  3. Einsteigerfragen
  4. Erstinstallation Ip Adresse nicht gefunden
111 Beiträge 5 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @pmther dann jetzt nochmal die Ausgabe von
    iob diag
    diesmal aber in CODETAGS posten und nicht einfach nur wild hier einfügen...
    mehr dazu gibt es hier:
    pmther
    #81
    @djmarc75 @Thomas-Braun
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 3 Model A Plus Rev 1.0
    Architecture: 	aarch64
    Docker: 	false
    Virtualization: none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:39:35 up 42 min,  1 user,  load average: 1.04, 1.46, 4.30
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Mar 16 19:39:35 UTC 2023
    Thu Mar 16 20:39:35 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    paul
    /home/paul
    paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            419M        107M        125M        0.0K        185M        256M
    Swap:            99M         31M         68M
    Total:          519M        139M        193M
              419 M total memory
              108 M used memory
               94 M active memory
              118 M inactive memory
              125 M free memory
               10 M buffer memory
              174 M swap cache
               99 M total swap
               31 M used swap
               68 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  2.2G   26G   8% /
    devtmpfs       devtmpfs   80M     0   80M   0% /dev
    tmpfs          tmpfs     210M     0  210M   0% /dev/shm
    tmpfs          tmpfs      84M 1020K   83M   2% /run
    /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
    tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
    Messages in dmesg:
    [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    481M	/var/
    178M	/var/cache
    172M	/var/cache/apt
    147M	/var/lib
    122M	/var/lib/apt/lists
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    3.2M	/opt/iobroker/iobroker-data/
    4.0K	/opt/iobroker/iobroker-data/states.jsonl.lock
    4.0K	/opt/iobroker/iobroker-data/objects.jsonl.lock
    4.0K	/opt/iobroker/iobroker-data/backup-objects
    3.1M	/opt/iobroker/iobroker-data/objects.jsonl
    36K	/opt/iobroker/iobroker-data/states.jsonl
    8.0K	/opt/iobroker/iobroker-data/iobroker.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.19.1
    /usr/bin/node 		v16.19.1
    /usr/bin/npm 		8.19.3
    /usr/bin/npx 		8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	"javascript" not found
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
    npm ERR! invalid: iobroker.backitup@2.5.12 /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
    npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR!     /home/paul/.npm/_logs/2023-03-16T19_39_57_392Z-debug-0.log
    Adapters from github: 	0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Objects and States
    Objects: 	43
    States: 	25
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
    udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
    udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
    2023-03-16 20:26:10.242  - info: host.paul iobroker.js-controller version 4.0.24 js-controller starting
    2023-03-16 20:26:10.256  - info: host.paul Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-03-16 20:26:10.295  - info: host.paul hostname: paul, node: v16.19.1
    2023-03-16 20:26:10.298  - info: host.paul ip addresses: 192.168.178.41 2a02:8108:83c0:6be6:6e48:546e:9c43:f897 fe80::f368:a842:35d3:70a
    2023-03-16 20:26:11.530  - info: host.paul connected to Objects and States
    2023-03-16 20:26:11.639  - info: host.paul Node.js version has changed from unknown to 16.19.1
    2023-03-16 20:26:11.774  - info: host.paul Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-03-16 20:26:12.015  - info: host.paul added notifications configuration of host
    2023-03-16 20:26:13.212  - info: host.paul  no instances found
    2023-03-16 20:26:13.214  - info: host.paul no instances found
      iob diag
      pmther
      #82
      @djmarc75 Danke, so sieht es doch gleich viel besser aus :)
      • P pmther
        #83
        @pmther
        iobroker start admin
        P 1 Antwort Letzte Antwort
          @pmther
          pmther
          #84
          Cannot find any instances of "admin"!
