  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.1k Aufrufe 4 Beobachtet
  • S searcher57
    @searcher57 said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    @thomas-braun said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
    @searcher57
    Das dir vermutlich mit dem Start des Javascript -Adapters das ganze wegknickt.
    Hilft dir das Protokoll weiter??
    admin.0
    	2023-05-24 21:51:07.778	info	<== Disconnect system.user.admin from ::ffff:192.168.178.30 javascript
    admin.0
    admin.0
    	2023-05-24 21:47:40.580	info	==> Connected system.user.admin from ::ffff:192.168.178.30
    host.raspberrypi
    	2023-05-24 21:42:54.392	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-05-24 21:42:16.372	info	instance system.adapter.yr.0 started with pid 1632
    host.raspberrypi
    	2023-05-24 21:42:16.351	info	instance scheduled system.adapter.yr.0 35 * * * *
    host.raspberrypi
    	2023-05-24 21:42:13.297	info	stopInstance canceled schedule system.adapter.yr.0
    host.raspberrypi
    	2023-05-24 21:42:13.294	info	stopInstance system.adapter.yr.0 (force=false, process=false)
    host.raspberrypi
    	2023-05-24 21:35:21.252	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-05-24 21:35:00.052	info	instance system.adapter.yr.0 started with pid 1582
    javascript.0
    	2023-05-24 21:28:11.471	info	received all states
    javascript.0
    	2023-05-24 21:28:10.997	info	received all objects
    javascript.0
    	2023-05-24 21:28:09.464	info	requesting all objects
    javascript.0
    	2023-05-24 21:28:09.463	info	requesting all states
    javascript.0
    	2023-05-24 21:28:09.371	warn	Alias alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer.SET has no target 12
    javascript.0
    	2023-05-24 21:28:09.369	warn	Alias alias.0.Kellergeschoss.Heizungsraum.Trockner.SET has no target 12
    javascript.0
    	2023-05-24 21:28:09.368	warn	Alias alias.0.Kellergeschoss.Heizungsraum.Waschmaschine.SET has no target 12
    javascript.0
    	2023-05-24 21:28:09.362	warn	Alias alias.0.Dachgeschoss.Wetterstation_Luftfeuchte.ICON has no target 12
    javascript.0
    	2023-05-24 21:28:09.360	warn	Alias alias.0.Dachgeschoss.Wetterstation_Windgeschwindigkeit.ICON has no target 12
    javascript.0
    	2023-05-24 21:28:08.150	info	starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 21:28:04.179	info	instance system.adapter.javascript.0 started with pid 1532
    host.raspberrypi
    	2023-05-24 21:28:04.044	info	"system.adapter.javascript.0" enabled
    alexa2.0
    	2023-05-24 20:37:22.326	info	Initialization Done ...
    alexa2.0
    	2023-05-24 20:37:20.456	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
    alexa2.0
    	2023-05-24 20:37:18.889	info	Subscribing to states...
    alexa2.0
    	2023-05-24 20:37:17.168	info	No smart home devices to query
    backitup.0
    	2023-05-24 20:37:08.123	info	[iobroker] backup will be activated at 02:00 every 1 day(s)
    backitup.0
    	2023-05-24 20:37:07.920	info	starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:37:05.084	info	instance system.adapter.backitup.0 started with pid 1206
    host.raspberrypi
    	2023-05-24 20:37:04.955	info	"system.adapter.backitup.0" enabled
    alexa2.0
    	2023-05-24 20:37:02.341	info	Initialize all Device states ...
