  4. Fire Tablet Jarvis aktualisiert sich nicht
    5.4k
vis
66 Beiträge 3 Kommentatoren 9.2k Aufrufe 4 Beobachtet
    @technodj23 sagte in Fire Tablet Jarvis aktualisiert sich nicht:
    Jetzt startet nicht mal mehr der Zigbee Adapter
    Ohne Meldung?
    technodj23
    zigbee.0
       2023-01-23 20:38:38.484	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
       2023-01-23 20:38:38.343	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    • Thomas BraunT Online
      @technodj23
      Schau das Log bitte per
      iob logs --watch | uniq
      in einem zweiten Terminal an und poste das. Da stimmt die Chronologie, wenn man das von oben nach unten liest.
        @technodj23
        technodj23
        2023-01-23 20:38:38.228  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:38:38.343  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        2023-01-23 20:38:38.484  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
        2023-01-23 20:38:39.949  - info: alexa2.0 (3177) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-01-23 20:38:44.768  - info: admin.0 (3073) <== Disconnect system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:38:48.742  - info: alexa2.0 (3177) Initialization Done ...
        2023-01-23 20:40:16.828  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
        2023-01-23 20:40:17.870  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
        2023-01-23 20:40:18.872  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 2 attempt
        2023-01-23 20:40:18.873  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
        2023-01-23 20:40:23.166  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3Installing iobroker.jarvis@3.1.2... (System call)
        2023-01-23 20:41:08.773  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
        2023-01-23 20:41:09.802  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
        2023-01-23 20:41:10.802  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 3 attempt
        2023-01-23 20:41:10.803  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
        2023-01-23 20:41:14.849  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
        2023-01-23 20:41:14.851  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
        2023-01-23 20:41:18.764  - info: admin.0 (3073) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:41:18.851  - error: zigbee.0 (3196) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        2023-01-23 20:41:19.032  - info: zigbee.0 (3196) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E20E8B","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E20E8B-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyAMA0"}]
        2023-01-23 20:42:08.518  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
        2023-01-23 20:42:09.552  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
        2023-01-23 20:42:10.553  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 4 attempt
        2023-01-23 20:42:10.554  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
        2023-01-23 20:42:14.610  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
        2023-01-23 20:42:14.613  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
        2023-01-23 20:42:46.990  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Cannot install iobroker.jarvis@3.1.2: 217
        2023-01-23 20:42:48.032  - info: host.raspberrypi4-iob iobroker npm-install: exit 25
        2023-01-23 20:42:49.032  - error: host.raspberrypi4-iob Cannot download and install adapter "jarvis@3.1.2". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2023-01-23 20:45:00.054  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 4421
        2023-01-23 20:45:02.864  - info: daswetter.0 (4421) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:45:19.336  - info: daswetter.0 (4421) still wrong data structure from server received! repaired...
        2023-01-23 20:45:24.227  - info: daswetter.0 (4421) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-01-23 20:45:24.758  - info: daswetter.0 (4421) cleaned everything up...
        2023-01-23 20:45:24.796  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-01-23 20:47:59.003  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.24 js-controller starting
        2023-01-23 20:47:59.010  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-01-23 20:47:59.011  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.19.0
        2023-01-23 20:47:59.013  - info: host.raspberrypi4-iob ip addresses: 192.168.178.50 2003:da:d70e:dd00:5828:3778:2798:d9e2 fe80::2874:b7d8:88bf:6c2d
        2023-01-23 20:48:00.925  - info: host.raspberrypi4-iob connected to Objects and States
        2023-01-23 20:48:00.994  - info: host.raspberrypi4-iob added notifications configuration of host
        2023-01-23 20:48:02.057  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeCurrent"
        2023-01-23 20:48:02.059  - info: host.raspberrypi4-iob 47 instances found
        2023-01-23 20:48:02.142  - info: host.raspberrypi4-iob starting 36 instances
        2023-01-23 20:48:02.359  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewest"
        2023-01-23 20:48:02.397  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 824
        2023-01-23 20:48:02.407  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.nodeNewestNext"
        2023-01-23 20:48:02.424  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmCurrent"
        2023-01-23 20:48:02.438  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewest"
        2023-01-23 20:48:02.454  - info: host.raspberrypi4-iob Delete state "system.host.raspberrypi4-iob.versions.npmNewestNext"
        2023-01-23 20:48:02.469  - info: host.raspberrypi4-iob Some obsolete host states deleted.
