  4. [gelöst] Fehler beim schreiben auf influxdb
46 Beiträge 5 Kommentatoren 5.4k Aufrufe 4 Beobachtet
  • Ben1983B Ben1983
    @oliverio
    Opened file	{"log_id": "0hvK92MG000", "service": "storage-engine", "engine": "tsm1", "service": "filestore", "path": "/var/lib/influxdb2/engine/data/1bb9099d3b7c3e2b/autogen/4/000000007-000000002.tsm", "id": 0, "duration": "10.483ms"}
    2023-05-20T13:06:39.732140Z	info	Opened shard	{"log_id": "0hvK92MG000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "index_version": "tsi1", "path": "/var/lib/influxdb2/engine/data/1bb9099d3b7c3e2b/autogen/4", "duration": "1615.077ms"}
    2023-05-20T13:06:40.087887Z	info	loading changes (end)	{"log_id": "0hvK92MG000", "service": "storage-engine", "engine": "tsm1", "op_name": "field indices", "op_event": "end", "op_elapsed": "899.816ms"}
    2023-05-20T13:06:40.088551Z	info	Reading file	{"log_id": "0hvK92MG000", "service": "storage-engine", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb2/engine/wal/7218bd3b5168e452/autogen/6/_00001.wal", "size": 1359140}
    2023-05-20T13:06:40.675328Z	info	Opened shard	{"log_id": "0hvK92MG000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "index_version": "tsi1", "path": "/var/lib/influxdb2/engine/data/7218bd3b5168e452/autogen/6", "duration": "1510.816ms"}
    2023-05-20T13:06:40.675775Z	info	Open store (end)	{"log_id": "0hvK92MG000", "service": "storage-engine", "service": "store", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "4409.592ms"}
    2023-05-20T13:06:40.675870Z	info	Starting retention policy enforcement service	{"log_id": "0hvK92MG000", "service": "retention", "check_interval": "30m"}
    2023-05-20T13:06:40.675935Z	info	Starting precreation service	{"log_id": "0hvK92MG000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
    2023-05-20T13:06:40.677588Z	info	Starting query controller	{"log_id": "0hvK92MG000", "service": "storage-reads", "concurrency_quota": 1024, "initial_memory_bytes_quota_per_query": 9223372036854775807, "memory_bytes_quota_per_query": 9223372036854775807, "max_memory_bytes": 0, "queue_size": 1024}
    2023-05-20T13:06:40.682348Z	info	Configuring InfluxQL statement executor (zeros indicate unlimited).	{"log_id": "0hvK92MG000", "max_select_point": 0, "max_select_series": 0, "max_select_buckets": 0}
    2023-05-20T13:06:42.173468Z	info	Starting	{"log_id": "0hvK92MG000", "service": "telemetry", "interval": "8h"}
    2023-05-20T13:06:42.218552Z	info	Listening	{"log_id": "0hvK92MG000", "service": "tcp-listener", "transport": "http", "addr": ":8086", "port": 8086}
    2023-05-20T13:20:43.289848Z	warn	internal error not returned to client	{"log_id": "0hvK92MG000", "handler": "error_logger", "error": "context canceled"}
    2023-05-20T13:20:43.296515Z	warn	internal error not returned to client	{"log_id": "0hvK92MG000", "handler": "error_logger", "error": "context canceled"}
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @ben1983
    kannst du bitte mal schauen ob die uhren in beiden containern gleich laufen? also die minuten reichen aus.
    das warn internal error not returned könnte passen, aber die zeit passt nicht. da ist der unterschied zu groß
    hab auch ein issue gefunden der passen könnte
    https://github.com/influxdata/influxdb/issues/24055
    allerdings geht es da um große datenmengen.
    das schreiben eines datenpunkts ist jetzt wirklich kein großer act
    daher könnte es schon sein, das genau zu diesem zeitpunkt die hostmaschine gut ausgelastet ist.
    wann läuft dein backup von iobroker oder eines anderen containers?
    aber du kannst mal schauen ob man am adapter irgendwo den timeout anpassen kann.
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO OliverIO
      @ben1983
      Ben1983B Offline
      Ben1983B Offline
      Ben1983
      @oliverio sagte in Fehler beim schreiben auf influxdb:
      @ben1983
      wie genau mache ich das? :-)
      Das Backup läuft nachts um 3 Uhr. Also daran kann es nicht gelegen haben.
      OliverIOO 3 Antworten Letzte Antwort
      • Ben1983B Ben1983
        @ben1983
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @ben1983
        docker oder portainer?
        shell öffnen und dann den date befehl ausführen
        shell öffnen mit docker:
        docker exec -it <container name> /bin/bash
        shell öffnen mit portainer
        den container auswählen und dann link zu console
        und console öffnen
        Links im Profil
        • Ben1983B Ben1983
          @ben1983
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @ben1983 sagte in Fehler beim schreiben auf influxdb:
          nachts oder nachmittags? am oder pm
          der Fehler trat 15:07 auf
          Links im Profil
          • Ben1983B Ben1983
            @ben1983
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @ben1983
            ich dachte ich habe es schon geschrieben, was du auch noch untersuchen kannst:
            ist es immer um die ähnliche uhrzeit wo der fehler auftritt?
            ggfs. musst du mal eine kontinuierliche leistungsaufzeichnung starten.
