  4. Errors nach einem Neustart
    5.2k
neustarterrornpm
15 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • H Offline
    homecineplexx
    Hallo
    seit neuestem kommen nach dem Starten des ioBrokers folgende Fehler.
    kann ich das was tun, wenn ja was?
    npm version: 8.19.2
    nodejs: v16.18.1
    node: v16.18.1
    javascript.2
    2023-01-12 07:51:16.251	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.2
    2023-01-12 07:51:16.249	error	npm
    host.ioBroker
    2023-01-12 07:51:16.067	info	instance system.adapter.mqtt.0 started with pid 17310
    javascript.2
    2023-01-12 07:51:15.579	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.2
    2023-01-12 07:51:15.575	error	npm
    javascript.2
    2023-01-12 07:51:13.934	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.2
    2023-01-12 07:51:13.932	error	npm
    host.ioBroker
    2023-01-12 07:51:13.027	info	instance system.adapter.alexa2.0 started with pid 17294
    host.ioBroker
    2023-01-12 07:51:12.937	info	instance system.adapter.mihome.0 started with pid 17288
    javascript.1
    2023-01-12 07:51:12.773	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.1
    2023-01-12 07:51:12.771	error	npm WARN
    javascript.2
    2023-01-12 07:51:12.558	error	deprecated har-validator@5.1.5: this library is no longer supported
    javascript.2
    2023-01-12 07:51:12.556	error	WARN
    javascript.2
    2023-01-12 07:51:12.554	error
    javascript.2
    2023-01-12 07:51:12.551	error	npm
    javascript.1
    2023-01-12 07:51:12.355	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.1
    2023-01-12 07:51:12.353	error	npm WARN
    javascript.1
    2023-01-12 07:51:11.873	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.1
    2023-01-12 07:51:11.871	error	npm
    host.ioBroker
    2023-01-12 07:51:11.249	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    javascript.1
    2023-01-12 07:51:11.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/generated'
    javascript.1
    2023-01-12 07:51:11.426	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
    javascript.1
    2023-01-12 07:51:11.424	error	npm
    javascript.1
    2023-01-12 07:51:11.416	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
    javascript.1
    2023-01-12 07:51:11.414	error	npm
    javascript.1
    2023-01-12 07:51:11.410	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
    javascript.1
    2023-01-12 07:51:11.409	error	npm
    javascript.1
    2023-01-12 07:51:11.396	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/src'
    javascript.1
    2023-01-12 07:51:11.395	error	npm
    javascript.1
    2023-01-12 07:51:11.386	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/lib'
    javascript.1
    2023-01-12 07:51:11.384	error	npm
    javascript.1
    2023-01-12 07:51:11.374	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is/lib'
    javascript.1
    2023-01-12 07:51:11.372	error	npm WARN
    javascript.1
    2023-01-12 07:51:11.354	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/deps' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/plugins'
    javascript.1
    2023-01-12 07:51:11.345	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/test'
    javascript.1
    2023-01-12 07:51:11.338	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/test'
    javascript.1
    2023-01-12 07:51:11.332	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/test'
    javascript.1
    2023-01-12 07:51:11.323	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/locale'
    javascript.1
    2023-01-12 07:51:11.318	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/README.md'
    javascript.1
    2023-01-12 07:51:11.313	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/esm/helpers.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/esm/index.js'
    javascript.1
    2023-01-12 07:51:11.308	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/esm/node.js'
    javascript.1
    2023-01-12 07:51:11.303	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/esm/package.json'
    javascript.1
    2023-01-12 07:51:11.299	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data/lib/populate.js'
    javascript.1
    2023-01-12 07:51:11.293	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/pipe.js'
    javascript.1
    2023-01-12 07:51:11.292	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.eslintrc'
    javascript.1
    2023-01-12 07:51:11.287	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/package.json'
    javascript.1
    2023-01-12 07:51:11.283	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/test'
    javascript.1
    2023-01-12 07:51:11.279	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/package.json'
    javascript.1
    2023-01-12 07:51:11.273	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/cache.json'
    javascript.1
    2023-01-12 07:51:11.267	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:11.263	error	npm
    javascript.1
    2023-01-12 07:51:11.260	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/index.js'
    javascript.1
    2023-01-12 07:51:11.255	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib'
    javascript.1
    2023-01-12 07:51:11.250	error	npm
    javascript.1
    2023-01-12 07:51:11.246	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/esm/Parser.js'
    javascript.1
    2023-01-12 07:51:11.242	error
    javascript.1
    2023-01-12 07:51:11.240	error	npm
    javascript.1
    2023-01-12 07:51:11.235	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/example.html' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/.jshintrc'
    javascript.1
    2023-01-12 07:51:11.229	error	WARN
    javascript.1
    2023-01-12 07:51:11.226	error
    javascript.1
    2023-01-12 07:51:11.224	error	npm
    javascript.1
    2023-01-12 07:51:11.209	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/README.md'
    javascript.1
    2023-01-12 07:51:11.203	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/parse.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/test'
    javascript.1
    2023-01-12 07:51:11.197	error	npm
    javascript.1
    2023-01-12 07:51:11.193	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/readable_test.js'
    javascript.3
    2023-01-12 07:51:11.164	error	Cannot install exceljs: 217
    javascript.1
    2023-01-12 07:51:11.187	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/listenercount/test/test.js'
    javascript.1
    2023-01-12 07:51:11.176	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys/implementation.js'
    javascript.1
    2023-01-12 07:51:11.173	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/default_bool.js'
    javascript.1
    2023-01-12 07:51:11.168	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_converters_43_inl.h'
    javascript.1
    2023-01-12 07:51:11.166	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_repl.js'
    javascript.1
    2023-01-12 07:51:11.164	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js'
    javascript.1
    2023-01-12 07:51:11.141	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako/lib/utils'
    javascript.1
    2023-01-12 07:51:11.129	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5/dist/tree-adapters'
    javascript.1
    2023-01-12 07:51:11.120	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/license.txt'
    javascript.1
    2023-01-12 07:51:11.116	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/safer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js'
    javascript.1
    2023-01-12 07:51:11.107	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf/README.md'
    javascript.3
    2023-01-12 07:51:11.096	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2023-01-12T06_51_00_204Z-debug-0.log
    javascript.3
    2023-01-12 07:51:11.083	error	npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
    javascript.3
    2023-01-12 07:51:11.080	error	npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m npm ERR! errno -39
    javascript.3
    2023-01-12 07:51:11.073	error	npm ERR! code ENOTEMPTY
    javascript.1
    2023-01-12 07:51:11.070	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/lib'
    javascript.1
    2023-01-12 07:51:11.067	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver/classes/comparator.js'
    javascript.1
    2023-01-12 07:51:11.066	error	npm
    javascript.1
    2023-01-12 07:51:11.020	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/README.md'
    javascript.1
    2023-01-12 07:51:11.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/README.md'
    javascript.1
    2023-01-12 07:51:11.015	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/man/man1'
    javascript.1
    2023-01-12 07:51:11.013	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/test.js'
    javascript.1
    2023-01-12 07:51:11.010	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/sandbox.js'
    javascript.1
    2023-01-12 07:51:11.000	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/examples'
    javascript.1
    2023-01-12 07:51:10.997	error	npm
    javascript.1
    2023-01-12 07:51:10.993	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unzipper/lib/Open/directory.js'
    javascript.1
    2023-01-12 07:51:10.964	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js'
    javascript.2
    2023-01-12 07:51:10.951	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/LICENSE'
    javascript.1
    2023-01-12 07:51:10.958	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node/buffer.d.ts'