        2023-01-23 20:48:05.202  - error: admin.0 (824) admin.0 already running
        2023-01-23 20:48:05.206  - warn: admin.0 (824) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:05.931  - error: host.raspberrypi4-iob instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:05.932  - info: host.raspberrypi4-iob Restart adapter system.adapter.admin.0 because enabled
        2023-01-23 20:48:06.305  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 835
        2023-01-23 20:48:10.352  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 846
        2023-01-23 20:48:10.666  - error: javascript.0 (835) javascript.0 already running
        2023-01-23 20:48:10.674  - warn: javascript.0 (835) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:11.381  - error: host.raspberrypi4-iob instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:11.382  - info: host.raspberrypi4-iob Restart adapter system.adapter.javascript.0 because enabled
        2023-01-23 20:48:12.516  - error: pushover.0 (846) pushover.0 already running
        2023-01-23 20:48:12.520  - warn: pushover.0 (846) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:13.222  - error: host.raspberrypi4-iob instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:13.223  - info: host.raspberrypi4-iob Restart adapter system.adapter.pushover.0 because enabled
        2023-01-23 20:48:14.340  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 857
        2023-01-23 20:48:16.369  - error: history.0 (857) history.0 already running
        2023-01-23 20:48:16.373  - warn: history.0 (857) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:17.058  - error: host.raspberrypi4-iob instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:17.059  - info: host.raspberrypi4-iob Restart adapter system.adapter.history.0 because enabled
        2023-01-23 20:48:18.363  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 868
        2023-01-23 20:48:21.559  - error: telegram.0 (868) telegram.0 already running
        2023-01-23 20:48:21.563  - warn: telegram.0 (868) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:22.286  - error: host.raspberrypi4-iob instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:22.287  - info: host.raspberrypi4-iob Restart adapter system.adapter.telegram.0 because enabled
        2023-01-23 20:48:22.443  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 879
        2023-01-23 20:48:23.477  - info: host.raspberrypi4-iob instance system.adapter.telegram.0 started with pid 886
        2023-01-23 20:48:24.613  - error: ping.0 (879) ping.0 already running
        2023-01-23 20:48:24.618  - warn: ping.0 (879) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:25.325  - error: host.raspberrypi4-iob instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:25.325  - info: host.raspberrypi4-iob Restart adapter system.adapter.ping.0 because enabled
        2023-01-23 20:48:26.503  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 901
        2023-01-23 20:48:27.338  - info: telegram.0 (886) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:48:28.849  - error: alexa2.0 (901) alexa2.0 already running
        2023-01-23 20:48:28.853  - warn: alexa2.0 (901) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:29.571  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:29.571  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
        2023-01-23 20:48:30.345  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 916
        2023-01-23 20:48:34.325  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 923
        2023-01-23 20:48:34.951  - error: zigbee.0 (916) zigbee.0 already running
        2023-01-23 20:48:34.956  - warn: zigbee.0 (916) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:35.640  - error: host.raspberrypi4-iob instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:35.641  - info: host.raspberrypi4-iob Restart adapter system.adapter.zigbee.0 because enabled
        2023-01-23 20:48:36.161  - info: host.raspberrypi4-iob instance system.adapter.admin.0 started with pid 934
        2023-01-23 20:48:36.751  - error: sonoff.0 (923) sonoff.0 already running
        2023-01-23 20:48:36.756  - warn: sonoff.0 (923) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:37.437  - error: host.raspberrypi4-iob instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:37.438  - info: host.raspberrypi4-iob Restart adapter system.adapter.sonoff.0 because enabled
        2023-01-23 20:48:38.326  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 945
        2023-01-23 20:48:39.417  - info: admin.0 (934) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:48:39.485  - info: admin.0 (934) requesting all states
        2023-01-23 20:48:39.486  - info: admin.0 (934) requesting all objects
        2023-01-23 20:48:41.662  - error: shelly.0 (945) shelly.0 already running
        2023-01-23 20:48:41.667  - warn: shelly.0 (945) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:41.731  - info: host.raspberrypi4-iob instance system.adapter.javascript.0 started with pid 972
        2023-01-23 20:48:41.959  - info: admin.0 (934) received all objects
        2023-01-23 20:48:42.360  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 979
        2023-01-23 20:48:42.542  - error: host.raspberrypi4-iob instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:42.543  - info: host.raspberrypi4-iob Restart adapter system.adapter.shelly.0 because enabled
        2023-01-23 20:48:43.002  - info: admin.0 (934) Request actual repository...
        2023-01-23 20:48:43.030  - info: admin.0 (934) http server listening on port 8081
        2023-01-23 20:48:43.031  - info: admin.0 (934) Use link "http://localhost:8081" to configure.
