  4. [gelöst] Neueres Docker Image fährt nicht hoch
    5.4k
52 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @ben1983 sagte in Neueres Docker Image fährt nicht hoch:
    @glasfaser OK, meinen Aktuellen,
    Wie oben geschrieben ... im alten Container .
    Damit ich sehe was du so hast !!
    Ben1983B Offline
    Ben1983B Offline
    Ben1983
    schrieb am zuletzt editiert von Ben1983
    @glasfaser
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          22233      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          22232      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          22231      -
    udp6       0      0 fe80::101b:1eff:fe6:123 :::*                                87         345104746  -
    udp6       0      0 fe80::1cd5:fff:feca:123 :::*                                87         339069787  -
    udp6       0      0 fe80::42:4bff:fed1::123 :::*                                87         281848120  -
    udp6       0      0 2003:c0:bf41:1000:2:123 :::*                                87         255558829  -
    udp6       0      0 fe80::211:32ff:fef8:123 :::*                                87         34930      -
    udp6       0      0 ::1:123                 :::*                                0          22173      -
    udp6       0      0 :::123                  :::*                                0          22164      -
    udp6       0      0 :::35886                :::*                                0          131011837  -
    udp6       0      0 :::3702                 :::*                                99         67622115   -
    udp6       0      0 :::5353                 :::*                                0          131011835  -
    2023-06-08 19:42:56.632  - info: fritzdect.0 (748) going over to cyclic polling, messages to poll activity only in debug-mode
    2023-06-08 19:42:56.665  - info: lowpass-filter.0 (791) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.lowpass-filter, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:42:57.036  - info: alexa2.0 (311) Subscribing to states...
    2023-06-08 19:42:57.039  - info: alexa2.0 (311) Deleting the following states: ["Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#enabled"
    ,"Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#delete","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.powerState"]
    2023-06-08 19:42:58.988  - info: alexa2.0 (311) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-06-08 19:42:59.450  - info: host.buanet-iobroker instance system.adapter.trashschedule.0 started with pid 832
    2023-06-08 19:43:00.861  - info: trashschedule.0 (832) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:01.202  - info: trashschedule.0 (832) [ical] configurured ical preview is 30 days - increase this value to find more events in the future
    2023-06-08 19:43:03.405  - info: host.buanet-iobroker instance scheduled system.adapter.birthdays.0 0 0 * * *
    2023-06-08 19:43:03.429  - info: host.buanet-iobroker instance system.adapter.birthdays.0 started with pid 864
    2023-06-08 19:43:04.807  - info: birthdays.0 (864) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.birthdays, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:05.848  - info: birthdays.0 (864) Terminated (NO_ERROR): Without reason
    2023-06-08 19:43:06.392  - info: host.buanet-iobroker instance system.adapter.birthdays.0 terminated with code 0 (NO_ERROR)
    2023-06-08 19:43:07.435  - info: host.buanet-iobroker instance system.adapter.device-reminder.0 started with pid 908
    2023-06-08 19:43:08.729  - info: device-reminder.0 (908) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:08.823  - info: device-reminder.0 (908) Device "Waschmaschine" was successfully created
    2023-06-08 19:43:08.976  - info: device-reminder.0 (908) Device "Trockner" was successfully created
    2023-06-08 19:43:11.428  - info: host.buanet-iobroker instance system.adapter.simple-api.0 started with pid 1204
    2023-06-08 19:43:12.831  - info: simple-api.0 (1204) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:12.854  - info: simple-api.0 (1204) simpleAPI server listening on port 8087
    2023-06-08 19:43:12.855  - info: simple-api.0 (1204) Allow states only when user is owner: true
    2023-06-08 19:43:12.869  - info: simple-api.0 (1204) http server listening on port 8087
    2023-06-08 19:43:12.973  - info: alexa2.0 (311) Initialization Done ...
    2023-06-08 19:43:15.430  - info: host.buanet-iobroker instance system.adapter.bidirectional-counter.0 started with pid 1523
    2023-06-08 19:43:16.649  - info: bidirectional-counter.0 (1523) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.bidirectional-counter, node: v18.16.0, js-controller: 4.0.24
    Irgendwie markiert er nicht alles
    • Ben1983B Ben1983
      @glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @ben1983
      Da fehlt alles !?
