  4. ESPHome - erster Versuch scheitert
7 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
    speerwerfer
    ich habe einen ESP32 hier mit ESPHome versorgt. Er wird in ESPHome auch als online angezeigt. Im Log von ESPHome sehe ich aber einen Fehler:
    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/ble-temp-receiver.yaml...
    INFO Starting log output from ble-temp-receiver.local using esphome API
    INFO Successfully connected to ble-temp-receiver.local
    [18:24:16][I][app:102]: ESPHome version 2022.9.4 compiled on Mar  9 2023, 18:14:46
    [18:24:16][C][wifi:502]: WiFi:
    [18:24:16][C][wifi:360]:   Local MAC: B4:E6:2D:97:F9:5D
    [18:24:16][C][wifi:361]:   SSID: [redacted]
    [18:24:16][C][wifi:362]:   IP Address: 192.168.1.140
    [18:24:16][C][wifi:364]:   BSSID: [redacted]
    [18:24:16][C][wifi:365]:   Hostname: 'ble-temp-receiver'
    [18:24:16][C][wifi:367]:   Signal strength: -59 dB ▂▄▆█
    [18:24:16][C][wifi:371]:   Channel: 11
    [18:24:16][C][wifi:372]:   Subnet: 255.255.0.0
    [18:24:16][C][wifi:373]:   Gateway: 192.168.0.2
    [18:24:16][C][wifi:374]:   DNS1: 192.168.0.8
    [18:24:16][C][wifi:375]:   DNS2: 0.0.0.0
    [18:24:16][C][logger:275]: Logger:
    [18:24:16][C][logger:276]:   Level: DEBUG
    [18:24:16][C][logger:277]:   Log Baud Rate: 115200
    [18:24:16][C][logger:278]:   Hardware UART: UART0
    [18:24:16][C][dht:017]: DHT:
    [18:24:16][C][dht:018]:   Pin: GPIO21
    [18:24:16][C][dht:020]:   Auto-detected model: DHT11
    [18:24:16][C][dht:027]:   Update Interval: 60.0s
    [18:24:16][C][dht:029]:   Temperature 'Temperature Test'
    [18:24:16][C][dht:029]:     Device Class: 'temperature'
    [18:24:16][C][dht:029]:     State Class: 'measurement'
    [18:24:16][C][dht:029]:     Unit of Measurement: '°C'
    [18:24:16][C][dht:029]:     Accuracy Decimals: 1
    [18:24:16][C][dht:030]:   Humidity 'Humidity Test'
    [18:24:16][C][dht:030]:     Device Class: 'humidity'
    [18:24:16][C][dht:030]:     State Class: 'measurement'
    [18:24:16][C][dht:030]:     Unit of Measurement: '%'
    [18:24:16][C][dht:030]:     Accuracy Decimals: 0
    [18:24:16][C][captive_portal:088]: Captive Portal:
    [18:24:16][C][mdns:100]: mDNS:
    [18:24:16][C][mdns:101]:   Hostname: ble-temp-receiver
    [18:24:16][C][ota:089]: Over-The-Air Updates:
    [18:24:16][C][ota:090]:   Address: ble-temp-receiver.local:3232
    [18:24:16][C][ota:093]:   Using Password.
    [18:24:16][C][api:138]: API Server:
    [18:24:16][C][api:139]:   Address: ble-temp-receiver.local:6053
    [18:24:16][C][api:141]:   Using noise encryption: YES
    [18:24:25][D][api:102]: Accepted ::FFFF:C0A8:69
    [18:24:25][W][api.connection:071]: ::FFFF:C0A8:69: Socket operation failed: BAD_INDICATOR errno=11
    Im Protokoll von iobroker steht dies:
    2023-03-09 18:29:26.248 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:29:26.249 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:29:31.238 - warn: esphome.0 (7960) Client 192.168.1.140 Timeout, connection Lost, will reconnect automatically when device is available!
    2023-03-09 18:29:56.376 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:29:56.379 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:30:01.343 - warn: esphome.0 (7960) Client 192.168.1.140 Timeout, connection Lost, will reconnect automatically when device is available!
