    "wled"         : 0.6.7    , installed 0.6.7
              Adapter    "ws"           : 1.3.0    , installed 1.3.0
              Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
              Objects and States
              Objects:        9586
              States:         8161
              OS-Repositories and Updates
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
              Reading package lists...
              Pending Updates: 3
              Listening Ports
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       12864      459/iobroker.js-con
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       11574      459/iobroker.js-con
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15033      1261/io.sonoff.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15581      548/sshd: /usr/sbin
              tcp        0      0 192.168.178.36:1030     0.0.0.0:*               LISTEN      1001       18041      1670/io.sainlogic.1
              tcp        0      0 192.168.178.36:42010    0.0.0.0:*               LISTEN      1001       46521      4240/io.hm-rpc.1
              tcp        0      0 192.168.178.36:42001    0.0.0.0:*               LISTEN      1001       16001      1134/io.hm-rpc.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18198      1864/io.simple-api.
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22573      2290/io.socketio.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19885      1886/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15819      993/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15583      548/sshd: /usr/sbin
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14515      709/dhcpcd
              udp        0      0 0.0.0.0:48254           0.0.0.0:*                           108        12732      338/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12730      338/avahi-daemon: r
              udp6       0      0 :::51223                :::*                                108        12733      338/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        12731      338/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          12835      709/dhcpcd
              2023-07-22 11:58:20.708  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:58:30.710  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:58:30.713  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:58:30.713  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:58:32.076  - debug: shuttercontrol.0 (1738) start pendingAlarm to check if an alarm is currently pending (exept frost)
              2023-07-22 11:58:32.077  - debug: shuttercontrol.0 (1738) status alarm pending for hm-rpc.0.OEQ1223791.1.LEVEL: false
              2023-07-22 11:58:39.840  - debug: shuttercontrol.0 (1738) Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 13667
              2023-07-22 11:58:40.714  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:58:40.718  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:58:40.719  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:58:50.720  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:58:50.725  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:58:50.725  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:59:00.726  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:59:02.121  - debug: shuttercontrol.0 (1738) start pendingAlarm to check if an alarm is currently pending (exept frost)
              2023-07-22 11:59:02.124  - debug: shuttercontrol.0 (1738) status alarm pending for hm-rpc.0.OEQ1223824.1.LEVEL: false
              2023-07-22 11:59:03.104  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:59:03.105  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:59:13.107  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:59:13.673  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:59:13.674  - info: mqtt.0 (2940) Disconnected from localhost
              2023-07-22 11:59:21.710  - debug: shuttercontrol.0 (1738) Lightsensor changed: hm-rpc.1.000D5D89AEBAAF.1.AVERAGE_ILLUMINATION Value: 34900
              2023-07-22 11:59:23.676  - info: mqtt.0 (2940) Reconnected to localhost
              2023-07-22 11:59:23.680  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
              2023-07-22 11:59:23.680  - info: mqtt.0 (2940) Disconnected from localhost
              • DJMarc75D DJMarc75
                RaspiUserR Online
                RaspiUserR Online
                RaspiUser
                @djmarc75 said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                ... das habe ich schon einmal gehört ...
                Also Adapter "stoppen" oder komplett "deinstallieren" ?
                Aber hilft das dann ?
                EDIT:
                Ich habe die "unwichtigen" Adapter gestoppt, das bringt nix ...
                  EDIT:
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @raspiuser sagte in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                  2 GB sind schon recht wenig - bei 24 laufenden Adaptern.
                  Nicht benötigte Adapter deinstallieren/stoppen.
                  Und danach die Kiste rebooten und den Speicher beobachten, der füllt sich erst nach ein paar Stunden wenn die Adapter alle ihren Dienst tun..
                  Aber im Prinzip rate ich zu einer anderen Kiste mit mehr RAM.
                    RaspiUserR Online
                    RaspiUserR Online
                    RaspiUser
                    ... wie schon gesagt:
                    Habe ich schon einmal gehört und plane demnächst den ioBroker auf einem QNAP NAS laufen zu lassen (Ich schrecke noch davor zurück / schafft sicher neue Probleme ....)
