  4. neuer Adapter webCal
306 Beiträge 27 Kommentatoren 94.3k Aufrufe 24 Beobachtet
  • Smilie108S Smilie108
    @dirkhe
    	2023-10-19 19:01:14.378	debug	check calendar(Calendar 2) event test3 test3
    webcal.0
    	2023-10-19 19:01:14.378	debug	check calendar(Calendar 2) event testevent1 Party 1
    webcal.0
    	2023-10-19 19:01:14.377	debug	check calendar(Calendar 2) event test2 test 2
    webcal.0
    	2023-10-19 19:01:14.377	debug	check calendar(Calendar 2) event test11 test11desc
    webcal.0
    	2023-10-19 19:01:14.377	debug	check calendar(Calendar 2) event test10 test10beschreibung
    webcal.0
    	2023-10-19 19:01:14.377	debug	parse calendar data: BEGIN:VCALENDAR CALSCALE:GREGORIAN VERSION:2.0 PRODID:-//IDN nextcloud.com//Calendar app 4.5.2//EN BEGIN:VEVENT CREATED:20231007T190321Z DTSTAMP:20231019T165936Z LAST-MODIFIED:20231019T165936Z SEQUENCE:5 UID:b63b012e-1673-4a62-8698-63819f3325c2 DTSTART;VALUE=DATE:20231021 DTEND;VALUE=DATE:20231022 STATUS:CONFIRMED SUMMARY:test3 LOCATION:test3 DESCRIPTION:test3 END:VEVENT END:VCALENDAR
    webcal.0
    	2023-10-19 19:01:14.376	debug	parse calendar data: BEGIN:VCALENDAR CALSCALE:GREGORIAN VERSION:2.0 PRODID:-//IDN nextcloud.com//Calendar app 4.5.2//EN BEGIN:VEVENT CREATED:20231007T190241Z DTSTAMP:20231019T165929Z LAST-MODIFIED:20231019T165929Z SEQUENCE:4 UID:56f98133-3156-446d-9c33-0688ef987e5f DTSTART;VALUE=DATE:20231020 DTEND;VALUE=DATE:20231021 STATUS:CONFIRMED SUMMARY:testevent1 LOCATION:Zuhause 1 DESCRIPTION:Party 1 END:VEVENT END:VCALENDAR
    webcal.0
    	2023-10-19 19:01:14.376	debug	parse calendar data: BEGIN:VCALENDAR CALSCALE:GREGORIAN VERSION:2.0 PRODID:-//IDN nextcloud.com//Calendar app 4.5.2//EN BEGIN:VEVENT CREATED:20231007T190301Z DTSTAMP:20231019T165927Z LAST-MODIFIED:20231019T165927Z SEQUENCE:4 UID:fc188c0d-0ed5-46ea-a28f-f34f88952ada DTSTART;TZID=Europe/Vienna:20231019T100000 DTEND;TZID=Europe/Vienna:20231019T110000 STATUS:CONFIRMED SUMMARY:test2 LOCATION:test 2 DESCRIPTION:test 2 END:VEVENT BEGIN:VTIMEZONE TZID:Europe/Vienna BEGIN:DAYLIGHT TZOFFSETFROM:+0100 TZOFFSETTO:+0200 TZNAME:CEST DTSTART:19700329T020000 RRULE:FREQ=YEARLY;BYMONTH=3;BYDAY=-1SU END:DAYLIGHT BEGIN:STANDARD TZOFFSETFROM:+0200 TZOFFSETTO:+0100 TZNAME:CET DTSTART:19701025T030000 RRULE:FREQ=YEARLY;BYMONTH=10;BYDAY=-1SU END:STANDARD END:VTIMEZONE END:VCALENDAR
    webcal.0
    	2023-10-19 19:01:14.375	debug	parse calendar data: BEGIN:VCALENDAR CALSCALE:GREGORIAN VERSION:2.0 PRODID:-//IDN nextcloud.com//Calendar app 4.5.2//EN BEGIN:VEVENT CREATED:20231008T192341Z DTSTAMP:20231019T165933Z LAST-MODIFIED:20231019T165933Z SEQUENCE:3 UID:f89c2100-43f6-4929-99f6-656eec5f2cec DTSTART;TZID=Europe/Vienna:20231020T100000 DTEND;TZID=Europe/Vienna:20231020T110000 STATUS:CONFIRMED SUMMARY:test11 LOCATION:test11loc DESCRIPTION:test11desc END:VEVENT BEGIN:VTIMEZONE TZID:Europe/Vienna BEGIN:DAYLIGHT TZOFFSETFROM:+0100 TZOFFSETTO:+0200 TZNAME:CEST DTSTART:19700329T020000 RRULE:FREQ=YEARLY;BYMONTH=3;BYDAY=-1SU END:DAYLIGHT BEGIN:STANDARD TZOFFSETFROM:+0200 TZOFFSETTO:+0100 TZNAME:CET DTSTART:19701025T030000 RRULE:FREQ=YEARLY;BYMONTH=10;BYDAY=-1SU END:STANDARD END:VTIMEZONE END:VCALENDAR
