  4. Fire Tablet Jarvis aktualisiert sich nicht
    5.4k
vis
66 Beiträge 3 Kommentatoren 9.2k Aufrufe 4 Beobachtet
  • T technodj23
    2023-01-23 20:38:38.228  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:38:38.343  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2023-01-23 20:38:38.484  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
    2023-01-23 20:38:39.949  - info: alexa2.0 (3177) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-01-23 20:38:44.768  - info: admin.0 (3073) <== Disconnect system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:38:48.742  - info: alexa2.0 (3177) Initialization Done ...
    2023-01-23 20:40:16.828  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    2023-01-23 20:40:17.870  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
    2023-01-23 20:40:18.872  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 2 attempt
    2023-01-23 20:40:18.873  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
    2023-01-23 20:40:23.166  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3Installing iobroker.jarvis@3.1.2... (System call)
    2023-01-23 20:41:08.773  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    2023-01-23 20:41:09.802  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
    2023-01-23 20:41:10.802  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 3 attempt
    2023-01-23 20:41:10.803  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
    2023-01-23 20:41:14.849  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
    2023-01-23 20:41:14.851  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
    2023-01-23 20:41:18.764  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:41:18.851  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2023-01-23 20:41:19.032  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
    2023-01-23 20:42:08.518  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    2023-01-23 20:42:09.552  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
    2023-01-23 20:42:10.553  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 4 attempt
    2023-01-23 20:42:10.554  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
    2023-01-23 20:42:14.610  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
    2023-01-23 20:42:14.613  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
    2023-01-23 20:42:46.990  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
    2023-01-23 20:42:48.032  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
    2023-01-23 20:42:49.032  - error: host.raspberrypi4-iob Cannot download and install adapter "jarvis@3.1.2". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2023-01-23 20:45:00.054  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 4421
    2023-01-23 20:45:02.864  - info: daswetter.0 (4421) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:45:19.336  - info: daswetter.0 (4421) still wrong data structure from server received! repaired...
    2023-01-23 20:45:24.227  - info: daswetter.0 (4421) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-23 20:45:24.758  - info: daswetter.0 (4421) cleaned everything up...
    2023-01-23 20:45:24.796  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 20:47:59.003  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.24 js-controller starting
    2023-01-23 20:47:59.010  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-01-23 20:47:59.011  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.19.0
    2023-01-23 20:47:59.013  - info: host.raspberrypi4-iob ip addresses: 192.168.178.50 2003:da:d70e:dd00:5828:3778:2798:d9e2 fe80::2874:b7d8:88bf:6c2d
    2023-01-23 20:48:00.925  - info: host.raspberrypi4-iob connected to Objects and States
    2023-01-23 20:48:00.994  - info: host.raspberrypi4-iob added notifications configuration of host
    2023-01-23 20:48:02.057  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeCurrent"
    2023-01-23 20:48:02.059  - info: host.raspberrypi4-iob 47 instances found
    2023-01-23 20:48:02.142  - info: host.raspberrypi4-iob starting 36 instances
    2023-01-23 20:48:02.359  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewest"
    2023-01-23 20:48:02.397  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 824
    2023-01-23 20:48:02.407  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewestNext"
    2023-01-23 20:48:02.424  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmCurrent"
    2023-01-23 20:48:02.438  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewest"
    2023-01-23 20:48:02.454  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewestNext"
    2023-01-23 20:48:02.469  - info: host.raspberrypi4-iob Some obsolete host states deleted.
