  4. Probleme bei Buster 32bit auf Bullseye 64bit Upgrade
    6.4k
39 Beiträge 7 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • RaspiUserR RaspiUser
    ich habe eine neue SD Karte mit dem Raspian Bullseye 64bit lite Image beschrieben, den ioBroker installiert und das alte Buster Backitup aufgespielt (Raspberry Pi4 2GB). Fast alle Adapter "GRÜN", bis auf diese 2 "GELB"en ...
    mqtt.0
    	2023-07-22 11:12:02.938	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:12:02.931	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:52.941	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017112935,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:52.938	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017112934,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017112934}
    mqtt.0
    	2023-07-22 11:11:52.929	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:52.928	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:52.923	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:42.932	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017102926,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:42.929	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017102925,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017102925}
    mqtt.0
    	2023-07-22 11:11:42.919	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:42.918	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:42.912	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:32.930	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017092918,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:32.923	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017092917,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017092917}
    mqtt.0
    	2023-07-22 11:11:32.908	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:32.907	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:32.896	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:22.908	debug	stateChange mqtt.0.info.connection: {"val":false,"ack":true,"ts":1690017082901,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690016924651}
    mqtt.0
    	2023-07-22 11:11:22.906	debug	stateChange mqtt.0.info.connection: {"val":true,"ack":true,"ts":1690017082900,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1690017082900}
    mqtt.0
    	2023-07-22 11:11:22.893	info	Disconnected from localhost
    mqtt.0
    	2023-07-22 11:11:22.893	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:22.886	info	Reconnected to localhost
    mqtt.0
    	2023-07-22 11:11:12.882	error	Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
    mqtt.0
    	2023-07-22 11:11:12.749	info	Try to connect to mqtt://localhost:1883 with clientId=ioBroker-Raspi.mqtt.0and credentials Nutzer:*******************
    mqtt.0
    	2023-07-22 11:11:12.187	info	starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.16.1, js-controller: 4.0.24
    mqtt.0
    	2023-07-22 11:11:11.669	debug	Plugin sentry Initialize Plugin (enabled=true)
    mqtt.0
    	2023-07-22 11:11:11.426	debug	States connected to redis: 0.0.0.0:9000
    mqtt.0
    	2023-07-22 11:11:11.335	debug	States create User PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.334	debug	States create System PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.303	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    mqtt.0
    	2023-07-22 11:11:11.249	debug	Objects connected to redis: 0.0.0.0:9001
    mqtt.0
    	2023-07-22 11:11:11.240	debug	Objects client initialize lua scripts
    mqtt.0
    	2023-07-22 11:11:11.136	debug	Objects create User PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.134	debug	Objects create System PubSub Client
    mqtt.0
    	2023-07-22 11:11:11.132	debug	Objects client ready ... initialize now
    mqtt.0
    	2023-07-22 11:11:11.065	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    mqtt.0
    	2023-07-22 11:11:06.819	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mqtt.0
    	2023-07-22 11:11:06.819	debug	Plugin sentry destroyed
    mqtt.0
    	2023-07-22 11:11:06.817	info	terminating
    mqtt.0
    	2023-07-22 11:11:06.313	info	Got terminate signal TERMINATE_YOURSELF
    	2023-07-22 11:18:04.246	debug	create/update parser 180.02
    canbus.0
    	2023-07-22 11:18:04.190	debug	create/update message id: 180, uuid: 1a56e754-7bd5-40f9-a1e5-5ba65c5ac578
    canbus.0
    	2023-07-22 11:18:04.150	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.16.1, js-controller: 4.0.24
    canbus.0
    	2023-07-22 11:18:03.534	debug	Plugin sentry Initialize Plugin (enabled=true)
    canbus.0
    	2023-07-22 11:18:03.209	debug	States create User PubSub Client
    canbus.0
    	2023-07-22 11:18:03.207	debug	States create System PubSub Client
    canbus.0
    	2023-07-22 11:18:03.177	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    canbus.0
    	2023-07-22 11:18:03.121	debug	Objects connected to redis: 0.0.0.0:9001
    canbus.0
    	2023-07-22 11:18:03.111	debug	Objects client initialize lua scripts
    canbus.0
    	2023-07-22 11:18:03.020	debug	Objects create User PubSub Client
    canbus.0
    	2023-07-22 11:18:03.017	debug	Objects create System PubSub Client
    canbus.0
    	2023-07-22 11:18:03.015	debug	Objects client ready ... initialize now
    canbus.0
    	2023-07-22 11:18:02.939	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    canbus.0
    	2023-07-22 11:17:58.046	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    canbus.0
    	2023-07-22 11:17:58.045	debug	Plugin sentry destroyed
    canbus.0
    	2023-07-22 11:17:58.043	info	terminating
    canbus.0
    	2023-07-22 11:17:58.042	debug	cleaned everything up...
