  4. Node-Red
  5. Extra Warmwasser mit PV Überschuss
    6.5k
51 Beiträge 3 Kommentatoren 6.9k Aufrufe 3 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    #41
    Ansonsten nimm halt nochmal den Flow - und schau, ob der funktioniert:
    Du musst halt die Zeiten und die Datenpunkte nochmal ändern:
           "id": "78ea932b6144ea56",
           "type": "switch",
           "z": "c7454c976ad86c7e",
           "name": "PV Überschuss",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "lt",
                   "v": "2.4",
                   "vt": "num"
                   "t": "gte",
                   "v": "2.4",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 360,
           "y": 680,
           "wires": [
                   "45c84f129773d19b"
                   "0478f81a30fe3639",
                   "e4a8735798502e7c"
           "outputLabels": [
               "Brauchwasser AUS",
               "Brauchwasser EIN"
           "info": "Ich würde hier eine Hysterese einbauen. \r\n\r\nDie Ausgänge kannst Du auch beschreiben, wenn Du mit der Maus drüber gehst."
           "id": "0423db8ebd88425a",
           "type": "debug",
           "name": "Brauchwasser EIN (Shelly)",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": true,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "payload",
           "statusType": "auto",
           "x": 2040,
           "y": 960,
           "wires": []
           "id": "7e029bf35fe30f0c",
           "type": "debug",
           "name": "Brauchwasser AUS (Shelly)",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": true,
           "x": 2060,
           "y": 540,
           "wires": []
           "id": "490f9fe9d29ac5c8",
           "type": "delay",
           "name": "20 Minuten verzögern",
           "pauseType": "rate",
           "timeout": "20",
           "timeoutUnits": "seconds",
           "rate": "1",
           "nbRateUnits": "20",
           "rateUnits": "second",
           "randomFirst": "1",
           "randomLast": "5",
           "randomUnits": "seconds",
           "drop": true,
           "allowrate": false,
           "outputs": 1,
           "x": 1180,
           "y": 920,
           "wires": [
                   "467fd83885fcecf0",
                   "c9f79effc6659927"
           "id": "467fd83885fcecf0",
           "type": "trigger",
           "name": "30 Minuten MinON",
           "op1": "true",
           "op2": "false",
           "op1type": "bool",
           "op2type": "bool",
           "duration": "30",
           "extend": true,
           "overrideDelay": false,
           "units": "s",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 1430,
           "y": 1020,
           "wires": [
                   "43d93b25398134f9"
           "id": "43d93b25398134f9",
           "type": "ioBroker out",
           "name": "Brauchwasser_AKTIV (MinOn)",
           "topic": "0_userdata.0.Test.Brauchwasser.Brauchwasser_AKTIV",
           "ack": "true",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1710,
           "y": 1020,
           "wires": []
           "id": "0a9ff9331c1b8e3c",
           "type": "ioBroker get",
           "name": "Hole Brauchwasser_AKTIV (MinOn)",
           "attrname": "payload",
           "payloadType": "value",
           "errOnInvalidState": "nothing",
           "x": 1210,
           "y": 580,
           "wires": [
                   "265413e346c4ce5d"
           "id": "265413e346c4ce5d",
           "type": "switch",
           "name": "MinOn = false?",
           "rules": [
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 1480,
           "y": 580,
           "wires": [
                   "0befa3eabb32d9fe"
           "id": "0b8b63c145022cf3",
           "d": true,
           "name": "Shelly Brauchwasser AUS",
           "topic": "",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2050,
           "y": 580,
           "wires": []
           "id": "3ed7efab20047cb6",
           "d": true,
           "name": "Shelly Brauchwasser EIN",
           "topic": "",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2030,
           "y": 920,
           "wires": []
           "id": "495778e29bdffe0d",
           "type": "switch",
           "name": "Wassertemperatur",
           "rules": [
                   "t": "gte",
                   "v": "57",
                   "vt": "num"
                   "t": "lte",
                   "v": "54",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 890,
           "y": 800,
           "wires": [
                   "5a258f3309617617"
                   "afc867f18b037b22"
           "outputLabels": [
               "Brauchwasser AUS",
               "Brauchwasser EIN"
           "id": "8c82cfd59b96688d",
           "type": "comment",
           "name": "Brauchwasser EIN",
           "info": "",
           "x": 1750,
           "y": 840,
           "wires": []
           "id": "59b342efc4818a85",
           "type": "trigger",
           "name": "Mindestens 2 Min < 2.4",
           "op1": "",
           "op2": "true",
           "op1type": "nul",
           "op2type": "bool",
           "duration": "2",
           "extend": false,
           "units": "s",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 870,
           "y": 580,
           "wires": [
                   "0a9ff9331c1b8e3c"
           "id": "0478f81a30fe3639",
           "type": "change",
           "name": "reset",
           "rules": [
                   "t": "set",
                   "p": "reset",
                   "pt": "msg",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 650,
           "y": 640,
           "wires": [
                   "59b342efc4818a85"
           "id": "c0daa92ca05b87f7",
           "type": "ioBroker in",
           "name": "Meter.Active_Power",