    2023-01-23 20:48:05.202  - error: admin.0 (824) admin.0 already running
    2023-01-23 20:48:05.206  - warn: admin.0 (824) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:05.931  - error: host.raspberrypi4-iob instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:05.932  - info: host.raspberrypi4-iob Restart adapter system.adapter.admin.0 because enabled
    2023-01-23 20:48:06.305  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 835
    2023-01-23 20:48:10.352  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 846
    2023-01-23 20:48:10.666  - error: javascript.0 (835) javascript.0 already running
    2023-01-23 20:48:10.674  - warn: javascript.0 (835) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:11.381  - error: host.raspberrypi4-iob instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:11.382  - info: host.raspberrypi4-iob Restart adapter system.adapter.javascript.0 because enabled
    2023-01-23 20:48:12.516  - error: pushover.0 (846) pushover.0 already running
    2023-01-23 20:48:12.520  - warn: pushover.0 (846) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:13.222  - error: host.raspberrypi4-iob instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:13.223  - info: host.raspberrypi4-iob Restart adapter system.adapter.pushover.0 because enabled
    2023-01-23 20:48:14.340  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 857
    2023-01-23 20:48:16.369  - error: history.0 (857) history.0 already running
    2023-01-23 20:48:16.373  - warn: history.0 (857) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:17.058  - error: host.raspberrypi4-iob instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:17.059  - info: host.raspberrypi4-iob Restart adapter system.adapter.history.0 because enabled
    2023-01-23 20:48:18.363  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 868
    2023-01-23 20:48:21.559  - error: telegram.0 (868) telegram.0 already running
    2023-01-23 20:48:21.563  - warn: telegram.0 (868) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:22.286  - error: host.raspberrypi4-iob instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:22.287  - info: host.raspberrypi4-iob Restart adapter system.adapter.telegram.0 because enabled
    2023-01-23 20:48:22.443  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 879
    2023-01-23 20:48:23.477  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 886
    2023-01-23 20:48:24.613  - error: ping.0 (879) ping.0 already running
    2023-01-23 20:48:24.618  - warn: ping.0 (879) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:25.325  - error: host.raspberrypi4-iob instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:25.325  - info: host.raspberrypi4-iob Restart adapter system.adapter.ping.0 because enabled
    2023-01-23 20:48:26.503  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 901
    2023-01-23 20:48:27.338  - info: telegram.0 (886) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:48:28.849  - error: alexa2.0 (901) alexa2.0 already running
    2023-01-23 20:48:28.853  - warn: alexa2.0 (901) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:29.571  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:29.571  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
    2023-01-23 20:48:30.345  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 916
    2023-01-23 20:48:34.325  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 923
    2023-01-23 20:48:34.951  - error: zigbee.0 (916) zigbee.0 already running
    2023-01-23 20:48:34.956  - warn: zigbee.0 (916) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:35.640  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:35.641  - info: host.raspberrypi4-iob Restart adapter system.adapter.zigbee.0 because enabled
    2023-01-23 20:48:36.161  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 934
    2023-01-23 20:48:36.751  - error: sonoff.0 (923) sonoff.0 already running
    2023-01-23 20:48:36.756  - warn: sonoff.0 (923) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:37.437  - error: host.raspberrypi4-iob instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:37.438  - info: host.raspberrypi4-iob Restart adapter system.adapter.sonoff.0 because enabled
    2023-01-23 20:48:38.326  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 945
    2023-01-23 20:48:39.417  - info: admin.0 (934) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:48:39.485  - info: admin.0 (934) requesting all states
    2023-01-23 20:48:39.486  - info: admin.0 (934) requesting all objects
    2023-01-23 20:48:41.662  - error: shelly.0 (945) shelly.0 already running
    2023-01-23 20:48:41.667  - warn: shelly.0 (945) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:41.731  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 972
    2023-01-23 20:48:41.959  - info: admin.0 (934) received all objects
    2023-01-23 20:48:42.360  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 979
    2023-01-23 20:48:42.542  - error: host.raspberrypi4-iob instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:42.543  - info: host.raspberrypi4-iob Restart adapter system.adapter.shelly.0 because enabled
    2023-01-23 20:48:43.002  - info: admin.0 (934) Request actual repository...
    2023-01-23 20:48:43.030  - info: admin.0 (934) http server listening on port 8081
    2023-01-23 20:48:43.031  - info: admin.0 (934) Use link "http://localhost:8081" to configure.