    canbus.0
    	2023-07-22 11:17:58.040	info	Got terminate signal TERMINATE_YOURSELF
    Kann ein Fachmann etwas im Log erkennen bzw. mir sagen an welcher Schraube ich drehen muss ?
    Die alte Buster SD Karte funktioniert einwandfrei.
    TT-Tom
    @raspiuser
    Poste mal zusätzlich die volle Ausgabe von
    iob diag
    Damit gibt es noch mehr Informationen zu deinem System.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    RaspiUserR 1 Antwort Letzte Antwort
    • T TT-Tom
      @raspiuser
      iob diag
      RaspiUserR Online
      RaspiUserR Online
      RaspiUser
      schrieb am zuletzt editiert von RaspiUser
      @tt-tom
      Hallo und Guten Tag ...
      Das hier ? Oder den ewig langen Log davor ?
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Native
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     3
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                              /usr/bin/node           v18.16.1
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            1.8G        1.5G        144M        0.0K        227M        304M
      Swap:            99M         99M        0.0K
      Total:          1.9G        1.6G        144M
      Active iob-Instances:   25
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker-Raspi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ioBroker-Raspi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                9586
      States:                 8161
      Size of iob-Database:
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      8.9M    /opt/iobroker/iobroker-data/states.jsonl
      T DJMarc75D 2 Antworten Letzte Antwort
        @tt-tom
                             v.2023-04-16
        Kernel:                 6.1.21-v8+
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        MEMORY:
        Swap:            99M         99M        0.0K
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                9586
        States:                 8161
        TT-Tom
        @raspiuser das Lange sagt mehr
        Gruß Tom
        Public Transport
          @tt-tom
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          MEMORY:
          Swap:            99M         99M        0.0K
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                9586
          States:                 8161
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @raspiuser Dir geht der RAM aus
          Lehrling seit 1975 !!!
          • T TT-Tom
            RaspiUserR Online
            RaspiUserR Online
            RaspiUser
            @tt-tom said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
            das Lange sagt mehr
            Bitte sehr ...
            Skript v.2023-04-16
            BASE SYSTEM
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Architecture    : aarch64
            Docker          : false
            Virtualization  : none
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             11:57:49 up  1:24,  1 user,  load average: 0.37, 0.28, 0.28
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=55.5'C
            volt=0.8625V
            Time and Time Zones
                           Local time: Sat 2023-07-22 11:57:50 CEST
                       Universal time: Sat 2023-07-22 09:57:50 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            User and Groups
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            X-Server-Setup
            X-Server:       false
            Desktop:
            Terminal:       tty
            MEMORY
            Mem:            1.8G        1.5G        147M        0.0K        235M        315M
            Swap:            99M         99M        0.0K
            Total:          1.9G        1.6G        148M
                     1849 M total memory
                     1466 M used memory
                      860 M active memory
                      713 M inactive memory
                      147 M free memory
                        4 M buffer memory
                      230 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            FILESYSTEM
            /dev/root      ext4       14G  3.4G   10G  25% /
            devtmpfs       devtmpfs  667M     0  667M   0% /dev
            tmpfs          tmpfs     925M     0  925M   0% /dev/shm
            tmpfs          tmpfs     370M  1.1M  369M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
            [Sat Jul 22 10:33:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:B4:C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=228a697b-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Jul 22 10:33:27 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Sat Jul 22 10:33:27 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Sat Jul 22 10:33:28 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Sat Jul 22 10:33:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Jul 22 10:33:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sat Jul 22 10:33:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            502M    /var/
            190M    /var/cache
            185M    /var/cache/apt
            147M    /var/lib
            123M    /var/lib/apt/lists
            Archived and active journals take up 64.0M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            232M    /opt/iobroker/iobroker-data/
            193M    /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
            9.8M    /opt/iobroker/iobroker-data/states.jsonl
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
            NodeJS-Installation
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.1-deb-1nodesource1
              Candidate: 18.17.0-deb-1nodesource1
              Version table:
                 18.17.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                 18.16.1-deb-1nodesource1 100
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            ioBroker-Installation
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            admin:          6.3.5
            javascript:     7.0.3
            Adapters from github:   1
            Adapter State
            + system.adapter.backitup.0               : backitup              : ioBroker-Raspi                           -  enabled
            + system.adapter.canbus.0                 : canbus                : ioBroker-Raspi                           -  enabled