      Wo ist der Anfang ... und das Ende , von der Full Ausgabe
        @ben1983
        Da fehlt alles !?
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        @glasfaser ich kann es markieren, aber sobald ich es einfüge ist es nur der halbe teil
        • Ben1983B Ben1983
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @ben1983
          Mauszeiger auf die Terminal Ausgabe , rechte Maustaste dann "alles auswählen "
          Ben1983B 2 Antworten Letzte Antwort
            @ben1983
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            @glasfaser habe ich gemacht. dann copy past hier rein....
            • GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @ben1983
              Hast du vielleicht das Paket " Portainer "
                @ben1983
                Ben1983B Offline
                Ben1983B Offline
                Ben1983
                @glasfaser
                ======== Start marking the full check here =========
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Architecture    : x86_64
                Docker          : v8.0.0
                Virtualization  : Unknown (buanet/Synology?)
                Distributor ID: Debian
                Description:    Debian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                 19:42:31 up 48 days,  7:10,  0 users,  load average: 1.93, 1.47, 1.63
                CPU threads: 2
                *** Time and Time Zones ***
                Thu Jun  8 17:42:31 UTC 2023
                Thu Jun  8 19:42:31 CEST 2023
                CEST +0200
                Etc/UTC
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:             17G        2.1G        4.8G         37M         10G         15G
                Swap:            12G        330M         12G
                Total:           30G        2.5G         17G
                        17836 M total memory
                         2125 M used memory
                         5996 M active memory
                         5949 M inactive memory
                         4775 M free memory
                         4715 M buffer memory
                         6219 M swap cache
                        12749 M total swap
                          330 M used swap
                        12418 M free swap
                *** FILESYSTEM ***
                Filesystem        Type   Size  Used Avail Use% Mounted on
                /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /
                tmpfs             tmpfs   64M     0   64M   0% /dev
                tmpfs             tmpfs  8.8G     0  8.8G   0% /sys/fs/cgroup
                shm               tmpfs   64M     0   64M   0% /dev/shm
                /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /opt/iobroker
                /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /etc/hosts
                sudo: unable to resolve host buanet-iobroker: Name or service not known
                Show mounted filesystems (real ones only):
                TARGET             SOURCE
                    FSTYPE OPTIONS
                /                  /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f]
                    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol
                id=1302,subvol=/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f
                |-/opt/iobroker    /dev/vg1/volume_1[/@syno/docker/iobroker]
                id=275,subvol=/@syno/docker/iobroker
                |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.co
                nf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol
                id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.conf
                |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname]
                id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname
                `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts]
                id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts
                /var:
                33M     /var/
                30M     /var/lib
                18M     /var/lib/apt/lists
                18M     /var/lib/apt
                13M     /var/lib/dpkg
                /opt/iobroker/backups:
                58M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                340M    /opt/iobroker/iobroker-data/
                253M    /opt/iobroker/iobroker-data/files
                72M     /opt/iobroker/iobroker-data/files/telegram.admin
                71M     /opt/iobroker/iobroker-data/backup-objects
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa
                rseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                14M     /opt/iobroker/iobroker-data/objects.jsonl
                8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.16.0
                /usr/bin/node           v18.16.0
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Installed: 18.16.0-deb-1nodesource1
                  Candidate: 18.16.0-deb-1nodesource1
                  Version table:
                 *** 18.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                MULTIHOSTSERVICE/enabled: false
                Core adapters versions
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   3
                Adapter State
                + system.adapter.admin.0                  : admin                 : buanet-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : buanet-iobroker                          -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : buanet-iobroker                          -  enabled
                  system.adapter.awtrix-light.0           : awtrix-light          : buanet-iobroker                          -  enabled
                + system.adapter.backitup.0               : backitup              : buanet-iobroker                          -  enabled
                  system.adapter.bidirectional-counter.0  : bidirectional-counter : buanet-iobroker                          -  enabled
                  system.adapter.birthdays.0              : birthdays             : buanet-iobroker                          -  enabled
                  system.adapter.cloud.0                  : cloud                 : buanet-iobroker                          -  enabled