    alexa2.0
    	2023-05-24 20:36:59.228	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    alexa2.0
    	2023-05-24 20:36:59.159	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:36:56.652	info	instance system.adapter.alexa2.0 started with pid 1191
    host.raspberrypi
    	2023-05-24 20:36:56.497	info	"system.adapter.alexa2.0" enabled
    host.raspberrypi
    	2023-05-24 20:36:54.062	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-05-24 20:36:39.298	info	instance system.adapter.yr.0 started with pid 1175
    host.raspberrypi
    	2023-05-24 20:36:39.279	info	instance scheduled system.adapter.yr.0 35 * * * *
    host.raspberrypi
    	2023-05-24 20:36:36.162	info	stopInstance system.adapter.yr.0 (force=false, process=false)
    host.raspberrypi
    	2023-05-24 20:36:36.153	info	"system.adapter.yr.0" enabled
    web.0
    	2023-05-24 20:36:30.813	info	http server listening on port 8082
    web.0
    	2023-05-24 20:36:30.765	info	Allow states only when user is owner: false
    web.0
    	2023-05-24 20:36:30.764	info	simpleAPI server listening on port 8082
    web.0
    	2023-05-24 20:36:30.756	info	socket.io server listening on port 8082
    web.0
    	2023-05-24 20:36:30.325	info	starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:36:27.810	info	instance system.adapter.web.0 started with pid 1160
    host.raspberrypi
    	2023-05-24 20:36:27.654	info	"system.adapter.web.0" enabled
    host.raspberrypi
    	2023-05-24 20:36:22.706	info	instance system.adapter.vis.0 terminated while should be started once
    vis.0
    	2023-05-24 20:36:22.120	info	Terminated (NO_ERROR): Without reason
    vis.0
    	2023-05-24 20:36:21.232	info	vis license is OK.
    vis.0
    	2023-05-24 20:36:20.947	info	starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:36:18.860	info	"system.adapter.vis.0" enabled
    text2command.0
    	2023-05-24 20:36:15.195	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:36:12.876	info	instance system.adapter.text2command.0 started with pid 1108
    host.raspberrypi
    	2023-05-24 20:36:12.816	info	"system.adapter.text2command.0" enabled
    tankerkoenig.0
    	2023-05-24 20:36:10.310	info	Start first request
    telegram.0
    	2023-05-24 20:36:09.467	info	starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:36:05.259	info	instance system.adapter.telegram.0 started with pid 1093
    host.raspberrypi
    	2023-05-24 20:36:05.084	info	"system.adapter.telegram.0" enabled
    tankerkoenig.0
    	2023-05-24 20:36:01.943	info	Sync time set to 30 minutes or 1800000 ms
    tankerkoenig.0
    	2023-05-24 20:36:01.942	info	Adapter is already in daemon mode
    tankerkoenig.0
    	2023-05-24 20:36:01.868	info	starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:35:59.593	info	instance system.adapter.tankerkoenig.0 started with pid 1077
    host.raspberrypi
    	2023-05-24 20:35:59.438	info	"system.adapter.tankerkoenig.0" enabled
    admin.0
    	2023-05-24 20:32:44.358	info	<== Disconnect system.user.admin from ::ffff:192.168.178.30 tankerkoenig
    admin.0
    	2023-05-24 20:32:02.222	info	==> Connected system.user.admin from ::ffff:192.168.178.30
    simple-api.0
    	2023-05-24 20:31:56.722	info	http server listening on port 8087
    simple-api.0
    	2023-05-24 20:31:56.701	info	Allow states only when user is owner: false
    simple-api.0
    	2023-05-24 20:31:56.700	info	simpleAPI server listening on port 8087
    simple-api.0
    	2023-05-24 20:31:56.660	info	starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:31:54.510	info	instance system.adapter.simple-api.0 started with pid 1033
    host.raspberrypi
    	2023-05-24 20:31:54.424	info	"system.adapter.simple-api.0" enabled