    webcal.0
    	2023-10-19 19:01:14.373	debug	parse calendar data: BEGIN:VCALENDAR CALSCALE:GREGORIAN VERSION:2.0 PRODID:-//IDN nextcloud.com//Calendar app 4.5.2//EN BEGIN:VEVENT CREATED:20231008T192317Z DTSTAMP:20231019T165940Z LAST-MODIFIED:20231019T165940Z SEQUENCE:3 UID:7dabc7cf-0499-40ab-868f-3161fc60ba1f DTSTART;VALUE=DATE:20231022 DTEND;VALUE=DATE:20231023 STATUS:CONFIRMED SUMMARY:test10 LOCATION:test10 ort DESCRIPTION:test10beschreibung END:VEVENT END:VCALENDAR
    webcal.0
    	2023-10-19 19:01:14.372	info	found 5 calendar objects
    webcal.0
    	2023-10-19 19:00:58.053	debug	update addEvent-states
    webcal.0
    	2023-10-19 19:00:56.094	info	fetch calendar data all 60 minutes
    webcal.0
    	2023-10-19 19:00:56.052	info	init events
    webcal.0
    	2023-10-19 19:00:56.026	info	starting. Version 1.2.0 (non-npm: dirkhe/ioBroker.webcal#04f93e3e29dc6678cfdad495a49ded0414ad0a73) in /opt/iobroker/node_modules/iobroker.webcal, node: v18.17.1, js-controller: 5.0.14
    aber bei den ojekten webcal.0.events is dann nichts drin.
    D Nicht stören
    D Nicht stören
    dirkhe
    #141
    @smilie108 was hast du denn für events definiert, bzw. welche regex's?
    Smilie108S 1 Antwort Letzte Antwort
    • D dirkhe
      Smilie108S Offline
      Smilie108S Offline
      Smilie108
      schrieb am zuletzt editiert von Smilie108
      #142
      @dirkhe hi hab nur die daten von der cloud eingegebne ;) muss ich da sonst auch noch was machen ? dachte er wandelt die events inein vom kalender lesbares format gibts da ne anleitung ?
        D Nicht stören
        D Nicht stören
        dirkhe
        #143
        @smilie108 du kannst mehrere kalender definieren, die werden alle eingelesen, dann musst du events definieren, in der regel nimmt man den namesn des eintrags, wie "restmüll" oder so. Diese events Fischt er dann aus deinen kalendern und schrejbt das in die datenpunkte
        • D dirkhe
          Smilie108S Offline
          Smilie108S Offline
          Smilie108
          #144
          @dirkhe ah ok dachte er schreibt mir alle termine rein ok thx nur als hinweis auf iobrocker und im adapterverzeichniss ist da swebcal nicht mehr drinnen.
          gibt das da beispiele wie das geht ? oder geht das auch mit wildcard * ? habe da zb nur einen Kalender für alles was haus betrifft deswegen kann er da alles anzeigen
          danek im voraus
            danek im voraus
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #145
            @smilie108
            du musst " .* " schreiben - dann holt er alles
            • D Nicht stören
              D Nicht stören
              dirkhe
              #146
              @liv-in-sky ja das geht natürlich mit *. Ist halt nur die frage, wie sinnhaft das ist. Es geht ja eigentlich darum, im iobroker für ein bestimmtes event, zb redtmüll oder urlaubsreise odervwas auch immer, die db now, tomorrow usw. Zu haben, um damit in scrpten zu reagieren etc.
