  4. Fire Tablet Jarvis aktualisiert sich nicht
vis
66 Beiträge 3 Kommentatoren 8.8k Aufrufe 4 Beobachtet
  • T technodj23
    Hab ich alles gemacht, auch iob fix, Neustart usw.
    host.raspberrypi4-iob
    	2023-01-23 20:13:37.811	error	Cannot download and install adapter "jarvis@3.1.2". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    	2023-01-23 20:13:35.773	error	iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    zigbee.0
    	2023-01-23 20:13:16.575	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    	2023-01-23 20:12:48.533	error	iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    	2023-01-23 20:11:57.858	error	iobroker host.raspberrypi4-iob Cannot install iobroker.lovelace@3.0.1: 217
    	2023-01-23 20:11:57.169	error	iobroker npm-install: node:internal/modules/cjs/loader:998 throw err; ^Error: Cannot find module 'chokidar'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js- /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js:5:18) at Module._compile (node:internal/modules/cjs/loader:1165:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10) at Module.load (node:internal/modules/cjs/loader:1043:32) at Function.Module._load (node:internal/modules/cjs/loader:878:12) at Module.require (node:internal/modules/cjs/loader:1067:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}
    2023-01-23 20:11:53.777	error	iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    So sieht der Log nach einem Neustart aus :-/
    #41
    @technodj23
    cd /opt/iobroker
    npm ls chokidar
      @technodj23
      cd /opt/iobroker
      npm ls chokidar
      technodj23
      #42
      iobroker.inst@2.0.3 /opt/iobroker
      ├─┬ iobroker.javascript@6.1.4
      │ ├─┬ @iobroker/dev-server@0.6.0 extraneous
      │ │ └── chokidar@3.5.3 deduped
      │ ├─┬ browser-sync@2.27.11 extraneous
      │ ├── chokidar@3.5.3 extraneous
      │ ├─┬ glob-watcher@5.0.5 extraneous
      │ │ └── chokidar@2.1.8 extraneous
      │ ├─┬ mocha@10.2.0 extraneous
      │ └─┬ nodemon@2.0.20 extraneous
      └─┬ iobroker.js-controller@4.0.24
        └─┬ @iobroker/js-controller-cli@4.0.24
          └── chokidar@3.5.3
      • T technodj23
            └── chokidar@3.5.3
        #43
        @technodj23
        Restart host
        probiert?
          @technodj23
          Restart host
          probiert?
          technodj23
          #44
          @thomas-braun ja, alles, Host, Rasperry alles neu gestartet. Jetzt startet nicht mal mehr der Zigbee Adapter...Ich sehe mich schon alles neu aufsetzen :-/ Und das Alles bloß weil sich die Uhrzeit nicht aktualisiert hat grml
          • T technodj23
            #45
            @technodj23 sagte in Fire Tablet Jarvis aktualisiert sich nicht:
            Ohne Meldung?
              Ohne Meldung?
              technodj23
              #46
              zigbee.0
                 2023-01-23 20:38:38.484	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
              zigbee.0
                 2023-01-23 20:38:38.343	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              • Thomas BraunT Online
                #47
                @technodj23
                Schau das Log bitte per
                iob logs --watch | uniq
                in einem zweiten Terminal an und poste das. Da stimmt die Chronologie, wenn man das von oben nach unten liest.
                  @technodj23
                  technodj23
                  #48
                  2023-01-23 20:38:38.228  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:38:38.343  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2023-01-23 20:38:38.484  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
                  2023-01-23 20:38:39.949  - info: alexa2.0 (3177) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-01-23 20:38:44.768  - info: admin.0 (3073) <== Disconnect system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:38:48.742  - info: alexa2.0 (3177) Initialization Done ...
