  4. js-controller 5.0.x jetzt in der BETA
    5.7k
580 Beiträge 71 Kommentatoren 239.6k Aufrufe 67 Beobachtet
  • ice987I ice987
    Video:
    RPReplay_Final1688397259.mov
    2023-07-03 17:13:13.070 - info: admin.0 (2482) ==> Connected system.user.admin from ::ffff:192.168.1.175
    2023-07-03 17:13:21.657 - info: host.iobroker-testsystem8 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-07-03 17:13:53.313 - info: host.iobroker-testsystem8 Controller will upgrade itself to version 5.0.6
    2023-07-03 17:14:03.141 - info: host.iobroker-testsystem8 [CONTROLLER_AUTO_UPGRADE] Stopping controller
    2023-07-03 17:15:07.246 - info: admin.0 (2482) <== Disconnect system.user.admin from ::ffff:192.168.1.175 admin
    2023-07-03 17:17:10.634 - info: admin.0 (2482) ==> Connected system.user.admin from ::ffff:192.168.1.175
    2023-07-03 17:17:10.665 - info: admin.0 (2482) <== Disconnect system.user.admin from ::ffff:192.168.1.175 admin
    2023-07-03 17:17:11.712 - info: admin.0 (2482) ==> Connected system.user.admin from ::ffff:192.168.1.175
    admin: v6.5.9
    JS-Controller: v5.0.5 -> v5.0.6
    Plattform: ioBroker.docker v8.0.1
    Betriebssystem: linux
    Architektur: x64
    Node.js: v18.16.1
    NPM: 9.5.1
    ice987I Offline
    ice987I Offline
    ice987
    schrieb am zuletzt editiert von ice987
    #381
    -> SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
    2023-07-10 07:22:33.789 - info: host.iobroker-testsystem8 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-07-10 07:23:44.644 - info: host.iobroker-testsystem8 Controller will upgrade itself to version 5.0.7
    2023-07-10 07:23:50.402 - info: host.iobroker-testsystem8 [CONTROLLER_AUTO_UPGRADE] Stopping controller
    ioBroker.admin: v6.6.0
    ioBroker.js-controller: v5.0.6 -> v5.0.7
    Plattform: ioBroker.docker v8.1.0-beta.3
    Architektur: x64
    Node.js: v18.16.1
    NPM: 9.5.1
    husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
    foxriver76F ice987I 2 Antworten Letzte Antwort
    • ice987I ice987
      Architektur: x64
      Node.js: v18.16.1
      NPM: 9.5.1
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #382
      @ice987 As always, eine Neuerung die mit 5.0.7 kommt funktioniert nur wenn das Upgrade mit 5.0.7 angestoßen wird, also muss es leider erst eine 5.0.8 geben um das ausprobieren zu können.
      Videotutorials & mehr
      ? 1 Antwort Letzte Antwort
      • foxriver76F foxriver76
        #383
        @foxriver76
        Hi, der cannot call visutils ist in der 5.0.7 immer noch da..
          @foxriver76
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #384
          @ilovegym ganze Logzeile bitte
            Version 5.0.7 ist auf dem Weg:
            • Fehler in adapter.registerNotification Methode behoben (hatte aufgrund eines Fehlers noch nie funktioniert)
            • Webserver Upgrade für Adapter hinzugefügt - wird vorrangig Admin in naher Zukunft erlauben dem User den Status eines Admin Updates anzuzeigen obwohl der Adapter während des Vorgangs gestoppt ist
            • Fehler behoben um Controller UI Upgrade im offiziellen Docker Container zu unterstützen. Version 8.1.0 des Containers wird benötigt
            • Fehler in getStatesmit Aliassen behoben, was dazu geführt hatte, dass z. B. Alias Werte mit einem nicht Admin User immer als null angezeigt wurden
            • Absturz behoben, falls ein .thisisdocker File mit ungültiger Version existiert
            bommel_030
            #385
            @foxriver76
            Update über den Admin hat geklappt, evtl. Schönheitsfehler, Server läuft auf httpS nicht http. Und soll die Meldung doppelt kommen?