            dein screenshot ist ja nur eine momentaufnahme und zeigt bspw nicht die auslastung zu höchstzeiten an.
            auch kannst mal deine skripte prüfen, ob es da welche gibt die um die besagten uhrzeiten irgendwas größeres machen. kann ja auch ein skriptfehler sein, der die ressourcen (cpu, ram, netzkapazität) überbeansprucht auch wenn scheinbar genug da sind.
            oder auch bspw ein jdownloader der cpu und/oder netz zumacht
            Links im Profil
              @ben1983
              Ben1983B Offline
              Ben1983B Offline
              Ben1983
              @oliverio Es war heute das erste mal .... es läuft seit ca. 7 Wochen
              • Ben1983B Ben1983
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @ben1983
                dann weiter beobachten.
                aber das mit der uhrzeit noch prüfen, damit man in zukunft nicht nochmal suchen muss
                Links im Profil
                Ben1983B ? 2 Antworten Letzte Antwort
                  @ben1983
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  @oliverio das kommt raus:
                  root@buanet-iobroker:/opt/iobroker# date
                  Sa 20. Mai 20:17:24 CEST 2023
                  root@influxdb:/# date
                  Sat May 20 18:18:22 UTC 2023
                    @ben1983
                    @ben1983
                    Moin,
                    sorry Fußball ;)
                    Wie sieht es denn aktuell aus, nach den Neustarts? Ist es aktuell ruhig?
                    Und am besten wie @OliverIO schon schrieb, Langzeitmonitoring, von CPU, RAM, Netzwerk machen.
                    Welche Hardware setzt Du denn ein, NAS, oder Bare Metal?
                    Eine Minute Zeitdifferenz finde ich schon viel, dafür, dass die beiden auf der gleichen Maschine laufen.
                    VG
                    Bernd
                      @ben1983
                      Moin,
                      sorry Fußball ;)
                      VG
                      Bernd
                      @dp20eic sagte in Fehler beim schreiben auf influxdb:
                      zwei Stunden!
                      ? OliverIOO 2 Antworten Letzte Antwort
                        zwei Stunden!
                        Moin,
                        CEST und UTC, ja ist etwas daneben, sollte man mal angleichen.
                        VG
                        Bernd
                          Moin,
                          VG
                          Bernd
                          Ben1983B Offline
                          Ben1983B Offline
                          Ben1983
                          @dp20eic Wie passe ich es denn an und sind es jetzt 2 stunden?
                          die minuten und sekunden sind fast gleich. der versatz kam nur durch unterschiedliche eingaben
                            zwei Stunden!
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            Ne
                            UTC ist Zeitzone 0. so wie England, Greenwich Zeit
                            D ist eine Zone weiter und dann kommt noch die Sommerzeit =CEST central european summtet Time
                            Aber die eine Minute erklärt leider nicht,
                            Entweder das Nicht vorkommen im log
                            Oder der Zeitunterschied von ca 35 Minuten
                            Der log Ereignisse
                            Links im Profil
                            Ben1983B HomoranH 2 Antworten Letzte Antwort
                            • Ben1983B Ben1983
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @ben1983
                              Nein nix anpassen, die Zeitzonen sind egal
                              Es sind docker Container
                              Da kannst du nicht so einfach anpassen
                              Ist auch nicht wirklich notwendig
                              Zum synced mit dem host kannst du als volume das eintragen
                              -v /etc/localtime:/etc/localtime:ro
                              Links im Profil
                                Ne
                                Der log Ereignisse
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                @oliverio welche 35 min?
                                ? 1 Antwort Letzte Antwort
                                  Ne
                                  Der log Ereignisse
                                  das ist mir klar, aber dann sind (nur) die Zeitzonen falsch?
                                  • Ben1983B Ben1983
                                    Moin,
                                    im ersten Post, das Log vom ioBroker war von 15:07Uhr, die Logs vom influxDB Docker aber von ~15:30Uhr.
                                    VG
                                    Bernd
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @homoran sagte in Fehler beim schreiben auf influxdb:
                                      Nicht falsch, evtl Optimierungfähig
                                      Die zeitreferenz ist ja schon identisch(bis auf die eine Minute)
                                      Da das aber für die Funktionsfähigkeit von influx nicht relevant ist muss es nicht geändert werden.
                                      Manche docker Autoren bieten an die Zeitzone als Environment Parameter mitzugeben.
                                      Aber wie gesagt hier irrelevant. Ja beim log prüfen müssen wir einen Tick mehr überlegen.
                                      Die Zeit wird ja intern immer in ms seit 1970 gespeichert. Jegliche Anzeige wird immer anhand der eingestellten locale und Zeitzone berechnet,
                                      Also nix mit was wir hier Anfänger noch belasten müssen
                                      Bei Systemen die nah am Anwender sind sollte man es schon korrekt einstellen. Ist hier ja auch so der Fall
                                      Links im Profil
                                      • OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        Ergänzung zur Zeitzone
                                        https://stackoverflow.com/questions/57620589/docker-influxdb-runs-in-utc-timezone
                                        Also das mit utc ist Absicht von den influx Leuten
                                        Links im Profil
                                          Moin,
                                          VG
                                          Bernd
                                          Ben1983B Offline
                                          Ben1983B Offline
                                          Ben1983
                                          @dp20eic Das war nur Zufall, weil dauernd die gleiche Meldung dort stand. (mehr als 100 mal)