                  system.adapter.device-reminder.0        : device-reminder       : buanet-iobroker                          -  enabled
                + system.adapter.discovery.0              : discovery             : buanet-iobroker                          -  enabled
                  system.adapter.drag-indicator.0         : drag-indicator        : buanet-iobroker                          -  enabled
                  system.adapter.energiefluss.0           : energiefluss          : buanet-iobroker                          -  enabled
                  system.adapter.energiefluss.1           : energiefluss          : buanet-iobroker                          -  enabled
                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : buanet-iobroker                          -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : buanet-iobroker                          -  enabled
                  system.adapter.go-e.0                   : go-e                  : buanet-iobroker                          - disabled
                  system.adapter.heizoel.0                : heizoel               : buanet-iobroker                          - disabled
                  system.adapter.ical.0                   : ical                  : buanet-iobroker                          -  enabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : buanet-iobroker                          -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : buanet-iobroker                          -  enabled
                + system.adapter.influxdb.0               : influxdb              : buanet-iobroker                          -  enabled, port: 8086
                  system.adapter.iot.0                    : iot                   : buanet-iobroker                          -  enabled
                  system.adapter.janitza-gridvis.0        : janitza-gridvis       : buanet-iobroker                          -  enabled, port: 8080
                + system.adapter.javascript.0             : javascript            : buanet-iobroker                          -  enabled
                  system.adapter.lowpass-filter.0         : lowpass-filter        : buanet-iobroker                          -  enabled
                + system.adapter.modbus.0                 : modbus                : buanet-iobroker                          -  enabled
                + system.adapter.modbus.1                 : modbus                : buanet-iobroker                          -  enabled
                + system.adapter.modbus.2                 : modbus                : buanet-iobroker                          -  enabled
                + system.adapter.modbus.3                 : modbus                : buanet-iobroker                          -  enabled
                  system.adapter.mqtt.0                   : mqtt                  : buanet-iobroker                          - disabled, port: 1883, bind: 0.0.0.0
                  system.adapter.operating-hours.0        : operating-hours       : buanet-iobroker                          -  enabled
                + system.adapter.shelly.0                 : shelly                : buanet-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shelly.1                 : shelly                : buanet-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.simple-api.0             : simple-api            : buanet-iobroker                          -  enabled, port: 8087, bind: 0.0.0.0, run as: restuser
                + system.adapter.telegram.0               : telegram              : buanet-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.trashschedule.0          : trashschedule         : buanet-iobroker                          -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : buanet-iobroker                          -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : buanet-iobroker                          -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker                          -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : buanet-iobroker                          -  enabled
                  system.adapter.vis.0                    : vis                   : buanet-iobroker                          -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : buanet-iobroker                          -  enabled
                + system.adapter.web.0                    : web                   : buanet-iobroker                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.yahka.0                  : yahka                 : buanet-iobroker                          -  enabled
                + system.adapter.zigbee.0                 : zigbee                : buanet-iobroker                          -  enabled, port: tcp://192.168.2.40:20108
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.3.5    , installed 6.3.5
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
                Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
                Adapter    "cloud"        : 4.3.0    , installed 4.4.1
                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
                Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
                Adapter    "fritzdect"    : 2.2.6    , installed 2.3.1
                Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                Adapter    "ical"         : 1.13.2   , installed 1.13.2
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "iot"          : 1.14.2   , installed 1.14.5
                Adapter    "janitza-gridvis": 3.1.2  , installed 3.1.2
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "lowpass-filter": 2.2.1   , installed 2.2.1
                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                Adapter    "operating-hours": 1.0.1  , installed 1.0.1
                Adapter    "shelly"       : 6.3.1    , installed 6.4.1
                Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "web"          : 4.3.0    , installed 4.3.0
                Adapter    "ws"           : 1.3.0    , installed 1.3.0
                Adapter    "yahka"        : 0.17.0   , installed 0.17.0
                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                Objects and States
                Objects:        9062
                States:         7420
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                Reading package lists...
