  5. Roborock Adapter tester gesucht
    5.8k
766 Beiträge 51 Kommentatoren 310.8k Aufrufe 52 Beobachtet
  • D DonToben
    @copystring
    Könntest du dir das bitte ansehen.
    Gerade ein Update der Fritzbox gemacht. Danach hat iobroker den Roborock Adapter automatisch angehalten wegen zu vieler Neustarts.
    Kannst du dir das erklären?
    -03-24 09:00:11.217 - warn: roborock.0 (29551) MQTT connection close.
    2023-03-24 09:00:11.222 - warn: roborock.0 (29551) MQTT connection reconnect.
    2023-03-24 12:00:11.212 - warn: roborock.0 (29551) MQTT connection close.
    2023-03-24 12:00:11.213 - warn: roborock.0 (29551) MQTT connection reconnect.
    2023-03-24 15:00:11.213 - warn: roborock.0 (29551) MQTT connection close.
    2023-03-24 15:00:11.214 - warn: roborock.0 (29551) MQTT connection reconnect.
    2023-03-24 16:33:11.623 - warn: roborock.0 (29551) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.carpet_clean_mode" has no existing object, this might lead to an error in future versions
    2023-03-24 17:14:41.533 - error: roborock.0 (29551) MQTT connection offline: undefined
    2023-03-24 17:14:41.534 - warn: roborock.0 (29551) MQTT connection close.
    2023-03-24 17:14:42.534 - warn: roborock.0 (29551) MQTT connection reconnect.
    2023-03-24 17:14:47.446 - error: roborock.0 (29551) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-24 17:14:47.447 - error: roborock.0 (29551) unhandled promise rejection: getaddrinfo EAI_AGAIN api-eu.roborock.com
    2023-03-24 17:14:47.449 - error: roborock.0 (29551) Error: getaddrinfo EAI_AGAIN api-eu.roborock.com
    at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:825:14)
    at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.roborock/node_modules/axios/dist/node/axios.cjs:2973:25)
    at RedirectableRequest.emit (node:events:513:28)
    at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
    at ClientRequest.emit (node:events:513:28)
    at TLSSocket.socketErrorListener (node:_http_client:494:9)
    at TLSSocket.emit (node:events:513:28)
    at emitErrorNT (node:internal/streams/destroy:157:8)
    at emitErrorCloseNT (node:internal/streams/destroy:122:3)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
    2023-03-24 17:14:47.450 - error: roborock.0 (29551) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api-eu.roborock.com
    2023-03-24 17:14:47.458 - info: roborock.0 (29551) terminating
    2023-03-24 17:14:47.460 - warn: roborock.0 (29551) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-24 17:15:04.040 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-24 17:15:04.042 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-24 17:15:05.269 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24330
    2023-03-24 17:15:08.304 - info: roborock.0 (24330) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-03-24 17:15:30.675 - error: roborock.0 (24330) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-24 17:15:30.677 - error: roborock.0 (24330) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:30.682 - error: roborock.0 (24330) Error: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:30.683 - error: roborock.0 (24330) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:30.694 - info: roborock.0 (24330) terminating
    2023-03-24 17:15:30.697 - warn: roborock.0 (24330) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-24 17:15:31.326 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-24 17:15:31.327 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-24 17:15:32.473 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 24384
    2023-03-24 17:15:35.563 - info: roborock.0 (24384) starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-03-24 17:15:55.287 - error: roborock.0 (24384) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-03-24 17:15:55.288 - error: roborock.0 (24384) unhandled promise rejection: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:55.290 - error: roborock.0 (24384) Error: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:55.292 - error: roborock.0 (24384) Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND euiot.roborock.com
    2023-03-24 17:15:55.299 - info: roborock.0 (24384) terminating
    2023-03-24 17:15:55.301 - warn: roborock.0 (24384) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-03-24 17:15:55.944 - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-03-24 17:15:55.945 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2023-03-24 17:15:55.945 - warn: host.raspberrypi Do not restart adapter system.adapter.roborock.0 because restart loop detected
    copystringC Offline
    copystringC Offline
    copystring
    #501
    @dontoben ich weiß nicht was ich da machen kann. Deine dns Auflösung funktioniert nicht.
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • M Menfis
      @copystring nein, nein. Ich meinte bei anderen Usern.
      copystringC Offline
      copystringC Offline
      copystring
      #502
      @menfis tu mir einen Gefallen und mach bitte eine issue auf GitHub. Ist sonst ein bisschen durcheinander hier Forum. Dann kann ich mir das genauer angucken.