                  2023-01-23 20:40:16.828  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
                  2023-01-23 20:40:17.870  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
                  2023-01-23 20:40:18.872  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 2 attempt
                  2023-01-23 20:40:18.873  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
                  2023-01-23 20:40:23.166  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3Installing iobroker.jarvis@3.1.2... (System call)
                  2023-01-23 20:41:08.773  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
                  2023-01-23 20:41:09.802  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
                  2023-01-23 20:41:10.802  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 3 attempt
                  2023-01-23 20:41:10.803  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
                  2023-01-23 20:41:14.849  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
                  2023-01-23 20:41:14.851  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
                  2023-01-23 20:41:18.764  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:41:18.851  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2023-01-23 20:41:19.032  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
                  2023-01-23 20:42:08.518  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
                  2023-01-23 20:42:09.552  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
                  2023-01-23 20:42:10.553  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 4 attempt
                  2023-01-23 20:42:10.554  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
                  2023-01-23 20:42:14.610  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
                  2023-01-23 20:42:14.613  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
                  2023-01-23 20:42:46.990  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
                  2023-01-23 20:42:48.032  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
                  2023-01-23 20:42:49.032  - error: host.raspberrypi4-iob Cannot download and install adapter "jarvis@3.1.2". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                  2023-01-23 20:45:00.054  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 4421
                  2023-01-23 20:45:02.864  - info: daswetter.0 (4421) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:45:19.336  - info: daswetter.0 (4421) still wrong data structure from server received! repaired...
                  2023-01-23 20:45:24.227  - info: daswetter.0 (4421) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2023-01-23 20:45:24.758  - info: daswetter.0 (4421) cleaned everything up...
                  2023-01-23 20:45:24.796  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-01-23 20:47:59.003  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.24 js-controller starting
                  2023-01-23 20:47:59.010  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-01-23 20:47:59.011  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.19.0
                  2023-01-23 20:47:59.013  - info: host.raspberrypi4-iob ip addresses: 192.168.178.50 2003:da:d70e:dd00:5828:3778:2798:d9e2 fe80::2874:b7d8:88bf:6c2d
                  2023-01-23 20:48:00.925  - info: host.raspberrypi4-iob connected to Objects and States
                  2023-01-23 20:48:00.994  - info: host.raspberrypi4-iob added notifications configuration of host
                  2023-01-23 20:48:02.057  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeCurrent"
                  2023-01-23 20:48:02.059  - info: host.raspberrypi4-iob 47 instances found
                  2023-01-23 20:48:02.142  - info: host.raspberrypi4-iob starting 36 instances
                  2023-01-23 20:48:02.359  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewest"
                  2023-01-23 20:48:02.397  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 824
                  2023-01-23 20:48:02.407  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewestNext"
                  2023-01-23 20:48:02.424  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmCurrent"
                  2023-01-23 20:48:02.438  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewest"
                  2023-01-23 20:48:02.454  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewestNext"
                  2023-01-23 20:48:02.469  - info: host.raspberrypi4-iob Some obsolete host states deleted.
                  2023-01-23 20:48:05.202  - error: admin.0 (824) admin.0 already running
                  2023-01-23 20:48:05.206  - warn: admin.0 (824) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:05.931  - error: host.raspberrypi4-iob instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:05.932  - info: host.raspberrypi4-iob Restart adapter system.adapter.admin.0 because enabled
                  2023-01-23 20:48:06.305  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 835
                  2023-01-23 20:48:10.352  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 846
                  2023-01-23 20:48:10.666  - error: javascript.0 (835) javascript.0 already running
                  2023-01-23 20:48:10.674  - warn: javascript.0 (835) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:11.381  - error: host.raspberrypi4-iob instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:11.382  - info: host.raspberrypi4-iob Restart adapter system.adapter.javascript.0 because enabled
                  2023-01-23 20:48:12.516  - error: pushover.0 (846) pushover.0 already running