    hm-rpc.0
    	2023-05-24 20:31:49.927	info	Connected
    hm-rpc.0
    	2023-05-24 20:31:49.863	info	xmlrpc client is trying to connect to 192.168.178.27:2010/ with ["http://192.168.178.27:2010","raspberrypi:hm-rpc.0:1dd027a0d1f6500f064dc93d9d0b1251"]
    hm-rpc.0
    	2023-05-24 20:31:49.862	info	xmlrpc server is trying to listen on 0.0.0.0:2010
    hm-rpc.0
    	2023-05-24 20:31:49.547	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:31:47.211	info	instance system.adapter.hm-rpc.0 started with pid 1018
    host.raspberrypi
    	2023-05-24 20:31:47.057	info	"system.adapter.hm-rpc.0" enabled
    hm-rpc.1
    	2023-05-24 20:31:42.577	info	Connected
    hm-rpc.1
    	2023-05-24 20:31:42.544	info	xmlrpc -> 81 devices
    hm-rpc.1
    	2023-05-24 20:31:42.487	info	xmlrpc <- listDevices ["raspberrypi:hm-rpc.1:ee35540d39c05fe153ce80466f268150"]
    hm-rpc.1
    	2023-05-24 20:31:42.460	info	xmlrpc <- system.listMethods ["raspberrypi:hm-rpc.1:ee35540d39c05fe153ce80466f268150"]
    hm-rpc.1
    	2023-05-24 20:31:42.422	info	xmlrpc client is trying to connect to 192.168.178.27:2001/ with ["http://192.168.178.38:2001","raspberrypi:hm-rpc.1:ee35540d39c05fe153ce80466f268150"]
    hm-rpc.1
    	2023-05-24 20:31:42.422	info	xmlrpc server is trying to listen on 192.168.178.38:2001
    hm-rpc.1
    	2023-05-24 20:31:42.239	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.0, js-controller: 4.0.24
    host.raspberrypi
    	2023-05-24 20:31:39.970	info	instance system.adapter.hm-rpc.1 started with pid 1003
    host.raspberrypi
    	2023-05-24 20:31:39.823	info	"system.adapter.hm-rpc.1" enabled
    influxdb.0
    	2023-05-24 20:31:34.417	warn	Alias alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer.SET has no target 12
    influxdb.0
    	2023-05-24 20:31:34.414	warn	Alias alias.0.Kellergeschoss.Heizungsraum.Trockner.SET has no target 12
    influxdb.0
    	2023-05-24 20:31:34.413	warn	Alias alias.0.Kellergeschoss.Heizungsraum.Waschmaschine.SET has no target 12
    influxdb.0
    	2023-05-24 20:31:34.408	warn	Alias alias.0.Dachgeschoss.Wetterstation_Luftfeuchte.ICON has no target 12
    influxdb.0
    	2023-05-24 20:31:34.407	warn	Alias alias.0.Dachgeschoss.Wetterstation_Windgeschwindigkeit.ICON has no target 12
    influxdb.0
    	2023-05-24 20:31:33.501	info	Connected!
    influxdb.0
    	2023-05-24 20:31:33.338	info	enabled logging of alias.0.Erdgeschoss.Küche.Spülmaschine.ACTUAL, Alias=false, 49 points now activated
    influxdb.0
    	2023-05-24 20:31:33.338	info	enabled logging of alias.0.Erdgeschoss.Küche.E-Herd_L3.ACTUAL, Alias=false, 48 points now activated
    influxdb.0
    	2023-05-24 20:31:33.338	info	enabled logging of alias.0.Erdgeschoss.Küche.E-Herd_L2.ACTUAL, Alias=false, 47 points now activated
    influxdb.0
    	2023-05-24 20:31:33.337	info	enabled logging of alias.0.Erdgeschoss.Küche.Backofen.ACTUAL, Alias=false, 46 points now activated
    influxdb.0
    	2023-05-24 20:31:33.337	info	enabled logging of alias.0.Kellergeschoss.Werkstatt.Werkstatt_Schreibtisch.ELECTRIC_POWER, Alias=false, 45 points now activated
    influxdb.0
    	2023-05-24 20:31:33.337	info	enabled logging of alias.0.Kellergeschoss.Heizungsraum.Waschmaschine.ELECTRIC_POWER, Alias=false, 44 points now activated
    influxdb.0
    	2023-05-24 20:31:33.336	info	enabled logging of alias.0.Kellergeschoss.Heizungsraum.Trockner.ELECTRIC_POWER, Alias=false, 43 points now activated
    influxdb.0
    	2023-05-24 20:31:33.336	info	enabled logging of alias.0.Kellergeschoss.Büro_Rainer.Büro_Rainer_Schreibtisch.ELECTRIC_POWER, Alias=false, 42 points now activated
    influxdb.0
    	2023-05-24 20:31:33.336	info	enabled logging of alias.0.Kellergeschoss.Büro_Rainer.Büro_Rainer.ELECTRIC_POWER, Alias=false, 41 points now activated