            Stopping controller
            Successfully stopped js-controller
            Server is running on http://localhost:8081
            changed 14 packages in 36s
            286 packages are looking for funding
              run `npm fund` for details
            js-controller wurde erfolgreich auf 5.0.7 aktualisiert
            Meine "null"-Aliase haben jetzt auch wieder einen Inhalt als nicht-admin Nutzer. Ich habe weiterhin das Probleme, dass ich mich nach einem reboot einmal als admin anmelden muss. Nehme ich nach dem reboot meinen Standaruser kommt die Fehlermeldung.
            Error in GUI!
            Please open the browser console (F12), copy error text from there and create the issue on github
            Without this information it is not possible to analyse the error.
            It should looks like
            error
            If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
            please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
            Loading chunk 8855 failed. (error: https://mein.reverse.proxy/static/js/8855.45f1cd9d.chunk.js)
            ChunkLoadError: Loading chunk 8855 failed.function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}(error: https://mein.reverse.proxy/static/js/8855.45f1cd9d.chunk.js)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at t.f.j (https://mein.reverse.proxy/static/js/main.e2346901.js:1:13656)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at https://mein.reverse.proxy/static/js/main.e2346901.js:1:1292function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at Array.reduce (<anonymous>)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at t.e (https://mein.reverse.proxy/static/js/main.e2346901.js:1:1257)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at https://mein.reverse.proxy/static/js/58.6dd21bc9.chunk.js:2:240446function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at P (https://mein.reverse.proxy/static/js/2791.8afe157f.chunk.js:2:3351)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at Ei (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:120786)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at ks (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:109418)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at ys (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:109346)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at vs (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:109209)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at as (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:104313)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at S (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:131316)function(e,t){return(0,le.jsxs)("div",{children:[e,(0,le.jsx)("br",{})]},t)}    at MessagePort.T (https://mein.reverse.proxy/static/js/4164.29c179b8.chunk.js:2:131850)
            Danach hilft nur reboot und anmelden als Admin. Mir wird dann Instanz admin.0 als deaktiviert weil loop detect angezeigt. Wenn ich dann den admin abmelde und wieder den normalen Nutzer anmelde läuft alles einwandfrei. Bin mir jetzt n icht sicher ob das hier oder als admin issue besser aufgehoben ist.
            • B bommel_030
              @foxriver76
              Stopping controller
              Error in GUI!
              error
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              #386
              @bommel_030 Wenn Restart Loop detected muss ja was im Log stehen.
              Und bitte auch Log aus Browser Console posten, wie oben beschrieben ist.
              Doppel Logging und http/s Logging fixe ich
              B 1 Antwort Letzte Antwort
                bommel_030
                #387
                @foxriver76
                Erstmal Log nach reboot. Versucht als user anzumelden. Dann den webserver :8082 aufgerufen, dort abgemeldet. Unter :8081 als admin angemeldet, alles ok.
                Admin abmelden, user anmelden, soweit alles ok. Was ich jetzt aber noch festgestellt habe, ich habe als user versucht die Logstufe von admin.0 zu ändern bekomme ich den Toast "permission error", das taucht im Log allerdings nicht auf. Habe dann noch probiert via shuttercontrol mal alle Rolläden zu öffnen, da wurde mir der Zugriff auch verweigert. Letzte Zeile im Log. Als admin fahren die Rolläden wie erwartet hoch.
