  4. Akku Zustand Proxmox Laptop abfragen
59 Beiträge 4 Kommentatoren 6.9k Aufrufe 2 Beobachtet
  • wendy2702W wendy2702
    @biker1602 Dann ist das tool dort nicht installiert.
    Was ist mit den anderen sachen die ich geschrieben hatte?
    biker1602
    @wendy2702
    2023-01-13 10:21:32.976 - info: linux-control.0 (1628) Got terminate signal TERMINATE_YOURSELF
    2023-01-13 10:21:32.977 - info: linux-control.0 (1628) cleaned everything up...
    2023-01-13 10:21:32.978 - info: linux-control.0 (1628) terminating
    2023-01-13 10:21:32.978 - debug: linux-control.0 (1628) Plugin sentry destroyed
    2023-01-13 10:21:32.979 - info: linux-control.0 (1628) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-13 10:21:37.129 - debug: linux-control.0 (2109) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-01-13 10:21:37.222 - debug: linux-control.0 (2109) Objects client ready ... initialize now
    2023-01-13 10:21:37.224 - debug: linux-control.0 (2109) Objects create System PubSub Client
    2023-01-13 10:21:37.225 - debug: linux-control.0 (2109) Objects create User PubSub Client
    2023-01-13 10:21:37.450 - debug: linux-control.0 (2109) Objects client initialize lua scripts
    2023-01-13 10:21:37.456 - debug: linux-control.0 (2109) Objects connected to redis: 127.0.0.1:9001
    2023-01-13 10:21:37.534 - debug: linux-control.0 (2109) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-01-13 10:21:37.612 - debug: linux-control.0 (2109) States create System PubSub Client
    2023-01-13 10:21:37.613 - debug: linux-control.0 (2109) States create User PubSub Client
    2023-01-13 10:21:37.806 - debug: linux-control.0 (2109) States connected to redis: 127.0.0.1:9000
    2023-01-13 10:21:38.246 - debug: linux-control.0 (2109) Plugin sentry Initialize Plugin (enabled=true)
    2023-01-13 10:21:38.418 - warn: linux-control.0 (2109) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-01-13 10:21:38.419 - warn: linux-control.0 (2109) This object will not be created in future versions. Please report this to the developer.
    2023-01-13 10:21:38.424 - info: linux-control.0 (2109) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.linux-control, node: v16.19.0, js-controller: 4.0.24
    2023-01-13 10:21:38.466 - warn: linux-control.0 (2109) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-01-13 10:21:38.467 - warn: linux-control.0 (2109) This object will not be created in future versions. Please report this to the developer.
    2023-01-13 10:21:38.476 - info: linux-control.0 (2109) getting data from Linux (192.168.57.210:22, Adapter start)
    2023-01-13 10:21:38.493 - info: linux-control.0 (2109) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
    2023-01-13 10:21:38.494 - debug: linux-control.0 (2109) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
    2023-01-13 10:21:38.674 - debug: linux-control.0 (2109) [refreshHost] Linux (192.168.57.210:22): button 'linux-control.0.Linux.refresh' subscribed
    2023-01-13 10:26:38.674 - info: linux-control.0 (2109) getting data from Linux (192.168.57.210:22)
    2023-01-13 10:26:38.686 - info: linux-control.0 (2109) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
    2023-01-13 10:26:38.687 - debug: linux-control.0 (2109) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
    • B biker1602
      @wendy2702
      wendy2702W Offline
      wendy2702W Offline
      wendy2702
      @biker1602
      SSH auf iobroker dann mal die eigene IP pingen
      Was kommt dann?
