  4. Yahka Adapter in iobroker im Docker Container
255 Beiträge 6 Kommentatoren 62.4k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @tomme
    meinst du die Ausgabe von
    iob diag
    Tomme
    schrieb am zuletzt editiert von Tomme
    #222
    @glasfaser ja
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : v8.0.1
    Virtualization  : Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     22:00:12 up 33 min,  0 users,  load average: 0.40, 1.20, 1.50
    CPU threads: 4
    *** Time and Time Zones ***
    Sun May  7 20:00:12 UTC 2023
    Sun May  7 22:00:12 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            7.8G        350M        5.1G        1.0M        2.4G        7.3G
    Swap:            99M          0B         99M
    Total:          7.9G        350M        5.2G
             7811 M total memory
              350 M used memory
              516 M active memory
             1934 M inactive memory
             5098 M free memory
               79 M buffer memory
             2282 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    overlay        overlay   28G  3.7G   24G  14% /
    tmpfs          tmpfs     64M     0   64M   0% /dev
    shm            tmpfs     64M     0   64M   0% /dev/shm
    /dev/root      ext4      28G  3.7G   24G  14% /opt/iobroker
    tmpfs          tmpfs    3.9G     0  3.9G   0% /proc/asound
    tmpfs          tmpfs    3.9G     0  3.9G   0% /sys/firmware
    sudo: unable to resolve host iobroker: Name or service not known
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/root[/var/lib/docker/volumes/22418e67230c731b7410855d52aa4469ef889fe65795ad9d5af2fd40b244b4e1/_data]          ext4   rw,noatime
    /etc/resolv.conf /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/resolv.conf] ext4   rw,noatime
    /etc/hostname    /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/hostname]    ext4   rw,noatime
    /etc/hosts       /dev/root[/var/lib/docker/containers/80380ce4e22cbb78b41d464a8592c94361c8a0658cfa14bdcc95515edae486f6/hosts]       ext4   rw,noatime
    /var:
    16M     /var/
    13M     /var/lib/dpkg
    13M     /var/lib
    12M     /var/lib/dpkg/info
    2.0M    /var/cache
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.3M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 100
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Objects and States
    Objects:        143
    States:         104
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       13065      -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       55572      -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       55579      -
    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          24049      -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15320      -
    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          22262      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       55658      -
    tcp6       0      0 :::8000                 :::*                    LISTEN      0          24052      -
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15322      -
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       13064      -
    tcp6       0      0 :::9443                 :::*                    LISTEN      0          22265      -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3640       -
    udp        0      0 0.0.0.0:43895           0.0.0.0:*                           108        3642       -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15370      -
    udp6       0      0 :::41919                :::*                                108        3643       -
    udp6       0      0 :::5353                 :::*                                108        3641       -
    2023-05-07 21:55:57.118  - info: host.iobroker ip addresses: 192.168.7.39 2a01:598:b1ae:5fa:d6ec:ac55:4f72:b26f fe80::aecb:962d:34de:9047 172.17.0.1 fe80::42:38ff:fe87:f417 169.254.118.22 fe80::1f6f:f0c7:c469:59da fe80::a0d4:75ff:fe52:e950
    2023-05-07 21:55:57.542  - info: host.iobroker connected to Objects and States
    2023-05-07 21:55:57.572  - info: host.iobroker Node.js version has changed from unknown to 18.16.0
    2023-05-07 21:55:57.646  - info: host.iobroker added notifications configuration of host
    2023-05-07 21:55:58.016  - info: host.iobroker 3 instances found
    2023-05-07 21:55:58.026  - info: host.iobroker starting 3 instances
    2023-05-07 21:55:58.088  - info: host.iobroker instance system.adapter.admin.0 started with pid 1850
    2023-05-07 21:56:00.382  - info: admin.0 (1850) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 21:56:00.435  - info: admin.0 (1850) requesting all states
    2023-05-07 21:56:00.437  - info: admin.0 (1850) requesting all objects
    2023-05-07 21:56:00.611  - info: admin.0 (1850) received all objects
    2023-05-07 21:56:00.641  - info: admin.0 (1850) Request actual repository...
    2023-05-07 21:56:00.657  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-05-07 21:56:00.708  - info: admin.0 (1850) http server listening on port 8081
    2023-05-07 21:56:00.709  - info: admin.0 (1850) Use link "http://localhost:8081" to configure.
    2023-05-07 21:56:00.718  - info: admin.0 (1850) socket.io server listening on port 8081
    2023-05-07 21:56:00.799  - warn: admin.0 (1850) Repository cannot be read: Active repo - stable
    2023-05-07 21:56:00.801  - warn: admin.0 (1850) Active repository "stable" cannot be read
    2023-05-07 21:56:02.066  - info: host.iobroker instance system.adapter.discovery.0 started with pid 1873
    2023-05-07 21:56:04.303  - info: discovery.0 (1873) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 21:56:06.056  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1892
    2023-05-07 21:56:08.208  - info: backitup.0 (1892) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-05-07 21:56:08.325  - info: backitup.0 (1892) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-05-07 21:56:13.804  - info: admin.0 (1850) Repository received successfully.
    2023-05-07 21:56:19.540  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    iob diag has finished.