        2023-01-23 20:48:43.044  - info: admin.0 (934) socket.io server listening on port 8081
        2023-01-23 20:48:43.745  - info: host.raspberrypi4-iob instance system.adapter.pushover.0 started with pid 990
        2023-01-23 20:48:45.527  - info: host.raspberrypi4-iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2023-01-23 20:48:46.143  - error: hmip.0 (979) hmip.0 already running
        2023-01-23 20:48:46.150  - warn: hmip.0 (979) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:47.501  - info: host.raspberrypi4-iob instance scheduled system.adapter.ical.0 30 * * * *
        2023-01-23 20:48:47.532  - info: host.raspberrypi4-iob instance system.adapter.ical.0 started with pid 1009
        2023-01-23 20:48:47.816  - info: admin.0 (934) Repository received successfully.
        2023-01-23 20:48:48.159  - error: host.raspberrypi4-iob instance system.adapter.hmip.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:48.160  - info: host.raspberrypi4-iob Restart adapter system.adapter.hmip.0 because enabled
        2023-01-23 20:48:48.314  - info: host.raspberrypi4-iob instance system.adapter.history.0 started with pid 1016
        2023-01-23 20:48:49.688  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:48:49.749  - info: javascript.0 (972) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:48:49.752  - info: pushover.0 (990) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:48:53.195  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1039
        2023-01-23 20:48:53.734  - info: admin.0 (934) ==> Connected system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:48:54.328  - info: javascript.0 (972) requesting all states
        2023-01-23 20:48:54.330  - info: javascript.0 (972) requesting all objects
        2023-01-23 20:48:56.290  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1050
        2023-01-23 20:48:56.668  - info: host.raspberrypi4-iob instance system.adapter.ping.0 started with pid 1057
        2023-01-23 20:48:56.851  - info: javascript.0 (972) received all objects
        2023-01-23 20:48:57.087  - error: tuya.0 (1039) tuya.0 already running
        2023-01-23 20:48:57.093  - warn: tuya.0 (1039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:48:57.155  - info: javascript.0 (972) received all states
        2023-01-23 20:48:57.357  - info: javascript.0 (972) Start javascript script.js.Knopf_Kueche
        2023-01-23 20:48:57.457  - info: javascript.0 (972) script.js.Knopf_Kueche: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.458  - info: javascript.0 (972) Start javascript script.js.Update_Telegram
        2023-01-23 20:48:57.490  - info: javascript.0 (972) script.js.Update_Telegram: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.553  - info: history.0 (1016) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:48:57.499  - info: javascript.0 (972) Start javascript script.js.Haustuer_offen_Pushover
        2023-01-23 20:48:57.508  - info: javascript.0 (972) script.js.Haustuer_offen_Pushover: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.510  - info: javascript.0 (972) Start javascript script.js.Aquarium_undicht
        2023-01-23 20:48:57.517  - info: javascript.0 (972) script.js.Aquarium_undicht: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.519  - info: javascript.0 (972) Start javascript script.js.Boxen_PC_aus
        2023-01-23 20:48:57.527  - info: javascript.0 (972) script.js.Boxen_PC_aus: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.529  - info: javascript.0 (972) Start javascript script.js.Aquarium_Schreibtisch_Zeitplan
        2023-01-23 20:48:57.540  - info: javascript.0 (972) script.js.Aquarium_Schreibtisch_Zeitplan: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.541  - info: javascript.0 (972) Start javascript script.js.Taster_für_Flurlicht_unten
        2023-01-23 20:48:57.549  - info: javascript.0 (972) script.js.Taster_für_Flurlicht_unten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.551  - info: javascript.0 (972) Start javascript script.js.LED_Stimmungslicht_und_alles_aus
        2023-01-23 20:48:57.559  - info: javascript.0 (972) script.js.LED_Stimmungslicht_und_alles_aus: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.560  - info: javascript.0 (972) Start javascript script.js.Computerzimmer_hochfahren
        2023-01-23 20:48:57.568  - info: javascript.0 (972) script.js.Computerzimmer_hochfahren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.570  - info: javascript.0 (972) Start javascript script.js.Ikea_Schalter_Schreibtischlampe
        2023-01-23 20:48:57.592  - info: javascript.0 (972) script.js.Ikea_Schalter_Schreibtischlampe: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.593  - info: javascript.0 (972) Start javascript script.js.Taster_Licht__Vorratsraum
        2023-01-23 20:48:57.604  - info: javascript.0 (972) script.js.Taster_Licht__Vorratsraum: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:57.605  - info: javascript.0 (972) Start javascript script.js.Bewegung_Vorrat
        2023-01-23 20:48:57.621  - info: javascript.0 (972) script.js.Bewegung_Vorrat: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2023-01-23 20:48:58.186  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.3 (Count=1), Alias=false