              liv-in-skyL Smilie108S 2 Antworten Letzte Antwort
              • D dirkhe
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                #147
                @dirkhe du weißt doch - ich "missbrauche" deinen adapter :-) :-) :-)
                • D dirkhe
                  Smilie108S Offline
                  Smilie108S Offline
                  Smilie108
                  #148
                  @dirkhe sorry teilweise recht aber man kann wie bei mir zb der einen eigenen server besitzt im netz mit unter anderem nextcloud drauf einen Kalender fürs haus machen wo du alle termine bekommst und dementsprechend als liste anzeigen kannst. nicht nur müllkübel sondern auch zb kommt zähler ablesen oder anderes und das ganze haben auch alle familenmitglierder am handy da dort auch mehrere kalender verknüpft sind und termine werden in den Kalender eingetragen dens betrifft. und jeder der wie meine frau oder ich bei meiner frau bekommt die dementsprechenden freigaben. und gesammelt zb wieder eben auch fürs haus :) deswegen
                  mfg
                  • liv-in-skyL liv-in-sky
                    Smilie108S Offline
                    Smilie108S Offline
                    Smilie108
                    #149
                    @liv-in-sky ;) ja das mit .* geht gut so @dirkhe habe grad nochmal alles nachgelesen als das mit dem jason string wäre echt genjal vor allem wenn es dann so wäre das er mit ioBroker.vis-materialdesign#calendar zusammenarbeiten würde eventeuell via schaltfeld brauch json oder so ;) das wäre der hammer
                    Aber danke soweit mal bekomme wenigsten jetzt mal die tabele für die nächsten termine ;)
                      Smilie108S Offline
                      Smilie108S Offline
                      Smilie108
                      #150
                      @liv-in-sky @dirkhe mhm jetzt bin ich etwas verwirrt.
                      Habe das https://forum.iobroker.net/topic/35791/html-tabelle-calendar-adapter/59 ausprobiert.
                      Die im Post 1 vorhandene Version macht die Tabelle zwar nicht ganz richtig aber ich bekomme sie.
                      Habe dann weiter unten die andere version probiert (wo du die Tage hinzugefügt hast) und da ist ja das mit json mit drinnen.
                      Dachte das du hattest das als ausgabe hinzugefügt oder war die Annahme falsch weil die 2 version geht garnicht .
                      Echt Schade das es eigentlich nichts gibt mit dem die Nextcloud vernünftig eingebunden werden kann.
                      oder seh ich den wald vor lauter bäumen nicht ?
                      Danke an euch für die ganze Arbeit die ihr macht ;)
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        liv-in-sky
                        #151
                        @smilie108 jetzt verwirrst du mich etwas
                        das erwähnte script von dir ist nicht für diesen adapter gemacht - es gehört zu einem anderen adapter
                        am einfachsten ist die anzeige in der vis mit dem inventwo json widget - die inventwo widgets musst du installieren - in vis1 - funktionieren noch nicht in vis2
                        das ist ein beispiel von dem json des webcal adapters
                        das widget zum import für webcal.0 instanz
                        [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"20","iTableRefreshRate":"0","iTblSortOrder":"asc","iColCount":"7","iColShow1":false,"iTblHeadTextAlign1":"center","iTblTextAlign1":"left","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"#479de6","iTblRowUnevenColor":"#8dadb9","iTblHeaderColor":"#333333","iRowSpacing":"10","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"0","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"webcal.0.events.termine.data","iColShow2":true,"iTblHeadTextAlign2":"center","iTblTextAlign2":"left","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":true,"iTblHeadTextAlign3":"center","iTblTextAlign3":"left","iTblCellFormat3":"datetime","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iColShow4":"true","iTblHeadTextAlign4":"center","iTblTextAlign4":"left","iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblCellThresholdsDp4":"","iTblCellThresholdsText4":"","iColShow5":"true","iTblHeadTextAlign5":"center","iTblTextAlign5":"left","iTblCellFormat5":"normal","iTblCellImageSize5":"200","iTblCellBooleanCheckbox5":"false","iTblCellBooleanColorFalse5":"#ff0000","iTblCellBooleanColorTrue5":"#00ff00","iTblCellNumberDecimals5":"2","iTblCellNumberDecimalSeperator5":".","iTblCellNumberThousandSeperator5":",","iTblCellThresholdsDp5":"","iTblCellThresholdsText5":"","iColShow6":"true","iTblHeadTextAlign6":"center","iTblTextAlign6":"left","iTblCellFormat6":"normal","iTblCellImageSize6":"200","iTblCellBooleanCheckbox6":"false","iTblCellBooleanColorFalse6":"#ff0000","iTblCellBooleanColorTrue6":"#00ff00","iTblCellNumberDecimals6":"2","iTblCellNumberDecimalSeperator6":".","iTblCellNumberThousandSeperator6":",","iTblCellThresholdsDp6":"","iTblCellThresholdsText6":"","iColShow7":"true","iTblHeadTextAlign7":"center","iTblTextAlign7":"left","iTblCellFormat7":"normal","iTblCellImageSize7":"200","iTblCellBooleanCheckbox7":"false","iTblCellBooleanColorFalse7":"#ff0000","iTblCellBooleanColorTrue7":"#00ff00","iTblCellNumberDecimals7":"2","iTblCellNumberDecimalSeperator7":".","iTblCellNumberThousandSeperator7":",","iTblCellThresholdsDp7":"","iTblCellThresholdsText7":"","iTblCellDatetimeFormat3":"d M"},"style":{"left":"891px","top":"382px","font-size":"small","width":"880px","height":"520px"},"widgetSet":"vis-inventwo"}]
                          Smilie108S Offline
                          Smilie108S Offline
                          Smilie108
                          #152
                          @liv-in-sky ok dann werde ich wohl noch warten müssen und einstweilen mit meiner tabelle begnügen da ich ja auf vis-2 bin und nicht zurück kann ;)
                          Aber danke trotzdem für die info ;)
                          Mfg
                            Mfg
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            #153
                            @smilie108
                            würde dir so eine tabelle für deine vis2 helfen? ist aus webcal.0...