    javascript.1
    2023-01-12 07:51:10.956	error	npm
    javascript.2
    2023-01-12 07:51:10.945	error	tar
    javascript.2
    2023-01-12 07:51:10.941	error	npm WARN
    javascript.1
    2023-01-12 07:51:10.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node/buffer.d.ts'
    javascript.1
    2023-01-12 07:51:10.930	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid/dist/esm-browser/index.js'
    javascript.2
    2023-01-12 07:51:10.921	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/package.json'
    javascript.1
    2023-01-12 07:51:10.927	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anySeries.js'
    javascript.1
    2023-01-12 07:51:10.918	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data/yarn.lock'
    javascript.1
    2023-01-12 07:51:10.917	error	npm
    javascript.2
    2023-01-12 07:51:10.916	error	WARN
    javascript.2
    2023-01-12 07:51:10.914	error
    javascript.2
    2023-01-12 07:51:10.912	error	npm
    javascript.1
    2023-01-12 07:51:10.914	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/package.json'
    javascript.1
    2023-01-12 07:51:10.912	error	npm WARN
    javascript.1
    2023-01-12 07:51:10.911	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/test'
    javascript.1
    2023-01-12 07:51:10.910	error	npm
    javascript.2
    2023-01-12 07:51:10.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist/LICENSE'
    javascript.2
    2023-01-12 07:51:10.893	error
    javascript.2
    2023-01-12 07:51:10.891	error	WARN
    javascript.2
    2023-01-12 07:51:10.889	error
    javascript.2
    2023-01-12 07:51:10.887	error	npm
    javascript.1
    2023-01-12 07:51:10.873	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/build/src/formatter'
    javascript.1
    2023-01-12 07:51:10.872	error	npm
    javascript.1
    2023-01-12 07:51:10.843	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnParser.js'
    javascript.1
    2023-01-12 07:51:10.839	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib'
    javascript.1
    2023-01-12 07:51:10.837	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/index.js'
    javascript.1
    2023-01-12 07:51:10.836	error	npm
    javascript.1
    2023-01-12 07:51:10.832	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib'
    javascript.1
    2023-01-12 07:51:10.814	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer/BigInteger.min.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/README.md'
    javascript.1
    2023-01-12 07:51:10.804	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/parallel.js'
    javascript.1
    2023-01-12 07:51:10.800	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/README.md'
    javascript.1
    2023-01-12 07:51:10.788	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/test' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird/js/browser/bluebird.core.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/buf.js'
    javascript.1
    2023-01-12 07:51:10.764	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind/test/callBound.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer/package.json'
    javascript.1
    2023-01-12 07:51:10.741	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/README.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/example/map.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/bin/cake' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/prompt.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/dist/es5' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio-select/lib/helpers.js'
    javascript.1
    2023-01-12 07:51:10.713	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tslint.json'
    javascript.1
    2023-01-12 07:51:10.711	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.709	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/package.json'
    javascript.1
    2023-01-12 07:51:10.696	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.687	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile.targ'
    javascript.1
    2023-01-12 07:51:10.685	error	npm
    host.ioBroker
    2023-01-12 07:51:10.676	info	stopInstance system.adapter.alexa2.0 killing pid 17223
    javascript.1
    2023-01-12 07:51:10.674	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash/etc/dashdash.bash_completion.in' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn/lib/LICENSE-jsbn' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/lib/date.js'
    javascript.1
    2023-01-12 07:51:10.655	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-what/lib/es'
    javascript.1
    2023-01-12 07:51:10.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/feeds.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream/lib/delayed_stream.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/foreignNames.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/esm/locale/af.js'
    javascript.1
    2023-01-12 07:51:10.616	error	npm
    javascript.2
    2023-01-12 07:51:10.604	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async'
    javascript.1
    2023-01-12 07:51:10.603	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/component.json'
    javascript.1
    2023-01-12 07:51:10.598	error
    javascript.2
    2023-01-12 07:51:10.599	error	WARN
    javascript.2
    2023-01-12 07:51:10.596	error
    javascript.1
    2023-01-12 07:51:10.594	error	WARN
    javascript.1
    2023-01-12 07:51:10.592	error
    javascript.1
    2023-01-12 07:51:10.591	error	npm
    javascript.1
    2023-01-12 07:51:10.588	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has/test/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/esm/generated/decode-data-html.js'
    javascript.2
    2023-01-12 07:51:10.586	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node' npm
    javascript.1
    2023-01-12 07:51:10.577	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
    javascript.2
    2023-01-12 07:51:10.578	error	WARN
    javascript.2
    2023-01-12 07:51:10.576	error
    javascript.1
    2023-01-12 07:51:10.574	error
    javascript.2
    2023-01-12 07:51:10.574	error	npm
    javascript.1
    2023-01-12 07:51:10.572	error	npm
    javascript.1
    2023-01-12 07:51:10.567	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/filter-pipe.js'
    javascript.2
    2023-01-12 07:51:10.565	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node'
    javascript.1
    2023-01-12 07:51:10.560	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.travis.yml'
    javascript.2
    2023-01-12 07:51:10.558	error
    javascript.1
    2023-01-12 07:51:10.558	error	npm
    javascript.2
    2023-01-12 07:51:10.556	error	WARN
    javascript.2
    2023-01-12 07:51:10.554	error
    javascript.2
    2023-01-12 07:51:10.552	error	npm
    javascript.1
    2023-01-12 07:51:10.552	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/.travis.yml'
    javascript.1
    2023-01-12 07:51:10.549	error	npm
    javascript.2
    2023-01-12 07:51:10.548	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.546	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/index.js'
    javascript.1
    2023-01-12 07:51:10.541	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/README.md'
    javascript.2
    2023-01-12 07:51:10.537	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.536	error	npm
    javascript.2
    2023-01-12 07:51:10.532	error	tar
    javascript.1
    2023-01-12 07:51:10.532	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/browser.json'
    javascript.2
    2023-01-12 07:51:10.531	error
    javascript.1
    2023-01-12 07:51:10.525	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/README.md'
    javascript.2
    2023-01-12 07:51:10.529	error	WARN
    javascript.2
    2023-01-12 07:51:10.527	error
    javascript.2
    2023-01-12 07:51:10.525	error	npm
    javascript.1
    2023-01-12 07:51:10.521	error	npm
    javascript.2
    2023-01-12 07:51:10.521	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.517	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/package.json'
    javascript.1
    2023-01-12 07:51:10.514	error	npm
    javascript.2
    2023-01-12 07:51:10.510	error	tar
    javascript.1
    2023-01-12 07:51:10.509	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/get-own-property-symbols.js'
    javascript.2
    2023-01-12 07:51:10.508	error
    javascript.2
    2023-01-12 07:51:10.507	error	WARN
    javascript.1
    2023-01-12 07:51:10.506	error	npm
    javascript.2
    2023-01-12 07:51:10.505	error
    javascript.1
    2023-01-12 07:51:10.503	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/index.js'
    javascript.2
    javascript.2
    2023-01-12 07:51:10.501	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.496	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/Readme.md'
    javascript.1
    2023-01-12 07:51:10.494	error	npm
    javascript.1
    2023-01-12 07:51:10.489	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
    javascript.2
    2023-01-12 07:51:10.489	error	tar
    javascript.2
    2023-01-12 07:51:10.487	error
    javascript.1
    2023-01-12 07:51:10.486	error	npm
    javascript.2
    2023-01-12 07:51:10.485	error	WARN
    javascript.2
    2023-01-12 07:51:10.484	error
    javascript.2
    2023-01-12 07:51:10.482	error	npm
    javascript.1
    2023-01-12 07:51:10.477	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/package.json'
    javascript.2