    2023-01-23 20:48:43.044  - info: admin.0 (934) socket.io server listening on port 8081
    2023-01-23 20:48:43.745  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 990
    2023-01-23 20:48:45.527  - info: host.raspberrypi4-iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-23 20:48:46.143  - error: hmip.0 (979) hmip.0 already running
    2023-01-23 20:48:46.150  - warn: hmip.0 (979) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:47.501  - info: host.raspberrypi4-iob instance scheduled system.adapter.ical.0 30 * * * *
    2023-01-23 20:48:47.532  - info: host.raspberrypi4-iob instance system.adapter.ical.0 started with pid 1009
    2023-01-23 20:48:47.816  - info: admin.0 (934) Repository received successfully.
    2023-01-23 20:48:48.159  - error: host.raspberrypi4-iob instance system.adapter.hmip.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:48.160  - info: host.raspberrypi4-iob Restart adapter system.adapter.hmip.0 because enabled
    2023-01-23 20:48:48.314  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 1016
    2023-01-23 20:48:49.688  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:48:49.749  - info: javascript.0 (972) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:48:49.752  - info: pushover.0 (990) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:48:53.195  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1039
    2023-01-23 20:48:53.734  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:48:54.328  - info: javascript.0 (972) requesting all states
    2023-01-23 20:48:54.330  - info: javascript.0 (972) requesting all objects
    2023-01-23 20:48:56.290  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1050
    2023-01-23 20:48:56.668  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 1057
    2023-01-23 20:48:56.851  - info: javascript.0 (972) received all objects
    2023-01-23 20:48:57.087  - error: tuya.0 (1039) tuya.0 already running
    2023-01-23 20:48:57.093  - warn: tuya.0 (1039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:48:57.155  - info: javascript.0 (972) received all states
    2023-01-23 20:48:57.357  - info: javascript.0 (972) Start javascript script.js.Knopf_Kueche
    2023-01-23 20:48:57.457  - info: javascript.0 (972) script.js.Knopf_Kueche: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.458  - info: javascript.0 (972) Start javascript script.js.Update_Telegram
    2023-01-23 20:48:57.490  - info: javascript.0 (972) script.js.Update_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.553  - info: history.0 (1016) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:48:57.499  - info: javascript.0 (972) Start javascript script.js.Haustuer_offen_Pushover
    2023-01-23 20:48:57.508  - info: javascript.0 (972) script.js.Haustuer_offen_Pushover: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.510  - info: javascript.0 (972) Start javascript script.js.Aquarium_undicht
    2023-01-23 20:48:57.517  - info: javascript.0 (972) script.js.Aquarium_undicht: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.519  - info: javascript.0 (972) Start javascript script.js.Boxen_PC_aus
    2023-01-23 20:48:57.527  - info: javascript.0 (972) script.js.Boxen_PC_aus: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.529  - info: javascript.0 (972) Start javascript script.js.Aquarium_Schreibtisch_Zeitplan
    2023-01-23 20:48:57.540  - info: javascript.0 (972) script.js.Aquarium_Schreibtisch_Zeitplan: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.541  - info: javascript.0 (972) Start javascript script.js.Taster_für_Flurlicht_unten
    2023-01-23 20:48:57.549  - info: javascript.0 (972) script.js.Taster_für_Flurlicht_unten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.551  - info: javascript.0 (972) Start javascript script.js.LED_Stimmungslicht_und_alles_aus
    2023-01-23 20:48:57.559  - info: javascript.0 (972) script.js.LED_Stimmungslicht_und_alles_aus: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.560  - info: javascript.0 (972) Start javascript script.js.Computerzimmer_hochfahren
    2023-01-23 20:48:57.568  - info: javascript.0 (972) script.js.Computerzimmer_hochfahren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.570  - info: javascript.0 (972) Start javascript script.js.Ikea_Schalter_Schreibtischlampe
    2023-01-23 20:48:57.592  - info: javascript.0 (972) script.js.Ikea_Schalter_Schreibtischlampe: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.593  - info: javascript.0 (972) Start javascript script.js.Taster_Licht__Vorratsraum
    2023-01-23 20:48:57.604  - info: javascript.0 (972) script.js.Taster_Licht__Vorratsraum: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:57.605  - info: javascript.0 (972) Start javascript script.js.Bewegung_Vorrat
    2023-01-23 20:48:57.621  - info: javascript.0 (972) script.js.Bewegung_Vorrat: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 20:48:58.186  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.3 (Count=1), Alias=false