      B 1 Antwort Letzte Antwort
        @biker1602
        Was kommt dann?
        biker1602
        @wendy2702 said in Akkustand vom Laptop auslesen:
        login as: biker1602
        biker1602@192.168.57.210's password:
        Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.83-1-pve x86_64)
         * Documentation:  https://help.ubuntu.com
         * Management:     https://landscape.canonical.com
         * Support:        https://ubuntu.com/advantage
        Last login: Fri Jan 13 10:24:22 2023 from 192.168.57.120
        biker1602@iobroker:~$ ping 192.168.57.210
        • B biker1602
          login as: biker1602
          wendy2702W Offline
          wendy2702W Offline
          wendy2702
          @biker1602 Kommt was bei
          sudo ping 192.168.57.210
          oder bei
          ping 8.8.8.8
          Wenn beides nicht geht bitte das:
          sudo apt install iputils-ping
          und erneut testen
            oder bei
            ping 8.8.8.8
            und erneut testen
            biker1602
            schrieb am zuletzt editiert von biker1602
            @wendy2702
            bei sudo ping will er das Passwort und dann fängt an zu laufen
            login as: biker1602
            Last login: Fri Jan 13 10:46:06 2023
            biker1602@iobroker:~$ sudo ping 192.168.57.210
            [sudo] password for biker1602:
            Ich habe ihn dann mal auf 10 begrenzt
            biker1602@iobroker:~$ sudo ping -c 10 192.168.57.210
            PING 192.168.57.210 (192.168.57.210) 56(84) bytes of data.
            64 bytes from 192.168.57.210: icmp_seq=1 ttl=64 time=0.039 ms
            64 bytes from 192.168.57.210: icmp_seq=2 ttl=64 time=0.046 ms
            64 bytes from 192.168.57.210: icmp_seq=3 ttl=64 time=0.052 ms
            64 bytes from 192.168.57.210: icmp_seq=4 ttl=64 time=0.047 ms
            64 bytes from 192.168.57.210: icmp_seq=5 ttl=64 time=0.046 ms
            64 bytes from 192.168.57.210: icmp_seq=6 ttl=64 time=0.065 ms
            64 bytes from 192.168.57.210: icmp_seq=7 ttl=64 time=0.045 ms
            64 bytes from 192.168.57.210: icmp_seq=8 ttl=64 time=0.051 ms
            64 bytes from 192.168.57.210: icmp_seq=9 ttl=64 time=0.059 ms
            64 bytes from 192.168.57.210: icmp_seq=10 ttl=64 time=0.068 ms
            --- 192.168.57.210 ping statistics ---
            10 packets transmitted, 10 received, 0% packet loss, time 9194ms
            rtt min/avg/max/mdev = 0.039/0.051/0.068/0.008 ms
            • B biker1602
              @wendy2702
              login as: biker1602
              wendy2702W Offline
              wendy2702W Offline
              wendy2702
              @biker1602 OK. Screenshot der Einstellungen vom Linux Control Adapter bitte
              und die Ausgabe von
              groups
                und die Ausgabe von
                groups
                biker1602
                • B biker1602
                  wendy2702W Offline
                  wendy2702W Offline
                  wendy2702
                  @biker1602 Setze mal den haken bei "benutze Sudo".
                  Speichern und neu testen
                    biker1602
                    2023-01-13 11:05:35.409 - info: linux-control.0 (2150) getting data from Linux (192.168.57.210:22)
                    2023-01-13 11:05:35.418 - info: linux-control.0 (2150) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
                    2023-01-13 11:05:35.419 - debug: linux-control.0 (2150) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                    2023-01-13 11:06:34.573 - info: linux-control.0 (2150) Got terminate signal TERMINATE_YOURSELF
                    2023-01-13 11:06:34.574 - info: linux-control.0 (2150) cleaned everything up...