      • copystringC copystring
        DonToben
        #503
        @copystring said in Roborock Adapter tester gesucht:
        Ist halt blöd, dass der Adapter angehalten wird, wenn die Internetverbindung eine gewisse Zeit nicht vorhanden ist.
        Muss das mal beobachten. Das Problem hat nur der Roborock Adapter. Kann man das im iobroker irgendwo deaktivieren?
        copystringC 1 Antwort Letzte Antwort
        • D DonToben
          copystringC Offline
          copystringC Offline
          copystring
          #504
          @dontoben ach so. Jetzt weiß ich was du meinst. Ja, dann musst euch das irgendwie abfangen. Wäre Klasse, wenn du dafür ein issue auf GitHub öffnen würdest, damit das nicht untergeht. Ich muss dann Mal schauen wie ich Zeit dafür finden kann.
          • wendy2702W Online
            wendy2702W Online
            wendy2702
            #505
            Habe gerade mal wegen einem anderen Thema mein Log durchgesehen und bin auf diese Meldungen gestossen: Version 0.1.6
            Leider nur als text da zu viele Zeichen.
            Soll ich ein Issue aufmachen oder ist das schon bekannt?
            roborock.txt
            • wendy2702W wendy2702
              roborock.txt
              copystringC Offline
              copystringC Offline
              copystring
              #506
              @wendy2702 Das ist schon bekannt und in der dev bereits behoben. Ich brauche noch ein bisschen Zeit für den nächsten Release weil die integrierung der Kamera vom den MaxV Robotern noch nicht geht fertig ist. ;)
              wendy2702W David G.D 2 Antworten Letzte Antwort
                wendy2702W Online
                wendy2702W Online
                wendy2702
                #507
                @copystring OK, Danke für die Info.
                Dann warte ich mal auf den nächsten Release.
                  David G.D Online
                  David G.D Online
                  David G.
                  #508
                  @copystring sagte in Roborock Adapter tester gesucht:
                  Das hört sich interessant an^^.
                  Gibt's schon was neues zu dem wasserfilter und der Reinigungdbürste in der Station?
                  Wenn das drinnen ist, kann man eigentlich komplett ohne App arbeiten.
                  • David G.D David G.
                    copystringC Offline
                    copystringC Offline
                    copystring
                    #509
                    @david-g said in Roborock Adapter tester gesucht:
                    Nein. Ich bin mir immer noch unschlüssig darüber, ob ich sowas einbauen soll oder nicht. Aktuell bietet der Adapter ausschließlich Werte an, welche von Roborock direkt bereitgestellt werden. Die Werte für die Station müssten allerdings errechnet werden. Das könnte man tatsächlich auch außerhalb des Adapters erledigen. Es ist schlussendlich eine Frage der Gestaltung des Adapters und über die bin ich mir diesbezüglich noch unsicher.
                    • copystringC Offline
                      copystringC Offline
                      copystring
                      schrieb am zuletzt editiert von copystring
                      #510
                      Wer mag, kann die neue dev testen. Dort wird die Kamera für MaxV Modelle unterstützt.
                      Das sieht dann so aus:
                      Wichtig! Man muss in den Optionen die IP oder den Hostname eingeben, auf dem ioBroker läuft, damit die URLs/URI sauber erstellt werden kann.
                      Auch die PIN für das Freischalten der Kamera muss abgespeichert werden. Diese muss dann noch vom Wischcode in Zahlen übersetzt werden.
                      Außerdem kann die Karte über das Webinterface mit dem Mausrad größer und kleiner gemacht werden. Verschieben lässt sie sich ebenfalls.
                      Ich bin mir sicher, dass es noch Bugs hat! Daher bitte ich euch dafür entsprechend ein Issue auf Github zu öffnen. Das macht es für mich deutlich einfacher, die Fehler bearbeiten. Ich bedanke mich schon mal fürs Testen.
                      https://github.com/copystring/ioBroker.roborock/tree/dev
                      Achtung: Gebt bitte niemanden (auch nicht mir) NIEMALS den Inhalt von go2rtcConfig! Damit könnte jeder eure Kamera aufrufen.
                      • David G.D Online
                        David G.D Online
                        David G.
                        #511
                        Gibt es denn für beide Werte einen Datenpunkt oder etwas was ich per Skript weiterverarbeiten kann?
                        Oder anders, vorhanden sind die Datenpunkte. Aber leer.