    Press any key for a summary
    • T Tomme
      @glasfaser ja
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : v8.0.1
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
                350 M used memory
                516 M active memory
               5098 M free memory
                 79 M buffer memory
               2282 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      16M     /var/
      13M     /var/lib/dpkg
      13M     /var/lib
      2.0M    /var/cache
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        143
      States:         104
      Pending Updates: 0
      Tomme
      #223
      @tomme
      Copy text starting here:
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Docker
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        378M        5.1G        1.0M        2.4G        7.3G
      Swap:            99M          0B         99M
      Total:          7.9G        378M        5.2G
      Active iob-Instances:   4
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                143
      States:                 104
      Size of iob-Database:
      128K    /opt/iobroker/iobroker-data/states.jsonl
      root@iobroker:/opt/iobroker#
      GlasfaserG T 2 Antworten Letzte Antwort
      • T Tomme
        @tomme
                             v.2023-04-16
        Kernel:                 6.1.21-v8+
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                143
        States:                 104
        GlasfaserG Offline
        GlasfaserG Offline
        #224
        @tomme
        also ist der sudo Fehler weg !
        Dann kannst du weiter machen ....
        • T Tomme
          @tomme
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          Timezone:               Etc/UTC
          User-ID:                0
          X-Server:               false
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          MEMORY:
          Swap:            99M          0B         99M
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                143
          States:                 104
          Tomme
          #225
          @tomme das sieht doch erstmal gut aus oder?
          ich schaue gleich nach dem backup und hoffe das es danach noch geht
          das backup kriege ich jetzt aber nur über /var/lib/docker/volumes/... oder so mit suchen welche Volume Nummer rein kopiert oder?
          dazu muss ich aber mit chmod 777 /var/lib/docker die Rechte ändern sonst komme ich da nicht rein mit sftp
          • T Tomme
            GlasfaserG Offline
            GlasfaserG Offline
            #226
            @tomme
            Nichts da machen mit den Rechten !
            Jetzt kannst das Image mit volumes ( Mount ) mal testen !
              @tomme
              Tomme
              #227
              @glasfaser ich habe noch gewartet keine Sorge ...
              kann ich die 2 Zeilen nachtragen im Stack oder muss ich den schnell neu machen?
              • T Tomme
                GlasfaserG Offline
                GlasfaserG Offline
                #228
                @tomme
                ich würde den Stack neu erstellen
                  @tomme
                  Tomme
                  #229
                  @glasfaser ok das geht ja schnell und danach mache ich nochmal iob diag und wenn fehlerfrei dann hole ich das backup zurück und dann nochmal iob diag?
                  • T Tomme
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #230
                    @tomme
                    Jipp ..
                      @tomme
                      Jipp ..
                      Tomme
                      #231
                      @glasfaser das läuft doch wie ein Länderspiel ;)
                      • T Tomme
                        Tomme
                        #232
                        @tomme diag läuft sauber durch aber smbclient findet er nicht
                        da muss ich erstmal mit lokalen Backups klar kommen das mit "NAS" nehme ich erstmal wieder raus das kam durch das Backup wieder rein
                        wahrscheinlich muss ich die Source von smbclient registrieren oder?
                        root@iobroker:/opt/iobroker# apt install smbclient
                        Reading package lists... Done
                        Package smbclient is not available, but is referred to by another package.
                        This may mean that the package is missing, has been obsoleted, or
                        is only available from another source
                        E: Package 'smbclient' has no installation candidate
                        • T Tomme
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #233
                          @tomme sagte in Yahka Adapter in iobroker im Docker Container:
                          Brauchst du nicht ..
                          per Putty über pi
                          docker exec -ti iobroker /bin/bash
                            @tomme
                            Jipp ..
                            Tomme
                            #234
                            @glasfaser 230 Nachrichten ... wie kann ich das wieder gut machen?????
                            wenn ihr mal was habt zwecks KNX, LON, Loxone, Logo oder SPS Programmierung, Honeywell, Saia, Priva oder allgemein Elektrotechnik dann bitte melden da kann ich vielleicht mal helfen.
                            Vielen Dank ihr seid meine neuen Idole ;) ihr seid echt Klasse!!!
                              per Putty über pi
                              Tomme
                              #235
                              @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
                              dann bin ich root im iobroker ...
                              da nochmal apt install smbclient oder was meinst du?
                              • T Tomme
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #236
                                Das ist ein "abgespeckter root " ( Docker Container buanet ).... alles gut
                                  Tomme
                                  #237
                                  @glasfaser ist abgespeichert
                                    Tomme
                                    #238
                                    woran das nun aber lag weiß man nicht oder?
                                    einziger Unterschied ist das es vorher keine Lite Version vom Image war aber daran kann es ja nicht gelegen haben oder?
                                    • T Tomme
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #239
                                      @tomme
                                      Mhh ...
                                      Ich schreibe gerade in anderen Threads ... ( du Folgst mir auch / abonniert)
                                        @tomme
                                        Mhh ...
                                        Tomme
                                        #240
                                        @glasfaser achso dann kriege ich jedes Mal eine Meldung ok ...
                                        • T Tomme
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #241
                                          @tomme
                                          sieht dann so aus bei mir ( die andere User von mir unkenntlich gemacht ) :
