  3. Off Topic
  4. apt full-upgrade Error
    6.1k
71 Beiträge 6 Kommentatoren 6.1k Aufrufe 5 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Hallo
    Wollte eben eine VM (100 GB Disk) updaten, bekomm aber die Meldung dass zuwenig Speicher frei ist.
    nega@ubuntu:~$ sudo apt full-upgrade
    Reading package lists... Done
    Building dependency tree
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libfwupdplugin1 libxmlb1 linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic linux-modules-5.4.0-139-generic linux-modules-extra-5.4.0-139-generic
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      distro-info libatasmart4 libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libevdev2 libfwupdplugin5 libimobiledevice6 libjcat1
      libmbim-glib4 libmbim-proxy libmm-glib0 libparted-fs-resize0 libplist3 libqmi-glib5 libqmi-proxy libudisks2-0 libupower-glib3 libusbmuxd6 libvolume-key1 libxmlb2 modemmanager udisks2 upower usb-modeswitch usb-modeswitch-data
      usbmuxd
    The following packages will be upgraded:
      alsa-ucm-conf apport apt apt-transport-https apt-utils base-files bind9-dnsutils bind9-host bind9-libs bolt cloud-init cloud-initramfs-copymods cloud-initramfs-dyn-netconf command-not-found distro-info-data friendly-recovery fwupd
      fwupd-signed grub-common grub-pc grub-pc-bin grub2-common initramfs-tools initramfs-tools-bin initramfs-tools-core isc-dhcp-client isc-dhcp-common kmod landscape-common libapt-pkg6.0 libasound2 libasound2-data libc-bin libc6
      libefiboot1 libefivar1 libfwupd2 libfwupdplugin1 libglib2.0-0 libglib2.0-bin libglib2.0-data libkeyutils1 libkmod2 libnetplan0 libnl-3-200 libnl-genl-3-200 libparted2 libpci3 libprocps8 libtss2-esys0 libunwind8 libxmlb1 linux-base
      linux-firmware locales lshw lsof mongodb-org mongodb-org-mongos mongodb-org-server mongodb-org-shell mongodb-org-tools motd-news-config netplan.io open-iscsi open-vm-tools openssh-client openssh-server openssh-sftp-server
      overlayroot parted pciutils pollinate procps python-apt-common python3-apport python3-apt python3-commandnotfound python3-distupgrade python3-problem-report python3-software-properties python3-update-manager sbsigntool snapd
      software-properties-common sosreport tcpdump thermald ubuntu-advantage-tools ubuntu-keyring ubuntu-release-upgrader-core ufw unattended-upgrades update-manager-core update-notifier-common wget
    96 upgraded, 32 newly installed, 0 to remove and 0 not upgraded.
    Need to get 289 MB of archives.
    After this operation, 203 MB of additional disk space will be used.
    E: You don't have enough free space in /var/cache/apt/archives/.
    Wie finde ich den freien Speicher raus?
    ° Fixer ---> iob fix
    OliverIOO crunchipC 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      Hallo
        usbmuxd
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @negalein
      df -h
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        @negalein
        df -h
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @oliverio sagte in apt full-upgrade Error:
        df -h
        nega@ubuntu:~$ df -h
        Filesystem                         Size  Used Avail Use% Mounted on
        udev                               947M     0  947M   0% /dev
        tmpfs                              199M 1004K  198M   1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.3G     0 100% /
        tmpfs                              992M     0  992M   0% /dev/shm
        tmpfs                              5.0M     0  5.0M   0% /run/lock
        tmpfs                              992M     0  992M   0% /sys/fs/cgroup
        /dev/loop0                          64M   64M     0 100% /snap/core20/1828
        /dev/sda2                          974M  406M  501M  45% /boot
        /dev/loop2                          56M   56M     0 100% /snap/core18/2721
        /dev/loop3                          64M   64M     0 100% /snap/core20/1852
        /dev/loop1                          56M   56M     0 100% /snap/core18/2714
        /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
        /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
        /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
        /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
        tmpfs                              199M     0  199M   0% /run/user/1000
          df -h
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @negalein
          warum steht da oben "ich lehnte ab"?