            + system.adapter.cloud.0                  : cloud                 : ioBroker-Raspi                           -  enabled
              system.adapter.discovery.0              : discovery             : ioBroker-Raspi                           - disabled
              system.adapter.email.0                  : email                 : ioBroker-Raspi                           - disabled
              system.adapter.feiertage.0              : feiertage             : ioBroker-Raspi                           -  enabled
            + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-Raspi                           -  enabled
              system.adapter.go-e.0                   : go-e                  : ioBroker-Raspi                           - disabled
              system.adapter.habpanel.0               : habpanel              : ioBroker-Raspi                           - disabled
            + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Raspi                           -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Raspi                           -  enabled, port: 0
              system.adapter.influxdb.0               : influxdb              : ioBroker-Raspi                           - disabled, port: 8086
              system.adapter.info.0                   : info                  : ioBroker-Raspi                           - disabled
            + system.adapter.iqontrol.0               : iqontrol              : ioBroker-Raspi                           -  enabled
            + system.adapter.javascript.0             : javascript            : ioBroker-Raspi                           -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : ioBroker-Raspi                           -  enabled
              system.adapter.luftdaten.0              : luftdaten             : ioBroker-Raspi                           -  enabled
            + system.adapter.modbus.0                 : modbus                : ioBroker-Raspi                           -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Raspi                           -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.onkyo.0                  : onkyo                 : ioBroker-Raspi                           - disabled
              system.adapter.psa.0                    : psa                   : ioBroker-Raspi                           - disabled
            + system.adapter.sainlogic.1              : sainlogic             : ioBroker-Raspi                           -  enabled, port: 1030, bind: 192.168.178.36
            + system.adapter.scenes.0                 : scenes                : ioBroker-Raspi                           -  enabled
            + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Raspi                           -  enabled
            + system.adapter.simple-api.0             : simple-api            : ioBroker-Raspi                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : ioBroker-Raspi                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : ioBroker-Raspi                           -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-Raspi                           -  enabled
            + system.adapter.telegram.0               : telegram              : ioBroker-Raspi                           -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : ioBroker-Raspi                           - disabled
            + system.adapter.tr-064.0                 : tr-064                : ioBroker-Raspi                           -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Raspi                           - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Raspi                           - disabled
              system.adapter.vis-metro.0              : vis-metro             : ioBroker-Raspi                           - disabled
              system.adapter.vis.0                    : vis                   : ioBroker-Raspi                           - disabled
              system.adapter.vw-connect.0             : vw-connect            : ioBroker-Raspi                           - disabled
              system.adapter.wled.0                   : wled                  : ioBroker-Raspi                           - disabled
            + system.adapter.zigbee.0                 : zigbee                : ioBroker-Raspi                           -  enabled, port: /dev/ttyUSB0
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "canbus"       : 1.3.1    , installed 1.3.1
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "frontier_silicon": 0.0.11, installed 0.0.11
            Adapter    "go-e"         : 1.0.27   , installed 1.0.27
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
            Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
            Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
            Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
            Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
            Adapter    "psa"          : 0.0.11   , installed 0.0.11
            Adapter    "sainlogic"    : 0.10.3   , installed 0.10.3
            Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
            Adapter    "wled"         : 0.6.7    , installed 0.6.7
            Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
            Objects and States
            Objects:        9586
            States:         8161
            OS-Repositories and Updates
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 3
            Listening Ports
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       12864      459/iobroker.js-con
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       11574      459/iobroker.js-con
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15033      1261/io.sonoff.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15581      548/sshd: /usr/sbin
            tcp        0      0 192.168.178.36:1030     0.0.0.0:*               LISTEN      1001       18041      1670/io.sainlogic.1
            tcp        0      0 192.168.178.36:42010    0.0.0.0:*               LISTEN      1001       46521      4240/io.hm-rpc.1
            tcp        0      0 192.168.178.36:42001    0.0.0.0:*               LISTEN      1001       16001      1134/io.hm-rpc.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18198      1864/io.simple-api.