        2023-01-23 20:48:58.189  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.4 (Count=2), Alias=false
        2023-01-23 20:48:58.191  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.5 (Count=3), Alias=false
        2023-01-23 20:48:58.193  - info: history.0 (1016) enabled logging of tuya.0.370053454855194f9dd6.6 (Count=4), Alias=false
        2023-01-23 20:48:58.291  - error: host.raspberrypi4-iob instance system.adapter.tuya.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:48:58.292  - info: host.raspberrypi4-iob Restart adapter system.adapter.tuya.0 because enabled
        2023-01-23 20:48:58.919  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1068
        2023-01-23 20:48:59.058  - info: ical.0 (1009) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:00.047  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 1087
        2023-01-23 20:49:00.421  - error: discovery.0 (1050) discovery.0 already running
        2023-01-23 20:49:00.426  - warn: discovery.0 (1050) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:01.384  - error: host.raspberrypi4-iob instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:01.384  - info: host.raspberrypi4-iob Restart adapter system.adapter.discovery.0 because enabled
        2023-01-23 20:49:01.798  - info: ping.0 (1057) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:02.385  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1108
        2023-01-23 20:49:02.717  - info: ical.0 (1009) processing URL: calendar1 https://calendar.google.com/calendar/ical/paule3236%40gmail.com/private-e6a517dc6f8d2491b62ba38ebb8483e0/basic.ics
        2023-01-23 20:49:04.486  - error: info.0 (1068) info.0 already running
        2023-01-23 20:49:04.501  - warn: info.0 (1068) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:04.955  - info: alexa2.0 (1087) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:05.105  - info: alexa2.0 (1087) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
        2023-01-23 20:49:05.329  - error: host.raspberrypi4-iob instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:05.330  - info: host.raspberrypi4-iob Restart adapter system.adapter.info.0 because enabled
        2023-01-23 20:49:06.040  - info: host.raspberrypi4-iob instance system.adapter.zigbee.0 started with pid 1137
        2023-01-23 20:49:06.481  - error: web.0 (1108) web.0 already running
        2023-01-23 20:49:06.486  - warn: web.0 (1108) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:07.202  - error: host.raspberrypi4-iob instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:07.202  - info: host.raspberrypi4-iob Restart adapter system.adapter.web.0 because enabled
        2023-01-23 20:49:07.641  - info: host.raspberrypi4-iob instance system.adapter.sonoff.0 started with pid 1153
        2023-01-23 20:49:09.360  - info: alexa2.0 (1087) Initialize all Device states ...
        2023-01-23 20:49:09.558  - info: vis.0 (1145) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:10.024  - info: vis.0 (1145) vis license is OK.
        2023-01-23 20:49:10.527  - info: alexa2.0 (1087) Unknown Device, but enabling commands, Try it and report back if commands work.
        2023-01-23 20:49:10.528  - info: alexa2.0 (1087) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2023-01-23 20:49:10.529  - info: alexa2.0 (1087)     Device-type:A1MUORL8FP149X - Holger's AlexaWidget (AlexaWidget) (AlexaWidget) (AMAZON_MUSIC,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,VOLUME_SETTING,TIMERS_AND_ALARMS,AUDIO_PLAYER,TUNE_IN,APPLE_MUSIC,SIRIUSXM,KINDLE_BOOKS,GOLDFISH,MICROPHONE,MUSIC_SKILL,AUDIBLE,I_HEART_RADIO,SLEEP,DREAM_TRAINING,DEEZER,ADAPTIVE_LISTENING,CHANGE_NAME,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,TOUCH_INITIATED,TIDAL)
        2023-01-23 20:49:11.299  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1179
        2023-01-23 20:49:11.559  - info: ical.0 (1009) Terminated (NO_ERROR): Without reason
        2023-01-23 20:49:12.396  - info: host.raspberrypi4-iob instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-01-23 20:49:12.823  - info: host.raspberrypi4-iob instance system.adapter.shelly.0 started with pid 1187
        2023-01-23 20:49:13.306  - info: sonoff.0 (1153) starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:13.427  - info: zigbee.0 (1137) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:13.444  - info: sonoff.0 (1153) Starting MQTT authenticated  server on port 1881
        2023-01-23 20:49:15.331  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1207
        2023-01-23 20:49:15.601  - error: backitup.0 (1179) backitup.0 already running
        2023-01-23 20:49:15.607  - warn: backitup.0 (1179) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:16.396  - error: host.raspberrypi4-iob instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:16.396  - info: host.raspberrypi4-iob Restart adapter system.adapter.backitup.0 because enabled
        2023-01-23 20:49:14.821  - info: zigbee.0 (1137) delete old Backup files. keep only last 10
        2023-01-23 20:49:14.824  - info: zigbee.0 (1137) Starting Zigbee  npm ...