                  2023-01-23 20:48:12.520  - warn: pushover.0 (846) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:13.222  - error: host.raspberrypi4-iob instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:13.223  - info: host.raspberrypi4-iob Restart adapter system.adapter.pushover.0 because enabled
                  2023-01-23 20:48:14.340  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 857
                  2023-01-23 20:48:16.369  - error: history.0 (857) history.0 already running
                  2023-01-23 20:48:16.373  - warn: history.0 (857) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:17.058  - error: host.raspberrypi4-iob instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:17.059  - info: host.raspberrypi4-iob Restart adapter system.adapter.history.0 because enabled
                  2023-01-23 20:48:18.363  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 868
                  2023-01-23 20:48:21.559  - error: telegram.0 (868) telegram.0 already running
                  2023-01-23 20:48:21.563  - warn: telegram.0 (868) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:22.286  - error: host.raspberrypi4-iob instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:22.287  - info: host.raspberrypi4-iob Restart adapter system.adapter.telegram.0 because enabled
                  2023-01-23 20:48:22.443  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 879
                  2023-01-23 20:48:23.477  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 886
                  2023-01-23 20:48:24.613  - error: ping.0 (879) ping.0 already running
                  2023-01-23 20:48:24.618  - warn: ping.0 (879) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:25.325  - error: host.raspberrypi4-iob instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:25.325  - info: host.raspberrypi4-iob Restart adapter system.adapter.ping.0 because enabled
                  2023-01-23 20:48:26.503  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 901
                  2023-01-23 20:48:27.338  - info: telegram.0 (886) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:48:28.849  - error: alexa2.0 (901) alexa2.0 already running
                  2023-01-23 20:48:28.853  - warn: alexa2.0 (901) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:29.571  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:29.571  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
                  2023-01-23 20:48:30.345  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 916
                  2023-01-23 20:48:34.325  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 923
                  2023-01-23 20:48:34.951  - error: zigbee.0 (916) zigbee.0 already running
                  2023-01-23 20:48:34.956  - warn: zigbee.0 (916) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:35.640  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:35.641  - info: host.raspberrypi4-iob Restart adapter system.adapter.zigbee.0 because enabled
                  2023-01-23 20:48:36.161  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 934
                  2023-01-23 20:48:36.751  - error: sonoff.0 (923) sonoff.0 already running
                  2023-01-23 20:48:36.756  - warn: sonoff.0 (923) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:37.437  - error: host.raspberrypi4-iob instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:37.438  - info: host.raspberrypi4-iob Restart adapter system.adapter.sonoff.0 because enabled
                  2023-01-23 20:48:38.326  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 945
                  2023-01-23 20:48:39.417  - info: admin.0 (934) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:48:39.485  - info: admin.0 (934) requesting all states
                  2023-01-23 20:48:39.486  - info: admin.0 (934) requesting all objects
                  2023-01-23 20:48:41.662  - error: shelly.0 (945) shelly.0 already running
                  2023-01-23 20:48:41.667  - warn: shelly.0 (945) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:41.731  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 972
                  2023-01-23 20:48:41.959  - info: admin.0 (934) received all objects
                  2023-01-23 20:48:42.360  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 979
                  2023-01-23 20:48:42.542  - error: host.raspberrypi4-iob instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:42.543  - info: host.raspberrypi4-iob Restart adapter system.adapter.shelly.0 because enabled
                  2023-01-23 20:48:43.002  - info: admin.0 (934) Request actual repository...
                  2023-01-23 20:48:43.030  - info: admin.0 (934) http server listening on port 8081
                  2023-01-23 20:48:43.031  - info: admin.0 (934) Use link "http://localhost:8081" to configure.
                  2023-01-23 20:48:43.044  - info: admin.0 (934) socket.io server listening on port 8081
                  2023-01-23 20:48:43.745  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 990
                  2023-01-23 20:48:45.527  - info: host.raspberrypi4-iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-01-23 20:48:46.143  - error: hmip.0 (979) hmip.0 already running
                  2023-01-23 20:48:46.150  - warn: hmip.0 (979) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:47.501  - info: host.raspberrypi4-iob instance scheduled system.adapter.ical.0 30 * * * *
                  2023-01-23 20:48:47.532  - info: host.raspberrypi4-iob instance system.adapter.ical.0 started with pid 1009
                  2023-01-23 20:48:47.816  - info: admin.0 (934) Repository received successfully.