           "topic": "0_userdata.0.Huawei.Meter.Active_Power",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 150,
           "y": 680,
           "wires": [
                   "78ea932b6144ea56"
           "id": "6fc8e8c3b2da9141",
           "d": true,
           "name": "Warmwassertemperatur",
           "topic": "alias.0.Warmwassertemperatur",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "true",
           "x": 660,
           "y": 840,
           "wires": [
                   "495778e29bdffe0d"
           "id": "e4a8735798502e7c",
           "name": "Hole Wassertemperatur",
           "x": 650,
           "y": 780,
           "wires": [
                   "495778e29bdffe0d"
           "id": "58f585b8cb128cf9",
           "name": "Manuell",
           "topic": "0_userdata.0.Manuell",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "x": 1150,
           "y": 720,
           "wires": [
                   "ad3e4cfa3268f4c3"
           "id": "ad3e4cfa3268f4c3",
           "type": "switch",
           "name": "Ein-/Ausschalten",
           "rules": [
                   "t": "false"
                   "t": "true"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 1350,
           "y": 720,
           "wires": [
                   "693f0ce1d455c24d"
                   "c9f79effc6659927"
           "id": "3777b383486653c4",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1770,
           "y": 920,
           "wires": [
                   "3ed7efab20047cb6",
                   "0423db8ebd88425a"
           "id": "0befa3eabb32d9fe",
           "type": "trigger",
           "name": "Brauchwasser AUS",
           "op1": "true",
           "op2": "0",
           "op1type": "bool",
           "op2type": "str",
           "duration": "0",
           "extend": false,
           "units": "ms",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 1750,
           "y": 560,
           "wires": [
                   "0b8b63c145022cf3",
                   "7e029bf35fe30f0c"
           "id": "8f14a89a639ef9ce",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "x": 1190,
           "y": 500,
           "wires": [
                   "b9773c301b25d80b"
           "id": "b9773c301b25d80b",
           "type": "switch",
           "name": "nur <= 0.1",
           "rules": [
                   "t": "lte",
                   "v": "0.1",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 1390,
           "y": 500,
           "wires": [
                   "8dbc2ceaa816df43"
           "id": "8dbc2ceaa816df43",
           "type": "change",
           "name": "reset",
           "rules": [
                   "t": "set",
                   "p": "reset",
                   "pt": "msg",
                   "to": "true",
                   "tot": "bool"
                   "t": "delete",
                   "p": "payload",
                   "pt": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1550,
           "y": 500,
           "wires": [
                   "0befa3eabb32d9fe"
           "id": "afc867f18b037b22",
           "type": "junction",
           "x": 1040,
           "y": 840,
           "wires": [
                   "490f9fe9d29ac5c8"
           "id": "45c84f129773d19b",
           "type": "junction",
           "x": 600,
           "y": 580,
           "wires": [
                   "59b342efc4818a85"
           "id": "8441b30f28e429c3",
           "type": "junction",
           "x": 980,
           "y": 800,
           "wires": [
           "id": "5a258f3309617617",
           "type": "junction",
           "x": 1040,
           "y": 640,
           "wires": [
                   "693f0ce1d455c24d"
           "id": "693f0ce1d455c24d",
           "type": "junction",
           "x": 1600,
           "y": 640,
           "wires": [
                   "0befa3eabb32d9fe"
           "id": "c9f79effc6659927",
           "type": "junction",
           "x": 1580,
           "y": 920,
           "wires": [
                   "3777b383486653c4"
    P 1 Antwort Letzte Antwort
    • mickymM mickym
             "type": "switch",
             "rules": [
                     "t": "lt",
                     "v": "2.4",
                     "vt": "num"
                     "t": "gte",
                     "v": "2.4",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 360,
             "y": 680,
             "wires": [
                     "45c84f129773d19b"
                     "0478f81a30fe3639",
                     "e4a8735798502e7c"
             "outputLabels": [
                 "Brauchwasser AUS",
                 "Brauchwasser EIN"
             "type": "debug",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "x": 2040,
             "y": 960,
             "wires": []
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "x": 2060,
             "y": 540,
             "wires": []
             "type": "delay",
             "timeout": "20",
             "rate": "1",
             "randomFirst": "1",
             "randomLast": "5",
             "drop": true,
             "allowrate": false,
             "outputs": 1,
             "x": 1180,
             "y": 920,
             "wires": [
                     "467fd83885fcecf0",
                     "c9f79effc6659927"
             "type": "trigger",
             "op1": "true",
             "op2": "false",
             "op1type": "bool",
             "op2type": "bool",
             "duration": "30",
             "extend": true,
             "units": "s",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 1430,
             "y": 1020,
             "wires": [
                     "43d93b25398134f9"
             "ack": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1710,
             "y": 1020,
             "wires": []
             "x": 1210,
             "y": 580,
             "wires": [
                     "265413e346c4ce5d"
             "type": "switch",