          hat sich erledigt. hatte die automatische übersetzung noch drin und die versucht auch die usernamen zu übersetzen
          du kannst mal mit dem folgenden befehl schauen
          was die 10 größten dateien sind
          tree -isafF |grep -v /$|sort -k2nr|head
          falls tree nicht da ist, dann installieren (ist nur wenig)
          sudo apt install tree
          wenn es eine VM ist, im zweifel die HD vergrößern.
          da bitte nachlesen, da müssen ein paar arbeitsschritte gemacht werden.
          von 100gb sehe ich da nix
          Links im Profil
            df -h
            crunchipC Abwesend
            crunchipC Abwesend
            @negalein sagte in apt full-upgrade Error:
            das ist aber keine 100GB, eher eine 12GB VM
              @negalein
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              geht nicht wegen Platzproblem
              Hab sie heute deswegen von 30 GB auf 100 GB vergrößert.
              Da läuft nur der Unifi-Controller drauf. Das müsste locker reichen.
              beim vergrößern?
              crunchipC OliverIOO 2 Antworten Letzte Antwort
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @crunchip sagte in apt full-upgrade Error:
                  beim vergrößern?
                  crunchipC Abwesend
                  crunchipC Abwesend
                  wie?
                  eine VM kannst du nicht einfach so vergrößern, du musst die Vergrößerung dem System auch bekannt machen
                  @Negalein z.b https://beyond.lol/disk-einer-vm-vergroessern-in-proxmox/
                  Stichwort Gparted
                  NegaleinN OliverIOO 2 Antworten Letzte Antwort
                    beim vergrößern?
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @negalein
                    das ist das was ich gemeint habe
                    in der vm ist sie vergrößert
                    jetzt musst du noch in der vm das filesystem auf die neue größe anpassen.
                    es ist jetzt ungefähr so wie wenn du eine kleine festplatte auf eine größere geklont hast.
                    das betriebssystem weiß noch nix davon.
                    hier mal ein beispiel für proxmox (ohne garantie, ich weiß nicht welches vm system du hast)
                    https://beyond.lol/disk-einer-vm-vergroessern-in-proxmox/#:~:text=Als erstes loggen wir uns,man die Disk vergrössern möchte.
                    im zweiten teil wird mit gparted die partitionen angepasst und vergrößert. zur sicherheit würde ich die hdd datei der fm vorher sichern.
                    Links im Profil
                      wie?
                      Stichwort Gparted
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      wie?
                      über Synology VM-Manager
                      puhhh, kannst du da behilflich sein?
                      OliverIOO ? 2 Antworten Letzte Antwort
                        wie?
                        Stichwort Gparted
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        hehe, gleicher link gefunden
                        Links im Profil
                          wie?
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          ungern, da
                          • ich habe keine synology
                          • das ist eine operation am offenen herzen, wenn was schief geht sind deine daten weg
                          • ich das vor langer zeit zwar schonmal gemacht habe, aber mich da nur noch grob erinnere
                          • ich kein tutorial für synology vm gefunden habe
                          evtl hilft hier jemand weiter, der synology und vm kennt
                          alternativ kannst du ja mal mit einer anderen neuen kleinen vm probieren und experimentieren.
                          grob müsste es wie folgt sein
                          1. in der vm verwaltung den hdd speicher erhöhen (wobei ich würde da dynamische allokierung wählen, kenne das von virtual box)
                          2. dann auf der shell IN der VM mit gparted die partition und ggfs das logische laufwerk entsprechend vergrößern.
                            ungefähr so
                            https://dev.to/rishiabee/how-to-expand-a-linux-partition-using-gparted-31c3
                          aber alles ohne garantie.
                          für sicherung deiner vm-festplatte musst du vorher sorgen
                          falls für gparted in deiner vm kein platz ist musst du etwas löschen.
