  4. Yahka Adapter in iobroker im Docker Container
255 Beiträge 6 Kommentatoren 62.4k Aufrufe 5 Beobachtet
  • T Tomme
    @tomme Diagnose läuft ohne Fehler am Anfang
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    #221
    @tomme
    meinst du die Ausgabe von
    iob diag
    • GlasfaserG Glasfaser
      @tomme
      iob diag
      Tomme
      schrieb am zuletzt editiert von Tomme
      #222
      @glasfaser ja
      ======== Start marking the full check here =========
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Architecture    : aarch64
      Docker          : v8.0.1
      Virtualization  : Unknown (buanet/Synology?)
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       22:00:12 up 33 min,  0 users,  load average: 0.40, 1.20, 1.50
      CPU threads: 4
      *** Time and Time Zones ***
      Sun May  7 20:00:12 UTC 2023
      Sun May  7 22:00:12 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.8G        350M        5.1G        1.0M        2.4G        7.3G
      Swap:            99M          0B         99M
      Total:          7.9G        350M        5.2G
               7811 M total memory
                350 M used memory
                516 M active memory
               1934 M inactive memory
               5098 M free memory
                 79 M buffer memory
               2282 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      Filesystem     Type     Size  Used Avail Use% Mounted on
      overlay        overlay   28G  3.7G   24G  14% /
      tmpfs          tmpfs     64M     0   64M   0% /dev
      shm            tmpfs     64M     0   64M   0% /dev/shm
      /dev/root      ext4      28G  3.7G   24G  14% /opt/iobroker
      tmpfs          tmpfs    3.9G     0  3.9G   0% /proc/asound
      tmpfs          tmpfs    3.9G     0  3.9G   0% /sys/firmware
      sudo: unable to resolve host iobroker: Name or service not known
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET           SOURCE        FSTYPE OPTIONS
      /opt/iobroker    /dev/root[/var/lib/docker/volumes/22418e67230c731b7410855d52aa4469ef889fe65795ad9d5af2fd40b244b4e1/_data]          ext4   rw,noatime
      /etc/resolv.conf /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/resolv.conf] ext4   rw,noatime
      /etc/hostname    /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/hostname]    ext4   rw,noatime
      /etc/hosts       /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/hosts]       ext4   rw,noatime
      /var:
      16M     /var/
      13M     /var/lib/dpkg
      13M     /var/lib
      12M     /var/lib/dpkg/info
      2.0M    /var/cache
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      18M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      3.3M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Objects and States
      Objects:        143
      States:         104
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       13065      -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       55572      -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       55579      -
      tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          24049      -
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15320      -
      tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          22262      -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       55658      -
      tcp6       0      0 :::8000                 :::*                    LISTEN      0          24052      -
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15322      -
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       13064      -
      tcp6       0      0 :::9443                 :::*                    LISTEN      0          22265      -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3640       -
      udp        0      0 0.0.0.0:43895           0.0.0.0:*                           108        3642       -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15370      -
      udp6       0      0 :::41919                :::*                                108        3643       -
      udp6       0      0 :::5353                 :::*                                108        3641       -
      2023-05-07 21:55:57.118  - info: host.iobroker ip addresses: 192.168.7.39 2a01:598:b1ae:5fa:d6ec:ac55:4f72:b26f fe80::aecb:962d:34de:9047 172.17.0.1 fe80::42:38ff:fe87:f417 169.254.118.22 fe80::1f6f:f0c7:c469:59da fe80::a0d4:75ff:fe52:e950
      2023-05-07 21:55:57.542  - info: host.iobroker connected to Objects and States
      2023-05-07 21:55:57.572  - info: host.iobroker Node.js version has changed from unknown to 18.16.0
      2023-05-07 21:55:57.646  - info: host.iobroker added notifications configuration of host
      2023-05-07 21:55:58.016  - info: host.iobroker 3 instances found
      2023-05-07 21:55:58.026  - info: host.iobroker starting 3 instances
      2023-05-07 21:55:58.088  - info: host.iobroker instance system.adapter.admin.0 started with pid 1850
      2023-05-07 21:56:00.382  - info: admin.0 (1850) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
      2023-05-07 21:56:00.435  - info: admin.0 (1850) requesting all states
      2023-05-07 21:56:00.437  - info: admin.0 (1850) requesting all objects
      2023-05-07 21:56:00.611  - info: admin.0 (1850) received all objects
      2023-05-07 21:56:00.641  - info: admin.0 (1850) Request actual repository...
      2023-05-07 21:56:00.657  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-05-07 21:56:00.708  - info: admin.0 (1850) http server listening on port 8081
      2023-05-07 21:56:00.709  - info: admin.0 (1850) Use link "http://localhost:8081" to configure.
      2023-05-07 21:56:00.718  - info: admin.0 (1850) socket.io server listening on port 8081
      2023-05-07 21:56:00.799  - warn: admin.0 (1850) Repository cannot be read: Active repo - stable
      2023-05-07 21:56:00.801  - warn: admin.0 (1850) Active repository "stable" cannot be read
      2023-05-07 21:56:02.066  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1873
      2023-05-07 21:56:04.303  - info: discovery.0 (1873) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
      2023-05-07 21:56:06.056  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1892
      2023-05-07 21:56:08.208  - info: backitup.0 (1892) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
      2023-05-07 21:56:08.325  - info: backitup.0 (1892) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2023-05-07 21:56:13.804  - info: admin.0 (1850) Repository received successfully.