             "rules": [
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 1480,
             "y": 580,
             "wires": [
                     "0befa3eabb32d9fe"
             "d": true,
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2050,
             "y": 580,
             "wires": []
             "d": true,
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2030,
             "y": 920,
             "wires": []
             "type": "switch",
             "rules": [
                     "t": "gte",
                     "v": "57",
                     "vt": "num"
                     "t": "lte",
                     "v": "54",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 890,
             "y": 800,
             "wires": [
                     "5a258f3309617617"
                     "afc867f18b037b22"
             "outputLabels": [
                 "Brauchwasser AUS",
                 "Brauchwasser EIN"
             "type": "comment",
             "info": "",
             "x": 1750,
             "y": 840,
             "wires": []
             "type": "trigger",
             "op1": "",
             "op2": "true",
             "op1type": "nul",
             "op2type": "bool",
             "duration": "2",
             "extend": false,
             "units": "s",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 870,
             "y": 580,
             "wires": [
                     "0a9ff9331c1b8e3c"
             "type": "change",
             "name": "reset",
             "rules": [
                     "t": "set",
                     "p": "reset",
                     "pt": "msg",
                     "to": "true",
                     "tot": "bool"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 650,
             "y": 640,
             "wires": [
                     "59b342efc4818a85"
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 150,
             "y": 680,
             "wires": [
                     "78ea932b6144ea56"
             "d": true,
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 660,
             "y": 840,
             "wires": [
                     "495778e29bdffe0d"
             "x": 650,
             "y": 780,
             "wires": [
                     "495778e29bdffe0d"
             "name": "Manuell",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 1150,
             "y": 720,
             "wires": [
                     "ad3e4cfa3268f4c3"
             "type": "switch",
             "rules": [
                     "t": "false"
                     "t": "true"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 1350,
             "y": 720,
             "wires": [
                     "693f0ce1d455c24d"
                     "c9f79effc6659927"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "true",
                     "tot": "bool"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1770,
             "y": 920,
             "wires": [
                     "3ed7efab20047cb6",
                     "0423db8ebd88425a"
             "type": "trigger",
             "op1": "true",
             "op2": "0",
             "op1type": "bool",
             "op2type": "str",
             "duration": "0",
             "extend": false,
             "units": "ms",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 1750,
             "y": 560,
             "wires": [
                     "0b8b63c145022cf3",
                     "7e029bf35fe30f0c"
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 1190,
             "y": 500,
             "wires": [
                     "b9773c301b25d80b"
             "type": "switch",
             "rules": [
                     "t": "lte",
                     "v": "0.1",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 1390,
             "y": 500,
             "wires": [
                     "8dbc2ceaa816df43"
             "type": "change",
             "name": "reset",
             "rules": [
                     "t": "set",
                     "p": "reset",
                     "pt": "msg",
                     "to": "true",
                     "tot": "bool"
                     "t": "delete",
                     "p": "payload",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1550,
             "y": 500,
             "wires": [
                     "0befa3eabb32d9fe"
             "type": "junction",
             "x": 1040,
             "y": 840,
             "wires": [
                     "490f9fe9d29ac5c8"
             "type": "junction",
             "x": 600,
             "y": 580,
             "wires": [
                     "59b342efc4818a85"
             "type": "junction",
             "x": 980,
             "y": 800,
             "wires": [
             "type": "junction",
             "x": 1040,
             "y": 640,
             "wires": [
                     "693f0ce1d455c24d"
             "type": "junction",
             "x": 1600,
             "y": 640,
             "wires": [
                     "0befa3eabb32d9fe"
             "type": "junction",
             "x": 1580,
             "y": 920,
             "wires": [
                     "3777b383486653c4"
      Peter666666
      #42
      @mickym mach ich. Kann ich wie in Blockly wo Zeiten eingeben zu welchen der Flow läuft? Also die Trigger verarbeitet werden?
      LG Peter
      Intel NUC i5 / 16GB RAM / 512GB SSD
      Synology DS220+ 10GB RAM / 8TB
      • P Peter666666
        mickymM Offline
        mickymM Offline
        mickym
        #43
        @peter666666 Ja Du kannst Zeiten filtern etc. Wenn Du in der Schedules in der Woche haben will, empfehle ich Dir zu Einfachheit Dir die Light Scheduler Nodes zu installieren:
        https://flows.nodered.org/node/node-red-contrib-light-scheduler
        Damit kannst Du dann so Zeitfenster grafisch filtern.