                2023-07-10 11:21:12.932  - info: admin.0 (578) failed connection to socket.io from ::ffff:192.168.10.57: Passport was not initialized
                2023-07-10 11:21:24.713  - info: admin.0 (578) ==> Connected system.user.bommel from ::ffff:192.168.10.57
                2023-07-10 11:21:25.218  - warn: admin.0 (578) Permission error for user "system.user.bommel" on "system.adapter.admin.0.logging": setState
                2023-07-10 11:21:25.219  - error: admin.0 (578) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-07-10 11:21:25.219  - error: admin.0 (578) unhandled promise rejection: permissionError
                2023-07-10 11:21:25.313  - error: admin.0 (578) Error: permissionError
                   at AdapterClass._checkStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7931:27)
                   at runNextTicks (node:internal/process/task_queues:60:5)
                   at processImmediate (node:internal/timers:447:9)
                   at AdapterClass.setForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8290:24)
                2023-07-10 11:21:25.314  - error: admin.0 (578) permissionError
                2023-07-10 11:21:25.321  - info: admin.0 (578) terminating https server on port 8081
                2023-07-10 11:21:25.323  - info: admin.0 (578) terminating
                2023-07-10 11:21:25.323  - warn: admin.0 (578) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-07-10 11:21:25.823  - info: admin.0 (578) terminating
                2023-07-10 11:21:26.067  - error: host.iobroker-master Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2023-07-10 11:21:26.069  - error: host.iobroker-master Caught by controller[0]: Error: permissionError
                2023-07-10 11:21:26.069  - error: host.iobroker-master Caught by controller[0]:     at AdapterClass._checkStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7931:27)
                2023-07-10 11:21:26.070  - error: host.iobroker-master Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
                2023-07-10 11:21:26.070  - error: host.iobroker-master Caught by controller[0]:     at processImmediate (node:internal/timers:447:9)
                2023-07-10 11:21:26.070  - error: host.iobroker-master Caught by controller[0]:     at AdapterClass.setForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8290:24)
                2023-07-10 11:21:26.070  - error: host.iobroker-master instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-07-10 11:21:58.526  - info: admin.0 (2198) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 5.0.7
                2023-07-10 11:21:58.586  - info: admin.0 (2198) requesting all states
                2023-07-10 11:21:58.586  - info: admin.0 (2198) requesting all objects
                2023-07-10 11:21:58.995  - info: admin.0 (2198) Request actual repository...
                2023-07-10 11:22:01.267  - info: admin.0 (2198) received all objects
                2023-07-10 11:22:01.402  - info: admin.0 (2198) Secure socket.io server listening on port 8081
                2023-07-10 11:22:01.403  - info: admin.0 (2198) https server listening on port 8081
                2023-07-10 11:22:01.404  - info: admin.0 (2198) Use link "https://127.0.0.1:8081" to configure.
                2023-07-10 11:22:01.838  - info: admin.0 (2198) Repository received successfully.
                2023-07-10 11:22:05.392  - info: admin.0 (2198) ==> Connected system.user.bommel from ::ffff:192.168.10.57
                2023-07-10 11:22:05.901  - warn: admin.0 (2198) Permission error for user "system.user.bommel" on "system.adapter.admin.0.logging": setState
                2023-07-10 11:22:05.903  - error: admin.0 (2198) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-07-10 11:22:05.904  - error: admin.0 (2198) unhandled promise rejection: permissionError
                2023-07-10 11:22:05.971  - error: admin.0 (2198) Error: permissionError
                2023-07-10 11:22:05.971  - error: admin.0 (2198) permissionError
                2023-07-10 11:22:05.977  - info: admin.0 (2198) terminating https server on port 8081
                2023-07-10 11:22:05.978  - info: admin.0 (2198) terminating
                2023-07-10 11:22:05.979  - warn: admin.0 (2198) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-07-10 11:22:06.479  - info: admin.0 (2198) terminating
                2023-07-10 11:22:06.614  - error: host.iobroker-master Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2023-07-10 11:22:06.615  - error: host.iobroker-master Caught by controller[0]: Error: permissionError
                2023-07-10 11:22:06.615  - error: host.iobroker-master Caught by controller[0]:     at AdapterClass._checkStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7931:27)
                2023-07-10 11:22:06.615  - error: host.iobroker-master Caught by controller[0]:     at AdapterClass.setForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8290:24)
                2023-07-10 11:22:06.615  - error: host.iobroker-master instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-07-10 11:22:38.961  - info: admin.0 (2229) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 5.0.7
                2023-07-10 11:22:39.024  - info: admin.0 (2229) requesting all states
                2023-07-10 11:22:39.024  - info: admin.0 (2229) requesting all objects
                2023-07-10 11:22:39.414  - info: admin.0 (2229) Request actual repository...
                2023-07-10 11:22:41.555  - info: admin.0 (2229) received all objects
                2023-07-10 11:22:41.693  - info: admin.0 (2229) Secure socket.io server listening on port 8081
                2023-07-10 11:22:41.694  - info: admin.0 (2229) https server listening on port 8081
                2023-07-10 11:22:41.695  - info: admin.0 (2229) Use link "https://127.0.0.1:8081" to configure.