                              @smilie108
                              Smilie108S Offline
                              Smilie108S Offline
                              Smilie108
                              #154
                              @liv-in-sky Ja sogar sehr
                                Mfg
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                #155
                                @smilie108
                                du musst zeile 9 und 10 anpassen - dann ein html widget mit binding auf den in zeile 9 dp
                                script:
                                //@liv-in-sky 2020 21.1023.-07:48
                                const path = "/htmlexample.html";                   //FIlenamen definieren
                                let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                                let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                let dpVIS="0_userdata.0.CONTROL-OWN.AAATEST.TestHTML"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                let dataPointWebCal="webcal.0.events.termine.data"
                                let mySchedule1=" */10 * * * * ";                       //jede minute
                                //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
                                var htmlFeld1='EVENT';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                                var htmlFeld2='DATE';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                var htmlFeld3='FROM';         var Feld3lAlign="left";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                var htmlFeld4='TO';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
                                var htmlFeld5='IN ...';        var Feld5lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                                //ÜBERSCHRIFT ÜBER TABELLE
                                let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                                let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                const htmlFeldUeber='ioBroker Instanzen';              // Überschrift und Signature
                                const htmlFarbUber="white";                         // Farbe der Überschrift
                                const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                                let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                const farbetrennungsLinie="white";
                                const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                //ÜBERSCHRIFT SPALTEN
                                const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                                const farbeLinieUnterUeberschrift="white";
                                const groesseUeberschrift=16;
                                const UeberschriftStyle="normal"                     // möglich "bold"
                                //GANZE TABELLE
                                let abstandZelle="3";
                                let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                let weite="450";                                     //Weite der Tabelle
                                const htmlSchriftart="Helvetica";
                                const htmlSchriftgroesse="15px";
                                //FELDER UND RAHMEN
                                const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                                const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                // HIER NICHTS  ÄNDERN
                                let borderHelpBottum;
                                let borderHelpRight;
                                let htmlcenterHelp;
                                let htmlcenterHelp2;
                                const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                      "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                const htmlTabUeber3="</tr>";
                                //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
                                var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td>";
                                var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                                                   "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                                                   "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld5+"&ensp;</td>";
                                var htmlOut="";
                                var mix;
                                var counter;
                                var val1; var val2; var val0; var val3; var val4;
                                var htmlTabUeber="";
                                function writeHTML(){
                                htmlOut="";
                                counter=-1;
                                htmlTabUeber="";
                                switch (mehrfachTabelle) {
                                   case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                                //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
                                let mySelktor=JSON.parse(getState(dataPointWebCal).val)
                                for (let i=0;i<mySelktor.length;i++) {           // hier eigene schleife definieren
                                       // var ida = id.split('.');
                                      //   if(existsState(id) && existsState(id.replace("StandortBlitzer","Abfahrt")) && existsState(id.replace("StandortBlitzer","Destination"))) {
                                          counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                          val0=mySelktor[i].summary
                                          val1=formatDate(getDateObject(mySelktor[i].date), "TT")+' '+formatDate(getDateObject(mySelktor[i].date), "O", "de")
                                          val2=mySelktor[i].startTime
                                          val3=mySelktor[i].endTime
                                          val4=mySelktor[i].dateText.replace("in ","").replace(" Tagen","")
                                     tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                   }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                } // function ende
                                //MAIN:
                                schedule(mySchedule1,  function () {
                                 writeHTML();
                                 if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                 writeHTML();
                                   				 function tabelleBind(){
                                     //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                                         case 1:  if(counter%2==0) {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>"; break; } else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>"; break; }
                                        case 2: if(counter%4==0){