    2023-01-23 20:48:58.189  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.4 (Count=2), Alias=false
    2023-01-23 20:48:58.191  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.5 (Count=3), Alias=false
    2023-01-23 20:48:58.193  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.6 (Count=4), Alias=false
    2023-01-23 20:48:58.291  - error: host.raspberrypi4-iob instance system.adapter.tuya.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:48:58.292  - info: host.raspberrypi4-iob Restart adapter system.adapter.tuya.0 because enabled
    2023-01-23 20:48:58.919  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1068
    2023-01-23 20:48:59.058  - info: ical.0 (1009) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:00.047  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 1087
    2023-01-23 20:49:00.421  - error: discovery.0 (1050) discovery.0 already running
    2023-01-23 20:49:00.426  - warn: discovery.0 (1050) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:01.384  - error: host.raspberrypi4-iob instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:01.384  - info: host.raspberrypi4-iob Restart adapter system.adapter.discovery.0 because enabled
    2023-01-23 20:49:01.798  - info: ping.0 (1057) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:02.385  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1108
    2023-01-23 20:49:02.717  - info: ical.0 (1009) processing URL: calendar1 https://calendar.google.com/calendar/ical/paule3236%40gmail.com/private-e6a517dc6f8d2491b62ba38ebb8483e0/basic.ics
    2023-01-23 20:49:04.486  - error: info.0 (1068) info.0 already running
    2023-01-23 20:49:04.501  - warn: info.0 (1068) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:04.955  - info: alexa2.0 (1087) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:05.105  - info: alexa2.0 (1087) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2023-01-23 20:49:05.329  - error: host.raspberrypi4-iob instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:05.330  - info: host.raspberrypi4-iob Restart adapter system.adapter.info.0 because enabled
    2023-01-23 20:49:06.040  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 1137
    2023-01-23 20:49:06.481  - error: web.0 (1108) web.0 already running
    2023-01-23 20:49:06.486  - warn: web.0 (1108) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:07.202  - error: host.raspberrypi4-iob instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:07.202  - info: host.raspberrypi4-iob Restart adapter system.adapter.web.0 because enabled
    2023-01-23 20:49:07.641  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 1153
    2023-01-23 20:49:09.360  - info: alexa2.0 (1087) Initialize all Device states ...
    2023-01-23 20:49:09.558  - info: vis.0 (1145) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:10.024  - info: vis.0 (1145) vis license is OK.
    2023-01-23 20:49:10.527  - info: alexa2.0 (1087) Unknown Device, but enabling commands, Try it and report back if commands work.
    2023-01-23 20:49:10.528  - info: alexa2.0 (1087) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2023-01-23 20:49:10.529  - info: alexa2.0 (1087)     Device-type:A1MUORL8FP149X - Holger's AlexaWidget (AlexaWidget) (AlexaWidget) (AMAZON_MUSIC,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,VOLUME_SETTING,TIMERS_AND_ALARMS,AUDIO_PLAYER,TUNE_IN,APPLE_MUSIC,SIRIUSXM,KINDLE_BOOKS,GOLDFISH,MICROPHONE,MUSIC_SKILL,AUDIBLE,I_HEART_RADIO,SLEEP,DREAM_TRAINING,DEEZER,ADAPTIVE_LISTENING,CHANGE_NAME,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,TOUCH_INITIATED,TIDAL)
    2023-01-23 20:49:11.299  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1179
    2023-01-23 20:49:11.559  - info: ical.0 (1009) Terminated (NO_ERROR): Without reason
    2023-01-23 20:49:12.396  - info: host.raspberrypi4-iob instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-01-23 20:49:12.823  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 1187
    2023-01-23 20:49:13.306  - info: sonoff.0 (1153) starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:13.427  - info: zigbee.0 (1137) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:13.444  - info: sonoff.0 (1153) Starting MQTT authenticated  server on port 1881
    2023-01-23 20:49:15.331  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1207
    2023-01-23 20:49:15.601  - error: backitup.0 (1179) backitup.0 already running
    2023-01-23 20:49:15.607  - warn: backitup.0 (1179) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:16.396  - error: host.raspberrypi4-iob instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:16.396  - info: host.raspberrypi4-iob Restart adapter system.adapter.backitup.0 because enabled
    2023-01-23 20:49:14.821  - info: zigbee.0 (1137) delete old Backup files. keep only last 10
    2023-01-23 20:49:14.824  - info: zigbee.0 (1137) Starting Zigbee  npm ...