    2023-03-09 18:30:26.463 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:30:26.464 - error: esphome.0 (7960) ESPHome client 192.168.1.140 Error: Bad format. Expected 0 at the begin
    2023-03-09 18:30:31.449 - warn: esphome.0 (7960) Client 192.168.1.140 Timeout, connection Lost, will reconnect automatically when device is available!
    die Konfiguration vom ESP sieht so aus:
    esphome:
    esp32:
      board: esp32dev
      framework:
        type: arduino
    # Enable logging
    logger:
    # Enable Home Assistant API
    api:
      encryption:
        key: "sMmBZapO8u/XXXXXF3AaxPII5T2K4I0DlFxSEUXOioY="
    ota:
      password: "6bc17b5b9XXXXXd284cf36d5a73da56b"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Ble-Temp-Receiver"
        password: "neenee"
    captive_portal:
    # Example configuration entry
    sensor:
      - platform: dht
        pin: GPIO21
        temperature:
        humidity:
        update_interval: 60s
    MOD-EDIT: private Daten entfernt!
    Was mache ich falsch? Ich komme irgendwie nicht weiter, da ich nicht weiß wo der Fehler liegt. Irgendwas hab ich noch nicht verstanden.
    VG
    FredFF 1 Antwort Letzte Antwort
    • arteckA Offline
      arteckA Offline
      arteck
      @speerwerfer sagte in ESPHome - erster Versuch scheitert:
      prikelnd ist es nicht.. und es steht auch im Log..
      • arteckA arteck
        speerwerfer
        schrieb am zuletzt editiert von speerwerfer
        @arteck ich glaube nicht, das es am schlechten WLAN liegt.
        Wenn ich in der YAML zum ESP die Zeilen
        api:
          encryption:
        durch
        api:
          password: "myPassword"
        ersetze, geht es. Irgendwas stimmt bei mir mit der Einrichtung der API nicht.
        draexlerD 1 Antwort Letzte Antwort
        • S speerwerfer
          api:
            encryption:
          durch
          api:
          draexlerD Offline
          draexlerD Offline
          draexler
          @speerwerfer Ersetze mal „passwort“ durch dein Passwort und trage dieses Passwort auch noch in den Adaptereinstellungen ein.
          • draexlerD draexler
            speerwerfer
            @draexler said in ESPHome - erster Versuch scheitert:
            Hmm, ich glaube wir reden aneinander vorbei :-) Wenn ich das folgende benutze (natürlich mit einem anderen Passwort und auch in der Adaptereinstellung eingetragen)
            api:
            dann funktioniert es ja einwandfrei. Nur laut Doku ist dies deprecated. Soll also so nicht mehr gemacht werden.
            Wenn ich hingegen mit encryption und key arbeite, dann bekomme ich die Fehlermeldungen. Was muss ich tun, damit encryption funktioniert.
            • S speerwerfer
              api:
              draexlerD Offline
              draexlerD Offline
              draexler
              @speerwerfer: Du Sprichst von der ESPHOME Doku vermutlich und nicht die vom Adapter?
              Da muss man machmal ein bisschen Abstriche machen... Der Adapter hängt an ein paar stellen zurück.
              Zum Beispiel geht nur Switch und kein Button etc.
              Die YAML Prüfung wird dir keinen Fehler melden, aber halt der ioBroker ;-)
              Am besten den alten Weg verwenden und das API Passwort in die "Secret" YAML eintragen.
              • S speerwerfer
                esphome:
                esp32:
                  board: esp32dev
                  framework:
                    type: arduino
                # Enable logging
                logger:
                api:
                  encryption:
                ota:
                wifi:
                  ap:
                    password: "neenee"
                captive_portal:
                sensor:
                  - platform: dht
                    pin: GPIO21
                    temperature:
                    humidity:
                VG
                FredFF Online
                FredFF Online
                FredF
                Most Active Forum Testing
                schrieb am zuletzt editiert von FredF
                @speerwerfer
                Auszug aus der ESPHome Doku zum Thema Native API:
                Currently, only the ESPHome tool and Home Assistant use this native API.
                Ich Frage mich also für was du das brauchst beim ioBroker...