                  2023-01-23 20:48:48.159  - error: host.raspberrypi4-iob instance system.adapter.hmip.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:48.160  - info: host.raspberrypi4-iob Restart adapter system.adapter.hmip.0 because enabled
                  2023-01-23 20:48:48.314  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 1016
                  2023-01-23 20:48:49.688  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:48:49.749  - info: javascript.0 (972) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:48:49.752  - info: pushover.0 (990) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:48:53.195  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1039
                  2023-01-23 20:48:53.734  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:48:54.328  - info: javascript.0 (972) requesting all states
                  2023-01-23 20:48:54.330  - info: javascript.0 (972) requesting all objects
                  2023-01-23 20:48:56.290  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1050
                  2023-01-23 20:48:56.668  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 1057
                  2023-01-23 20:48:56.851  - info: javascript.0 (972) received all objects
                  2023-01-23 20:48:57.087  - error: tuya.0 (1039) tuya.0 already running
                  2023-01-23 20:48:57.093  - warn: tuya.0 (1039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:48:57.155  - info: javascript.0 (972) received all states
                  2023-01-23 20:48:57.357  - info: javascript.0 (972) Start javascript script.js.Knopf_Kueche
                  2023-01-23 20:48:57.457  - info: javascript.0 (972) script.js.Knopf_Kueche: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.458  - info: javascript.0 (972) Start javascript script.js.Update_Telegram
                  2023-01-23 20:48:57.490  - info: javascript.0 (972) script.js.Update_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.553  - info: history.0 (1016) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:48:57.499  - info: javascript.0 (972) Start javascript script.js.Haustuer_offen_Pushover
                  2023-01-23 20:48:57.508  - info: javascript.0 (972) script.js.Haustuer_offen_Pushover: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.510  - info: javascript.0 (972) Start javascript script.js.Aquarium_undicht
                  2023-01-23 20:48:57.517  - info: javascript.0 (972) script.js.Aquarium_undicht: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.519  - info: javascript.0 (972) Start javascript script.js.Boxen_PC_aus
                  2023-01-23 20:48:57.527  - info: javascript.0 (972) script.js.Boxen_PC_aus: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.529  - info: javascript.0 (972) Start javascript script.js.Aquarium_Schreibtisch_Zeitplan
                  2023-01-23 20:48:57.540  - info: javascript.0 (972) script.js.Aquarium_Schreibtisch_Zeitplan: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.541  - info: javascript.0 (972) Start javascript script.js.Taster_für_Flurlicht_unten
                  2023-01-23 20:48:57.549  - info: javascript.0 (972) script.js.Taster_für_Flurlicht_unten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.551  - info: javascript.0 (972) Start javascript script.js.LED_Stimmungslicht_und_alles_aus
                  2023-01-23 20:48:57.559  - info: javascript.0 (972) script.js.LED_Stimmungslicht_und_alles_aus: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.560  - info: javascript.0 (972) Start javascript script.js.Computerzimmer_hochfahren
                  2023-01-23 20:48:57.568  - info: javascript.0 (972) script.js.Computerzimmer_hochfahren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.570  - info: javascript.0 (972) Start javascript script.js.Ikea_Schalter_Schreibtischlampe
                  2023-01-23 20:48:57.592  - info: javascript.0 (972) script.js.Ikea_Schalter_Schreibtischlampe: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.593  - info: javascript.0 (972) Start javascript script.js.Taster_Licht__Vorratsraum
                  2023-01-23 20:48:57.604  - info: javascript.0 (972) script.js.Taster_Licht__Vorratsraum: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:57.605  - info: javascript.0 (972) Start javascript script.js.Bewegung_Vorrat
                  2023-01-23 20:48:57.621  - info: javascript.0 (972) script.js.Bewegung_Vorrat: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2023-01-23 20:48:58.186  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.3 (Count=1), Alias=false
                  2023-01-23 20:48:58.189  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.4 (Count=2), Alias=false
                  2023-01-23 20:48:58.191  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.5 (Count=3), Alias=false
                  2023-01-23 20:48:58.193  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.6 (Count=4), Alias=false
                  2023-01-23 20:48:58.291  - error: host.raspberrypi4-iob instance system.adapter.tuya.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:48:58.292  - info: host.raspberrypi4-iob Restart adapter system.adapter.tuya.0 because enabled
                  2023-01-23 20:48:58.919  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1068
                  2023-01-23 20:48:59.058  - info: ical.0 (1009) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:00.047  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 1087
                  2023-01-23 20:49:00.421  - error: discovery.0 (1050) discovery.0 already running
                  2023-01-23 20:49:00.426  - warn: discovery.0 (1050) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:01.384  - error: host.raspberrypi4-iob instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:01.384  - info: host.raspberrypi4-iob Restart adapter system.adapter.discovery.0 because enabled
                  2023-01-23 20:49:01.798  - info: ping.0 (1057) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:02.385  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1108
                  2023-01-23 20:49:02.717  - info: ical.0 (1009) processing URL: calendar1 https://calendar.google.com/calendar/ical/paule3236%40gmail.com/private-e6a517dc6f8d2491b62ba38ebb8483e0/basic.ics
                  2023-01-23 20:49:04.486  - error: info.0 (1068) info.0 already running
                  2023-01-23 20:49:04.501  - warn: info.0 (1068) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:04.955  - info: alexa2.0 (1087) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:05.105  - info: alexa2.0 (1087) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                  2023-01-23 20:49:05.329  - error: host.raspberrypi4-iob instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:05.330  - info: host.raspberrypi4-iob Restart adapter system.adapter.info.0 because enabled
                  2023-01-23 20:49:06.040  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 1137
                  2023-01-23 20:49:06.481  - error: web.0 (1108) web.0 already running
                  2023-01-23 20:49:06.486  - warn: web.0 (1108) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:07.202  - error: host.raspberrypi4-iob instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:07.202  - info: host.raspberrypi4-iob Restart adapter system.adapter.web.0 because enabled
                  2023-01-23 20:49:07.641  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 1153
                  2023-01-23 20:49:09.360  - info: alexa2.0 (1087) Initialize all Device states ...