                    2023-01-13 11:06:34.574 - info: linux-control.0 (2150) terminating
                    2023-01-13 11:06:34.575 - debug: linux-control.0 (2150) Plugin sentry destroyed
                    2023-01-13 11:06:34.575 - info: linux-control.0 (2150) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-01-13 11:06:38.724 - debug: linux-control.0 (3829) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2023-01-13 11:06:38.815 - debug: linux-control.0 (3829) Objects client ready ... initialize now
                    2023-01-13 11:06:38.817 - debug: linux-control.0 (3829) Objects create System PubSub Client
                    2023-01-13 11:06:38.818 - debug: linux-control.0 (3829) Objects create User PubSub Client
                    2023-01-13 11:06:39.028 - debug: linux-control.0 (3829) Objects client initialize lua scripts
                    2023-01-13 11:06:39.034 - debug: linux-control.0 (3829) Objects connected to redis: 127.0.0.1:9001
                    2023-01-13 11:06:39.116 - debug: linux-control.0 (3829) Redis States: Use Redis connection: 127.0.0.1:9000
                    2023-01-13 11:06:39.193 - debug: linux-control.0 (3829) States create System PubSub Client
                    2023-01-13 11:06:39.194 - debug: linux-control.0 (3829) States create User PubSub Client
                    2023-01-13 11:06:39.394 - debug: linux-control.0 (3829) States connected to redis: 127.0.0.1:9000
                    2023-01-13 11:06:39.809 - debug: linux-control.0 (3829) Plugin sentry Initialize Plugin (enabled=true)
                    2023-01-13 11:06:40.010 - warn: linux-control.0 (3829) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                    2023-01-13 11:06:40.011 - warn: linux-control.0 (3829) This object will not be created in future versions. Please report this to the developer.
                    2023-01-13 11:06:40.017 - info: linux-control.0 (3829) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.linux-control, node: v16.19.0, js-controller: 4.0.24
                    2023-01-13 11:06:40.061 - warn: linux-control.0 (3829) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                    2023-01-13 11:06:40.062 - warn: linux-control.0 (3829) This object will not be created in future versions. Please report this to the developer.
                    2023-01-13 11:06:40.072 - info: linux-control.0 (3829) getting data from Linux (192.168.57.210:22, Adapter start)
                    2023-01-13 11:06:40.088 - info: linux-control.0 (3829) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
                    2023-01-13 11:06:40.089 - debug: linux-control.0 (3829) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                    2023-01-13 11:06:40.276 - debug: linux-control.0 (3829) [refreshHost] Linux (192.168.57.210:22): button 'linux-control.0.Linux.refresh' subscribed
                    2023-01-13 11:09:38.410 - info: linux-control.0 (3829) Got terminate signal TERMINATE_YOURSELF
                    2023-01-13 11:09:38.411 - info: linux-control.0 (3829) cleaned everything up...
                    2023-01-13 11:09:38.412 - info: linux-control.0 (3829) terminating
                    2023-01-13 11:09:38.412 - debug: linux-control.0 (3829) Plugin sentry destroyed
                    2023-01-13 11:09:38.413 - info: linux-control.0 (3829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-01-13 11:09:42.580 - debug: linux-control.0 (4142) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2023-01-13 11:09:42.669 - debug: linux-control.0 (4142) Objects client ready ... initialize now
                    2023-01-13 11:09:42.671 - debug: linux-control.0 (4142) Objects create System PubSub Client
                    2023-01-13 11:09:42.672 - debug: linux-control.0 (4142) Objects create User PubSub Client
                    2023-01-13 11:09:42.869 - debug: linux-control.0 (4142) Objects client initialize lua scripts
                    2023-01-13 11:09:42.875 - debug: linux-control.0 (4142) Objects connected to redis: 127.0.0.1:9001
                    2023-01-13 11:09:42.954 - debug: linux-control.0 (4142) Redis States: Use Redis connection: 127.0.0.1:9000
                    2023-01-13 11:09:43.047 - debug: linux-control.0 (4142) States create System PubSub Client
                    2023-01-13 11:09:43.048 - debug: linux-control.0 (4142) States create User PubSub Client
                    2023-01-13 11:09:43.242 - debug: linux-control.0 (4142) States connected to redis: 127.0.0.1:9000
                    2023-01-13 11:09:43.652 - debug: linux-control.0 (4142) Plugin sentry Initialize Plugin (enabled=true)
                    2023-01-13 11:09:43.832 - warn: linux-control.0 (4142) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                    2023-01-13 11:09:43.833 - warn: linux-control.0 (4142) This object will not be created in future versions. Please report this to the developer.