                    Pi's mit mehr RAM sind z.Zt. wohl genauso teuer ... bzw. diese zu bekommen wird wohl schwierig.
                      @raspiuser sagte: Pi's mit mehr RAM sind z.Zt. wohl genauso teuer
                      RasPi 4 mit 4 GB RAM ist wieder ab ca. 80 € verfügbar.
                        RaspiUserR Online
                        RaspiUserR Online
                        RaspiUser
                        @paul53 said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                        Stimmt, habe ich jetzt auch gefunden.
                        Aber das löst wohl nicht die ursprünglichen Problemen mit den 2 Adaptern ... 🙄
                          TT-Tom
                          @raspiuser
                          hast du jetzt mal die unwichtigen alle deinstalliert?
                          ggf auch mal die MQTT und Canbus mit deinstallieren, dann mal den Ram checken.
                          und Einen nach dem Anderen neu laden.
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            @raspiuser
                            RaspiUserR Online
                            RaspiUserR Online
                            RaspiUser
                            ... also alle unwichtigen sind gestoppt. Der RAM sieht so aus ...!
                            CAN und MQTT deinstalliert und dann neu installiert ... ohne Erfolg.
                            Bei MQTT localhost, 192.168.178.36 und 127.0.0.1 try & error eingesetzt, Fehlermeldung bleibt.
                            Wie schon geschrieben: Alle Einstellungen hatten mit Buster funktioniert ...
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @raspiuser in der Konsole
                              free -m
                              eingeben und die Ausgabe hier bitte zeigen.
                              Auf eine GUI ist nicht immer verlass ;)
                              edit: und die Kiste auch mal neu gestartet wie ich empfohlen habe ?
                                free -m
                                RaspiUserR Online
                                RaspiUserR Online
                                RaspiUser
                                @djmarc75
                                ... sieht so aus ...
                                Mem:            1849        1332         311           1         205         447
                                Swap:             99           0          99
                                Ja ... nach jeder Änderung ...
                                Wieso konzentrierst Du Dich auf den RAM ?!
                                Mit Buster 32bit funktioniert es doch ... Das der RAM zu Buster 64bit mehr genutzt wird kann ich noch glauben (mal so als Laie rausgehauen ...)
                                Die Fehlermeldung deutet doch eher auf ein Netzwerkproblem hin, oder ?
                                  @djmarc75
                                  Swap:             99           0          99
                                  @raspiuser
                                  Da läuft nix auf dem Port 1883.
                                  Schau dir das Setup vom mqtt-Server an.
                                  Welcher wird da verwendet?
                                  Das ganze ist auch kein Thema 32/64bit.
                                    @raspiuser
                                    RaspiUserR Online
                                    RaspiUserR Online
                                    RaspiUser
                                    @thomas-braun said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                                    ... und wenn ich auf "DIE VERBINDUNG ZUM SERVER TESTEN" klicke kommt "OK" als Antwort.
                                    Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
                                      @raspiuser
                                      Ich hab zwar von sonoff/mqtt usw. keine Ahnung, aber das ist da ein Client-Setup. Stell mal Port 1885 ein, da läuft der sonoff drauf
                                        @raspiuser
                                        RaspiUserR Online
                                        RaspiUserR Online
                                        RaspiUser
                                        Stimmt, der läuft bei mir mit Port 1885 auch "GRÜN".
                                        Den habe ich jetzt gestoppt, den Port 1885 beim MQTT Adapter eingestellt, reboot und nix ...
                                        Der Fehler ist noch immer da, der Adapter "GELB".
                                        Und wieder alles auf Anfang ...
                                        (An dieser Stelle vielen Dank, dass ihr eure Zeit / Gedanken mit meinem Problem teilt .... 👍 )
                                        Ich glaube langsam, ich nehme wieder die Buster-Karte und fertig.
                                        Irgend etwas ist (scheinbar) in der LINUX Unterwäsche passiert, aber was ...
                                        Kann es sein, dass das Backitup von der Buster-Installation von Bullseye nicht richtig übernommen wird ?
                                        Ich werde mal eine frische Bullseye / ioBroker Karte OHNE Backitup probieren und das Sorgenkind MQTT als erstes installieren ...
                                          Quatsch.