                  2023-01-23 20:49:09.558  - info: vis.0 (1145) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:10.024  - info: vis.0 (1145) vis license is OK.
                  2023-01-23 20:49:10.527  - info: alexa2.0 (1087) Unknown Device, but enabling commands, Try it and report back if commands work.
                  2023-01-23 20:49:10.528  - info: alexa2.0 (1087) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                  2023-01-23 20:49:10.529  - info: alexa2.0 (1087)     Device-type:A1MUORL8FP149X - Holger's AlexaWidget (AlexaWidget) (AlexaWidget) (AMAZON_MUSIC,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,VOLUME_SETTING,TIMERS_AND_ALARMS,AUDIO_PLAYER,TUNE_IN,APPLE_MUSIC,SIRIUSXM,KINDLE_BOOKS,GOLDFISH,MICROPHONE,MUSIC_SKILL,AUDIBLE,I_HEART_RADIO,SLEEP,DREAM_TRAINING,DEEZER,ADAPTIVE_LISTENING,CHANGE_NAME,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,TOUCH_INITIATED,TIDAL)
                  2023-01-23 20:49:11.299  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1179
                  2023-01-23 20:49:11.559  - info: ical.0 (1009) Terminated (NO_ERROR): Without reason
                  2023-01-23 20:49:12.396  - info: host.raspberrypi4-iob instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-01-23 20:49:12.823  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 1187
                  2023-01-23 20:49:13.306  - info: sonoff.0 (1153) starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:13.427  - info: zigbee.0 (1137) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:13.444  - info: sonoff.0 (1153) Starting MQTT authenticated  server on port 1881
                  2023-01-23 20:49:15.331  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1207
                  2023-01-23 20:49:15.601  - error: backitup.0 (1179) backitup.0 already running
                  2023-01-23 20:49:15.607  - warn: backitup.0 (1179) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:16.396  - error: host.raspberrypi4-iob instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:16.396  - info: host.raspberrypi4-iob Restart adapter system.adapter.backitup.0 because enabled
                  2023-01-23 20:49:14.821  - info: zigbee.0 (1137) delete old Backup files. keep only last 10
                  2023-01-23 20:49:14.824  - info: zigbee.0 (1137) Starting Zigbee  npm ...
                  2023-01-23 20:49:17.199  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
                  2023-01-23 20:49:17.488  - info: sonoff.0 (1153) Client [WLED-d13794] connected with secret 1674503357471_5469
                  2023-01-23 20:49:17.794  - info: vis.0 (1145) Terminated (NO_ERROR): Without reason
                  2023-01-23 20:49:18.586  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1221
                  2023-01-23 20:49:18.650  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 1227
                  2023-01-23 20:49:18.859  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
                  2023-01-23 20:49:19.264  - info: shelly.0 (1187) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:19.913  - error: iot.0 (1207) iot.0 already running
                  2023-01-23 20:49:19.919  - warn: iot.0 (1207) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:20.112  - info: shelly.0 (1187) Starting in CoAP mode.
                  2023-01-23 20:49:20.303  - info: shelly.0 (1187) [CoAP Server] Listening for packets in the network
                  2023-01-23 20:49:20.467  - info: shelly.0 (1187) [CoAP] Device 192.168.178.72 (shelly1 / shelly1-32CEC7 / SHSW-1#32CEC7#1) connected! Polltime set to 15 sec.