    2023-01-23 20:49:17.199  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
    2023-01-23 20:49:17.488  - info: sonoff.0 (1153) Client [WLED-d13794] connected with secret 1674503357471_5469
    2023-01-23 20:49:17.794  - info: vis.0 (1145) Terminated (NO_ERROR): Without reason
    2023-01-23 20:49:18.586  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1221
    2023-01-23 20:49:18.650  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 1227
    2023-01-23 20:49:18.859  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
    2023-01-23 20:49:19.264  - info: shelly.0 (1187) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:19.913  - error: iot.0 (1207) iot.0 already running
    2023-01-23 20:49:19.919  - warn: iot.0 (1207) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:20.112  - info: shelly.0 (1187) Starting in CoAP mode.
    2023-01-23 20:49:20.303  - info: shelly.0 (1187) [CoAP Server] Listening for packets in the network
    2023-01-23 20:49:20.467  - info: shelly.0 (1187) [CoAP] Device 192.168.178.72 (shelly1 / shelly1-32CEC7 / SHSW-1#32CEC7#1) connected! Polltime set to 15 sec.
    2023-01-23 20:49:20.973  - error: host.raspberrypi4-iob instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:20.974  - info: host.raspberrypi4-iob Restart adapter system.adapter.iot.0 because enabled
    2023-01-23 20:49:22.773  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1253
    2023-01-23 20:49:22.780  - error: moma.0 (1221) moma.0 already running
    2023-01-23 20:49:22.787  - warn: moma.0 (1221) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:23.552  - error: host.raspberrypi4-iob instance system.adapter.moma.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:23.553  - info: host.raspberrypi4-iob Restart adapter system.adapter.moma.0 because enabled
    2023-01-23 20:49:24.204  - info: hmip.0 (1227) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:25.977  - info: sonoff.0 (1153) Client [Licht Backofen] connected with secret 1674503365975_2224
    2023-01-23 20:49:25.969  - error: vis-2-beta.0 (1253) vis-2-beta.0 already running
    2023-01-23 20:49:25.987  - info: sonoff.0 (1153) Client [Arbeitsplatte] connected with secret 1674503365985_1470
    2023-01-23 20:49:25.991  - warn: vis-2-beta.0 (1253) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:26.162  - info: sonoff.0 (1153) Client [Boxen PC] connected with secret 1674503366161_6734
    2023-01-23 20:49:26.402  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1271
    2023-01-23 20:49:26.739  - error: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:26.739  - info: host.raspberrypi4-iob Restart adapter system.adapter.vis-2-beta.0 because enabled
    2023-01-23 20:49:27.493  - info: sonoff.0 (1153) Client [NAS-Xpenology] connected with secret 1674503367490_5886
    2023-01-23 20:49:27.542  - info: shelly.0 (1187) [CoAP] Device 192.168.178.59 (shelly1 / shelly1-32C8ED / SHSW-1#32C8ED#1) connected! Polltime set to 15 sec.