          • P pmther
            #85
            @pmther
            Keine Ahnung was da bei dir krumm ist. Vielleicht einfach zu wenig PS...
            iobroker add admin
            iobroker list instances
            P 2 Antworten Letzte Antwort
              @pmther
              iobroker add admin
              pmther
              #86
              + system.adapter.admin.0                  : admin                 : paul                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + instance is alive
                @pmther
                iobroker add admin
                pmther
                #87
                @thomas-braun jetzt funktioniert es. endlich.. vielen vielen dank für die Geduld und Mühe! :)
                • P pmther
                  + instance is alive
                  #88
                  @pmther
                  Bitte immer vollständige Ein- und Ausgaben posten, damit man sieht wo du da wie unterwegs bist. Siehe die Installation auf dem Air von Saskia...
                    @pmther
                    pmther
                    #89
                    ja das mache ich beim nächsten mal.. danke.
                    jetzt zeigt der Biobroker mir langsame Verbindung an. Laut fritzbox wird er aber mit 390 mbit/s gespeist.. muss ich da noch etwas umstellen?
                    P wendy2702W Thomas BraunT 3 Antworten Letzte Antwort
                    • P pmther
                      pmther
                      #90
                      @pmther iobroker natürlich..
                      • P pmther
                        wendy2702W Offline
                        wendy2702W Offline
                        wendy2702
                        #91
                        @pmther Wo zeigt er das an?
                        Du vergisst das wir deinen Bildschirm nicht sehen.
                        • P pmther
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #92
                          @pmther zeig nochmal die Ausgabe von
                          iob diag
                          bitte...
                          Tippe drauf dass da jetzt schon kein Speicher mehr verfügbar ist.
                          Lehrling seit 1975 !!!
                            iob diag
                            bitte...
                            pmther
                            #93
                            @djmarc75
                            Skript v.2023-01-02
                            *** BASE SYSTEM ***
                            Docker: 	false
                            Release:	11
                            Codename:	bullseye
                            VERSION_ID="11"
                            ID=debian
                             21:10:22 up  1:12,  1 user,  load average: 0.16, 0.22, 0.89
                            CPU threads: 4
                            Thu Mar 16 20:10:22 UTC 2023
                            Thu Mar 16 21:10:22 CET 2023
                            CET +0100
                            Europe/Berlin
                            paul
                            /home/paul
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Mem:            419M        253M         93M        0.0K         72M        113M
                            Swap:            99M         95M        4.0M
                            Total:          519M        348M         97M
                                      419 M total memory
                                      253 M used memory
                                       75 M active memory
                                      183 M inactive memory
                                       93 M free memory
                                        5 M buffer memory
                                       67 M swap cache
                                       99 M total swap
                                       95 M used swap
                                        4 M free swap
                            *** FILESYSTEM ***
                            Messages in dmesg:
                            /var:
                            481M	/var/
                            178M	/var/cache
                            172M	/var/cache/apt
                            147M	/var/lib
                            4.0K	/opt/iobroker/backups/
                            18M	/opt/iobroker/iobroker-data/
                            15M	/opt/iobroker/iobroker-data/files
                            13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                            3.2M	/opt/iobroker/iobroker-data/objects.jsonl
                            2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                            1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                            652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                            /usr/bin/npm 		8.19.3
                            /usr/bin/npx 		8.19.3
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.3.5
                            Adapter State
                            + system.adapter.backitup.0               : backitup              : paul                                     -  enabled
                            + system.adapter.discovery.0              : discovery             : paul                                     -  enabled
                            + system.adapter.hue.0                    : hue                   : paul                                     -  enabled, port: 443
                            + instance is alive
                            Adapter    "hue"          : 3.7.1    , installed 3.7.1
                            Objects and States