                                                   if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld5lAlign+">"+val4+"</td>"; }
                                                              else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>";} break;
                                               }else{
                                                              if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                                              else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val4+"</td></tr>";} break;}
                                        case 3:  if(counter%2==0)   {
                                                 if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td  align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                                              else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td align="+Feld5lAlign+">"+val4+"</td></tr>";}
        } break;} else{
                                                 if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>"; }
                                                              else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
        } break; }
                                        case 4:  if(counter%8==0)   {
                                                 if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val4+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val3+"</td>"; }
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">"+val4+"</td>";}
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val3+"</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val4+"</td></tr>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val4+"</td>";}}
        } break;} else{
                                                 if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td><td align="+Feld4lAlign+">"+val3+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld5lAlign+">"+val3+"</td>"; }
        } break; }
                                     } //switch ende
                                function tabelleFinish() {
                                      // tabelle fertigstellen
                                       case 1:    break;
                                       case 2:
                                                  if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                  break;
                                       case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                 if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                 if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                  break;
                                       case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                 if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                 if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                 if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                 break; }
                                                    var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                           var htmlOutVIS="";
                                            if (htmlUberschrift)
                                                { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                              } else {
                                               zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                 //log(htmlOut);
                                • D Nicht stören
                                  D Nicht stören
                                  dirkhe
                                  schrieb am zuletzt editiert von dirkhe
                                  #156
                                  @smilie108 das gesamt-json muss ich noch machen, ist noch nicht fertig.
                                  Was mich halt wundert warum ihr das in iobroker vis braucht. Die Termine an sich kann man doch auch ganz normal im handykakender anzeigen? Also ich habe einen eugenen nectcloud kalender für smarthome, einen für mich, meine Frau und meinem Sohn und Familie. Diese werden halt ganz normal im handy gehandhabt und mit verschiedenen farben dargestellt und alerts nur auf bedtimmte kalender angelegt. Im iobroker habe ich nur den smarthome drin, weil ich da azf bestimmte events, wie zb. Ob jemand das Büro nutzt (heizung an/aus), oder ob wir auf urlaubsreise sind. Das ging auch alles mit dem ical adapter schon, was mich gestört hattem war dasman beim anlegen von neuen events immer darauf achten musste, sas man einträgt, daher habe ich jetzt den webcal programmiert, der auch schreiben kann, und damit das event per knopfdruck immer korrekt erzeugt.
                                  liv-in-skyL Smilie108S 3 Antworten Letzte Antwort
                                  • D dirkhe
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #157
                                    @dirkhe damit ich in der küche den kalender ansehen kann, ohne immer das handy zur hand zu nehmen
                                    • D dirkhe
                                      Smilie108S Offline
                                      Smilie108S Offline
                                      Smilie108
                                      #158
                                      @dirkhe mhm jap am handy stimmt aber wenn ich schon eine Visu fürs ganze haus mache kann ich das mit reinnehmen und sehe dann die ansehenden termine auf einem Richtigen bildschirm ;)
                                      Die kleinen Handybildschirme siind ja jetzt für visus nicht so toll ;)
                                      • D dirkhe
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        #159
                                        @dirkhe sagte in Test neuer Adapter webCal:
                                        und dafür bin ich dankbar -ein cooles feature - einträge löschen wäre halt noch schön :-)
                                        ich nutze webcal nur für die eingabe in einen google kalender - leider ist mir das ganze google-api zeugs zu komplex - daher mal die frage
                                        hast du nicht lust und zeit, deinen adapter so umzubauen, dass man nur den google kalender nutzen kann - fürs eingeben und löschen von einträgen - und das dann zu einem neuen adapter zu machen
                                        für den calender adapter war das mal geplant - der wird aber leide nicht mehr gepflegt (https://github.com/WLAN-Kabel/ioBroker.calendar)
                                          D Nicht stören
                                          D Nicht stören
                                          dirkhe
                                          #160
                                          @liv-in-sky das löschen könnte man schon hinzufügen, denke ich, aber im prinzip würde das dann nur per sendto gehen, weil ich nicht wüsste, wie man sowas in datenpunkte reinbringen sollte, oder man müsste die als flache lixte machen, also pro event ein datenpunkt... aber ob das so schön ist.
                                          man könnte einen dp machen "deleteById" oder so. Muss ich mir mal anschauen.