    2023-01-12 07:51:10.477	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir/node_modules/semver' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/node_modules/rimraf'
    javascript.1
    2023-01-12 07:51:10.471	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
    javascript.1
    2023-01-12 07:51:10.469	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CHANGES.md'
    javascript.2
    2023-01-12 07:51:10.467	error
    javascript.2
    2023-01-12 07:51:10.465	error	WARN
    javascript.1
    2023-01-12 07:51:10.464	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/index.js'
    javascript.2
    2023-01-12 07:51:10.463	error
    javascript.2
    2023-01-12 07:51:10.462	error	npm
    javascript.1
    2023-01-12 07:51:10.460	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/pipe_test.js'
    javascript.2
    2023-01-12 07:51:10.457	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion'
    javascript.1
    2023-01-12 07:51:10.450	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types/README.md'
    javascript.1
    2023-01-12 07:51:10.448	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp/bin/usage.txt'
    javascript.1
    2023-01-12 07:51:10.446	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_callbacks.h' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/dash.js'
    javascript.1
    2023-01-12 07:51:10.441	error	npm
    javascript.2
    2023-01-12 07:51:10.443	error
    javascript.2
    2023-01-12 07:51:10.440	error	npm
    javascript.1
    2023-01-12 07:51:10.439	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_client.js'
    javascript.1
    2023-01-12 07:51:10.435	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-ssh/LICENSE.md'
    javascript.2
    2023-01-12 07:51:10.433	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data'
    javascript.1
    2023-01-12 07:51:10.431	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5-htmlparser2-tree-adapter/dist/index.js'
    javascript.1
    2023-01-12 07:51:10.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/.tm_properties'
    javascript.1
    2023-01-12 07:51:10.426	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors/types.ts'
    javascript.1
    2023-01-12 07:51:10.424	error	npm WARN tar
    javascript.2
    2023-01-12 07:51:10.424	error	WARN
    javascript.1
    2023-01-12 07:51:10.422	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode/README.md'
    javascript.2
    2023-01-12 07:51:10.423	error
    javascript.1
    2023-01-12 07:51:10.421	error	npm WARN
    javascript.2
    2023-01-12 07:51:10.420	error	npm
    javascript.1
    2023-01-12 07:51:10.419	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/getProxyFromURI.js'
    javascript.1
    2023-01-12 07:51:10.418	error	npm
    javascript.2
    2023-01-12 07:51:10.417	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs'
    javascript.2
    2023-01-12 07:51:10.410	error	tar
    javascript.2
    2023-01-12 07:51:10.409	error
    javascript.2
    2023-01-12 07:51:10.407	error	WARN
    javascript.2
    2023-01-12 07:51:10.405	error
    javascript.1
    2023-01-12 07:51:10.401	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/Readme.md'
    javascript.1
    2023-01-12 07:51:10.398	error
    javascript.1
    2023-01-12 07:51:10.395	error	npm
    javascript.2
    2023-01-12 07:51:10.391	error	npm
    javascript.1
    2023-01-12 07:51:10.391	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/saxes/saxes.js.map'
    javascript.1
    2023-01-12 07:51:10.383	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/README.md'
    javascript.2
    2023-01-12 07:51:10.381	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv'
    javascript.1
    2023-01-12 07:51:10.381	error	npm
    javascript.1
    2023-01-12 07:51:10.378	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-scandir/README.md'
    javascript.1
    2023-01-12 07:51:10.374	error
    javascript.2
    2023-01-12 07:51:10.373	error
    javascript.1
    2023-01-12 07:51:10.372	error	npm
    javascript.2
    2023-01-12 07:51:10.371	error	npm
    javascript.1
    2023-01-12 07:51:10.368	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/shell-escape/test/simple.js'
    javascript.1
    2023-01-12 07:51:10.358	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/package.json'
    javascript.1
    2023-01-12 07:51:10.354	error	npm
    javascript.1
    2023-01-12 07:51:10.351	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/LICENSE'
    javascript.1
    2023-01-12 07:51:10.348	error	npm
    javascript.1
    2023-01-12 07:51:10.343	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/pack.js'
    javascript.1
    2023-01-12 07:51:10.337	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tmp/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.330	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie/lib/cookie.js'
    javascript.1
    2023-01-12 07:51:10.327	error	npm
    javascript.1
    2023-01-12 07:51:10.322	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/LICENSE'
    javascript.1
    2023-01-12 07:51:10.320	error	WARN tar
    javascript.1
    2023-01-12 07:51:10.318	error
    javascript.2
    2023-01-12 07:51:10.316	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is'
    javascript.1
    2023-01-12 07:51:10.316	error	npm
    javascript.1
    2023-01-12 07:51:10.312	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl/nacl-fast.js'
    javascript.2
    2023-01-12 07:51:10.311	error
    javascript.2
    2023-01-12 07:51:10.309	error	WARN
    javascript.2
    2023-01-12 07:51:10.307	error
    javascript.1
    2023-01-12 07:51:10.306	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js/dist'
    javascript.2
    javascript.1
    2023-01-12 07:51:10.298	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5-browser.js'
    javascript.2
    2023-01-12 07:51:10.298	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.295	error
    javascript.1
    2023-01-12 07:51:10.293	error	WARN
    javascript.1
    2023-01-12 07:51:10.291	error	npm
    javascript.2
    2023-01-12 07:51:10.290	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils'
    javascript.2
    2023-01-12 07:51:10.287	error	WARN
    javascript.1
    2023-01-12 07:51:10.286	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CHANGES.md'
    javascript.2
    2023-01-12 07:51:10.285	error
    javascript.1
    2023-01-12 07:51:10.283	error
    javascript.2
    2023-01-12 07:51:10.283	error	npm
    javascript.1
    2023-01-12 07:51:10.282	error	npm
    javascript.1
    2023-01-12 07:51:10.278	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/test.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xmlns/1.0/ed3.js'
    javascript.2
    2023-01-12 07:51:10.277	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
    javascript.2
    2023-01-12 07:51:10.273	error
    javascript.1
    2023-01-12 07:51:10.272	error
    javascript.2
    2023-01-12 07:51:10.271	error	npm
    javascript.1
    2023-01-12 07:51:10.270	error	npm
    javascript.2
    2023-01-12 07:51:10.265	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
    javascript.1
    2023-01-12 07:51:10.262	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anyLimit.js'
    javascript.2
    2023-01-12 07:51:10.261	error
    javascript.1
    2023-01-12 07:51:10.259	error
    javascript.2
    2023-01-12 07:51:10.259	error	WARN
    javascript.1
    2023-01-12 07:51:10.257	error	WARN
    javascript.2
    javascript.1
    2023-01-12 07:51:10.255	error
    javascript.2
    2023-01-12 07:51:10.255	error	npm
    javascript.1
    2023-01-12 07:51:10.253	error	npm
    javascript.2
    2023-01-12 07:51:10.250	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
    javascript.2
    2023-01-12 07:51:10.241	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
    javascript.1
    2023-01-12 07:51:10.239	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion/.github/FUNDING.yml'
    javascript.2
    2023-01-12 07:51:10.237	error
    javascript.2
    2023-01-12 07:51:10.235	error	WARN
    javascript.2
    2023-01-12 07:51:10.233	error
    javascript.1
    2023-01-12 07:51:10.229	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/lib/path.js'
    javascript.2
    2023-01-12 07:51:10.231	error	npm
    javascript.1
    2023-01-12 07:51:10.226	error
    javascript.1
    2023-01-12 07:51:10.224	error	npm WARN
    javascript.2
    2023-01-12 07:51:10.218	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format'
    javascript.2
    2023-01-12 07:51:10.209	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse'
    javascript.1
    2023-01-12 07:51:10.214	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/lib/index.js'
    javascript.2
    2023-01-12 07:51:10.205	error
    javascript.1
    2023-01-12 07:51:10.199	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnFormatter.js'
    javascript.2
    2023-01-12 07:51:10.203	error	WARN
    javascript.2
    2023-01-12 07:51:10.201	error
    javascript.2
    2023-01-12 07:51:10.199	error	npm
    javascript.1
    2023-01-12 07:51:10.182	error	npm
    javascript.2
    2023-01-12 07:51:10.193	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver'
    javascript.2
    2023-01-12 07:51:10.182	error	tar
    javascript.2
    2023-01-12 07:51:10.181	error
    javascript.2
    2023-01-12 07:51:10.179	error	WARN
    javascript.2
    2023-01-12 07:51:10.177	error
    javascript.2
    2023-01-12 07:51:10.175	error	npm
    javascript.1
    2023-01-12 07:51:10.167	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/scripts/travis-gh-pages'
