  5. Datapoint influxdb per script aktivieren
3 Beiträge 2 Kommentatoren 466 Aufrufe 2 Beobachtet
    Adrian
    Hallo
    Wie kann ich wenn ich einen Datenpunkt erstelle, gleich auch die Datenbankverknüpfung automatisch aktivieren ?
    "common": {
    "name": "",
    "type": "number",
    "role": "state",
    "read": true,
    "write": true,
    "desc": "Manuell erzeugt",
    "def": 0,
    "unit": "kWh",
    "custom": {
    "influxdb.0": {
    "enabled": true,
    "storageType": "",
    "aliasId": "",
    "debounceTime": 0,
    "blockTime": 0,
    "changesOnly": true,
    "changesRelogInterval": 0,
    "changesMinDelta": 0,
    "ignoreBelowNumber": "",
    "disableSkippedValueLogging": false,
    "enableDebugLogs": false,
    "debounce": 1000
    • A Adrian
      Hallo
      "common": {
      "name": "",
      "type": "number",
      "role": "state",
      "read": true,
      "write": true,
      "def": 0,
      "unit": "kWh",
      "custom": {
      "influxdb.0": {
      "enabled": true,
      "storageType": "",
      "aliasId": "",
      "debounceTime": 0,
      "blockTime": 0,
      "debounce": 1000
      @adrian
      Man kann an createState() das komplette Objekt common übergeben.
      const id = '0_userdata.0.xyz';
      const myName = 'mein Name';
      const common = {
          type: "number",
          role: "value",
          read: true,
          write: false,
          desc: "per Skript erzeugt",
          def: 0,
          unit: "kWh",
          custom: {
              "influxdb.0": {
                  enabled: true,
                  storageType: "",
                  aliasId: "",
                  debounceTime: 0,
                  blockTime: 0,
                  changesOnly: true,
                  changesRelogInterval: 0,
                  changesMinDelta: 0,
                  ignoreBelowNumber: "",
                  disableSkippedValueLogging: false,
                  enableDebugLogs: false,
                  debounce: 1000
      createState(id, 0, common);
      A 1 Antwort Letzte Antwort
        @adrian
        const common = {
            type: "number",
            role: "value",
            read: true,
            write: false,
            def: 0,
            unit: "kWh",
            custom: {
                "influxdb.0": {
                    enabled: true,
                    storageType: "",
                    aliasId: "",
                    debounceTime: 0,
                    blockTime: 0,
                    changesOnly: true,
                    changesMinDelta: 0,
                    debounce: 1000
        Adrian
        @paul53 Vielen Dank. Funktioniert.
        Erspart mir Stunden um alles händisch zu aktivieren