                2023-07-10 11:22:42.015  - info: admin.0 (2229) Repository received successfully.
                2023-07-10 11:22:54.806  - info: admin.0 (2229) failed connection to socket.io from ::ffff:192.168.10.57: Passport was not initialized
                2023-07-10 11:23:14.817  - info: admin.0 (2229) ==> Connected system.user.admin from ::ffff:192.168.10.57
                2023-07-10 11:23:26.360  - info: admin.0 (2229) <== Disconnect system.user.admin from ::ffff:192.168.10.57 admin
                2023-07-10 11:23:32.591  - info: admin.0 (2229) ==> Connected system.user.bommel from ::ffff:192.168.10.57
                2023-07-10 11:23:55.651  - warn: admin.0 (2229) Permission error for user "system.user.bommel" on "shuttercontrol.0.control.openAll": setState
                iobroker.admin@6.6.0
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:24.579Z] Try to connect
                312.4df0a1cd.chunk.js:2 Stored version: , new version: 6.6.0
                312.4df0a1cd.chunk.js:2 Connected: true
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:25.857Z] ws connection error: CLOSE_ABNORMAL
                (anonymous) @ 312.4df0a1cd.chunk.js:2
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:25.858Z] Start reconnect 0
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:25.859Z] Try to connect
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980885859&name=admin' failed:
                SocketClient.connect @ socket.io.js:140
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:27.902Z] Start reconnect 1
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:27.902Z] ws connection error: CLOSE_ABNORMAL
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:27.902Z] Reconnect is already running 1
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:28.912Z] Try to connect
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980888913&name=admin' failed:
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:30.964Z] Start reconnect 2
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:30.965Z] ws connection error: CLOSE_ABNORMAL
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:30.965Z] Reconnect is already running 2
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:32.970Z] Try to connect
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980892970&name=admin' failed:
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:35.013Z] Start reconnect 3
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:35.013Z] ws connection error: CLOSE_ABNORMAL
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:35.014Z] Reconnect is already running 3
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:38.017Z] Try to connect
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980898017&name=admin' failed:
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:40.065Z] Start reconnect 4
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:40.065Z] ws connection error: CLOSE_ABNORMAL
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:40.065Z] Reconnect is already running 4
                312.4df0a1cd.chunk.js:2 Cannot getRepositoryCompact: timeout
                312.4df0a1cd.chunk.js:2 Cannot getInstalled: notConnectedError
                312.4df0a1cd.chunk.js:2 Cannot read adapters: notConnectedError
                312.4df0a1cd.chunk.js:2 notConnectedError
                2312.4df0a1cd.chunk.js:2 [ADAPTERS] Cannot compare "" and "5.0.7"
                :8081/#tab-intro:1 Mixed Content: The page at 'https://192.168.10.15:8081/#tab-intro' was loaded over HTTPS, but requested an insecure element 'https://192.168.10.15:8081/img/no-image.png'. This request was not upgraded to HTTPS because its URL's host is an IP address.
                312.4df0a1cd.chunk.js:2 Cannot get instances: notConnectedError
                312.4df0a1cd.chunk.js:2 Cannot get hosts: notConnectedError
                312.4df0a1cd.chunk.js:2 Cannot get notifications: notConnectedError
                312.4df0a1cd.chunk.js:2 Cannot get logs: notConnectedError
                8855.45f1cd9d.chunk.js:1     Failed to load resource: net::ERR_CONNECTION_REFUSED
                312.4df0a1cd.chunk.js:2 ChunkLoadError: Loading chunk 8855 failed.
                (error: https://192.168.10.15:8081/static/js/8855.45f1cd9d.chunk.js)
                   at t.f.j (main.e2346901.js:1:13656)
                   at main.e2346901.js:1:1292
                   at t.e (main.e2346901.js:1:1257)
                   at 58.6dd21bc9.chunk.js:2:240446
                   at P (2791.8afe157f.chunk.js:2:3351)
                   at Ei (4164.29c179b8.chunk.js:2:120786)
                   at ks (4164.29c179b8.chunk.js:2:109418)
                   at ys (4164.29c179b8.chunk.js:2:109346)
                   at vs (4164.29c179b8.chunk.js:2:109209)
                   at as (4164.29c179b8.chunk.js:2:104313)
                   at S (4164.29c179b8.chunk.js:2:131316)
                   at MessagePort.T (4164.29c179b8.chunk.js:2:131850)
                :8081/#tab-intro:1 Mixed Content: The page at 'https://192.168.10.15:8081/#tab-intro' was loaded over HTTPS, but requested an insecure element 'https://192.168.10.15:8081/img/browserError.png'. This request was not upgraded to HTTPS because its URL's host is an IP address.