    javascript.1
    2023-01-12 07:51:10.163	error	npm
    javascript.2
    2023-01-12 07:51:10.162	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
    javascript.2
    2023-01-12 07:51:10.161	error	npm
    javascript.2
    2023-01-12 07:51:10.155	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
    javascript.2
    2023-01-12 07:51:10.154	error	npm
    javascript.1
    2023-01-12 07:51:10.154	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/error.js'
    javascript.1
    2023-01-12 07:51:10.151	error
    javascript.1
    2023-01-12 07:51:10.149	error	npm
    javascript.1
    2023-01-12 07:51:10.143	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib/ber/index.js'
    javascript.1
    2023-01-12 07:51:10.140	error	tar
    javascript.1
    2023-01-12 07:51:10.139	error
    javascript.1
    2023-01-12 07:51:10.136	error	WARN
    javascript.1
    2023-01-12 07:51:10.134	error
    javascript.2
    2023-01-12 07:51:10.134	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
    javascript.2
    2023-01-12 07:51:10.132	error	npm
    javascript.1
    javascript.2
    2023-01-12 07:51:10.125	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4'
    javascript.2
    2023-01-12 07:51:10.123	error	npm
    javascript.1
    2023-01-12 07:51:10.113	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/LICENSE'
    javascript.1
    2023-01-12 07:51:10.105	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils/README.md'
    javascript.2
    2023-01-12 07:51:10.097	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
    javascript.2
    2023-01-12 07:51:10.096	error	npm
    javascript.1
    2023-01-12 07:51:10.101	error
    javascript.1
    2023-01-12 07:51:10.099	error	WARN
    javascript.1
    javascript.1
    javascript.2
    2023-01-12 07:51:10.091	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
    javascript.2
    2023-01-12 07:51:10.090	error	npm
    javascript.1
    2023-01-12 07:51:10.079	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/stream.js'
    javascript.1
    2023-01-12 07:51:10.078	error	npm
    javascript.1
    2023-01-12 07:51:10.020	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/package.json'
    javascript.1
    2023-01-12 07:51:10.019	error	npm
    javascript.1
    2023-01-12 07:51:10.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match/.github/FUNDING.yml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js/index.d.ts'
    javascript.2
    2023-01-12 07:51:10.013	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
    javascript.2
    2023-01-12 07:51:10.012	error	WARN
    javascript.1
    2023-01-12 07:51:10.009	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/parse.js'
    javascript.1
    2023-01-12 07:51:10.007	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/init-buffer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/examples/splice.js'
    javascript.1
    2023-01-12 07:51:09.986	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/add_do.js'
    javascript.2
    2023-01-12 07:51:09.990	error	npm
    javascript.2
    2023-01-12 07:51:09.987	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer'
    javascript.1
    2023-01-12 07:51:09.985	error	npm
    javascript.2
    2023-01-12 07:51:09.980	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary'
    javascript.1
    2023-01-12 07:51:09.981	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/lib'
    javascript.1
    2023-01-12 07:51:09.979	error	npm
    javascript.2
    2023-01-12 07:51:09.965	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird'
    javascript.1
    2023-01-12 07:51:09.973	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream/lib/combined_stream.js'
    javascript.1
    2023-01-12 07:51:09.971	error	npm
    javascript.2
    2023-01-12 07:51:09.956	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/boolbase'
    javascript.2
    2023-01-12 07:51:09.945	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
    javascript.1
    2023-01-12 07:51:09.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tsconfig.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/LICENSE'
    javascript.2
    2023-01-12 07:51:09.930	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv'
    javascript.2
    2023-01-12 07:51:09.921	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
    javascript.1
    2023-01-12 07:51:09.926	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/package.json'
    javascript.1
    2023-01-12 07:51:09.921	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/react.js'
    javascript.2
    2023-01-12 07:51:09.915	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers'
    javascript.1
    2023-01-12 07:51:09.915	error	tar
    javascript.1
    2023-01-12 07:51:09.913	error
    javascript.1
    2023-01-12 07:51:09.911	error	WARN
    javascript.1
    2023-01-12 07:51:09.910	error
    javascript.1
    2023-01-12 07:51:09.908	error	npm
    javascript.2
    2023-01-12 07:51:09.906	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
    javascript.2
    2023-01-12 07:51:09.905	error	npm
    javascript.1
    2023-01-12 07:51:09.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-select/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/build/src/index.js.map'
    javascript.1
    2023-01-12 07:51:09.891	error
    javascript.2
    2023-01-12 07:51:09.890	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck'
    javascript.1
    2023-01-12 07:51:09.889	error	WARN
    javascript.2
    2023-01-12 07:51:09.887	error	npm
    javascript.1
    javascript.1
    2023-01-12 07:51:09.884	error	npm
    javascript.2
    2023-01-12 07:51:09.883	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
    javascript.2
    2023-01-12 07:51:09.881	error	npm
    javascript.1
    2023-01-12 07:51:09.881	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/src/node.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/package.json'
    javascript.1
    2023-01-12 07:51:09.870	error
    javascript.1
    2023-01-12 07:51:09.867	error	WARN
    javascript.2
    2023-01-12 07:51:09.864	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw'
    javascript.1
    2023-01-12 07:51:09.865	error
    javascript.1
    2023-01-12 07:51:09.863	error	npm
    javascript.2
    2023-01-12 07:51:09.858	error	npm
    javascript.1
    2023-01-12 07:51:09.853	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:09.844	error
    javascript.1
    2023-01-12 07:51:09.841	error	WARN
    javascript.1
    2023-01-12 07:51:09.839	error
    javascript.1
    2023-01-12 07:51:09.837	error	npm
    javascript.1
    2023-01-12 07:51:09.830	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/index.js'
    javascript.1
    2023-01-12 07:51:09.823	error	npm
    javascript.1
    2023-01-12 07:51:09.817	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/lib/index.js'
    javascript.1
    2023-01-12 07:51:09.815	error	npm
    javascript.1
    2023-01-12 07:51:09.807	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/implementation.js'
    javascript.1
    2023-01-12 07:51:09.801	error	npm
    javascript.1
    2023-01-12 07:51:09.796	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/sync.js'
    javascript.1
    2023-01-12 07:51:09.783	error
    javascript.1
    2023-01-12 07:51:09.781	error	WARN
    javascript.1
    2023-01-12 07:51:09.778	error
    javascript.1
    2023-01-12 07:51:09.776	error	npm
    javascript.1
    2023-01-12 07:51:09.773	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/header.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/package.json'
    javascript.1
    2023-01-12 07:51:09.762	error	npm
    javascript.1
    2023-01-12 07:51:09.758	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/test/index.js'
    javascript.1
    2023-01-12 07:51:09.752	error	WARN
    javascript.1
    2023-01-12 07:51:09.749	error
    javascript.1
    2023-01-12 07:51:09.746	error	npm
    javascript.1
    2023-01-12 07:51:09.741	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/core-js.js'
    javascript.1
    2023-01-12 07:51:09.739	error	npm
    javascript.1
    2023-01-12 07:51:09.700	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/http_signing.md'
    javascript.1
    2023-01-12 07:51:09.699	error	npm
    javascript.1
    2023-01-12 07:51:09.672	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/LICENSE'
    javascript.1
    2023-01-12 07:51:09.670	error	npm
    javascript.1
    2023-01-12 07:51:09.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/dist/immediate.min.js'
    javascript.1
    2023-01-12 07:51:09.648	error	npm
    javascript.1
    2023-01-12 07:51:09.620	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/LICENSE.md'
    javascript.1
    2023-01-12 07:51:09.608	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/index.js'
    javascript.1
    2023-01-12 07:51:09.594	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/README.md'
    javascript.1
    2023-01-12 07:51:09.592	error	npm
    javascript.1
    2023-01-12 07:51:09.582	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/package.json'
    javascript.1
    2023-01-12 07:51:09.580	error	npm
    javascript.1
    2023-01-12 07:51:09.573	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/index.js'
    javascript.1
    2023-01-12 07:51:09.569	error	npm
    • H homecineplexx
      Hallo
      seit neuestem kommen nach dem Starten des ioBrokers folgende Fehler.
      kann ich das was tun, wenn ja was?