                          Links im Profil
                            ungern, da
                              ungefähr so
                            crunchipC Abwesend
                            crunchipC Abwesend
                            ich ebenfalls nicht, aber vllt hilft @Negalein https://indibit.de/ubuntu-partition-vergroessern/
                              wie?
                              Moin,
                              kommst Du noch per ssh auf die VM?
                              Wenn ja, dann mal
                              ls -la /var/log/
                              Ich vermute, dass das Filesystem mit Logs voll ist.
                              Wenn das so sein sollte, dann kann man erstmal versuchen, durch Löschen von alten Logs etwas Platz zu schaffen.
                              Aber zeig erst mal was da so im /var/log/ los ist.
                              Falls Du schon ncdu in der Vm Installiert haben solltest, dann
                              sudo ncdu /
                              VG
                              Bernd
                              NegaleinN 2 Antworten Letzte Antwort
                                Moin,
                                Wenn ja, dann mal
                                ls -la /var/log/
                                sudo ncdu /
                                VG
                                Bernd
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @dp20eic sagte in apt full-upgrade Error:
                                Ja, dauert aber noch, da ich gerade die VM sichere.
                                Ich schreib dann hier wieder.
                                  Moin,
                                  Wenn ja, dann mal
                                  ls -la /var/log/
                                  sudo ncdu /
                                  VG
                                  Bernd
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  ls -la /var/log/
                                  nega@ubuntu:~$ ls -la /var/log/
                                  total 2688
                                  drwxrwxr-x  11 root      syslog             4096 Mar 28 19:43 .
                                  drwxr-xr-x  13 root      root               4096 Jul 31  2020 ..
                                  -rw-r--r--   1 root      root               6676 Mar 21 06:28 alternatives.log
                                  -rw-r--r--   1 root      root                178 Mar  1 06:41 alternatives.log.1
                                  -rw-r--r--   1 root      root                464 Nov 16  2021 alternatives.log.10.gz
                                  -rw-r--r--   1 root      root                459 Sep 29  2021 alternatives.log.11.gz
                                  -rw-r--r--   1 root      root                131 Sep  9  2021 alternatives.log.12.gz
                                  -rw-r--r--   1 root      root                469 Jan 13 06:23 alternatives.log.2.gz
                                  -rw-r--r--   1 root      root                459 Sep 20  2022 alternatives.log.3.gz
                                  -rw-r--r--   1 root      root                461 Sep 16  2022 alternatives.log.4.gz
                                  -rw-r--r--   1 root      root                408 Apr 21  2022 alternatives.log.5.gz
                                  -rw-r--r--   1 root      root                135 Mar 16  2022 alternatives.log.6.gz
                                  -rw-r--r--   1 root      root                152 Feb 10  2022 alternatives.log.7.gz
                                  -rw-r--r--   1 root      root                459 Feb  3  2022 alternatives.log.8.gz
                                  -rw-r--r--   1 root      root                459 Jan 22  2022 alternatives.log.9.gz
                                  -rw-r-----   1 root      adm                   0 Mar 28 19:12 apport.log
                                  -rw-r-----   1 root      adm               43730 Jan 13 06:32 apport.log.1
                                  -rw-r-----   1 root      adm               58069 Jan  7 17:04 apport.log.2.gz
                                  -rw-r-----   1 root      adm                 684 Dec  3 03:49 apport.log.3.gz
                                  -rw-r-----   1 root      adm                 470 Dec  2 06:40 apport.log.4.gz
                                  -rw-r-----   1 root      adm                 724 Nov 17 16:24 apport.log.5.gz
                                  drwxr-xr-x   2 root      root               4096 Mar 28 06:03 apt