        2023-01-23 20:49:17.199  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
        2023-01-23 20:49:17.488  - info: sonoff.0 (1153) Client [WLED-d13794] connected with secret 1674503357471_5469
        2023-01-23 20:49:17.794  - info: vis.0 (1145) Terminated (NO_ERROR): Without reason
        2023-01-23 20:49:18.586  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1221
        2023-01-23 20:49:18.650  - info: host.raspberrypi4-iob instance system.adapter.hmip.0 started with pid 1227
        2023-01-23 20:49:18.859  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
        2023-01-23 20:49:19.264  - info: shelly.0 (1187) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:19.913  - error: iot.0 (1207) iot.0 already running
        2023-01-23 20:49:19.919  - warn: iot.0 (1207) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:20.112  - info: shelly.0 (1187) Starting in CoAP mode.
        2023-01-23 20:49:20.303  - info: shelly.0 (1187) [CoAP Server] Listening for packets in the network
        2023-01-23 20:49:20.467  - info: shelly.0 (1187) [CoAP] Device 192.168.178.72 (shelly1 / shelly1-32CEC7 / SHSW-1#32CEC7#1) connected! Polltime set to 15 sec.
        2023-01-23 20:49:20.973  - error: host.raspberrypi4-iob instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:20.974  - info: host.raspberrypi4-iob Restart adapter system.adapter.iot.0 because enabled
        2023-01-23 20:49:22.773  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1253
        2023-01-23 20:49:22.780  - error: moma.0 (1221) moma.0 already running
        2023-01-23 20:49:22.787  - warn: moma.0 (1221) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:23.552  - error: host.raspberrypi4-iob instance system.adapter.moma.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:23.553  - info: host.raspberrypi4-iob Restart adapter system.adapter.moma.0 because enabled
        2023-01-23 20:49:24.204  - info: hmip.0 (1227) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:25.977  - info: sonoff.0 (1153) Client [Licht Backofen] connected with secret 1674503365975_2224
        2023-01-23 20:49:25.969  - error: vis-2-beta.0 (1253) vis-2-beta.0 already running
        2023-01-23 20:49:25.987  - info: sonoff.0 (1153) Client [Arbeitsplatte] connected with secret 1674503365985_1470
        2023-01-23 20:49:25.991  - warn: vis-2-beta.0 (1253) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:26.162  - info: sonoff.0 (1153) Client [Boxen PC] connected with secret 1674503366161_6734
        2023-01-23 20:49:26.402  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1271
        2023-01-23 20:49:26.739  - error: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:26.739  - info: host.raspberrypi4-iob Restart adapter system.adapter.vis-2-beta.0 because enabled
        2023-01-23 20:49:27.493  - info: sonoff.0 (1153) Client [NAS-Xpenology] connected with secret 1674503367490_5886
        2023-01-23 20:49:27.542  - info: shelly.0 (1187) [CoAP] Device 192.168.178.59 (shelly1 / shelly1-32C8ED / SHSW-1#32C8ED#1) connected! Polltime set to 15 sec.
        2023-01-23 20:49:28.681  - info: host.raspberrypi4-iob instance system.adapter.tuya.0 started with pid 1279
        2023-01-23 20:49:30.558  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1291
        2023-01-23 20:49:31.021  - error: trashschedule.0 (1271) trashschedule.0 already running
        2023-01-23 20:49:31.027  - warn: trashschedule.0 (1271) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:32.175  - info: host.raspberrypi4-iob instance system.adapter.discovery.0 started with pid 1299
        2023-01-23 20:49:32.285  - error: host.raspberrypi4-iob instance system.adapter.trashschedule.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:32.286  - info: host.raspberrypi4-iob Restart adapter system.adapter.trashschedule.0 because enabled
        2023-01-23 20:49:32.814  - info: admin.0 (934) <== Disconnect system.user.admin from ::ffff:192.168.178.20
        2023-01-23 20:49:34.592  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1315
        2023-01-23 20:49:35.223  - error: fullybrowser.0 (1291) fullybrowser.0 already running
        2023-01-23 20:49:35.242  - warn: fullybrowser.0 (1291) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:35.359  - info: shelly.0 (1187) [CoAP] Device 192.168.178.82 (shelly1 / shelly1-C42C21 / SHSW-1#C42C21#1) connected! Polltime set to 15 sec.