                            Objects: 	164
                            States: 	122
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Pending Updates: 0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41198      9258/io.admin.0
                            2023-03-16 20:59:37.383  - info: host.paul iobroker host.paul object system.adapter.hue.0.memHeapTotal created
                            2023-03-16 20:59:37.404  - info: host.paul iobroker host.paul object system.adapter.hue.0.memRss created
                            2023-03-16 20:59:37.423  - info: host.paul iobroker host.paul object system.adapter.hue.0.uptime created
                            2023-03-16 20:59:37.444  - info: host.paul iobroker host.paul object system.adapter.hue.0.inputCount created
                            2023-03-16 20:59:37.474  - info: host.paul iobroker host.paul object system.adapter.hue.0.outputCount created
                            2023-03-16 20:59:37.492  - info: host.paul iobroker host.paul object system.adapter.hue.0.eventLoopLag created
                            2023-03-16 20:59:37.523  - info: host.paul iobroker host.paul object system.adapter.hue.0.sigKill created
                            2023-03-16 20:59:37.538  - info: host.paul iobroker host.paul object system.adapter.hue.0.logLevel created
                            2023-03-16 20:59:37.551  - info: host.paul iobroker host.paul object hue.0.info created
                            2023-03-16 20:59:37.565  - info: host.paul iobroker host.paul object hue.0.info.connection created
                            2023-03-16 20:59:37.586  - info: host.paul iobroker host.paul Set default value of hue.0.info.connection: false
                            2023-03-16 20:59:37.620  - info: host.paul iobroker host.paul object system.adapter.hue.0 created
                            2023-03-16 20:59:37.949  - info: backitup.0 (9434) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                            2023-03-16 20:59:38.183  - info: backitup.0 (9434) [iobroker] backup was activated at 02:40 every 1 day(s)
                            2023-03-16 20:59:38.778  - info: host.paul iobroker exit 0
                            2023-03-16 20:59:40.678  - info: host.paul instance system.adapter.hue.0 started with pid 9457
                            2023-03-16 20:59:40.852  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
                            2023-03-16 20:59:44.837  - info: hue.0 (9457) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.1, js-controller: 4.0.24
                            2023-03-16 20:59:44.897  - warn: hue.0 (9457) No bridge configured yet - please configure the adapter first
                            2023-03-16 21:01:20.805  - error: hue.0 (9457) Error on browsing via NUPNP: Problems resolving hue bridges, Request failed with status code 429
                            2023-03-16 21:01:26.662  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31
                            2023-03-16 21:02:05.344  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
                            2023-03-16 21:02:05.919  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
                            2023-03-16 21:12:39.742  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
                            2023-03-16 21:12:40.568  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
                              iob diag
                              bitte...
                              pmther
                              #94
                              @djmarc75
                              Habe gerade schon nach einem vierer geschaut. Meinst du, die 2gb Variante reicht oder ist das wieder nichts halbes und nichts ganzes?
                              wendy2702W DJMarc75D 2 Antworten Letzte Antwort
                              • P pmther
                                @djmarc75
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #95
                                @pmther Nichts halbes und nichts ganzes.
                                Meine Meinung.
                                • wendy2702W wendy2702
                                  Meine Meinung.
                                  pmther
                                  #96
                                  @wendy2702 okay, also gleich den 8er?
                                  • P pmther
                                    @djmarc75
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #97
                                    @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
                                    Ich hab mal nen 2GB als Prodsystem genutzt - nach paar Wochen dann aber nen 8GB geholt mit dem ich mehr als zufrieden bin.
                                    Bedenke:
                                    Die Ansprüche wachsen mit der Zeit und dann sind 2GB eigentlich NIX ;)
                                      Bedenke:
                                      pmther
                                      #98
                                      @djmarc75 ja gut das stimmt natürlich. dann werde ich mir wohl einen 8 gb holen. Ist bei meinem jetzt das Problem der Arbeitsspeicher?
                                      • P pmther
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #99
                                        Kurz und knapp: ja, wie am Anfang schon geschrieben ;)
                                          pmther
                                          #100
                                          @djmarc75 okay, das heißt, dass ich mit dem rein gar nichts anfangen kann im Moment?