                  2023-01-23 20:49:20.973  - error: host.raspberrypi4-iob instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:20.974  - info: host.raspberrypi4-iob Restart adapter system.adapter.iot.0 because enabled
                  2023-01-23 20:49:22.773  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1253
                  2023-01-23 20:49:22.780  - error: moma.0 (1221) moma.0 already running
                  2023-01-23 20:49:22.787  - warn: moma.0 (1221) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:23.552  - error: host.raspberrypi4-iob instance system.adapter.moma.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:23.553  - info: host.raspberrypi4-iob Restart adapter system.adapter.moma.0 because enabled
                  2023-01-23 20:49:24.204  - info: hmip.0 (1227) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:25.977  - info: sonoff.0 (1153) Client [Licht Backofen] connected with secret 1674503365975_2224
                  2023-01-23 20:49:25.969  - error: vis-2-beta.0 (1253) vis-2-beta.0 already running
                  2023-01-23 20:49:25.987  - info: sonoff.0 (1153) Client [Arbeitsplatte] connected with secret 1674503365985_1470
                  2023-01-23 20:49:25.991  - warn: vis-2-beta.0 (1253) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:26.162  - info: sonoff.0 (1153) Client [Boxen PC] connected with secret 1674503366161_6734
                  2023-01-23 20:49:26.402  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1271
                  2023-01-23 20:49:26.739  - error: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:26.739  - info: host.raspberrypi4-iob Restart adapter system.adapter.vis-2-beta.0 because enabled
                  2023-01-23 20:49:27.493  - info: sonoff.0 (1153) Client [NAS-Xpenology] connected with secret 1674503367490_5886
                  2023-01-23 20:49:27.542  - info: shelly.0 (1187) [CoAP] Device 192.168.178.59 (shelly1 / shelly1-32C8ED / SHSW-1#32C8ED#1) connected! Polltime set to 15 sec.
                  2023-01-23 20:49:28.681  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1279
                  2023-01-23 20:49:30.558  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1291
                  2023-01-23 20:49:31.021  - error: trashschedule.0 (1271) trashschedule.0 already running
                  2023-01-23 20:49:31.027  - warn: trashschedule.0 (1271) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:32.175  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1299
                  2023-01-23 20:49:32.285  - error: host.raspberrypi4-iob instance system.adapter.trashschedule.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:32.286  - info: host.raspberrypi4-iob Restart adapter system.adapter.trashschedule.0 because enabled
                  2023-01-23 20:49:32.814  - info: admin.0 (934) <== Disconnect system.user.admin from ::ffff:192.168.178.20
                  2023-01-23 20:49:34.592  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1315
                  2023-01-23 20:49:35.223  - error: fullybrowser.0 (1291) fullybrowser.0 already running
                  2023-01-23 20:49:35.242  - warn: fullybrowser.0 (1291) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:35.359  - info: shelly.0 (1187) [CoAP] Device 192.168.178.82 (shelly1 / shelly1-C42C21 / SHSW-1#C42C21#1) connected! Polltime set to 15 sec.
                  2023-01-23 20:49:35.389  - info: shelly.0 (1187) [CoAP] Device 192.168.178.113 (shelly1 / shelly1-C425C7 / SHSW-1#C425C7#1) connected! Polltime set to 15 sec.
                  2023-01-23 20:49:36.174  - info: hmip.0 (1227) ws connection opened
                  2023-01-23 20:49:36.256  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1327
                  2023-01-23 20:49:36.528  - error: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:36.529  - info: host.raspberrypi4-iob Restart adapter system.adapter.fullybrowser.0 because enabled
                  2023-01-23 20:49:37.888  - info: tuya.0 (1279) starting. Version 3.12.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:38.408  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                  2023-01-23 20:49:38.409  - error: zigbee.0 (1137) Failed to start Zigbee
                  2023-01-23 20:49:38.410  - error: zigbee.0 (1137) Error herdsman start
                  2023-01-23 20:49:38.459  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1353
                  2023-01-23 20:49:38.615  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 1 attempt
                  2023-01-23 20:49:38.616  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
                  2023-01-23 20:49:39.187  - error: net-tools.0 (1315) net-tools.0 already running
                  2023-01-23 20:49:39.193  - warn: net-tools.0 (1315) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:40.274  - error: host.raspberrypi4-iob instance system.adapter.net-tools.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:40.275  - info: host.raspberrypi4-iob Restart adapter system.adapter.net-tools.0 because enabled
                  2023-01-23 20:49:41.377  - info: discovery.0 (1299) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:41.911  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
                  2023-01-23 20:49:41.914  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
                  2023-01-23 20:49:41.928  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
                  2023-01-23 20:49:41.938  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
                  2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
                  2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
                  2023-01-23 20:49:42.025  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
                  2023-01-23 20:49:42.030  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
                  2023-01-23 20:49:42.250  - info: host.raspberrypi4-iob instance scheduled system.adapter.daswetter.0 */15 * * * *