        2023-01-23 20:49:35.389  - info: shelly.0 (1187) [CoAP] Device 192.168.178.113 (shelly1 / shelly1-C425C7 / SHSW-1#C425C7#1) connected! Polltime set to 15 sec.
        2023-01-23 20:49:36.174  - info: hmip.0 (1227) ws connection opened
        2023-01-23 20:49:36.256  - info: host.raspberrypi4-iob instance system.adapter.info.0 started with pid 1327
        2023-01-23 20:49:36.528  - error: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:36.529  - info: host.raspberrypi4-iob Restart adapter system.adapter.fullybrowser.0 because enabled
        2023-01-23 20:49:37.888  - info: tuya.0 (1279) starting. Version 3.12.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:38.408  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2023-01-23 20:49:38.409  - error: zigbee.0 (1137) Failed to start Zigbee
        2023-01-23 20:49:38.410  - error: zigbee.0 (1137) Error herdsman start
        2023-01-23 20:49:38.459  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 1353
        2023-01-23 20:49:38.615  - warn: host.raspberrypi4-iob startInstance cannot find adapter "jarvis@3.1.2". Try to install it... 1 attempt
        2023-01-23 20:49:38.616  - info: host.raspberrypi4-iob iobroker install jarvis@3.1.2 using installedVersion
        2023-01-23 20:49:39.187  - error: net-tools.0 (1315) net-tools.0 already running
        2023-01-23 20:49:39.193  - warn: net-tools.0 (1315) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:40.274  - error: host.raspberrypi4-iob instance system.adapter.net-tools.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:40.275  - info: host.raspberrypi4-iob Restart adapter system.adapter.net-tools.0 because enabled
        2023-01-23 20:49:41.377  - info: discovery.0 (1299) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:41.911  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
        2023-01-23 20:49:41.914  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
        2023-01-23 20:49:41.928  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
        2023-01-23 20:49:41.938  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
        2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
        2023-01-23 20:49:42.010  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
        2023-01-23 20:49:42.025  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
        2023-01-23 20:49:42.030  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
        2023-01-23 20:49:42.250  - info: host.raspberrypi4-iob instance scheduled system.adapter.daswetter.0 */15 * * * *
        2023-01-23 20:49:42.285  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 1378
        2023-01-23 20:49:42.032  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
        2023-01-23 20:49:42.034  - info: tuya.0 (1279) Existing devices initialized
        2023-01-23 20:49:42.046  - info: tuya.0 (1279) Try to sync devices from Cloud using stored cloud credentials
        2023-01-23 20:49:43.221  - info: tuya.0 (1279) Listen for local Tuya devices on port 6666
        2023-01-23 20:49:43.222  - info: tuya.0 (1279) Listen for encrypted local Tuya devices on port 6667
        2023-01-23 20:49:44.427  - info: tuya.0 (1279) IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
        2023-01-23 20:49:46.064  - error: daswetter.0 (1378) daswetter.0 already running
        2023-01-23 20:49:46.069  - warn: daswetter.0 (1378) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        2023-01-23 20:49:46.327  - info: tuya.0 (1279) 370053454855194f9944: Connect locally to device
        2023-01-23 20:49:46.328  - info: tuya.0 (1279) 370053454855194f9944 Init with IP=192.168.178.121, Key=b4a7c2da725a0a90, Version=3.3
        2023-01-23 20:49:46.876  - error: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        2023-01-23 20:49:46.910  - info: host.raspberrypi4-iob instance system.adapter.backitup.0 started with pid 1415
        2023-01-23 20:49:47.043  - info: web.0 (1353) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:47.360  - info: hmip.0 (1227) hmip adapter connected and ready
        2023-01-23 20:49:47.757  - info: tuya.0 (1279) 0407020484f3eb61ba13: Connect locally to device
        2023-01-23 20:49:47.821  - info: tuya.0 (1279) 370053454cebd6e603a4: Connect locally to device
        2023-01-23 20:49:47.822  - info: tuya.0 (1279) 370053454cebd6e603a4 Init with IP=192.168.178.124, Key=0a570aa674a6f5aa, Version=3.3
        2023-01-23 20:49:48.417  - info: zigbee.0 (1137) Try to reconnect. 1 attempts left
        2023-01-23 20:49:48.478  - info: host.raspberrypi4-iob iobroker npm-install: NPM version: 8.19.3
        2023-01-23 20:49:48.418  - info: zigbee.0 (1137) Starting Zigbee  npm ...