                                  -rw-r-----   1 syslog    adm               16023 Mar 28 19:43 auth.log
                                  -rw-r-----   1 syslog    adm               36481 Mar 25 23:17 auth.log.1
                                  -rw-r-----   1 syslog    adm                2451 Mar 18 23:17 auth.log.2.gz
                                  -rw-r-----   1 syslog    adm                2433 Mar 11 23:17 auth.log.3.gz
                                  -rw-r-----   1 syslog    adm                2486 Mar  4 23:17 auth.log.4.gz
                                  -rw-r--r--   1 root      root             104003 Jul 31  2020 bootstrap.log
                                  -rw-rw----   1 root      utmp                  0 Mar  1 00:00 btmp
                                  -rw-rw----   1 root      utmp                  0 Feb  1 00:00 btmp.1
                                  -rw-r-----   1 root      adm               77347 Mar 28 19:43 cloud-init-output.log
                                  -rw-r--r--   1 syslog    adm             1611408 Mar 28 19:43 cloud-init.log
                                  drwxr-xr-x   2 root      root               4096 Jul 21  2020 dist-upgrade
                                  -rw-r--r--   1 root      adm               46831 Mar 28 19:43 dmesg
                                  -rw-r--r--   1 root      adm               45680 Mar 28 18:18 dmesg.0
                                  -rw-r--r--   1 root      adm               13431 Feb  2 08:30 dmesg.1.gz
                                  -rw-r--r--   1 root      adm               13622 Jan  7 17:30 dmesg.2.gz
                                  -rw-r--r--   1 root      adm               13579 Sep  8  2022 dmesg.3.gz
                                  -rw-r--r--   1 root      adm               13612 Jul 16  2022 dmesg.4.gz
                                  -rw-r--r--   1 root      root              41016 Mar 28 06:09 dpkg.log
                                  -rw-r--r--   1 root      root              32749 Feb 28 06:35 dpkg.log.1
                                  -rw-r--r--   1 root      root               3250 May 27  2022 dpkg.log.10.gz
                                  -rw-r--r--   1 root      root               3283 Apr 30  2022 dpkg.log.11.gz
                                  -rw-r--r--   1 root      root               4089 Mar 31  2022 dpkg.log.12.gz
                                  -rw-r--r--   1 root      root               5033 Jan 27 06:30 dpkg.log.2.gz
                                  -rw-r--r--   1 root      root               3148 Dec 14 06:26 dpkg.log.3.gz
                                  -rw-r--r--   1 root      root               2291 Nov 30 07:00 dpkg.log.4.gz
                                  -rw-r--r--   1 root      root               3620 Oct 28 06:14 dpkg.log.5.gz
                                  -rw-r--r--   1 root      root               2985 Sep 27 06:43 dpkg.log.6.gz
                                  -rw-r--r--   1 root      root               2466 Aug 27  2022 dpkg.log.7.gz
                                  -rw-r--r--   1 root      root               2618 Jul 21  2022 dpkg.log.8.gz
                                  -rw-r--r--   1 root      root               4011 Jun 30  2022 dpkg.log.9.gz
                                  -rw-r--r--   1 root      root              32032 Nov 16  2020 faillog
                                  drwxr-xr-x   3 root      root               4096 Nov 14  2020 installer
                                  drwxr-sr-x+  3 root      systemd-journal    4096 Nov 14  2020 journal
                                  -rw-r-----   1 syslog    adm               57344 Mar 28 19:43 kern.log
                                  -rw-r-----   1 syslog    adm                5370 Mar 21 13:43 kern.log.1
                                  -rw-r-----   1 syslog    adm                 845 Feb 16 02:09 kern.log.2.gz
                                  -rw-r-----   1 syslog    adm                 241 Feb 10 06:40 kern.log.3.gz
                                  -rw-r-----   1 syslog    adm                 547 Feb  6 00:00 kern.log.4.gz
                                  drwxr-xr-x   2 landscape landscape          4096 Nov 16  2020 landscape
                                  -rw-rw-r--   1 root      utmp             292292 Mar 28 19:43 lastlog
                                  drwxr-xr-x   2 mongodb   mongodb            4096 Nov 16  2020 mongodb
                                  drwx------   2 root      root               4096 Jul 31  2020 private
                                  -rw-r-----   1 syslog    adm              155648 Mar 28 19:43 syslog