                  2023-01-23 20:49:42.285  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 1378
                  2023-01-23 20:49:42.032  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
                  2023-01-23 20:49:42.034  - info: tuya.0 (1279) Existing devices initialized
                  2023-01-23 20:49:42.046  - info: tuya.0 (1279) Try to sync devices from Cloud using stored cloud credentials
                  2023-01-23 20:49:43.221  - info: tuya.0 (1279) Listen for local Tuya devices on port 6666
                  2023-01-23 20:49:43.222  - info: tuya.0 (1279) Listen for encrypted local Tuya devices on port 6667
                  2023-01-23 20:49:44.427  - info: tuya.0 (1279) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
                  2023-01-23 20:49:46.064  - error: daswetter.0 (1378) daswetter.0 already running
                  2023-01-23 20:49:46.069  - warn: daswetter.0 (1378) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-01-23 20:49:46.327  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
                  2023-01-23 20:49:46.328  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
                  2023-01-23 20:49:46.876  - error: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-01-23 20:49:46.910  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1415
                  2023-01-23 20:49:47.043  - info: web.0 (1353) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:47.360  - info: hmip.0 (1227) hmip adapter connected and ready
                  2023-01-23 20:49:47.757  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
                  2023-01-23 20:49:47.821  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
                  2023-01-23 20:49:47.822  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
                  2023-01-23 20:49:48.417  - info: zigbee.0 (1137) Try to reconnect. 1 attempts left
                  2023-01-23 20:49:48.478  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
                  2023-01-23 20:49:48.418  - info: zigbee.0 (1137) Starting Zigbee  npm ...
                  2023-01-23 20:49:48.483  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
                  2023-01-23 20:49:48.497  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
                  2023-01-23 20:49:48.689  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
                  2023-01-23 20:49:49.008  - info: web.0 (1353) socket.io server listening on port 8082
                  2023-01-23 20:49:49.029  - info: web.0 (1353) habpanel server listening on port 8082
                  2023-01-23 20:49:49.031  - info: web.0 (1353) habpanel web extension - Install extension on /rest/habpanel/
                  2023-01-23 20:49:49.034  - info: web.0 (1353) Connect extension "habpanel/lib/habpanelapi.js"
                  2023-01-23 20:49:49.053  - info: web.0 (1353) http server listening on port 8082
                  2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
                  2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
                  2023-01-23 20:49:49.170  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  2023-01-23 20:49:49.172  - error: zigbee.0 (1137) Failed to start Zigbee
                  2023-01-23 20:49:49.173  - error: zigbee.0 (1137) Error herdsman start
                  2023-01-23 20:49:49.546  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
                  2023-01-23 20:49:49.576  - info: info.0 (1327) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:49.900  - info: info.0 (1327) Reading/updating systemdata.
                  2023-01-23 20:49:51.168  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1474
                  2023-01-23 20:49:52.097  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                  2023-01-23 20:49:52.429  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                  2023-01-23 20:49:52.484  - info: backitup.0 (1415) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:52.502  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                  2023-01-23 20:49:52.514  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                  2023-01-23 20:49:52.540  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                  2023-01-23 20:49:52.880  - info: info.0 (1327) cpu Temp res = {"main":64.27,"cores":[],"max":64.27,"socket":[],"chipset":null}
                  2023-01-23 20:49:53.748  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1542
                  2023-01-23 20:49:55.025  - info: backitup.0 (1415) [iobroker] backup was activated at 02:00 every 7 day(s)
                  2023-01-23 20:49:57.061  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1628
                  2023-01-23 20:49:57.847  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
                  2023-01-23 20:49:57.935  - info: iot.0 (1474) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:49:59.023  - info: iot.0 (1474) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                  2023-01-23 20:49:59.109  - info: web.0 (1353) <== Disconnect system.user.admin from ::ffff:192.168.178.119 habpanel.0
                  2023-01-23 20:50:02.825  - error: vis-2-beta.0 (1628) : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
                  2023-01-23 20:50:02.845  - info: iot.0 (1474) Connection changed: connect
                  2023-01-23 20:50:02.968  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1651
                  2023-01-23 20:50:03.245  - info: moma.0 (1542) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.moma, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:50:03.755  - info: vis-2-beta.0 (1628) starting. Version 2.0.16 in /opt/iobroker/node_modules/iobroker.vis-2-beta, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:50:03.954  - error: vis-2-beta.0 (1628) No license found for vis. Please get one on https://iobroker.net !