                no-image.png:1     Failed to load resource: net::ERR_CONNECTION_REFUSED
                browserError.png:1     Failed to load resource: net::ERR_CONNECTION_REFUSED
                :8081/#tab-intro:1 Uncaught (in promise) notConnectedError
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:44.066Z] Try to connect
                200312.4df0a1cd.chunk.js:2 notConnectedError
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980904067&name=admin' failed:
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:46.113Z] Start reconnect 5
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:46.113Z] ws connection error: CLOSE_ABNORMAL
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:46.113Z] Reconnect is already running 5
                leaflet.css:1     GET https://192.168.10.15:8081/css/leaflet.css net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/lib/js/sparkline.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/main.e2346901.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/4223.59e16f0c.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/9907.74f37862.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/5377.b4b7e5a7.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/4564.8797be67.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:51.127Z] Try to connect
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/2791.8afe157f.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/2007.7259ed0a.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/7273.ce8e3693.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/4410.f7536cb0.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/4164.29c179b8.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/7116.2532a7ad.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                socket.io.js:140 WebSocket connection to 'wss://192.168.10.15:8081/?sid=1688980911127&name=admin' failed:
                (anonymous) @ socket.io.js:428
                o @ 312.4df0a1cd.chunk.js:2
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:53.183Z] Start reconnect 5
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:53.183Z] ws connection error: CLOSE_ABNORMAL
                error @ socket.io.js:68
                socket.onclose @ socket.io.js:177
                312.4df0a1cd.chunk.js:2 [2023-07-10T09:21:53.183Z] Reconnect is already running 5
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/9256.4c640c0d.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/6264.ba6e9ccf.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                DevTools failed to load source map: Could not load content for https://192.168.10.15:8081/static/js/3303.2a92f4de.chunk.js.map: Connection error: net::ERR_CONNECTION_REFUSED
                • B bommel_030
                  @foxriver76
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #388
                  @bommel_030 Danke, ich konnte es fixen.
                    #389
                    @foxriver76 gerne, ich hab zwar Vis installiert, benutze das aber nicht. Meine view wird mit MinuVis dargestellt.
                    System: Debian Bookworm, Proxmox lxc, Node 18.16.1, NPM 9.5.1, Admin 6.6.0, JS Controller 5.0.7
                    2023-07-10 13:21:00.633  - error: host.iobrokerS2 cannot call visUtils: Not exists
                    Was ist das VisUtils…?
                    • mcm1957M mcm1957
                      @bommel_030 said in js-controller 5.0.x jetzt in der BETA:
                      @foxriver76
                      der km200 Version 2.0.4 läuft bei mir wieder mit js-controller 5.0.6, danke!
                      Hi bommel_030
                      Ich hab am km200 noch ein paar lange fällige Aufräumaktionen gemacht (Tests zum Laufen gebracht, fehlende dependencies ergänzt, Fehler in io-package.json gefixed, noch nicht angepasste urls angepasst, ...). Am Code selbst sollte sich aber nichts geändert haben.
                      Da du offensichtlich eine Testmöglichkeit für den km200 hast könntest du bitte so nett sein und die 2.0.5 nochmal bewusst testen.
                      DANKE
                      P.S. LEdier kann ich von den offenen Issues voraussichtlich nichts fixen, da der Code selbst ei n gröberes Rewrite benötigen würde und ich keinerlei Testmöglichkeiten habe. Da muss ich / wir warten bis es einen dev mit Testmöglichkeit gibt :-(
                      bommel_030
                      #390
                      @mcm57
                      Kurz zum km200 und js 5.X
                      Habe km200 auf 2.0.4 aktualisiert gehabt und nur stichprobenartig in meine Datenpunkte geschaut. Abgastemperatur z.B. hat sich korrekt aktualisiert und geändert.