    2023-01-23 20:49:28.681  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1279
    2023-01-23 20:49:30.558  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1291
    2023-01-23 20:49:31.021  - error: trashschedule.0 (1271) trashschedule.0 already running
    2023-01-23 20:49:31.027  - warn: trashschedule.0 (1271) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:32.175  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1299
    2023-01-23 20:49:32.285  - error: host.raspberrypi4-iob instance system.adapter.trashschedule.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:32.286  - info: host.raspberrypi4-iob Restart adapter system.adapter.trashschedule.0 because enabled
    2023-01-23 20:49:32.814  - info: admin.0 (934) <== Disconnect system.user.admin from ::ffff:192.168.178.20
    2023-01-23 20:49:34.592  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1315
    2023-01-23 20:49:35.223  - error: fullybrowser.0 (1291) fullybrowser.0 already running
    2023-01-23 20:49:35.242  - warn: fullybrowser.0 (1291) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:35.359  - info: shelly.0 (1187) [CoAP] Device 192.168.178.82 (shelly1 / shelly1-C42C21 / SHSW-1#C42C21#1) connected! Polltime set to 15 sec.
    2023-01-23 20:49:35.389  - info: shelly.0 (1187) [CoAP] Device 192.168.178.113 (shelly1 / shelly1-C425C7 / SHSW-1#C425C7#1) connected! Polltime set to 15 sec.
    2023-01-23 20:49:36.174  - info: hmip.0 (1227) ws connection opened
    2023-01-23 20:49:36.256  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1327
    2023-01-23 20:49:36.528  - error: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:36.529  - info: host.raspberrypi4-iob Restart adapter system.adapter.fullybrowser.0 because enabled
    2023-01-23 20:49:37.888  - info: tuya.0 (1279) starting. Version 3.12.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:38.408  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2023-01-23 20:49:38.409  - error: zigbee.0 (1137) Failed to start Zigbee
    2023-01-23 20:49:38.410  - error: zigbee.0 (1137) Error herdsman start
    2023-01-23 20:49:38.459  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1353
    2023-01-23 20:49:38.615  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 1 attempt
    2023-01-23 20:49:38.616  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
    2023-01-23 20:49:39.187  - error: net-tools.0 (1315) net-tools.0 already running
    2023-01-23 20:49:39.193  - warn: net-tools.0 (1315) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:40.274  - error: host.raspberrypi4-iob instance system.adapter.net-tools.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:40.275  - info: host.raspberrypi4-iob Restart adapter system.adapter.net-tools.0 because enabled
    2023-01-23 20:49:41.377  - info: discovery.0 (1299) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:41.911  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
    2023-01-23 20:49:41.914  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
    2023-01-23 20:49:41.928  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
    2023-01-23 20:49:41.938  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
    2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
    2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
    2023-01-23 20:49:42.025  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
    2023-01-23 20:49:42.030  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
    2023-01-23 20:49:42.250  - info: host.raspberrypi4-iob instance scheduled system.adapter.daswetter.0 */15 * * * *
    2023-01-23 20:49:42.285  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 1378
    2023-01-23 20:49:42.032  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
    2023-01-23 20:49:42.034  - info: tuya.0 (1279) Existing devices initialized
    2023-01-23 20:49:42.046  - info: tuya.0 (1279) Try to sync devices from Cloud using stored cloud credentials
    2023-01-23 20:49:43.221  - info: tuya.0 (1279) Listen for local Tuya devices on port 6666
    2023-01-23 20:49:43.222  - info: tuya.0 (1279) Listen for encrypted local Tuya devices on port 6667
    2023-01-23 20:49:44.427  - info: tuya.0 (1279) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
    2023-01-23 20:49:46.064  - error: daswetter.0 (1378) daswetter.0 already running
    2023-01-23 20:49:46.069  - warn: daswetter.0 (1378) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-01-23 20:49:46.327  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
    2023-01-23 20:49:46.328  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
    2023-01-23 20:49:46.876  - error: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-01-23 20:49:46.910  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1415
    2023-01-23 20:49:47.043  - info: web.0 (1353) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:47.360  - info: hmip.0 (1227) hmip adapter connected and ready
    2023-01-23 20:49:47.757  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
    2023-01-23 20:49:47.821  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
    2023-01-23 20:49:47.822  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
    2023-01-23 20:49:48.417  - info: zigbee.0 (1137) Try to reconnect. 1 attempts left
    2023-01-23 20:49:48.478  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
    2023-01-23 20:49:48.418  - info: zigbee.0 (1137) Starting Zigbee  npm ...