                        cleaning_brush_work_times
                        haben wir ja schon mit Werten im Log gefunden.
                        filter_element_work_time
                        liefert dort allerdings nur eine 0.
                        Das werde ich heute definitiv mal machen
                        Edit
                        Die Kamera bekomme ich nicht ans laufen.
                        Bei mir wird nur der Datenpunkt rstp gefüllt.
                        Den Stream bekomme ich mit dem vlc nicht abgespielt.
                        Pin ist eingegeben, Kartendarstellung deaktiviert und der Roboter aus der Basis herausgefahren.
                        Den hab ich im Log gefunden:
                        roborock.0
                        2023-03-27 06:50:05.525	error	Error executing fileError: spawn /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc ENOENT
                        Auch eine pi/32bit Geschichte?
                          Dimi
                          #512
                          @copystring
                          Auch bei mir kommt eine Fehlermeldung beim Adapterstart bei der Kamerafunktion.
                          roborock.0
                          2023-03-27 16:36:36.172	error	Error executing fileError: spawn /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc ENOENT
                          @David-G
                          An der 32 Bit Version kann es nicht liegen. Der Fehler kommt auch in der 64 Bit Version auf dem pi
                            Edit
                            roborock.0
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #513
                            Ok, dass die Datenpunkte nicht ausgefüllt werden, müsste genauer geprüft werden.
                            Nein. Ich glaube nicht. Einfach nur schlecht programmiert. ;)
                            Ich bitte dich darum, für mich jeweils ein Issue für die Probleme auf GitHub zu erstellen und dort entsprechend ein vollständiges Debug-Log anzuhängen.
                            Die verschiedene Fehler hier zu verfolgen, ist gar nicht so einfach.
                            • M-A HuebM Offline
                              M-A HuebM Offline
                              M-A Hueb
                              schrieb am zuletzt editiert von M-A Hueb
                              #514
                              Moin. diese Meldung kommen bei mir permanent im Log, sprich alle 10 Sekunden
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable cleaning_brush_work_times with value: 113
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable dust_collection_work_times with value: 0
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable strainer_work_times with value: 113
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable sensor_dirty_time with value: 1
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable filter_element_work_time with value: 0
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable filter_work_time with value: 52
                              roborock.0
                              	2023-03-31 10:29:45.842	error	Setting consumable side_brush_work_time with value: 196
                              roborock.0
                              	2023-03-31 10:29:45.841	error	Setting consumable main_brush_work_time with value: 196
                              roborock.0
                              	2023-03-31 10:29:45.556	info	MQTT initialized
                              roborock.0
                              	2023-03-31 10:29:45.221	info	starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in c:/iobroker/node_modules/iobroker.roborock, node: v18.15.0, js-controller: 4.0.24
                              roborock.0
                              	2023-03-31 10:29:40.937	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              roborock.0
                              	2023-03-31 10:29:40.936	info	terminating
                              roborock.0
                              	2023-03-31 10:29:40.935	info	Got terminate signal TERMINATE_YOURSELF
                              iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                              David G.D copystringC 2 Antworten Letzte Antwort
                              • M-A HuebM M-A Hueb
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                David G.D Online
                                David G.D Online
                                David G.
                                #515
                                @m-a-hueb
                                Da hast du eine Dev erwischt wo das zum testen eingebaut war.
                                Installier mal die aktuelle, dann sollte es weg sein.
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #516
                                  @m-a-hueb in der aktuellen dev ist das nicht mehr vorhanden.
                                    copystringC Offline
                                    copystring
                                    #517
                                    Läuft das mit der Kamera bei euch oder hat außer @David-G keiner einen mit Kamera? Bei ihm läuft es leider nicht. Bräuchte aber trotzdem noch etwas Feedback.
                                    D M-A HuebM 2 Antworten Letzte Antwort
                                      Dimi
                                      #518
                                      @copystring
                                      Also bei mir läuft die (S6 MaxV). Zwar kommt das bild manchmal nicht direkt oder braucht 2-3 Anläufe, aber wenn es da ist funktioniert es auch ohne Probleme
                                        M-A HuebM Offline
                                        M-A HuebM Offline
                                        M-A Hueb
                                        #519
                                        @copystring welche version muss man nehmen für die kamera?
                                          copystringC Offline
                                          copystringC Offline
                                          copystring
                                          #520
                                          @m-a-hueb https://github.com/copystring/ioBroker.roborock/tree/dev