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22573      2290/io.socketio.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19885      1886/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15819      993/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15583      548/sshd: /usr/sbin
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14515      709/dhcpcd
            udp        0      0 0.0.0.0:48254           0.0.0.0:*                           108        12732      338/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12730      338/avahi-daemon: r
            udp6       0      0 :::51223                :::*                                108        12733      338/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        12731      338/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          12835      709/dhcpcd
            2023-07-22 11:58:20.708  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:58:30.710  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:58:30.713  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:58:30.713  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:58:32.076  - debug: shuttercontrol.0 (1738) start pendingAlarm to check if an alarm is currently pending (exept frost)
            2023-07-22 11:58:32.077  - debug: shuttercontrol.0 (1738) status alarm pending for hm-rpc.0.OEQ1223791.1.LEVEL: false
            2023-07-22 11:58:39.840  - debug: shuttercontrol.0 (1738) Lightsensor changed: hm-rpc.1.000D58A9A5AE9A.1.AVERAGE_ILLUMINATION Value: 13667
            2023-07-22 11:58:40.714  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:58:40.718  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:58:40.719  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:58:50.720  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:58:50.725  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:58:50.725  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:59:00.726  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:59:02.121  - debug: shuttercontrol.0 (1738) start pendingAlarm to check if an alarm is currently pending (exept frost)
            2023-07-22 11:59:02.124  - debug: shuttercontrol.0 (1738) status alarm pending for hm-rpc.0.OEQ1223824.1.LEVEL: false
            2023-07-22 11:59:03.104  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:59:03.105  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:59:13.107  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:59:13.673  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:59:13.674  - info: mqtt.0 (2940) Disconnected from localhost
            2023-07-22 11:59:21.710  - debug: shuttercontrol.0 (1738) Lightsensor changed: hm-rpc.1.000D5D89AEBAAF.1.AVERAGE_ILLUMINATION Value: 34900
            2023-07-22 11:59:23.676  - info: mqtt.0 (2940) Reconnected to localhost
            2023-07-22 11:59:23.680  - error: mqtt.0 (2940) Client error:Error: connect ECONNREFUSED 127.0.0.1:1883
            2023-07-22 11:59:23.680  - info: mqtt.0 (2940) Disconnected from localhost
            • DJMarc75D DJMarc75
              RaspiUserR Online
              RaspiUserR Online
              RaspiUser
              @djmarc75 said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
              ... das habe ich schon einmal gehört ...
              Also Adapter "stoppen" oder komplett "deinstallieren" ?
              Aber hilft das dann ?
              EDIT:
              Ich habe die "unwichtigen" Adapter gestoppt, das bringt nix ...
                EDIT:
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @raspiuser sagte in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                2 GB sind schon recht wenig - bei 24 laufenden Adaptern.
                Nicht benötigte Adapter deinstallieren/stoppen.
                Und danach die Kiste rebooten und den Speicher beobachten, der füllt sich erst nach ein paar Stunden wenn die Adapter alle ihren Dienst tun..
                Aber im Prinzip rate ich zu einer anderen Kiste mit mehr RAM.
                  RaspiUserR Online
                  RaspiUserR Online
                  RaspiUser
                  ... wie schon gesagt:
                  Habe ich schon einmal gehört und plane demnächst den ioBroker auf einem QNAP NAS laufen zu lassen (Ich schrecke noch davor zurück / schafft sicher neue Probleme ....)
                  Pi's mit mehr RAM sind z.Zt. wohl genauso teuer ... bzw. diese zu bekommen wird wohl schwierig.