    2023-01-23 20:49:48.483  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
    2023-01-23 20:49:48.497  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
    2023-01-23 20:49:48.689  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
    2023-01-23 20:49:49.008  - info: web.0 (1353) socket.io server listening on port 8082
    2023-01-23 20:49:49.029  - info: web.0 (1353) habpanel server listening on port 8082
    2023-01-23 20:49:49.031  - info: web.0 (1353) habpanel web extension - Install extension on /rest/habpanel/
    2023-01-23 20:49:49.034  - info: web.0 (1353) Connect extension "habpanel/lib/habpanelapi.js"
    2023-01-23 20:49:49.053  - info: web.0 (1353) http server listening on port 8082
    2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
    2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
    2023-01-23 20:49:49.170  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2023-01-23 20:49:49.172  - error: zigbee.0 (1137) Failed to start Zigbee
    2023-01-23 20:49:49.173  - error: zigbee.0 (1137) Error herdsman start
    2023-01-23 20:49:49.546  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
    2023-01-23 20:49:49.576  - info: info.0 (1327) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:49.900  - info: info.0 (1327) Reading/updating systemdata.
    2023-01-23 20:49:51.168  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1474
    2023-01-23 20:49:52.097  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2023-01-23 20:49:52.429  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
    2023-01-23 20:49:52.484  - info: backitup.0 (1415) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:52.502  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
    2023-01-23 20:49:52.514  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
    2023-01-23 20:49:52.540  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2023-01-23 20:49:52.880  - info: info.0 (1327) cpu Temp res = {"main":64.27,"cores":[],"max":64.27,"socket":[],"chipset":null}
    2023-01-23 20:49:53.748  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1542
    2023-01-23 20:49:55.025  - info: backitup.0 (1415) [iobroker] backup was activated at 02:00 every 7 day(s)
    2023-01-23 20:49:57.061  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1628
    2023-01-23 20:49:57.847  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
    2023-01-23 20:49:57.935  - info: iot.0 (1474) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:49:59.023  - info: iot.0 (1474) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2023-01-23 20:49:59.109  - info: web.0 (1353) <== Disconnect system.user.admin from ::ffff:192.168.178.119 habpanel.0
    2023-01-23 20:50:02.825  - error: vis-2-beta.0 (1628) : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
    2023-01-23 20:50:02.845  - info: iot.0 (1474) Connection changed: connect
    2023-01-23 20:50:02.968  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1651
    2023-01-23 20:50:03.245  - info: moma.0 (1542) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.moma, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:50:03.755  - info: vis-2-beta.0 (1628) starting. Version 2.0.16 in /opt/iobroker/node_modules/iobroker.vis-2-beta, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:50:03.954  - error: vis-2-beta.0 (1628) No license found for vis. Please get one on https://iobroker.net !
    2023-01-23 20:50:04.982  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
    2023-01-23 20:50:07.168  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1837
    2023-01-23 20:50:10.053  - info: moma.0 (1542) library systeminformation version 5.17.3
    2023-01-23 20:50:11.094  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1879
    2023-01-23 20:50:12.701  - info: fullybrowser.0 (1837) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:50:12.816  - info: fullybrowser.0 (1837) timeout is 2000
    2023-01-23 20:50:12.842  - info: fullybrowser.0 (1837) Start with IP : 192.168.178.119
    2023-01-23 20:50:13.738  - info: trashschedule.0 (1651) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:50:14.739  - info: trashschedule.0 (1651) [ical] configurured ical preview is 7 days - increase this value to find more events in the future
    2023-01-23 20:50:14.741  - info: trashschedule.0 (1651) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
    2023-01-23 20:50:15.072  - info: net-tools.0 (1879) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 20:50:15.195  - info: net-tools.0 (1879) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
    2023-01-23 20:50:17.427  - info: net-tools.0 (1879) Port scan finished
    technodj23
    @technodj23
    zigbee.0
       2023-01-23 20:56:36.804	error	Error herdsman start
    zigbee.0
       2023-01-23 20:56:36.804	error	Failed to start Zigbee
    zigbee.0
       2023-01-23 20:56:36.803	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    • T technodj23
      @technodj23
      zigbee.0
      zigbee.0
      zigbee.0
      @technodj23
      Warum jetzt wieder das Log umgekehrt?