                    2023-01-13 11:09:43.839 - info: linux-control.0 (4142) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.linux-control, node: v16.19.0, js-controller: 4.0.24
                    2023-01-13 11:09:43.876 - warn: linux-control.0 (4142) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                    2023-01-13 11:09:43.877 - warn: linux-control.0 (4142) This object will not be created in future versions. Please report this to the developer.
                    2023-01-13 11:09:43.886 - info: linux-control.0 (4142) getting data from Linux (192.168.57.210:22, Adapter start)
                    2023-01-13 11:09:43.904 - info: linux-control.0 (4142) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
                    2023-01-13 11:09:43.905 - debug: linux-control.0 (4142) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                    2023-01-13 11:09:44.107 - debug: linux-control.0 (4142) [refreshHost] Linux (192.168.57.210:22): button 'linux-control.0.Linux.refresh' subscribed
                    Das verstehe wer will ich nicht
                    • wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      OK.
                      dann die Passwort abfrage für sudo deaktivieren.
                      sudo visudo
                      Dann diese Zeile auskommentieren: "#" davor
                      %sudo   ALL=(ALL:ALL) ALL
                      und diese Zeile einfügen:
                      %sudo  ALL=(ALL) NOPASSWD:ALL
                      Mit "ctrl+x" verlassen und Speichern bestätigen.
                      Ausloggen, einloggen und dann mal den Ping testen ob der mit sudo davor noch immer das PW haben will.
                      Wenn nicht nochmal Adapter neu starten ob der Host dann Online ist
                        OK.
                        sudo visudo
                        biker1602
                        @wendy2702
                        So Passwortabfrage habe ich so deaktiviert und beim Ping mit Sudo will er auch kein Passwort mehr.
                        Den Adapter habe ich neu gestartet, aber alles das Gleiche.
                        2023-01-13 11:24:42.667 - info: linux-control.0 (5510) Got terminate signal TERMINATE_YOURSELF
                        2023-01-13 11:24:42.668 - info: linux-control.0 (5510) cleaned everything up...
                        2023-01-13 11:24:42.669 - info: linux-control.0 (5510) terminating
                        2023-01-13 11:24:42.669 - debug: linux-control.0 (5510) Plugin sentry destroyed
                        2023-01-13 11:24:42.669 - info: linux-control.0 (5510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-01-13 11:24:46.853 - debug: linux-control.0 (5727) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-01-13 11:24:46.944 - debug: linux-control.0 (5727) Objects client ready ... initialize now
                        2023-01-13 11:24:46.945 - debug: linux-control.0 (5727) Objects create System PubSub Client
                        2023-01-13 11:24:46.946 - debug: linux-control.0 (5727) Objects create User PubSub Client
                        2023-01-13 11:24:47.146 - debug: linux-control.0 (5727) Objects client initialize lua scripts
                        2023-01-13 11:24:47.152 - debug: linux-control.0 (5727) Objects connected to redis: 127.0.0.1:9001
                        2023-01-13 11:24:47.235 - debug: linux-control.0 (5727) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-01-13 11:24:47.329 - debug: linux-control.0 (5727) States create System PubSub Client
                        2023-01-13 11:24:47.330 - debug: linux-control.0 (5727) States create User PubSub Client
                        2023-01-13 11:24:47.518 - debug: linux-control.0 (5727) States connected to redis: 127.0.0.1:9000
                        2023-01-13 11:24:47.942 - debug: linux-control.0 (5727) Plugin sentry Initialize Plugin (enabled=true)
                        2023-01-13 11:24:48.116 - warn: linux-control.0 (5727) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                        2023-01-13 11:24:48.117 - warn: linux-control.0 (5727) This object will not be created in future versions. Please report this to the developer.