      2023-05-07 21:56:19.540  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      iob diag has finished.
      Press any key for a summary
      • T Tomme
        @glasfaser ja
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : v8.0.1
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        CEST +0200
        Etc/UTC
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                  350 M used memory
                  516 M active memory
                 5098 M free memory
                   79 M buffer memory
                 2282 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        16M     /var/
        13M     /var/lib/dpkg
        13M     /var/lib
        2.0M    /var/cache
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        Adapter State
        + instance is alive
        Objects and States
        Objects:        143
        States:         104
        Pending Updates: 0
        Tomme
        #223
        @tomme
        Copy text starting here:
                             v.2023-04-16
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 6.1.21-v8+
        Installation:           Docker
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            7.8G        378M        5.1G        1.0M        2.4G        7.3G
        Swap:            99M          0B         99M
        Total:          7.9G        378M        5.2G
        Active iob-Instances:   4
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                143
        States:                 104
        Size of iob-Database:
        128K    /opt/iobroker/iobroker-data/states.jsonl
        root@iobroker:/opt/iobroker#
        GlasfaserG T 2 Antworten Letzte Antwort
        • T Tomme
          @tomme
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          Timezone:               Etc/UTC
          User-ID:                0
          X-Server:               false
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          MEMORY:
          Swap:            99M          0B         99M
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                143
          States:                 104
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #224
          @tomme
          also ist der sudo Fehler weg !
          Dann kannst du weiter machen ....
          • T Tomme
            @tomme
                                 v.2023-04-16
            Kernel:                 6.1.21-v8+
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Swap:            99M          0B         99M
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                143
            States:                 104
            Tomme
            #225
            @tomme das sieht doch erstmal gut aus oder?
            ich schaue gleich nach dem backup und hoffe das es danach noch geht
            das backup kriege ich jetzt aber nur über /var/lib/docker/volumes/... oder so mit suchen welche Volume Nummer rein kopiert oder?
            dazu muss ich aber mit chmod 777 /var/lib/docker die Rechte ändern sonst komme ich da nicht rein mit sftp
            • T Tomme
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #226
              @tomme
              Nichts da machen mit den Rechten !
              Jetzt kannst das Image mit volumes ( Mount ) mal testen !
                @tomme
                Tomme
                #227
                @glasfaser ich habe noch gewartet keine Sorge ...
                kann ich die 2 Zeilen nachtragen im Stack oder muss ich den schnell neu machen?
                • T Tomme
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #228
                  @tomme
                  ich würde den Stack neu erstellen
                    @tomme
                    Tomme
                    #229
                    @glasfaser ok das geht ja schnell und danach mache ich nochmal iob diag und wenn fehlerfrei dann hole ich das backup zurück und dann nochmal iob diag?
                    • T Tomme
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #230
                      @tomme
                      Jipp ..
                        @tomme
                        Jipp ..
                        Tomme
                        #231
                        @glasfaser das läuft doch wie ein Länderspiel ;)
                        • T Tomme
                          Tomme
                          #232
                          @tomme diag läuft sauber durch aber smbclient findet er nicht
                          da muss ich erstmal mit lokalen Backups klar kommen das mit "NAS" nehme ich erstmal wieder raus das kam durch das Backup wieder rein
                          wahrscheinlich muss ich die Source von smbclient registrieren oder?
                          root@iobroker:/opt/iobroker# apt install smbclient
                          Reading package lists... Done
                          Building dependency tree... Done
                          Package smbclient is not available, but is referred to by another package.
                          This may mean that the package is missing, has been obsoleted, or
                          is only available from another source
                          E: Package 'smbclient' has no installation candidate
                          • T Tomme
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #233
                            @tomme sagte in Yahka Adapter in iobroker im Docker Container:
                            Brauchst du nicht ..
                            per Putty über pi
                            docker exec -ti iobroker /bin/bash
                              @tomme
                              Jipp ..
                              Tomme
                              #234
                              @glasfaser 230 Nachrichten ... wie kann ich das wieder gut machen?????
                              wenn ihr mal was habt zwecks KNX, LON, Loxone, Logo oder SPS Programmierung, Honeywell, Saia, Priva oder allgemein Elektrotechnik dann bitte melden da kann ich vielleicht mal helfen.
                              Vielen Dank ihr seid meine neuen Idole ;) ihr seid echt Klasse!!!
                                per Putty über pi
                                Tomme
                                #235
                                @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
                                dann bin ich root im iobroker ...
                                da nochmal apt install smbclient oder was meinst du?
                                • T Tomme
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #236
                                  Das ist ein "abgespeckter root " ( Docker Container buanet ).... alles gut
                                    Tomme
                                    #237
                                    @glasfaser ist abgespeichert
                                      Tomme
                                      #238
                                      woran das nun aber lag weiß man nicht oder?
                                      einziger Unterschied ist das es vorher keine Lite Version vom Image war aber daran kann es ja nicht gelegen haben oder?
                                      • T Tomme
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #239
                                        @tomme
                                        Mhh ...
                                        Ich schreibe gerade in anderen Threads ... ( du Folgst mir auch / abonniert)
                                          @tomme
                                          Mhh ...
                                          Tomme
                                          #240
                                          @glasfaser achso dann kriege ich jedes Mal eine Meldung ok ...