                      Habe dann auf die 2.0.5 aktualisiert und die Anzahl der Datenpunkte (bei nicht geändertem Filter) ist auf 18 zusammengeschrumpft. Der Datenpunkt Flamme AN/AUS ist zum Beispiel nicht mehr vorhanden. Downgrade auf 2.0.4 hat die Datenpunkte auch nicht zurück gebracht.
                      Im Log kommt als Warnung nur:
                      INit getservices error TypeError: Cannot create property '0' on boolean 'false' at /opt/iobroker/node_modules/iobroker.km200/km200.js:455:61 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.km200/km200.js:455:37 at /opt/iobroker/node_modules/iobroker.km200/lib/myAdapter.js:822:53
                      Wenn ich den Filter, also die Blacklist komplett leer lasse kommt nur ein Datenpunkt zur Firmware und die anderen 18 sind weg. Für mein Verständnis sollte eine leere Blacklist keine Datenpunkte blockieren.
                      Ich werde mir den EMS Adapter mal anschauen was der für Daten liefert, vielleicht hat Buderus auch was geändert. Da ich dafür den QR auf dem Brenner brauche wird das allerdings frühestens nächste Woche was, selbiger steht aktuell gut 1000 km entfernt ;-)
                      • B bommel_030
                        @mcm57
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        #391
                        @bommel_030
                        Sorry,
                        Wenn es auch mit der .4 nicht geht hab ich im Moment keine Ahnung.
                        Da es aber - wie ich gestern mitbekommen habe - den ems-esp Adapter gibt laufen zur Zeit Überlegungen den km200 offiziell auf DEPRECATED zu setzen da es einerseits keine Maintainer mit Testmöglichkeit gibt (so wie es aussieht) und andrerseits 2 Adapter für dasselbe Gerät selten Sinn machen.
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          @bommel_030
                          Sorry,
                          bommel_030
                          #392
                          @mcm57
                          Kein Grund sich zu entschuldigen, ich hab da auf jeden Fall noch weniger Ahnung von :D
                          Ich schaue mir nächste Woche den EMS Adapter an. Wenn der die gleiche (ähnliche) Funktionalität bietet wäre der km200 für mich obsolet.
                          • ChaotC Offline
                            ChaotC Offline
                            Chaot
                            #393
                            @apollon77
                            Update auf 5.0.7 verlief Problemlos und alles scheint zu funktionieren.
                            Lediglich eine Fehlermeldung:
                            host.ioBroker
                            2023-07-10 22:33:52.784	error	[CONTROLLER_AUTO_UPGRADE] npm WARN skipping integrity check for git dependency ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git npm WARN skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git npm WARN skipping integrity check for git dependency ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git npm WARN skipping integrity check for git dependency ssh://git@github.com/nVuln/homebridge-lg-thinq.git
                            Scheinen wohl alte Adapterleichen zu sein, wenn ich das richtig verstehe.
                            • FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #394
                              js-controller 5.0.7 wurde auch auf meinem Master / Slave System aktualisiert und beide ioBrokers sind ohne Probleme gestartet
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #395
                                @ilovegym Ist Code, der schaut wie viele vis Projekte, DPs, etc. du hast. Allerdings nur für statistische Zwecke.
                                Die Frage ist, tritt das bei anderen auch noch auf?
                                D.h. du hast in deinem Fall kein einziges vis-Projekt oder ist das default noch da?
                                  #396
                                  @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                                  Objekte: 116948, Zustände: 98389, 78 Adapter, insgesamt so um die 650 Devices..
                                  definitiv default.. irgendwann vor 3 oder 4 Jahren mit js-controller 1.21 mal gestartet, fuer seltsam befunden und seitdem nicht mehr angerührt.. :-)
                                  Instanz irgendwie immer mal mitgeschleppt... auch zwischendurch mal geloescht gehabt, aber irgenwelche Adapter hatten dann gemeckert.. also wieder installiert..
                                  Eben mal aufgerufen, da kam das:
                                  habs jetzt n paarmal weg geclickt und n iob upload vis gemacht, jetzt kommt der Default..