                        2023-01-13 11:24:48.124 - info: linux-control.0 (5727) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.linux-control, node: v16.19.0, js-controller: 4.0.24
                        2023-01-13 11:24:48.163 - warn: linux-control.0 (5727) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                        2023-01-13 11:24:48.164 - warn: linux-control.0 (5727) This object will not be created in future versions. Please report this to the developer.
                        2023-01-13 11:24:48.173 - info: linux-control.0 (5727) getting data from Linux (192.168.57.210:22, Adapter start)
                        2023-01-13 11:24:48.190 - info: linux-control.0 (5727) [getConnection] Host 'Linux' (192.168.57.210:22) seems not to be online
                        2023-01-13 11:24:48.190 - debug: linux-control.0 (5727) [getConnection] Host 'Linux' (192.168.57.210:22) ping result: {"inputHost":"192.168.57.210","host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                        2023-01-13 11:24:48.391 - debug: linux-control.0 (5727) [refreshHost] Linux (192.168.57.210:22): button 'linux-control.0.Linux.refresh' subscribed
                        Nur nochmal eine Frage für Dumme. Der Port ist doch richtig mit der 22 oder?
                        • B biker1602
                          @wendy2702
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          @biker1602 Port 22 ist richtig.
                          Kannst du das mal bitte auf dem iobroker ausführen:
                          und die komplette ausgabe hier posten.
                            biker1602
                            Du meinst über Putty auf dem iobroker einloggen?
                              wendy2702W Offline
                              wendy2702
                              @biker1602 Ja
                                @biker1602 Ja
                                biker1602
                                @wendy2702
                                biker1602@iobroker:~$ sudo apt install iputils-ping
                                Reading package lists... Done
                                Building dependency tree... Done
                                iputils-ping is already the newest version (3:20211215-1).
                                0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
                                • B biker1602
                                  @wendy2702
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  wendy2702
                                  @biker1602 Dann gehen mir ausser einem Upgrade des Linux Control Adapters langsam die Ideen aus.
                                  Die Version 1.1.5 liegt im Beta Repo, die könntest du mal probieren. Das ist zumindest die Version mit der ich Arbeite.
                                  Oder, wenn noch nicht viel Konfiguriert den Container mal neu mit Debian Bullseye aufsetzen.
                                    biker1602
                                    Du wirst lachen, da hatte ich schon mal versucht, aber das klappt nach der Installation mit dem Login nicht, da es anders ist als Debian 10.
                                    Wenn ich das Template installiert habe, kommt gleich Login aber weder mit admin usw. funktioniert es.
                                    Edit
                                    Mit root komme ich erstmal rein.
                                    • B biker1602
                                      Edit
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      @biker1602 Ja,
                                      dann neuen User anlegen wie bereits eine Beiträge vorher geschrieben. Und als der dann den einzeiler zur iob installation ausführen.
                                        @biker1602 Ja,
                                        biker1602
                                        @wendy2702
                                        Na von dem Bullseye lasse ich mal die Finger von. Da funktioniert ja nach der Installation des Templates gar nichts. Bis auf den User wechsel nimmt, der keine Befehle an nicht mal update und Upgrade macht er. Kommando nicht gefunden und so ein Mist schreibt er ständig. Aber da bin ich kein Einzelfall, glaube ich, wenn man im Netz so liest.
                                        • B biker1602
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          wendy2702
                                          @biker1602 Komisch, lese ich zum ersten mal.
                                          Ich habe Bullseye auf allen meinen CTs und VMs laufen und keine Probleme.
                                          Und welches Template meinst du? Das für Proxmox?
                                          Wenn ja, wie nennt sich das denn?
                                          Ich denke dein Problem mit Bullseye liegt an der Netzwerk Einstellung des CT's. Da sollte man für IPv4 als unerfahrener User erstmal DHCP und für IPv6 wenn im Netzwerk aktiv SLAAC einstellen.
                                          Da du allerdings keine Ausgaben der "fehlschläge" und vom einrichten zeigst kann man nur schwer helfen.