                  2023-01-23 20:50:04.982  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
                  2023-01-23 20:50:07.168  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1837
                  2023-01-23 20:50:10.053  - info: moma.0 (1542) library systeminformation version 5.17.3
                  2023-01-23 20:50:11.094  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1879
                  2023-01-23 20:50:12.701  - info: fullybrowser.0 (1837) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:50:12.816  - info: fullybrowser.0 (1837) timeout is 2000
                  2023-01-23 20:50:12.842  - info: fullybrowser.0 (1837) Start with IP : 192.168.178.119
                  2023-01-23 20:50:13.738  - info: trashschedule.0 (1651) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:50:14.739  - info: trashschedule.0 (1651) [ical] configurured ical preview is 7 days - increase this value to find more events in the future
                  2023-01-23 20:50:14.741  - info: trashschedule.0 (1651) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
                  2023-01-23 20:50:15.072  - info: net-tools.0 (1879) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v16.19.0, js-controller: 4.0.24
                  2023-01-23 20:50:15.195  - info: net-tools.0 (1879) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                  2023-01-23 20:50:17.427  - info: net-tools.0 (1879) Port scan finished
                  • T technodj23
                    technodj23
                    #49
                    @technodj23
                    zigbee.0
                       2023-01-23 20:56:36.804	error	Error herdsman start
                    zigbee.0
                       2023-01-23 20:56:36.804	error	Failed to start Zigbee
                    zigbee.0
                       2023-01-23 20:56:36.803	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    • T technodj23
                      @technodj23
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      #50
                      @technodj23
                      Warum jetzt wieder das Log umgekehrt?
                      iob stop
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      iob restart
                      T 2 Antworten Letzte Antwort
                        @technodj23
                        iob stop
                        cd /opt/iobroker
                        iob restart
                        technodj23
                        #51
                        @thomas-braun sagte in Fire Tablet Jarvis aktualisiert sich nicht:
                        @technodj23
                        Kam jetzt als zusätzliche Meldung. Zigbee läuft wieder, habe mal kurz den dev Pfad geändert, danach lief Zigbee wieder...
                          @technodj23
                          iob stop
                          cd /opt/iobroker
                          iob restart
                          technodj23
                          #52
                          @technodj23
                          iob stop
                          cd /opt/iobroker
                          iob restart
                          pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                          npm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /opt/iobroker/node_modules/agentkeepalive
                          npm ERR! dest /opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agentkeepalive' -> '/opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn'
                          npm ERR!     /home/iobroker/.npm/_logs/2023-01-23T20_13_53_992Z-debug-0.log
                          So langsam nervt es.
                          • T technodj23
                            @technodj23
                            #53
                            Auf was? Hoffentlich auf den Link aus /dev/serial/by-id
                            • T technodj23
                              @technodj23
                              iob stop
                              cd /opt/iobroker
                              iob restart
                              npm ERR! errno -39
                              #54
                              Siehe oben.
                                technodj23
                                #55
                                Ja, genau.
                                  Siehe oben.
                                  technodj23
                                  #56
                                  Siehe oben.
                                  Drehen wir/ich uns nicht im Kreis? Das ganze hab ich ja nun schon paar Mal durch....
                                  • T technodj23
                                    Siehe oben.
                                    #57
                                    @technodj23
                                    Du kannst auch die Rosskur machen.
                                    Ich bekomme aber nicht mehr zusammen was da immer genau gelöscht wurde.
                                      @technodj23
                                      technodj23
                                      #58
                                       iobroker list instances
                                        throw err;
                                      Error: Cannot find module 'node-forge'
                                      Require stack:
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
                                        requireStack: [
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                      Was hat das jetzt wieder zu sagen? Kann die Iobroker Oberfläche jetzt gar nicht mehr erreichen :-/
                                      • T technodj23
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        #59
                                        @technodj23
                                        js-controller nochmal installieren.
                                          technodj23
                                          #60
                                          @thomas-braun keine Chance, alles versucht. Iobroker läuft per SSH komme ich drauf.