                                  -rw-r-----   1 syslog    adm                7422 Mar 28 00:00 syslog.1
                                  -rw-r-----   1 syslog    adm                2086 Mar 27 00:00 syslog.2.gz
                                  -rw-r-----   1 syslog    adm                1814 Mar 26 00:00 syslog.3.gz
                                  -rw-r-----   1 syslog    adm                1656 Mar 25 00:00 syslog.4.gz
                                  -rw-r-----   1 syslog    adm                1604 Mar 24 00:00 syslog.5.gz
                                  -rw-r-----   1 syslog    adm                1772 Mar 23 00:00 syslog.6.gz
                                  -rw-r-----   1 syslog    adm                3012 Mar 22 00:00 syslog.7.gz
                                  -rw-------   1 root      root                  0 Jul 31  2020 ubuntu-advantage.log
                                  drwxr-x---   2 root      adm                4096 Mar  1 00:00 unattended-upgrades
                                  drwxr-x---   3 unifi     unifi              4096 Mar 28 18:09 unifi
                                  -rw-rw-r--   1 root      utmp              58368 Mar 28 19:43 wtmp
                                  nicht installiert
                                    ls -la /var/log/
                                    total 2688
                                    nicht installiert
                                    Schau mal mit
                                     ls -S -lAh
                                    Liest sich besser.
                                      Schau mal mit
                                       ls -S -lAh
                                      Liest sich besser.
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      @thomas-braun sagte in apt full-upgrade Error:
                                      ls -S -lAh
                                      nega@ubuntu:~$  ls -S -lAh
                                      total 28K
                                      drwx------ 2 nega nega 4.0K Nov 14  2020 .cache
                                      drwx------ 3 nega nega 4.0K Mar 28 18:18 .config
                                      -rw-r--r-- 1 nega nega 3.7K Feb 25  2020 .bashrc
                                      -rw-r--r-- 1 nega nega  807 Feb 25  2020 .profile
                                      -rw------- 1 nega nega  285 Mar 28 19:12 .bash_history
                                      -rw-r--r-- 1 nega nega  220 Feb 25  2020 .bash_logout
                                      -rw------- 1 nega nega   52 Mar 28 18:17 .Xauthority
                                      -rw------- 1 nega nega    0 Mar 28 19:43 .Xauthority-n
                                      -rw-r--r-- 1 nega nega    0 Nov 14  2020 .sudo_as_admin_successful
                                        ls -S -lAh
                                        total 28K
                                        @negalein
                                        ls -lASh /var/log
                                          @negalein
                                          ls -lASh /var/log
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          ls -lASh /var/log
                                          nega@ubuntu:~$ ls -lASh /var/log
                                          total 2.7M
                                          -rw-r--r--  1 syslog    adm             1.6M Mar 28 19:44 cloud-init.log
                                          -rw-rw-r--  1 root      utmp            286K Mar 28 19:43 lastlog
                                          -rw-r-----  1 syslog    adm             152K Mar 28 19:44 syslog
                                          -rw-r--r--  1 root      root            102K Jul 31  2020 bootstrap.log
                                          -rw-r-----  1 root      adm              76K Mar 28 19:44 cloud-init-output.log
                                          -rw-rw-r--  1 root      utmp             58K Mar 28 19:44 wtmp
                                          -rw-r-----  1 root      adm              57K Jan  7 17:04 apport.log.2.gz
                                          -rw-r-----  1 syslog    adm              56K Mar 28 19:43 kern.log
                                          -rw-r--r--  1 root      adm              46K Mar 28 19:43 dmesg
                                          -rw-r--r--  1 root      adm              45K Mar 28 18:18 dmesg.0
                                          -rw-r-----  1 root      adm              43K Jan 13 06:32 apport.log.1