      npm version: 8.19.2
      nodejs: v16.18.1
      node: v16.18.1
      javascript.2
      2023-01-12 07:51:16.251	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.2
      2023-01-12 07:51:16.249	error	npm
      host.ioBroker
      2023-01-12 07:51:16.067	info	instance system.adapter.mqtt.0 started with pid 17310
      javascript.2
      2023-01-12 07:51:15.579	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.2
      2023-01-12 07:51:15.575	error	npm
      javascript.2
      2023-01-12 07:51:13.934	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      javascript.2
      2023-01-12 07:51:13.932	error	npm
      host.ioBroker
      2023-01-12 07:51:13.027	info	instance system.adapter.alexa2.0 started with pid 17294
      host.ioBroker
      2023-01-12 07:51:12.937	info	instance system.adapter.mihome.0 started with pid 17288
      javascript.1
      2023-01-12 07:51:12.773	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.1
      2023-01-12 07:51:12.771	error	npm WARN
      javascript.2
      2023-01-12 07:51:12.558	error	deprecated har-validator@5.1.5: this library is no longer supported
      javascript.2
      2023-01-12 07:51:12.556	error	WARN
      javascript.2
      2023-01-12 07:51:12.554	error
      javascript.2
      2023-01-12 07:51:12.551	error	npm
      javascript.1
      2023-01-12 07:51:12.355	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.1
      2023-01-12 07:51:12.353	error	npm WARN
      javascript.1
      2023-01-12 07:51:11.873	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      javascript.1
      2023-01-12 07:51:11.871	error	npm
      host.ioBroker
      2023-01-12 07:51:11.249	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      javascript.1
      2023-01-12 07:51:11.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/generated'
      javascript.1
      2023-01-12 07:51:11.426	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
      javascript.1
      2023-01-12 07:51:11.424	error	npm
      javascript.1
      2023-01-12 07:51:11.416	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
      javascript.1
      2023-01-12 07:51:11.414	error	npm
      javascript.1
      2023-01-12 07:51:11.410	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
      javascript.1
      2023-01-12 07:51:11.409	error	npm
      javascript.1
      2023-01-12 07:51:11.396	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/src'
      javascript.1
      2023-01-12 07:51:11.395	error	npm
      javascript.1
      2023-01-12 07:51:11.386	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/lib'
      javascript.1
      2023-01-12 07:51:11.384	error	npm
      javascript.1
      2023-01-12 07:51:11.374	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is/lib'
      javascript.1
      2023-01-12 07:51:11.372	error	npm WARN
      javascript.1
      2023-01-12 07:51:11.354	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/deps' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/plugins'
      javascript.1
      2023-01-12 07:51:11.345	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/test'
      javascript.1
      2023-01-12 07:51:11.338	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/test'
      javascript.1
      2023-01-12 07:51:11.332	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/test'
      javascript.1
      2023-01-12 07:51:11.323	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/locale'
      javascript.1
      2023-01-12 07:51:11.318	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/README.md'
      javascript.1
      2023-01-12 07:51:11.313	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/esm/helpers.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/esm/index.js'
      javascript.1
      2023-01-12 07:51:11.308	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/esm/node.js'
      javascript.1
      2023-01-12 07:51:11.303	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/esm/package.json'
      javascript.1
      2023-01-12 07:51:11.299	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data/lib/populate.js'
      javascript.1
      2023-01-12 07:51:11.293	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/pipe.js'
      javascript.1
      2023-01-12 07:51:11.292	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.eslintrc'
      javascript.1
      2023-01-12 07:51:11.287	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/package.json'
      javascript.1
      2023-01-12 07:51:11.283	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/test'
      javascript.1
      2023-01-12 07:51:11.279	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/package.json'
      javascript.1
      2023-01-12 07:51:11.273	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/cache.json'
      javascript.1
      2023-01-12 07:51:11.267	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/CHANGELOG.md'
      javascript.1
      2023-01-12 07:51:11.263	error	npm
      javascript.1
      2023-01-12 07:51:11.260	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/index.js'
      javascript.1
      2023-01-12 07:51:11.255	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib'
      javascript.1
      2023-01-12 07:51:11.250	error	npm
      javascript.1
      2023-01-12 07:51:11.246	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/esm/Parser.js'
      javascript.1
      2023-01-12 07:51:11.242	error
      javascript.1
      2023-01-12 07:51:11.240	error	npm
      javascript.1
      2023-01-12 07:51:11.235	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/example.html' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/.jshintrc'
      javascript.1
      2023-01-12 07:51:11.229	error	WARN
      javascript.1
      2023-01-12 07:51:11.226	error
      javascript.1
      2023-01-12 07:51:11.224	error	npm
      javascript.1
      2023-01-12 07:51:11.209	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/README.md'
      javascript.1
      2023-01-12 07:51:11.203	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/parse.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/test'
      javascript.1
      2023-01-12 07:51:11.197	error	npm
      javascript.1
      2023-01-12 07:51:11.193	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/readable_test.js'
      javascript.3
      2023-01-12 07:51:11.164	error	Cannot install exceljs: 217
      javascript.1
      2023-01-12 07:51:11.187	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/listenercount/test/test.js'
      javascript.1
      2023-01-12 07:51:11.176	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys/implementation.js'
      javascript.1
      2023-01-12 07:51:11.173	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/default_bool.js'
      javascript.1
      2023-01-12 07:51:11.168	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_converters_43_inl.h'
      javascript.1
      2023-01-12 07:51:11.166	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_repl.js'
      javascript.1
      2023-01-12 07:51:11.164	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js'
      javascript.1
      2023-01-12 07:51:11.141	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako/lib/utils'
      javascript.1
      2023-01-12 07:51:11.129	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5/dist/tree-adapters'
      javascript.1
      2023-01-12 07:51:11.120	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/license.txt'
      javascript.1
      2023-01-12 07:51:11.116	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/safer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js'
      javascript.1
      2023-01-12 07:51:11.107	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf/README.md'
      javascript.3
      2023-01-12 07:51:11.096	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2023-01-12T06_51_00_204Z-debug-0.log
      javascript.3
      2023-01-12 07:51:11.083	error	npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
      javascript.3
      2023-01-12 07:51:11.080	error	npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m npm ERR! errno -39
      javascript.3
      2023-01-12 07:51:11.073	error	npm ERR! code ENOTEMPTY
      javascript.1
      2023-01-12 07:51:11.070	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/lib'
      javascript.1
      2023-01-12 07:51:11.067	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver/classes/comparator.js'
      javascript.1
      2023-01-12 07:51:11.066	error	npm
      javascript.1
      2023-01-12 07:51:11.020	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/README.md'
      javascript.1
      2023-01-12 07:51:11.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/README.md'
      javascript.1
      2023-01-12 07:51:11.015	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/man/man1'
      javascript.1
      2023-01-12 07:51:11.013	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/test.js'
      javascript.1
      2023-01-12 07:51:11.010	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/sandbox.js'
      javascript.1
      2023-01-12 07:51:11.000	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/examples'
      javascript.1
      2023-01-12 07:51:10.997	error	npm
      javascript.1
      2023-01-12 07:51:10.993	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unzipper/lib/Open/directory.js'
      javascript.1
      2023-01-12 07:51:10.964	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js'
      javascript.2
      2023-01-12 07:51:10.951	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/LICENSE'
      javascript.1
      2023-01-12 07:51:10.958	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node/buffer.d.ts'
      javascript.1
      2023-01-12 07:51:10.956	error	npm
      javascript.2
      2023-01-12 07:51:10.945	error	tar
      javascript.2
      2023-01-12 07:51:10.941	error	npm WARN
      javascript.1
      2023-01-12 07:51:10.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node/buffer.d.ts'
      javascript.1
      2023-01-12 07:51:10.930	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid/dist/esm-browser/index.js'