        2023-01-23 20:49:48.483  - info: host.raspberrypi4-iob iobroker npm-install: Installing iobroker.jarvis@3.1.2... (System call)
        2023-01-23 20:49:48.497  - info: zigbee.0 (1137) Installed Version: iobroker.zigbee@1.8.10
        2023-01-23 20:49:48.689  - info: tuya.0 (1279) 6416540684f3ebefb384: Connect locally to device
        2023-01-23 20:49:49.008  - info: web.0 (1353) socket.io server listening on port 8082
        2023-01-23 20:49:49.029  - info: web.0 (1353) habpanel server listening on port 8082
        2023-01-23 20:49:49.031  - info: web.0 (1353) habpanel web extension - Install extension on /rest/habpanel/
        2023-01-23 20:49:49.034  - info: web.0 (1353) Connect extension "habpanel/lib/habpanelapi.js"
        2023-01-23 20:49:49.053  - info: web.0 (1353) http server listening on port 8082
        2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6: Connect locally to device
        2023-01-23 20:49:49.124  - info: tuya.0 (1279) 370053454855194f9dd6 Init with IP=192.168.178.125, Key=99b7ef5fe175266d, Version=3.3
        2023-01-23 20:49:49.170  - error: zigbee.0 (1137) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2023-01-23 20:49:49.172  - error: zigbee.0 (1137) Failed to start Zigbee
        2023-01-23 20:49:49.173  - error: zigbee.0 (1137) Error herdsman start
        2023-01-23 20:49:49.546  - info: tuya.0 (1279) 370053454cebd6e5dcc3: Connect locally to device
        2023-01-23 20:49:49.576  - info: info.0 (1327) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:49.900  - info: info.0 (1327) Reading/updating systemdata.
        2023-01-23 20:49:51.168  - info: host.raspberrypi4-iob instance system.adapter.iot.0 started with pid 1474
        2023-01-23 20:49:52.097  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
        2023-01-23 20:49:52.429  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
        2023-01-23 20:49:52.484  - info: backitup.0 (1415) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:52.502  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
        2023-01-23 20:49:52.514  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
        2023-01-23 20:49:52.540  - info: info.0 (1327) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
        2023-01-23 20:49:52.880  - info: info.0 (1327) cpu Temp res = {"main":64.27,"cores":[],"max":64.27,"socket":[],"chipset":null}
        2023-01-23 20:49:53.748  - info: host.raspberrypi4-iob instance system.adapter.moma.0 started with pid 1542
        2023-01-23 20:49:55.025  - info: backitup.0 (1415) [iobroker] backup was activated at 02:00 every 7 day(s)
        2023-01-23 20:49:57.061  - info: host.raspberrypi4-iob instance system.adapter.vis-2-beta.0 started with pid 1628
        2023-01-23 20:49:57.847  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
        2023-01-23 20:49:57.935  - info: iot.0 (1474) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:49:59.023  - info: iot.0 (1474) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2023-01-23 20:49:59.109  - info: web.0 (1353) <== Disconnect system.user.admin from ::ffff:192.168.178.119 habpanel.0
        2023-01-23 20:50:02.825  - error: vis-2-beta.0 (1628) : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
        2023-01-23 20:50:02.845  - info: iot.0 (1474) Connection changed: connect
        2023-01-23 20:50:02.968  - info: host.raspberrypi4-iob instance system.adapter.trashschedule.0 started with pid 1651
        2023-01-23 20:50:03.245  - info: moma.0 (1542) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.moma, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:50:03.755  - info: vis-2-beta.0 (1628) starting. Version 2.0.16 in /opt/iobroker/node_modules/iobroker.vis-2-beta, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:50:03.954  - error: vis-2-beta.0 (1628) No license found for vis. Please get one on https://iobroker.net !