      iob stop
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iob restart
      T 2 Antworten Letzte Antwort
        @technodj23
        iob stop
        cd /opt/iobroker
        iob restart
        technodj23
        @thomas-braun sagte in Fire Tablet Jarvis aktualisiert sich nicht:
        @technodj23
        Kam jetzt als zusätzliche Meldung. Zigbee läuft wieder, habe mal kurz den dev Pfad geändert, danach lief Zigbee wieder...
          @technodj23
          iob stop
          cd /opt/iobroker
          iob restart
          technodj23
          @technodj23
          iob stop
          cd /opt/iobroker
          iob restart
          pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/agentkeepalive
          npm ERR! dest /opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agentkeepalive' -> '/opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn'
          npm ERR!     /home/iobroker/.npm/_logs/2023-01-23T20_13_53_992Z-debug-0.log
          So langsam nervt es.
          • T technodj23
            @technodj23
            @technodj23 sagte in Fire Tablet Jarvis aktualisiert sich nicht:
            Auf was? Hoffentlich auf den Link aus /dev/serial/by-id
            • T technodj23
              @technodj23
              iob stop
              cd /opt/iobroker
              iob restart
              npm ERR! errno -39
              Siehe oben.
                technodj23
                Ja, genau.
                  Siehe oben.
                  technodj23
                  Siehe oben.
                  Drehen wir/ich uns nicht im Kreis? Das ganze hab ich ja nun schon paar Mal durch....
                  • T technodj23
                    Siehe oben.
                    @technodj23
                    Du kannst auch die Rosskur machen.
                    Ich bekomme aber nicht mehr zusammen was da immer genau gelöscht wurde.
                      @technodj23
                      technodj23
                       iobroker list instances
                      node:internal/modules/cjs/loader:998
                        throw err;
                      Error: Cannot find module 'node-forge'
                      Require stack:
                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                          at Module.require (node:internal/modules/cjs/loader:1067:19)
                          at require (node:internal/modules/cjs/helpers:103:18)
                          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
                          at Module._compile (node:internal/modules/cjs/loader:1165:14)
                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                          at Module.load (node:internal/modules/cjs/loader:1043:32)
                          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                          at Module.require (node:internal/modules/cjs/loader:1067:19) {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      Was hat das jetzt wieder zu sagen? Kann die Iobroker Oberfläche jetzt gar nicht mehr erreichen :-/
                      • T technodj23
                          throw err;
                        Require stack:
                          requireStack: [
                        @technodj23
                        js-controller nochmal installieren.
                          technodj23
                          @thomas-braun keine Chance, alles versucht. Iobroker läuft per SSH komme ich drauf.
                          • T technodj23
                            Was genau soll 'alles' sein?
                              technodj23
                              @thomas-braun alles was wir vorher schon durchgespielt haben + js controler neu installiert.
                                technodj23
                                @thomas-braun Komischerweise "läuft" Er jetzt wieder, aber so siehts beim Zigbee Adapter aus :-/
                                • T technodj23
                                  @technodj23
                                  Bitte dann einen eigenen Thread zu dem zigbee-Problem aufmachen. Dort dann Logfiles einstellen.
                                  Das ist einer der alten Heuler CC2531, oder?
                                    @technodj23
                                    technodj23
                                    schrieb am zuletzt editiert von technodj23
                                    Ja :-)
                                    Aber Adapter Updates kann ich immer noch nicht mache und auch nichts neues installieren...
                                    • T technodj23
                                      Ja :-)
                                      #66
                                      Mit welchen Meldungen?
                                      Vermutlich:
                                      https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