    influxdb.0
    	2023-05-24 20:31:33.336	info	enabled logging of alias.0.Kellergeschoss.Heizungsraum.Temperarur_Heizung_WW.ACTUAL, Alias=false, 40 points now activated
    influxdb.0
    	2023-05-24 20:31:33.335	info	enabled logging of alias.0.Kellergeschoss.Heizungsraum.Temperarur_Heizung_RL.ACTUAL, Alias=false, 39 points now activated
    searcher57
    #301
    @searcher57
    admin.0
    admin.0
    admin.0
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    host.raspberrypi
    host.raspberrypi
    alexa2.0
    alexa2.0
    alexa2.0
    alexa2.0
    backitup.0
    backitup.0
    host.raspberrypi
    host.raspberrypi
    alexa2.0
    alexa2.0
    alexa2.0
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    web.0
    web.0
    web.0
    web.0
    web.0
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    vis.0
    vis.0
    vis.0
    host.raspberrypi
    text2command.0
    host.raspberrypi
    host.raspberrypi
    tankerkoenig.0
    telegram.0
    host.raspberrypi
    host.raspberrypi
    tankerkoenig.0
    tankerkoenig.0
    tankerkoenig.0
    host.raspberrypi
    host.raspberrypi
    admin.0
    admin.0
    simple-api.0
    simple-api.0
    simple-api.0
    simple-api.0
    host.raspberrypi
    host.raspberrypi
    hm-rpc.0
    hm-rpc.0
    hm-rpc.0
    hm-rpc.0
    host.raspberrypi
    host.raspberrypi
    hm-rpc.1
    hm-rpc.1
    hm-rpc.1
    hm-rpc.1
    hm-rpc.1
    hm-rpc.1
    hm-rpc.1
    host.raspberrypi
    host.raspberrypi
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    influxdb.0
    pi@raspberrypi:~ $ top
    top - 21:46:00 up  1:21,  1 user,  load average: 0.02, 0.19, 0.23
    Tasks: 168 total,   1 running, 167 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.1 us,  1.3 sy,  0.0 ni, 94.0 id,  0.2 wa,  0.0 hi,  0.4 si,  0.0 st
    MiB Mem :   1849.2 total,    250.6 free,   1233.2 used,    365.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.    552.0 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
        588 iobroker  20   0  741212 184820  40692 S   9.9   9.8   8:39.44 iobroker.js-con
        955 iobroker  20   0  704020 124004  36216 S   5.3   6.5   4:35.67 io.shelly.0
        987 iobroker  20   0  936800  86620  36360 S   2.3   4.6   2:20.12 io.influxdb.0
       1532 iobroker  20   0  738236 151608  36140 S   2.3   8.0   0:38.14 io.javascript.0
        414 influxdb  20   0 1064740 144400  56808 S   1.0   7.6   0:45.06 influxd
       1003 iobroker  20   0  665460  76156  36532 S   1.0   4.0   0:09.93 io.hm-rpc.1
       1191 iobroker  20   0  930156  82856  37252 S   1.0   4.4   0:34.96 io.alexa2.0
        147 root      20   0   65500  17988  16996 S   0.3   0.9   0:01.76 systemd-journal
        700 iobroker  20   0  957404 116304  42532 S   0.3   6.1   0:43.59 io.admin.0
       1108 iobroker  20   0  660160  69648  35976 S   0.3   3.7   0:07.44 io.text2command
       1678 pi        20   0   10188   3296   2692 R   0.3   0.2   0:00.16 top
          1 root      20   0  165216  10144   7360 S   0.0   0.5   0:02.23 systemd
          2 root      20   0       0      0      0 S   0.0   0.0   0:00.03 kthreadd
          3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
          4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
          5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
          6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
    pi@raspberrypi:~ $
      @searcher57
      searcher57
      #302
      @searcher57
      Ich habe die Instanz gestoppt!
      • S searcher57
        @searcher57
        searcher57
        #303
        @searcher57
        Dienstschluss??