        Wenn Du anspruchsvoller Scheduler Aufgaben haben willst, dann kannst Du auch die Cron-Plus Node verwenden. Wenn Du zu bestimmten Zeiten triggern willst - kannst Du auch die Inject node verwenden.
        Ich würde aber dann wenn Du weitere Nodes installierst - in der Adapterkonfig erlauben, dass Du den Paletten-Manager in Node-Red nutzen kannst. Wenn Du hier Hilfe brauchst - melde Dich nochmal.
        • mickymM mickym
          Peter666666
          #44
          @mickym Ok danke. An was liegt das wenn ich im Auswahlfenster nicht alle DP sehe welche ich aber im ioBroker sehe? Habe einen erstellt "Poolpumpe Automatik EIN" welchen ich nicht auswählen kann
          LG Peter
          • mickymM Offline
            mickymM Offline
            mickym
            #45
            @peter666666 Das ist leider ein Bug im NodeRed Adapter - die Datenpunkte werden nur einmal beim Adapterstart eingelesen.
            Am Besten ist immer Du kopierst das topic direct aus dem Admin des iobrokers:
            und dann in das Topic in der Node einfügen. Die Behebung dieses Bugs im iobroker ist anscheinend nicht so einfach.
            • mickymM mickym
              Peter666666
              #46
              @mickym wie schaffe ich es das ich die AUTOMATIK EIN richtig verknüpfe das das ganze nur läuft wenn diese TRUE ist? Steh auf dem Schlauch :(
              LG Peter
              • P Peter666666
                mickymM Offline
                mickymM Offline
                mickym
                #47
                @peter666666 Nun Du willst wenn die Automatik nicht eingeschaltet ist - der ganze Flow unterbrochen wird. Deshalb einfach hinter die 1. iobroker-IN Node schalten. Damit Du Dir nicht die payload von Active Power überschreibst, musst Du Dir die Automatic einer anderen Nachrichteneigenschaft zuweisen:
                Also in der GetNode von der Poolpumpe Automatik zum Beispiel einer anderen Eigenschaft zuweisen, damit Du die payload nicht überschreibst.
                dann prüfst Du bei Automatik EIN - nicht die payload - sondern die Nachrichteneigenschaft auto - die Du über die get Node gesetzt hast:
                Hier zum Import:
                       "id": "b0a8505dd5617639",
                       "name": "Pool Automatik ein",
                       "topic": "",
                       "attrname": "auto",
                       "x": 1490,
                       "y": 1240,
                       "wires": [
                               "777c9b81a9f769ae"
                       "id": "777c9b81a9f769ae",
                       "type": "switch",
                       "name": "Automatik EIN",
                       "property": "auto",
                       "rules": [
                               "t": "true"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 1700,
                       "y": 1240,
                       "wires": [
                               "7581e414c1f002b5"
                Damit wird die Inverter Active Power payload nicht von der iobroker GET node überschrieben.
                • mickymM mickym
                  Hier zum Import:
                         "topic": "",
                         "attrname": "auto",
                         "x": 1490,
                         "y": 1240,
                         "wires": [
                                 "777c9b81a9f769ae"
                         "type": "switch",
                         "property": "auto",
                         "rules": [
                                 "t": "true"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 1700,
                         "y": 1240,
                         "wires": [
                                 "7581e414c1f002b5"
                  Peter666666
                  #48
                  @mickym danke. werd ich gleich mal versuchen
                  LG Peter
                  • P Peter666666
                    Peter666666
                    #49
                    @peter666666 ich bin zu blöd für NR...
                    AUTOMATIK ist false und bekomm jetzt die Inverterwerte nicht mehr weg auf bool...
                    LG Peter
                    mickymM 2 Antworten Letzte Antwort
                    • P Peter666666
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #50
                      @peter666666 na im oberen Ast setzt du nichts, sondern filterst aus. Bin aber unterwegs. Vielleicht beschreibst du halt die Aufgabenstellung. Im Prinzip musst du Dich doch nur an jedem Kabel entlang hangeln und bei jeder Node prüfen was mit dem Nachrichtenobjekt passiert
                      • P Peter666666
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #51
                        @peter666666 und mach debug nodes hinter jede Node damit du siehst was wo rauskommt
                        Und steuere halt erst die Datenpunkte an, wenn das Ergebnis passt.
                        Ansonsten mach ein Screenshot von deinem Blockly und ich versuche es umzusetzen und wir diskutieren anschließend