                Pending Updates: 33
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:10502           0.0.0.0:*               LISTEN      1000       348577658  277/io.modbus.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       348576391  141/iobroker.js-con
                tcp        0      0 192.168.2.80:49160      0.0.0.0:*               LISTEN      0          73764      -
                tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          35534      -
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       348576384  141/iobroker.js-con
                tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          35536      -
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          67621883   -
                tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          67622274   -
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          35538      -
                tcp        0      0 192.168.2.80:50001      0.0.0.0:*               LISTEN      0          71312      -
                tcp        0      0 0.0.0.0:9010            0.0.0.0:*               LISTEN      0          345103681  -
                tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN      0          71653      -
                tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          68478      -
                tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      1026       27940193   -
                tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         59666      -
                tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN      0          73793      -
                cp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       348581831  453/io.shelly.1
                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          35540      -
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          67621882   -
                tcp        0      0 0.0.0.0:1502            0.0.0.0:*               LISTEN      1000       348581514  425/io.modbus.3
                tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          105309     -
                tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          34386      -
                tcp        0      0 0.0.0.0:3010            0.0.0.0:*               LISTEN      0          339069213  -
                tcp6       0      0 :::5000                 :::*                    LISTEN      0          35535      -
                tcp6       0      0 :::5001                 :::*                    LISTEN      0          35537      -
                tcp6       0      0 :::139                  :::*                    LISTEN      0          67621881   -
                tcp6       0      0 :::5357                 :::*                    LISTEN      0          67622275   -
                tcp6       0      0 :::80                   :::*                    LISTEN      0          35539      -
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       348576577  162/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       348583777  608/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      1000       337736385  -
                tcp6       0      0 :::8087                 :::*                    LISTEN      1000       348589784  1204/io.simple-api.
                tcp6       0      0 :::443                  :::*                    LISTEN      0          35541      -
                tcp6       0      0 :::445                  :::*                    LISTEN      0          67621880   -
                tcp6       0      0 :::3261                 :::*                    LISTEN      0          38364      -
                tcp6       0      0 :::3263                 :::*                    LISTEN      0          38361      -
                tcp6       0      0 :::3264                 :::*                    LISTEN      0          38366      -
                tcp6       0      0 :::3265                 :::*                    LISTEN      0          40919      -
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20748      -
                udp        0      0 172.17.0.1:123          0.0.0.0:*                           87         281848115  -
                udp        0      0 192.168.2.80:123        0.0.0.0:*                           87         27816      -
                udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          22171      -
                udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          22167      -
                udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          256301103  -
                udp        0      0 192.168.2.80:137        0.0.0.0:*                           0          256301102  -
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          256301070  -
                udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          256301105  -
                udp        0      0 192.168.2.80:138        0.0.0.0:*                           0          256301104  -
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          256301071  -
                udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          34385      -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          73767      -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          71315      -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          66885      -
                udp        0      0 127.0.0.1:51112         0.0.0.0:*                           0          71313      -
                udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         67622113   -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          131011834  -
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       348577499  262/io.shelly.0
                udp        0      0 127.0.0.1:55884         0.0.0.0:*                           0          73765      -
                udp        0      0 192.168.2.80:55900      0.0.0.0:*                           0          71314      -
                udp        0      0 192.168.2.80:55901      0.0.0.0:*                           0          73766      -
                udp        0      0 0.0.0.0:57403           0.0.0.0:*                           0          131011836  -
                So müsste es stimmen
                DJMarc75D GlasfaserG 2 Antworten Letzte Antwort
                • Ben1983B Ben1983
                  @glasfaser
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : v8.0.0
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 2
                  CEST +0200
                  Etc/UTC
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:            12G        330M         12G
                  Total:           30G        2.5G         17G
                           2125 M used memory
                           4775 M free memory
                           6219 M swap cache
                          12749 M total swap
                            330 M used swap
                          12418 M free swap
                  *** FILESYSTEM ***
                  TARGET             SOURCE
                      FSTYPE OPTIONS
                  /var:
                  33M     /var/
                  30M     /var/lib
                  18M     /var/lib/apt
                  13M     /var/lib/dpkg
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        9062
                  States:         7420
                  Pending Updates: 33
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @ben1983 der Herr Root 😂 😘
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @djmarc75 sagte in Neueres Docker Image fährt nicht hoch:
                    Alles gut ... ist OK so .