        2023-01-23 20:50:04.982  - info: web.0 (1353) ==> Connected system.user.admin from ::ffff:192.168.178.119
        2023-01-23 20:50:07.168  - info: host.raspberrypi4-iob instance system.adapter.fullybrowser.0 started with pid 1837
        2023-01-23 20:50:10.053  - info: moma.0 (1542) library systeminformation version 5.17.3
        2023-01-23 20:50:11.094  - info: host.raspberrypi4-iob instance system.adapter.net-tools.0 started with pid 1879
        2023-01-23 20:50:12.701  - info: fullybrowser.0 (1837) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:50:12.816  - info: fullybrowser.0 (1837) timeout is 2000
        2023-01-23 20:50:12.842  - info: fullybrowser.0 (1837) Start with IP : 192.168.178.119
        2023-01-23 20:50:13.738  - info: trashschedule.0 (1651) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:50:14.739  - info: trashschedule.0 (1651) [ical] configurured ical preview is 7 days - increase this value to find more events in the future
        2023-01-23 20:50:14.741  - info: trashschedule.0 (1651) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
        2023-01-23 20:50:15.072  - info: net-tools.0 (1879) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v16.19.0, js-controller: 4.0.24
        2023-01-23 20:50:15.195  - info: net-tools.0 (1879) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
        2023-01-23 20:50:17.427  - info: net-tools.0 (1879) Port scan finished
        • T technodj23
          technodj23
          @technodj23
          zigbee.0
             2023-01-23 20:56:36.804	error	Error herdsman start
          zigbee.0
             2023-01-23 20:56:36.804	error	Failed to start Zigbee
          zigbee.0
             2023-01-23 20:56:36.803	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          • T technodj23
            @technodj23
            zigbee.0
            zigbee.0
            zigbee.0
            @technodj23
            Warum jetzt wieder das Log umgekehrt?
            iob stop
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iob restart
            T 2 Antworten Letzte Antwort
              @technodj23
              iob stop
              cd /opt/iobroker
              iob restart
              technodj23
              @thomas-braun sagte in Fire Tablet Jarvis aktualisiert sich nicht:
              @technodj23
              Kam jetzt als zusätzliche Meldung. Zigbee läuft wieder, habe mal kurz den dev Pfad geändert, danach lief Zigbee wieder...
                @technodj23
                iob stop
                cd /opt/iobroker
                iob restart
                technodj23
                @technodj23
                iob stop
                cd /opt/iobroker
                iob restart
                pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/agentkeepalive
                npm ERR! dest /opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agentkeepalive' -> '/opt/iobroker/node_modules/.agentkeepalive-G7SHyKbn'
                npm ERR!     /home/iobroker/.npm/_logs/2023-01-23T20_13_53_992Z-debug-0.log
                So langsam nervt es.
                • T technodj23
                  @technodj23
                  Auf was? Hoffentlich auf den Link aus /dev/serial/by-id
                  • T technodj23
                    @technodj23
                    iob stop
                    cd /opt/iobroker
                    iob restart
                    npm ERR! errno -39
                    Siehe oben.
                      technodj23
                      Ja, genau.
                        Siehe oben.
                        technodj23
                        Siehe oben.
                        Drehen wir/ich uns nicht im Kreis? Das ganze hab ich ja nun schon paar Mal durch....
                        • T technodj23
                          Siehe oben.
                          @technodj23
                          Du kannst auch die Rosskur machen.
                          Ich bekomme aber nicht mehr zusammen was da immer genau gelöscht wurde.
                            @technodj23
                            technodj23
                             iobroker list instances
                            node:internal/modules/cjs/loader:998
                              throw err;
                            Error: Cannot find module 'node-forge'
                            Require stack:
                            - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                            - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                            - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                            - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                at Module.require (node:internal/modules/cjs/loader:1067:19)
                                at require (node:internal/modules/cjs/helpers:103:18)
                                at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
                                at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                at Module.load (node:internal/modules/cjs/loader:1043:32)
                                at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                                at Module.require (node:internal/modules/cjs/loader:1067:19) {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: [
                                '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            Was hat das jetzt wieder zu sagen? Kann die Iobroker Oberfläche jetzt gar nicht mehr erreichen :-/
                            • T technodj23
                                throw err;
                              Require stack:
                                requireStack: [
                              @technodj23
                              js-controller nochmal installieren.
                                technodj23
                                @thomas-braun keine Chance, alles versucht. Iobroker läuft per SSH komme ich drauf.
                                • T technodj23
                                  Was genau soll 'alles' sein?
                                    technodj23
                                    @thomas-braun alles was wir vorher schon durchgespielt haben + js controler neu installiert.
                                      technodj23
                                      @thomas-braun Komischerweise "läuft" Er jetzt wieder, aber so siehts beim Zigbee Adapter aus :-/
                                      • T technodj23
                                        @technodj23
                                        Bitte dann einen eigenen Thread zu dem zigbee-Problem aufmachen. Dort dann Logfiles einstellen.
                                        Das ist einer der alten Heuler CC2531, oder?
                                          @technodj23
                                          technodj23
                                          schrieb am zuletzt editiert von technodj23
                                          Ja :-)
                                          Aber Adapter Updates kann ich immer noch nicht mache und auch nichts neues installieren...