                                          -rw-r--r--  1 root      root             41K Mar 28 06:09 dpkg.log
                                          -rw-r-----  1 syslog    adm              36K Mar 25 23:17 auth.log.1
                                          -rw-r--r--  1 root      root             32K Feb 28 06:35 dpkg.log.1
                                          -rw-r--r--  1 root      root             32K Nov 16  2020 faillog
                                          -rw-r-----  1 syslog    adm              16K Mar 28 19:43 auth.log
                                          -rw-r--r--  1 root      adm              14K Jan  7 17:30 dmesg.2.gz
                                          -rw-r--r--  1 root      adm              14K Jul 16  2022 dmesg.4.gz
                                          -rw-r--r--  1 root      adm              14K Sep  8  2022 dmesg.3.gz
                                          -rw-r--r--  1 root      adm              14K Feb  2 08:30 dmesg.1.gz
                                          -rw-r-----  1 syslog    adm             7.3K Mar 28 00:00 syslog.1
                                          -rw-r--r--  1 root      root            6.6K Mar 21 06:28 alternatives.log
                                          -rw-r-----  1 syslog    adm             5.3K Mar 21 13:43 kern.log.1
                                          -rw-r--r--  1 root      root            5.0K Jan 27 06:30 dpkg.log.2.gz
                                          drwxr-xr-x  2 root      root            4.0K Mar 28 06:03 apt
                                          drwxr-xr-x  2 root      root            4.0K Jul 21  2020 dist-upgrade
                                          drwxr-xr-x  3 root      root            4.0K Nov 14  2020 installer
                                          drwxr-sr-x+ 3 root      systemd-journal 4.0K Nov 14  2020 journal
                                          drwxr-xr-x  2 landscape landscape       4.0K Nov 16  2020 landscape
                                          drwxr-xr-x  2 mongodb   mongodb         4.0K Nov 16  2020 mongodb
                                          drwx------  2 root      root            4.0K Jul 31  2020 private
                                          drwxr-x---  2 root      adm             4.0K Mar  1 00:00 unattended-upgrades
                                          drwxr-x---  3 unifi     unifi           4.0K Mar 28 18:09 unifi
                                          -rw-r--r--  1 root      root            4.0K Mar 31  2022 dpkg.log.12.gz
                                          -rw-r--r--  1 root      root            4.0K Jun 30  2022 dpkg.log.9.gz
                                          -rw-r--r--  1 root      root            3.6K Oct 28 06:14 dpkg.log.5.gz
                                          -rw-r--r--  1 root      root            3.3K Apr 30  2022 dpkg.log.11.gz
                                          -rw-r--r--  1 root      root            3.2K May 27  2022 dpkg.log.10.gz
                                          -rw-r--r--  1 root      root            3.1K Dec 14 06:26 dpkg.log.3.gz
                                          -rw-r-----  1 syslog    adm             3.0K Mar 22 00:00 syslog.7.gz
                                          -rw-r--r--  1 root      root            3.0K Sep 27 06:43 dpkg.log.6.gz
                                          -rw-r--r--  1 root      root            2.6K Jul 21  2022 dpkg.log.8.gz
                                          -rw-r-----  1 syslog    adm             2.5K Mar  4 23:17 auth.log.4.gz
                                          -rw-r--r--  1 root      root            2.5K Aug 27  2022 dpkg.log.7.gz
                                          -rw-r-----  1 syslog    adm             2.4K Mar 18 23:17 auth.log.2.gz
                                          -rw-r-----  1 syslog    adm             2.4K Mar 11 23:17 auth.log.3.gz
                                          -rw-r--r--  1 root      root            2.3K Nov 30 07:00 dpkg.log.4.gz
                                          -rw-r-----  1 syslog    adm             2.1K Mar 27 00:00 syslog.2.gz
                                          -rw-r-----  1 syslog    adm             1.8K Mar 26 00:00 syslog.3.gz
                                          -rw-r-----  1 syslog    adm             1.8K Mar 23 00:00 syslog.6.gz
                                          -rw-r-----  1 syslog    adm             1.7K Mar 25 00:00 syslog.4.gz
                                          -rw-r-----  1 syslog    adm             1.6K Mar 24 00:00 syslog.5.gz