                    Ich habe eine DS220+ auf dem docker läuft.
                    Ben1983B DJMarc75D 2 Antworten Letzte Antwort
                      Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      @glasfaser Das bedeutet?
                      Sollte jetzt mit dem andern image auch gehen?
                      Ps. woran sieht man dass alles gut ist? :-)
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @glasfaser sagte in Neueres Docker Image fährt nicht hoch:
                        ist OK so .
                        also in diesem Docker ist das so ok ? Also Root ?
                        GlasfaserG FredFF 2 Antworten Letzte Antwort
                        • Ben1983B Ben1983
                          @glasfaser
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : v8.0.0
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 2
                          CEST +0200
                          Etc/UTC
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:            12G        330M         12G
                          Total:           30G        2.5G         17G
                                   2125 M used memory
                                   4775 M free memory
                                   6219 M swap cache
                                  12749 M total swap
                                    330 M used swap
                                  12418 M free swap
                          *** FILESYSTEM ***
                          TARGET             SOURCE
                              FSTYPE OPTIONS
                          /var:
                          33M     /var/
                          30M     /var/lib
                          18M     /var/lib/apt
                          13M     /var/lib/dpkg
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        9062
                          States:         7420
                          Pending Updates: 33
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          Sieht auf dem ersten Blick , alles gut aus .
                          das ist auch gut ... da können auch Fehler sonst kommen , aber du nutzt ja TCP
                          Also .. versuche es morgen mal , so wie beschrieben !
                            Ben1983B Offline
                            Ben1983B Offline
                            Ben1983
                            @glasfaser
                            Beenden, dann versuchen, oder erst neu starten?
                              ist OK so .
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              Ja schon mehere mal hier durchgekaut
                              Sorry ... :)
                              https://github.com/buanet/ioBroker.docker/blob/main/debian/scripts/iobroker_startup.sh
                              https://github.com/buanet/ioBroker.docker/blob/main/debian/scripts/iobroker_startup.sh#LL160C8-L160C8
                                Sorry ... :)
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                @glasfaser weil die uid und die gid auf 1000 stehen? oder wie?
                                • Ben1983B Ben1983
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  @glasfaser
                                  Was möchest du jetzt !?
                                  @ben1983
                                  Da sollte eigentlich mehr kommen ...
                                  keine Ahnung gerade was da jetzt so hängt .
                                  Alle Docker Container die du so hast mal stoppen , dann starte die Syn mal neu , erstelle einen neuen iobroker Container ... dann das Verzeichniss mounten .
                                  Was ist dann ..
                                  Dann schreibst du :
                                  @glasfaser Versuche ich spätestens morgen. muss jetzt erst mal was anderes machen. Melde mich wieder
                                  Was denn jetzt !????
                                    ist OK so .
                                    FredFF Online
                                    FredFF Online
                                    FredF
                                    Most Active Forum Testing
                                    @djmarc75
                                    Achtung Outing: Ich lege mir nicht jedes mal, wenn ich ein neues Docker Image baue einen Standarduser an...👼
                                    ...ich weiss gar nicht, wann ich das letzte mal die Konsole genutzt habe...
                                    • Ben1983B Ben1983
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      Das war nicht für dich !!!!
                                      Bitte die Finger von lassen
                                        @glasfaser
                                        @ben1983
                                        Was ist dann ..
                                        Dann schreibst du :
                                        Ben1983B Offline
                                        Ben1983B Offline
                                        Ben1983
                                        @glasfaser Ich meinte, ob ich dann morgen erst die container beenden soll und vor dem neustart der ds nochmal einen versuch mit dem neuen image machen soll, oder ob ich die erst neu starten soll?
                                        Die container dann nicht mit starten lassen, oder?
                                        Also ich habe gestern portainer drauf gemacht nur zur Info, falls das was ausmachen könnte.
                                        • Ben1983B Ben1983
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          @ben1983
                                          So wie geschrieben :
                                          darauf achten das der Autostart nicht aktiv ist