      javascript.2
      2023-01-12 07:51:10.921	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/package.json'
      javascript.1
      2023-01-12 07:51:10.927	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anySeries.js'
      javascript.1
      2023-01-12 07:51:10.918	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data/yarn.lock'
      javascript.1
      2023-01-12 07:51:10.917	error	npm
      javascript.2
      2023-01-12 07:51:10.916	error	WARN
      javascript.2
      2023-01-12 07:51:10.914	error
      javascript.2
      2023-01-12 07:51:10.912	error	npm
      javascript.1
      2023-01-12 07:51:10.914	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/package.json'
      javascript.1
      2023-01-12 07:51:10.912	error	npm WARN
      javascript.1
      2023-01-12 07:51:10.911	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/test'
      javascript.1
      2023-01-12 07:51:10.910	error	npm
      javascript.2
      2023-01-12 07:51:10.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist/LICENSE'
      javascript.2
      2023-01-12 07:51:10.893	error
      javascript.2
      2023-01-12 07:51:10.891	error	WARN
      javascript.2
      2023-01-12 07:51:10.889	error
      javascript.2
      2023-01-12 07:51:10.887	error	npm
      javascript.1
      2023-01-12 07:51:10.873	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/build/src/formatter'
      javascript.1
      2023-01-12 07:51:10.872	error	npm
      javascript.1
      2023-01-12 07:51:10.843	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnParser.js'
      javascript.1
      2023-01-12 07:51:10.839	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib'
      javascript.1
      2023-01-12 07:51:10.837	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/index.js'
      javascript.1
      2023-01-12 07:51:10.836	error	npm
      javascript.1
      2023-01-12 07:51:10.832	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib'
      javascript.1
      2023-01-12 07:51:10.814	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer/BigInteger.min.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/README.md'
      javascript.1
      2023-01-12 07:51:10.804	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/parallel.js'
      javascript.1
      2023-01-12 07:51:10.800	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/README.md'
      javascript.1
      2023-01-12 07:51:10.788	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/test' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird/js/browser/bluebird.core.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/buf.js'
      javascript.1
      2023-01-12 07:51:10.764	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind/test/callBound.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer/package.json'
      javascript.1
      2023-01-12 07:51:10.741	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/README.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/example/map.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/bin/cake' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/prompt.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/dist/es5' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio-select/lib/helpers.js'
      javascript.1
      2023-01-12 07:51:10.713	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tslint.json'
      javascript.1
      2023-01-12 07:51:10.711	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/CHANGELOG.md'
      javascript.1
      2023-01-12 07:51:10.709	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/package.json'
      javascript.1
      2023-01-12 07:51:10.696	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/CHANGELOG.md'
      javascript.1
      2023-01-12 07:51:10.687	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile.targ'
      javascript.1
      2023-01-12 07:51:10.685	error	npm
      host.ioBroker
      2023-01-12 07:51:10.676	info	stopInstance system.adapter.alexa2.0 killing pid 17223
      javascript.1
      2023-01-12 07:51:10.674	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash/etc/dashdash.bash_completion.in' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn/lib/LICENSE-jsbn' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/lib/date.js'
      javascript.1
      2023-01-12 07:51:10.655	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-what/lib/es'
      javascript.1
      2023-01-12 07:51:10.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/feeds.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream/lib/delayed_stream.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/foreignNames.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/esm/locale/af.js'
      javascript.1
      2023-01-12 07:51:10.616	error	npm
      javascript.2
      2023-01-12 07:51:10.604	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async'
      javascript.1
      2023-01-12 07:51:10.603	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/component.json'
      javascript.1
      2023-01-12 07:51:10.598	error
      javascript.2
      2023-01-12 07:51:10.599	error	WARN
      javascript.2
      2023-01-12 07:51:10.596	error
      javascript.1
      2023-01-12 07:51:10.594	error	WARN
      javascript.1
      2023-01-12 07:51:10.592	error
      javascript.1
      2023-01-12 07:51:10.591	error	npm
      javascript.1
      2023-01-12 07:51:10.588	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has/test/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/esm/generated/decode-data-html.js'
      javascript.2
      2023-01-12 07:51:10.586	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node' npm
      javascript.1
      2023-01-12 07:51:10.577	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
      javascript.2
      2023-01-12 07:51:10.578	error	WARN
      javascript.2
      2023-01-12 07:51:10.576	error
      javascript.1
      2023-01-12 07:51:10.574	error
      javascript.2
      2023-01-12 07:51:10.574	error	npm
      javascript.1
      2023-01-12 07:51:10.572	error	npm
      javascript.1
      2023-01-12 07:51:10.567	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/filter-pipe.js'
      javascript.2
      2023-01-12 07:51:10.565	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node'
      javascript.1
      2023-01-12 07:51:10.560	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.travis.yml'
      javascript.2
      2023-01-12 07:51:10.558	error
      javascript.1
      2023-01-12 07:51:10.558	error	npm
      javascript.2
      2023-01-12 07:51:10.556	error	WARN
      javascript.2
      2023-01-12 07:51:10.554	error
      javascript.2
      2023-01-12 07:51:10.552	error	npm
      javascript.1
      2023-01-12 07:51:10.552	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/.travis.yml'
      javascript.1
      2023-01-12 07:51:10.549	error	npm
      javascript.2
      2023-01-12 07:51:10.548	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/readable-stream'
      javascript.1
      2023-01-12 07:51:10.546	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/index.js'
      javascript.1
      2023-01-12 07:51:10.541	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/README.md'
      javascript.2
      2023-01-12 07:51:10.537	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl/node_modules/readable-stream'
      javascript.1
      2023-01-12 07:51:10.536	error	npm
      javascript.2
      2023-01-12 07:51:10.532	error	tar
      javascript.1
      2023-01-12 07:51:10.532	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/browser.json'
      javascript.2
      2023-01-12 07:51:10.531	error
      javascript.1
      2023-01-12 07:51:10.525	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/README.md'
      javascript.2
      2023-01-12 07:51:10.529	error	WARN
      javascript.2
      2023-01-12 07:51:10.527	error
      javascript.2
      2023-01-12 07:51:10.525	error	npm
      javascript.1
      2023-01-12 07:51:10.521	error	npm
      javascript.2
      2023-01-12 07:51:10.521	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/node_modules/readable-stream'
      javascript.1
      2023-01-12 07:51:10.517	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/package.json'
      javascript.1
      2023-01-12 07:51:10.514	error	npm
      javascript.2
      2023-01-12 07:51:10.510	error	tar
      javascript.1
      2023-01-12 07:51:10.509	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/get-own-property-symbols.js'
      javascript.2
      2023-01-12 07:51:10.508	error
      javascript.2
      2023-01-12 07:51:10.507	error	WARN
      javascript.1
      2023-01-12 07:51:10.506	error	npm
      javascript.2
      2023-01-12 07:51:10.505	error
      javascript.1
      2023-01-12 07:51:10.503	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/index.js'
      javascript.2
      javascript.2
      2023-01-12 07:51:10.501	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/readable-stream'
      javascript.1
      2023-01-12 07:51:10.496	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/Readme.md'
      javascript.1
      2023-01-12 07:51:10.494	error	npm
      javascript.1
      2023-01-12 07:51:10.489	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
      javascript.2
      2023-01-12 07:51:10.489	error	tar
      javascript.2
      2023-01-12 07:51:10.487	error
      javascript.1
      2023-01-12 07:51:10.486	error	npm
      javascript.2
      2023-01-12 07:51:10.485	error	WARN
      javascript.2
      2023-01-12 07:51:10.484	error
      javascript.2
      2023-01-12 07:51:10.482	error	npm
      javascript.1
      2023-01-12 07:51:10.477	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/package.json'
      javascript.2
      2023-01-12 07:51:10.477	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir/node_modules/semver' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/node_modules/rimraf'
      javascript.1
      2023-01-12 07:51:10.471	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
      javascript.1
