  4. [solved] iobroker läuft, aber keine Ports in netstat
23 Beiträge 5 Kommentatoren 864 Aufrufe 4 Beobachtet
  • Y yagharek
    @thomas-braun said in iobroker läuft, aber keine Ports in netstat:
    iob upgrade all
    Läuft:
    pi@iobroker:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 2a00:6020:200:800::b916:8d0b 443]
    Reading package lists... Done
    Building dependency tree... Done
    8 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 2a00:6020:200:800::b916:8d0b 443]
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    pi@iobroker:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 3.6.0  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 1.2.4  [Updatable]
    Adapter    "email"        : 1.1.4    , installed 1.0.4  [Updatable]
    Adapter    "javascript"   : 6.1.4    , installed 4.1.13 [Updatable]
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "socketio"     : 4.2.0    , installed 6.3.3
    Adapter    "sonoff"       : 2.5.1    , installed 2.2.2  [Updatable]
    Adapter    "vis"          : 1.4.15   , installed 1.2.0  [Updatable]
    Adapter    "web"          : 4.3.0    , installed 2.4.1  [Updatable]
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.0.1  [Updatable]
    pi@iobroker:~ $ iob upgrade all
    This upgrade of "yeelight-2" will at least introduce the following changes:
    -> 1.1.2:
    Fix Joi Error
    -> 1.1.1:
    js-controller 3.3 fixes
    fixed unhandled promise rejection causing the adapter to stop
    adapter won't set power of offline devices to off anymore
    -> 1.1.0:
    add release-script update testing and dependencies
    fixed data types
    -> 1.0.4:
    fixed data types
    -> 1.0.3:
    add Pedant
    Would you like to upgrade yeelight-2 from @1.0.1 to @1.1.2 now? [(y)es, (n)o]: y
    Update yeelight-2 from @1.0.1 to @1.1.2
    NPM version: 8.19.3
    Installing iobroker.yeelight-2@1.1.2... (System call)
    added 4 packages, and changed 6 packages in 48s
    28 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.yeelight-2.0"
    upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
    upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
    upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
    upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
    upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
    upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
    upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
    upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
    upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
    upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
    upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
    upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
    upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
    upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
    upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
    upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
    upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
    upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
    upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
    upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
    upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
    This upgrade of "sonoff" will at least introduce the following changes:
    -> 2.5.1:
    Fix crash case reported by Sentry
    -> 2.5.0:
    Implement writing of NSPanel Widget changes
    -> 2.4.7:
    Fix crash case (Sentry IOBROKER-SONOFF-1S)
    -> 2.4.6:
    Fix some crash cases reported by Sentry (IOBROKER-SONOFF-B, IOBROKER-SONOFF-R, IOBROKER-SONOFF-4, IOBROKER-SONOFF-1, IOBROKER-SONOFF-13, IOBROKER-SONOFF-1J, IOBROKER-SONOFF-16, IOBROKER-SONOFF-3, IOBROKER-SONOFF-H)
    Adjust Uptime to mixed because it seems that it can be number or string
    -> 2.4.5:
    -> 2.4.4:
    Added UvaIntensity and UvbIntensity
    -> 2.4.3:
    Better type detection for non-described states
    Would you like to upgrade sonoff from @2.2.2 to @2.5.1 now? [(y)es, (n)o]: y
    Update sonoff from @2.2.2 to @2.5.1
    NPM version: 8.19.3
    Installing iobroker.sonoff@2.5.1... (System call)
    changed 1 package in 43s
    Update "system.adapter.sonoff.0"
    Update "system.adapter.sonoff.1"
    Update "system.adapter.sonoff.2"
    Update "system.adapter.sonoff.3"
    upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
    upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
    upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
    upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
    This upgrade of "email" will at least introduce the following changes:
    -> 1.1.4:
    Prepare compatibility with future js-controller versions
    -> 1.1.3:
    Make sure the STARTTLS configuration field is displayed
    -> 1.1.2:
    Fix mail.ee settings
    -> 1.1.1:
    Allow to use connections to port 25 unencrypted
    -> 1.1.0:
    Adjust default settings for web.de and 1und1 and add ionos
    Add "Always use STARTTLS" option for custom SMTP settings
    -> 1.0.10:
    Optimize for js-controller 3.3
    -> 1.0.9:
    Call message callback always with error or without
    Would you like to upgrade email from @1.0.4 to @1.1.4 now? [(y)es, (n)o]: y
    Update email from @1.0.4 to @1.1.4
    NPM version: 8.19.3
    Installing iobroker.email@1.1.4... (System call)
    @yagharek
    Und welche Datenbankpaar hast du im alten iobroker benutzt?
    • Y Offline
      Y Offline
      yagharek
      Vielen dank an alle für die Hilfe.
      Ich habe komplett übersehen, dass man nach einem "iobroker restore --force" ein iob update und iob upgrade durchführen muss.
      • Y yagharek
        wendy2702W Offline
        wendy2702W Offline
        wendy2702
        @yagharek Das muss man nur wenn das Backup und die alte Installation hoffnungslos veraltet war.