        HomoranH Thomas BraunT 3 Antworten Letzte Antwort
        • S searcher57
          @searcher57
          Dienstschluss??
          HomoranH Offline
          HomoranH Offline
          #304
          @searcher57 Überstundenausgleich!
          • S searcher57
            @searcher57
            Dienstschluss??
            #305
            @searcher57
            Hab 'nen Teilzeitjob.
              searcher57
              #306
              @homoran said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
              Na den habe ich in meinem 45-jährigen Schaffen incl. Schweiss niiiie bekommen!
                @searcher57
                searcher57
                #307
                @searcher57
                Verstehe, evtl. morgen nochmal, sonst in vier Wochen! Rentner müssen auch mal Urlaub machen. WoMo Urlaub zum Nordkap!!😁 👍 🤒 😇
                • S searcher57
                  @searcher57
                  Dienstschluss??
                  HomoranH Offline
                  HomoranH Offline
                  #308
                  @searcher57 im Prinzip musst du nur
                  @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                  . 552.0 avail Mem
                  beobachten
                  während du systematisch die Adapter und Skripte (de-) aktivierst.
                  Irgendwann wird es eng und dann klemmt es wieder.
                  Dabei aber immer daran denken, dass Adapter und Skripte nicht immer gleichmäßig Last und RAM ziehen.
                  Aber mit Sicherheit kommst du mit deinen 2GB nicht weiter.
                  Spätestens wenn Backitup startet wird es bestenfalls sehr eng.
                    . 552.0 avail Mem
                    beobachten
                    searcher57
                    #309
                    edrnkrn
                    edrnkrn???
                    • S searcher57
                      edrnkrn
                      edrnkrn???
                      HomoranH Offline
                      HomoranH Offline
                      #310
                      edrnkrn
                      edrnkrn???
                      wo steht das?
                        edrnkrn
                        edrnkrn???
                        wo steht das?
                        searcher57
                        #311
                        edrnkrn
                        edrnkrn???
                        wo steht das?
                        Ich denke mein PC hat zuviel Hopfentee gesehen!
                        "Spätestens wenn Backitup startet wird es bestenfalls sehr eng." Wie kann ich den erhöhen??
                        • S searcher57
                          edrnkrn
                          edrnkrn???
                          wo steht das?
                          #312
                          Mehr Hopfentee einfüllen...
                            searcher57
                            #313
                            Wo ist der Einfüllstutzen?
                            • S searcher57
                              #314
                              @searcher57
                              Größeres Fass besorgen. Die 2GB reichen nicht für die Party aus.
                              S 2 Antworten Letzte Antwort
                              • S searcher57
                                edrnkrn
                                edrnkrn???
                                wo steht das?
                                HomoranH Offline
                                HomoranH Offline
                                #315
                                gar nicht, ist festgelötet
                                Entweder radikal entschlacken, oder bessere Hardware.
                                für ersteres fällt mir spontan eigentlich nur influxdb ein, die soll aber gar nicht sooo ressourcenhungrig sein.
                                Aber vielleicht beweist du ja auch das Gegenteil, und es liegt nicht am RAM
                                  @searcher57
                                  searcher57
                                  #316
                                  @searcher57
                                  Ok, bitte sag mir wie ich ein größeres Fass als 2GB einbinden kann? Mit einer SD Kart ja sicherlich nicht! EVTL externer Speicher??
                                    crunchipC Offline
                                    crunchipC Offline
                                    #317
                                    @homoran sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                                    Den discovery wäre noch ein Kandidat
                                      searcher57
                                      #318
                                      @crunchip said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                                      Bitte näher erklären!
                                      crunchipC HomoranH 2 Antworten Letzte Antwort
                                      • S searcher57
                                        crunchipC Offline
                                        crunchipC Offline
                                        #319
                                        @searcher57 den Adapter hast du doch auch laufen, ist aber eigentlich nicht nötig
                                        • S searcher57
                                          HomoranH Offline
                                          HomoranH Offline
                                          #320
                                          @searcher57
                                          wollte ich dir gerade zitieren, da sehe ich dass deine Ausgabe von top nicht nach MEM sortiert ist!
                                          mach das bitte noch mal