      2023-01-12 07:51:10.469	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CHANGES.md'
      javascript.2
      2023-01-12 07:51:10.467	error
      javascript.2
      2023-01-12 07:51:10.465	error	WARN
      javascript.1
      2023-01-12 07:51:10.464	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/index.js'
      javascript.2
      2023-01-12 07:51:10.463	error
      javascript.2
      2023-01-12 07:51:10.462	error	npm
      javascript.1
      2023-01-12 07:51:10.460	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/pipe_test.js'
      javascript.2
      2023-01-12 07:51:10.457	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion'
      javascript.1
      2023-01-12 07:51:10.450	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types/README.md'
      javascript.1
      2023-01-12 07:51:10.448	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp/bin/usage.txt'
      javascript.1
      2023-01-12 07:51:10.446	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_callbacks.h' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/dash.js'
      javascript.1
      2023-01-12 07:51:10.441	error	npm
      javascript.2
      2023-01-12 07:51:10.443	error
      javascript.2
      2023-01-12 07:51:10.440	error	npm
      javascript.1
      2023-01-12 07:51:10.439	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_client.js'
      javascript.1
      2023-01-12 07:51:10.435	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-ssh/LICENSE.md'
      javascript.2
      2023-01-12 07:51:10.433	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data'
      javascript.1
      2023-01-12 07:51:10.431	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5-htmlparser2-tree-adapter/dist/index.js'
      javascript.1
      2023-01-12 07:51:10.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/.tm_properties'
      javascript.1
      2023-01-12 07:51:10.426	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors/types.ts'
      javascript.1
      2023-01-12 07:51:10.424	error	npm WARN tar
      javascript.2
      2023-01-12 07:51:10.424	error	WARN
      javascript.1
      2023-01-12 07:51:10.422	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode/README.md'
      javascript.2
      2023-01-12 07:51:10.423	error
      javascript.1
      2023-01-12 07:51:10.421	error	npm WARN
      javascript.2
      2023-01-12 07:51:10.420	error	npm
      javascript.1
      2023-01-12 07:51:10.419	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/getProxyFromURI.js'
      javascript.1
      2023-01-12 07:51:10.418	error	npm
      javascript.2
      2023-01-12 07:51:10.417	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs'
      javascript.2
      2023-01-12 07:51:10.410	error	tar
      javascript.2
      2023-01-12 07:51:10.409	error
      javascript.2
      2023-01-12 07:51:10.407	error	WARN
      javascript.2
      2023-01-12 07:51:10.405	error
      javascript.1
      2023-01-12 07:51:10.401	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/Readme.md'
      javascript.1
      2023-01-12 07:51:10.398	error
      javascript.1
      2023-01-12 07:51:10.395	error	npm
      javascript.2
      2023-01-12 07:51:10.391	error	npm
      javascript.1
      2023-01-12 07:51:10.391	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/saxes/saxes.js.map'
      javascript.1
      2023-01-12 07:51:10.383	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/README.md'
      javascript.2
      2023-01-12 07:51:10.381	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv'
      javascript.1
      2023-01-12 07:51:10.381	error	npm
      javascript.1
      2023-01-12 07:51:10.378	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-scandir/README.md'
      javascript.1
      2023-01-12 07:51:10.374	error
      javascript.2
      2023-01-12 07:51:10.373	error
      javascript.1
      2023-01-12 07:51:10.372	error	npm
      javascript.2
      2023-01-12 07:51:10.371	error	npm
      javascript.1
      2023-01-12 07:51:10.368	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/shell-escape/test/simple.js'
      javascript.1
      2023-01-12 07:51:10.358	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/package.json'
      javascript.1
      2023-01-12 07:51:10.354	error	npm
      javascript.1
      2023-01-12 07:51:10.351	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/LICENSE'
      javascript.1
      2023-01-12 07:51:10.348	error	npm
      javascript.1
      2023-01-12 07:51:10.343	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/pack.js'
      javascript.1
      2023-01-12 07:51:10.337	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tmp/CHANGELOG.md'
      javascript.1
      2023-01-12 07:51:10.330	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie/lib/cookie.js'
      javascript.1
      2023-01-12 07:51:10.327	error	npm
      javascript.1
      2023-01-12 07:51:10.322	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/LICENSE'
      javascript.1
      2023-01-12 07:51:10.320	error	WARN tar
      javascript.1
      2023-01-12 07:51:10.318	error
      javascript.2
      2023-01-12 07:51:10.316	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is'
      javascript.1
      2023-01-12 07:51:10.316	error	npm
      javascript.1
      2023-01-12 07:51:10.312	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl/nacl-fast.js'
      javascript.2
      2023-01-12 07:51:10.311	error
      javascript.2
      2023-01-12 07:51:10.309	error	WARN
      javascript.2
      2023-01-12 07:51:10.307	error
      javascript.1
      2023-01-12 07:51:10.306	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js/dist'
      javascript.2
      javascript.1
      2023-01-12 07:51:10.298	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5-browser.js'
      javascript.2
      2023-01-12 07:51:10.298	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/node_modules/readable-stream'
      javascript.1
      2023-01-12 07:51:10.295	error
      javascript.1
      2023-01-12 07:51:10.293	error	WARN
      javascript.1
      2023-01-12 07:51:10.291	error	npm
      javascript.2
      2023-01-12 07:51:10.290	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils'
      javascript.2
      2023-01-12 07:51:10.287	error	WARN
      javascript.1
      2023-01-12 07:51:10.286	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CHANGES.md'
      javascript.2
      2023-01-12 07:51:10.285	error
      javascript.1
      2023-01-12 07:51:10.283	error
      javascript.2
      2023-01-12 07:51:10.283	error	npm
      javascript.1
      2023-01-12 07:51:10.282	error	npm
      javascript.1
      2023-01-12 07:51:10.278	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/test.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xmlns/1.0/ed3.js'
      javascript.2
      2023-01-12 07:51:10.277	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
      javascript.2
      2023-01-12 07:51:10.273	error
      javascript.1
      2023-01-12 07:51:10.272	error
      javascript.2
      2023-01-12 07:51:10.271	error	npm
      javascript.1
      2023-01-12 07:51:10.270	error	npm
      javascript.2
      2023-01-12 07:51:10.265	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
      javascript.1
      2023-01-12 07:51:10.262	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anyLimit.js'
      javascript.2
      2023-01-12 07:51:10.261	error
      javascript.1
      2023-01-12 07:51:10.259	error
      javascript.2
      2023-01-12 07:51:10.259	error	WARN
      javascript.1
      2023-01-12 07:51:10.257	error	WARN
      javascript.2
      javascript.1
      2023-01-12 07:51:10.255	error
      javascript.2
      2023-01-12 07:51:10.255	error	npm
      javascript.1
      2023-01-12 07:51:10.253	error	npm
      javascript.2
      2023-01-12 07:51:10.250	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
      javascript.2
      2023-01-12 07:51:10.241	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
      javascript.1
      2023-01-12 07:51:10.239	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion/.github/FUNDING.yml'
      javascript.2
      2023-01-12 07:51:10.237	error
      javascript.2
      2023-01-12 07:51:10.235	error	WARN
      javascript.2
      2023-01-12 07:51:10.233	error
      javascript.1
      2023-01-12 07:51:10.229	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/lib/path.js'
      javascript.2
      2023-01-12 07:51:10.231	error	npm
      javascript.1
      2023-01-12 07:51:10.226	error
      javascript.1
      2023-01-12 07:51:10.224	error	npm WARN
      javascript.2
      2023-01-12 07:51:10.218	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format'
      javascript.2
      2023-01-12 07:51:10.209	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse'
      javascript.1
      2023-01-12 07:51:10.214	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/lib/index.js'
      javascript.2
      2023-01-12 07:51:10.205	error
      javascript.1
      2023-01-12 07:51:10.199	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnFormatter.js'
      javascript.2
      2023-01-12 07:51:10.203	error	WARN
      javascript.2
      2023-01-12 07:51:10.201	error
      javascript.2
      2023-01-12 07:51:10.199	error	npm
      javascript.1
      2023-01-12 07:51:10.182	error	npm
      javascript.2
      2023-01-12 07:51:10.193	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver'
      javascript.2
      2023-01-12 07:51:10.182	error	tar
      javascript.2
      2023-01-12 07:51:10.181	error
      javascript.2
      2023-01-12 07:51:10.179	error	WARN
      javascript.2
      2023-01-12 07:51:10.177	error
      javascript.2
      2023-01-12 07:51:10.175	error	npm
      javascript.1
      2023-01-12 07:51:10.167	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/scripts/travis-gh-pages'
      javascript.1
      2023-01-12 07:51:10.163	error	npm
      javascript.2
      2023-01-12 07:51:10.162	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
      javascript.2
      2023-01-12 07:51:10.161	error	npm
      javascript.2
      2023-01-12 07:51:10.155	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