                                  sieht jetzt so aus, als ob der Fehler mit den VisUtils nicht mehr kommt.. war anscheinend was in dem Vis verbogen oder nicht vorhanden, weil nie benutzt..
                                  Haben die anderen diesen Fehler auch (noch?)...
                                  • ChaotC Chaot
                                    @apollon77
                                    host.ioBroker
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    #397
                                    @chaot
                                    Kommen diese skipping integrity check meldungen nicht IMMER wenn von github installiert wird? Kann es sein dass die gelisteten Adapter allesamt github Installationen sind?
                                    • mcm1957M mcm1957
                                      @chaot
                                      ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      #398
                                      @mcm57 Ja, da könntest du Recht haben. Muss ich am Wochenende mal drüberschauen was davon tatsächlich noch im Einsatz ist.
                                      • L Offline
                                        LordLolo
                                        #399
                                        Raspi4, NPM 9.5.1,Node.js v18.16.0, JSController 5.0.7
                                        Ich bekomme seit Installation des ViessmannAPI Adapters nur noch Fehler und kann nicht mehr auf Objekte zugreifen. Hier rotiert nur noch dieser Kreis.
                                        Kann mir jemand was dazu sagen?
                                        admin.0
                                        10647	2023-07-15 13:14:47.947	info	terminating http server on port 8081
                                        admin.0
                                        10647	2023-07-15 13:14:47.857	error	The pattern "viessmannapi.0.2277908.0.general.roles.capability:monetization;AdvancedReport" is not a valid ID pattern
                                        admin.0
                                        10647	2023-07-15 13:14:47.856	error	Error: The pattern "viessmannapi.0.2277908.0.general.roles.capability:monetization;AdvancedReport" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2473:15) at pattern2RegEx (/opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44) at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13) at SocketCommandsAdmin._subscribeStates (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22) at Object.commands.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25) at Socket.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43) at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83) at processImmediate (node:internal/timers:476:21)
                                        admin.0
                                        10647	2023-07-15 13:14:47.855	error	uncaught exception: The pattern "viessmannapi.0.2277908.0.general.roles.capability:monetization;AdvancedReport" is not a valid ID pattern
                                        admin.0
                                        10647	2023-07-15 13:14:47.817	error	The pattern "viessmannapi.0.2277908.0.general.roles.capability:backup;0002_HMU_VD2" is not a valid ID pattern
                                        admin.0
                                        10647	2023-07-15 13:14:47.816	error	Error: The pattern "viessmannapi.0.2277908.0.general.roles.capability:backup;0002_HMU_VD2" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2473:15) at pattern2RegEx (/opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44) at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13) at SocketCommandsAdmin._subscribeStates (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:492:22) at Object.commands.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25) at Socket.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43) at /opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:100 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/index.js:152:83) at processImmediate (node:internal/timers:476:21)
                                        admin.0
                                        10647	2023-07-15 13:14:47.815	error	uncaught exception: The pattern "viessmannapi.0.2277908.0.general.roles.capability:backup;0002_HMU_VD2" is not a valid ID pattern
                                        • apollon77A apollon77
                                          Neue erkannte Probleme, die noch nicht behandelt sind:
                                          • stiebel-isg update nötig
                                          • lgtv sollte fixed sein mit 1.1.12
                                          • web kann crashen falls Widgets in vis falsch konfiguriert sind (PR in socket-classes existiert bereits)
                                          • js-controller upgrade via Admin startet js-controller nicht wieder
                                          • Admin zeigt falsche Log grösse an -> Fixed in Admin 6.5.8+
                                          • km200 sollte gefixt sein mit 2.0.4
                                          • miio muss geprüft werden
                                          • fakeroku GitHub Version gefixt, release fehlt noch
                                          • pi-hole update nötig
                                          • node-red muss geprüft werden
                                          • enigma2.0 mindestens 1.4.0+
                                          • doorbird update nötig
                                          • linux-control update nötig
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          #400
                                          @apollon77 said in js-controller 5.0.x jetzt in der BETA:
                                          Liste wär anzupassen:
                                          Km200 funktioniert weder in 1.4 noch 1.5 stabil.
                                          Km200 wurde deprecated und wir - sollte sich nicht noch ein dev finden - ab js controller 5.x nicht mehr laufen. ems-esp existiert als ersatz.
