  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.1k Aufrufe 4 Beobachtet
  • S searcher57
    @glasfaser said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    iob diag
    Hier die Full Ausgabe, die jetzt auch funktioniert!
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     18:36:54 up  1:24,  1 user,  load average: 0.18, 0.19, 0.17
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=47.2'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-15 18:36:54 CEST
               Universal time: Mon 2023-05-15 16:36:54 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        1.4G        162M        1.0M        307M        405M
    Swap:            99M          0B         99M
    Total:          1.9G        1.4G        262M
             1849 M total memory
             1380 M used memory
             1424 M active memory
              155 M inactive memory
              161 M free memory
               38 M buffer memory
              268 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.7G   25G  14% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.1M  369M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    /dev/sda1      exfat      29G  2.1G   27G   7% /mnt/usb0
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Mon May 15 17:12:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=ae9ac4e2-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
    [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
    [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Mon May 15 17:12:11 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
    [Mon May 15 17:12:13 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dma        sk=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    /var:
    540M    /var/
    180M    /var/cache
    175M    /var/cache/apt
    155M    /var/lib
    130M    /var/lib/apt/lists
    Archived and active journals take up 104.0M in the file system.
    /opt/iobroker/backups:
    11M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    321M    /opt/iobroker/iobroker-data/
    276M    /opt/iobroker/iobroker-data/files
    61M     /opt/iobroker/iobroker-data/files/vis-2-beta
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.m        ap
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
    10M     /opt/iobroker/iobroker-data/states.jsonl
    9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.vis/io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.1
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "web"          : 4.3.0    , installed 5.3.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.1
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        8636
    States:         7351
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       1853       1014/io.hm-rpc.0
    tcp        0      0 192.168.178.38:2001     0.0.0.0:*               LISTEN      1001       15373      1040/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14817      485/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14810      485/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14005      510/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15569      1163/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3955       887/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25273      1401/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14007      510/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15415      1066/io.shelly.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2000       1133/io.broadlink2.
    udp        0      0 0.0.0.0:48160           0.0.0.0:*                           108        14723      352/avahi-daemon: r
    udp        0      0 0.0.0.0:35874           0.0.0.0:*                           1001       2029       1133/io.broadlink2.
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1487       720/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14721      352/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14038      720/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14722      352/avahi-daemon: r
    udp6       0      0 :::34081                :::*                                108        14724      352/avahi-daemon: r
    2023-05-15 17:46:14.532  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
    2023-05-15 17:46:14.826  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30 web
    2023-05-15 17:46:15.055  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-15 17:46:17.598  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1401
    2023-05-15 17:46:21.371  - info: web.0 (1401) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
    2023-05-15 17:46:21.907  - info: web.0 (1401) socket.io server listening on port 8082
    2023-05-15 17:46:21.920  - info: web.0 (1401) simpleAPI server listening on port 8082
    2023-05-15 17:46:21.922  - info: web.0 (1401) Allow states only when user is owner: false
    2023-05-15 17:46:21.938  - info: web.0 (1401) http server listening on port 8082
    2023-05-15 17:46:28.981  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
    2023-05-15 17:46:29.180  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2023-05-15 17:46:38.900  - info: host.raspberrypi "system.adapter.vis.0" disabled
    2023-05-15 17:46:50.059  - info: host.raspberrypi "system.adapter.vis.0" enabled
    2023-05-15 17:46:50.163  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
    2023-05-15 17:46:50.348  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2023-05-15 17:47:02.106  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
    2023-05-15 17:48:01.632  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30
    2023-05-15 17:49:49.333  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
    2023-05-15 17:50:24.172  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.36
    2023-05-15 17:52:34.771  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
    2023-05-15 18:00:00.023  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
    2023-05-15 18:15:00.066  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
    2023-05-15 18:30:00.051  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
    2023-05-15 18:35:00.106  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 1618
    2023-05-15 18:35:36.650  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Docker          : false
    Release:        11
    Codename:       bullseye
    VERSION_ID="11"
    ID=debian
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    temp=47.2'C
    volt=0.9360V
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    pi
    /home/pi
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Swap:            99M          0B         99M
             1849 M total memory
             1380 M used memory
              161 M free memory
               38 M buffer memory
              268 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /var:
    540M    /var/
    180M    /var/cache
    175M    /var/cache/apt
    155M    /var/lib
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Version table:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    admin:          6.3.5
    javascript:     6.1.4
    Adapter State
    + instance is alive
    Objects and States
    Objects:        8636
    States:         7351
    Pending Updates: 0
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    #41
    @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    @Thomas-Braun
    Wie kommt denn die Meldung da rein ... war noch nie !?