                    @raspiuser sagte: Pi's mit mehr RAM sind z.Zt. wohl genauso teuer
                    RasPi 4 mit 4 GB RAM ist wieder ab ca. 80 € verfügbar.
                      RaspiUserR Online
                      RaspiUserR Online
                      RaspiUser
                      @paul53 said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                      Stimmt, habe ich jetzt auch gefunden.
                      Aber das löst wohl nicht die ursprünglichen Problemen mit den 2 Adaptern ... 🙄
                        TT-Tom
                        @raspiuser
                        hast du jetzt mal die unwichtigen alle deinstalliert?
                        ggf auch mal die MQTT und Canbus mit deinstallieren, dann mal den Ram checken.
                        und Einen nach dem Anderen neu laden.
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @raspiuser
                          RaspiUserR Online
                          RaspiUserR Online
                          RaspiUser
                          ... also alle unwichtigen sind gestoppt. Der RAM sieht so aus ...!
                          CAN und MQTT deinstalliert und dann neu installiert ... ohne Erfolg.
                          Bei MQTT localhost, 192.168.178.36 und 127.0.0.1 try & error eingesetzt, Fehlermeldung bleibt.
                          Wie schon geschrieben: Alle Einstellungen hatten mit Buster funktioniert ...
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @raspiuser in der Konsole
                            free -m
                            eingeben und die Ausgabe hier bitte zeigen.
                            Auf eine GUI ist nicht immer verlass ;)
                            edit: und die Kiste auch mal neu gestartet wie ich empfohlen habe ?
                              free -m
                              RaspiUserR Online
                              RaspiUserR Online
                              RaspiUser
                              @djmarc75
                              ... sieht so aus ...
                              Mem:            1849        1332         311           1         205         447
                              Swap:             99           0          99
                              Ja ... nach jeder Änderung ...
                              Wieso konzentrierst Du Dich auf den RAM ?!
                              Mit Buster 32bit funktioniert es doch ... Das der RAM zu Buster 64bit mehr genutzt wird kann ich noch glauben (mal so als Laie rausgehauen ...)
                              Die Fehlermeldung deutet doch eher auf ein Netzwerkproblem hin, oder ?
                                @djmarc75
                                Swap:             99           0          99
                                @raspiuser
                                Da läuft nix auf dem Port 1883.
                                Schau dir das Setup vom mqtt-Server an.
                                Welcher wird da verwendet?
                                Das ganze ist auch kein Thema 32/64bit.
                                  @raspiuser
                                  RaspiUserR Online
                                  RaspiUserR Online
                                  RaspiUser
                                  @thomas-braun said in Probleme bei Buster 32bit auf Bullseye 64bit Upgrade:
                                  ... und wenn ich auf "DIE VERBINDUNG ZUM SERVER TESTEN" klicke kommt "OK" als Antwort.
                                  Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
                                    @raspiuser
                                    Ich hab zwar von sonoff/mqtt usw. keine Ahnung, aber das ist da ein Client-Setup. Stell mal Port 1885 ein, da läuft der sonoff drauf
                                      @raspiuser
                                      RaspiUserR Online
                                      RaspiUserR Online
                                      RaspiUser
                                      Stimmt, der läuft bei mir mit Port 1885 auch "GRÜN".
                                      Den habe ich jetzt gestoppt, den Port 1885 beim MQTT Adapter eingestellt, reboot und nix ...
                                      Der Fehler ist noch immer da, der Adapter "GELB".
                                      Und wieder alles auf Anfang ...
                                      (An dieser Stelle vielen Dank, dass ihr eure Zeit / Gedanken mit meinem Problem teilt .... 👍 )
                                      Ich glaube langsam, ich nehme wieder die Buster-Karte und fertig.
                                      Irgend etwas ist (scheinbar) in der LINUX Unterwäsche passiert, aber was ...
                                      Kann es sein, dass das Backitup von der Buster-Installation von Bullseye nicht richtig übernommen wird ?
                                      Ich werde mal eine frische Bullseye / ioBroker Karte OHNE Backitup probieren und das Sorgenkind MQTT als erstes installieren ...
                                        Quatsch.
                                          @raspiuser Die Standardfrage
                                          hat die neue Installation die gleiche IP und den gleichen Hostname?