    • GlasfaserG Glasfaser
      @Thomas-Braun
      #42
      @glasfaser
      Kann durch das unsaubere herunterfahren vor dem aktuellen boot-Vorgang kommen.
      @searcher57
      Nie nie niemals den Strom im laufenden Betrieb kappen. Immer richtig ordentlich herunterfahren.
      • S searcher57
        iob diag
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=47.2'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 1849 M total memory
                 1380 M used memory
                  161 M free memory
                   38 M buffer memory
                  268 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        540M    /var/
        180M    /var/cache
        175M    /var/cache/apt
        155M    /var/lib
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8636
        States:         7351
        Pending Updates: 0
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=47.2'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 1849 M total memory
                 1380 M used memory
                  161 M free memory
                   38 M buffer memory
                  268 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        540M    /var/
        180M    /var/cache
        175M    /var/cache/apt
        155M    /var/lib
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8636
        States:         7351
        Pending Updates: 0
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #43
        @searcher57
        Installiere den VIS Adapter nochmal neu !
          @glasfaser
          @searcher57
          searcher57
          #44
          OK, wieder was gelernt! Aber er hatte sich schon wieder aufgehängt und ich war ungeduldig!
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            @searcher57
            searcher57
            #45
            @glasfaser
            Den alten erst löschen?
            • S searcher57
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #46
              Das liegt daran ... auch bei anderen ... die Fummeln immer bei einer Restore rum ... anstatt zu warten !!!
              • S searcher57
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #47
                @glasfaser
                Ja , der wurde nicht sauber installiert !
                • S searcher57
                  #48
                  Wenn du dem System so brutal und hinterrücks den Stuhl unterm Hintern wegziehst musste dich auch nicht wundern wenn danach der Steiß schmerzt.
                    @glasfaser
                    searcher57
                    #49
                    @glasfaser
                    Ein Versuch war's wert. Fehlermeldung
                    ERROR: Process exited with code 27
                      searcher57
                      #50
                      Der tut mir sowieso vom langen sitzen aua!!!
                      • S searcher57
                        @glasfaser
                        #51
                        Fehlermeldung
                        Das ist nicht vollständig. Installier mit --debug-Option über die Kommandozeile.
                        • S searcher57
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #52
                          Das ist alles ... bitte komplett hier posten !
                          HomoranH S 2 Antworten Letzte Antwort
                            #53
                            @glasfaser sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                            ...nicht...!
                              searcher57
                              #54
                              @glasfaser
                              $ iobroker add vis --host raspberrypi
                              Could not read io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                              host.raspberrypi error: reading io-package.json /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                                Fehlermeldung
                                searcher57
                                #55
                                Bitte gib mir den kompletten Befehl an.
                                • S searcher57
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #56
                                  @searcher57
                                  Bitte über die Konsole
                                  iobroker upgrade iobroker.vis@1.4.0
                                    @searcher57
                                    searcher57
                                    #57
                                    pi@raspberrypi:~ $ iobroker upgrade iobroker.vis@1.4.0
                                    Cannot upgrade: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                                      @searcher57
                                      searcher57
                                      #58
                                      @glasfaser
                                      • S searcher57
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #59
                                        @searcher57
                                        iobroker install iobroker.vis@1.4.0
                                        • S searcher57
                                          iob diag
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=47.2'C
                                          volt=0.9360V
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   1849 M total memory
                                                   1380 M used memory
                                                    161 M free memory
                                                     38 M buffer memory
                                                    268 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          540M    /var/
                                          180M    /var/cache
                                          175M    /var/cache/apt
                                          155M    /var/lib
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        8636
                                          States:         7351
                                          Pending Updates: 0
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=47.2'C
                                          volt=0.9360V
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   1849 M total memory
                                                   1380 M used memory
                                                    161 M free memory
                                                     38 M buffer memory
                                                    268 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          540M    /var/
                                          180M    /var/cache
                                          175M    /var/cache/apt
                                          155M    /var/lib
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        8636
                                          States:         7351
                                          Pending Updates: 0
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          #60
                                          @Thomas-Braun
                                          ich kenne mich nicht mit SD aus , was heißt das bei Ihm .
                                          Ich dachte er hat es neu aufgesetzt !?