      javascript.2
      2023-01-12 07:51:10.154	error	npm
      javascript.1
      2023-01-12 07:51:10.154	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/error.js'
      javascript.1
      2023-01-12 07:51:10.151	error
      javascript.1
      2023-01-12 07:51:10.149	error	npm
      javascript.1
      2023-01-12 07:51:10.143	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib/ber/index.js'
      javascript.1
      2023-01-12 07:51:10.140	error	tar
      javascript.1
      2023-01-12 07:51:10.139	error
      javascript.1
      2023-01-12 07:51:10.136	error	WARN
      javascript.1
      2023-01-12 07:51:10.134	error
      javascript.2
      2023-01-12 07:51:10.134	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
      javascript.2
      2023-01-12 07:51:10.132	error	npm
      javascript.1
      javascript.2
      2023-01-12 07:51:10.125	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4'
      javascript.2
      2023-01-12 07:51:10.123	error	npm
      javascript.1
      2023-01-12 07:51:10.113	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/LICENSE'
      javascript.1
      2023-01-12 07:51:10.105	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils/README.md'
      javascript.2
      2023-01-12 07:51:10.097	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
      javascript.2
      2023-01-12 07:51:10.096	error	npm
      javascript.1
      2023-01-12 07:51:10.101	error
      javascript.1
      2023-01-12 07:51:10.099	error	WARN
      javascript.1
      javascript.1
      javascript.2
      2023-01-12 07:51:10.091	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
      javascript.2
      2023-01-12 07:51:10.090	error	npm
      javascript.1
      2023-01-12 07:51:10.079	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/stream.js'
      javascript.1
      2023-01-12 07:51:10.078	error	npm
      javascript.1
      2023-01-12 07:51:10.020	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/package.json'
      javascript.1
      2023-01-12 07:51:10.019	error	npm
      javascript.1
      2023-01-12 07:51:10.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match/.github/FUNDING.yml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js/index.d.ts'
      javascript.2
      2023-01-12 07:51:10.013	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
      javascript.2
      2023-01-12 07:51:10.012	error	WARN
      javascript.1
      2023-01-12 07:51:10.009	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/parse.js'
      javascript.1
      2023-01-12 07:51:10.007	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/init-buffer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/examples/splice.js'
      javascript.1
      2023-01-12 07:51:09.986	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/add_do.js'
      javascript.2
      2023-01-12 07:51:09.990	error	npm
      javascript.2
      2023-01-12 07:51:09.987	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer'
      javascript.1
      2023-01-12 07:51:09.985	error	npm
      javascript.2
      2023-01-12 07:51:09.980	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary'
      javascript.1
      2023-01-12 07:51:09.981	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/lib'
      javascript.1
      2023-01-12 07:51:09.979	error	npm
      javascript.2
      2023-01-12 07:51:09.965	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird'
      javascript.1
      2023-01-12 07:51:09.973	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream/lib/combined_stream.js'
      javascript.1
      2023-01-12 07:51:09.971	error	npm
      javascript.2
      2023-01-12 07:51:09.956	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/boolbase'
      javascript.2
      2023-01-12 07:51:09.945	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
      javascript.1
      2023-01-12 07:51:09.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tsconfig.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/LICENSE'
      javascript.2
      2023-01-12 07:51:09.930	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv'
      javascript.2
      2023-01-12 07:51:09.921	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
      javascript.1
      2023-01-12 07:51:09.926	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/package.json'
      javascript.1
      2023-01-12 07:51:09.921	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/react.js'
      javascript.2
      2023-01-12 07:51:09.915	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers'
      javascript.1
      2023-01-12 07:51:09.915	error	tar
      javascript.1
      2023-01-12 07:51:09.913	error
      javascript.1
      2023-01-12 07:51:09.911	error	WARN
      javascript.1
      2023-01-12 07:51:09.910	error
      javascript.1
      2023-01-12 07:51:09.908	error	npm
      javascript.2
      2023-01-12 07:51:09.906	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
      javascript.2
      2023-01-12 07:51:09.905	error	npm
      javascript.1
      2023-01-12 07:51:09.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-select/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/build/src/index.js.map'
      javascript.1
      2023-01-12 07:51:09.891	error
      javascript.2
      2023-01-12 07:51:09.890	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck'
      javascript.1
      2023-01-12 07:51:09.889	error	WARN
      javascript.2
      2023-01-12 07:51:09.887	error	npm
      javascript.1
      javascript.1
      2023-01-12 07:51:09.884	error	npm
      javascript.2
      2023-01-12 07:51:09.883	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
      javascript.2
      2023-01-12 07:51:09.881	error	npm
      javascript.1
      2023-01-12 07:51:09.881	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/src/node.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/package.json'
      javascript.1
      2023-01-12 07:51:09.870	error
      javascript.1
      2023-01-12 07:51:09.867	error	WARN
      javascript.2
      2023-01-12 07:51:09.864	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw'
      javascript.1
      2023-01-12 07:51:09.865	error
      javascript.1
      2023-01-12 07:51:09.863	error	npm
      javascript.2
      2023-01-12 07:51:09.858	error	npm
      javascript.1
      2023-01-12 07:51:09.853	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/CHANGELOG.md'
      javascript.1
      2023-01-12 07:51:09.844	error
      javascript.1
      2023-01-12 07:51:09.841	error	WARN
      javascript.1
      2023-01-12 07:51:09.839	error
      javascript.1
      2023-01-12 07:51:09.837	error	npm
      javascript.1
      2023-01-12 07:51:09.830	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/index.js'
      javascript.1
      2023-01-12 07:51:09.823	error	npm
      javascript.1
      2023-01-12 07:51:09.817	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/lib/index.js'
      javascript.1
      2023-01-12 07:51:09.815	error	npm
      javascript.1
      2023-01-12 07:51:09.807	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/implementation.js'
      javascript.1
      2023-01-12 07:51:09.801	error	npm
      javascript.1
      2023-01-12 07:51:09.796	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/sync.js'
      javascript.1
      2023-01-12 07:51:09.783	error
      javascript.1
      2023-01-12 07:51:09.781	error	WARN
      javascript.1
      2023-01-12 07:51:09.778	error
      javascript.1
      2023-01-12 07:51:09.776	error	npm
      javascript.1
      2023-01-12 07:51:09.773	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/header.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/package.json'
      javascript.1
      2023-01-12 07:51:09.762	error	npm
      javascript.1
      2023-01-12 07:51:09.758	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/test/index.js'
      javascript.1
      2023-01-12 07:51:09.752	error	WARN
      javascript.1
      2023-01-12 07:51:09.749	error
      javascript.1
      2023-01-12 07:51:09.746	error	npm
      javascript.1
      2023-01-12 07:51:09.741	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/core-js.js'
      javascript.1
      2023-01-12 07:51:09.739	error	npm
      javascript.1
      2023-01-12 07:51:09.700	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/http_signing.md'
      javascript.1
      2023-01-12 07:51:09.699	error	npm
      javascript.1
      2023-01-12 07:51:09.672	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/LICENSE'
      javascript.1
      2023-01-12 07:51:09.670	error	npm
      javascript.1
      2023-01-12 07:51:09.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/dist/immediate.min.js'
      javascript.1
      2023-01-12 07:51:09.648	error	npm
      javascript.1
      2023-01-12 07:51:09.620	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/LICENSE.md'
      javascript.1
      2023-01-12 07:51:09.608	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/index.js'
      javascript.1
      2023-01-12 07:51:09.594	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/README.md'
      javascript.1
      2023-01-12 07:51:09.592	error	npm
      javascript.1
      2023-01-12 07:51:09.582	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/package.json'
      javascript.1
      2023-01-12 07:51:09.580	error	npm
      javascript.1
      2023-01-12 07:51:09.573	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/index.js'
      javascript.1
      2023-01-12 07:51:09.569	error	npm
      @homecineplexx
      Du könntest bei den Instanzen schon mal aufräumen.
      Warum laufen da drei Instanzen?
      H 1 Antwort Letzte Antwort
        @homecineplexx
        homecineplexx
        @thomas-braun du meinst bei javascript?
        weil ich da unterschiedliche dinge am laufen habe
        • H homecineplexx
          @homecineplexx
          Würde ich nicht machen.
          iob diag
          sagt?
          crunchipC H 3 Antworten Letzte Antwort
            @homecineplexx
            iob diag
            sagt?
            crunchipC Offline
            crunchipC Offline
            @thomas-braun sagte in Errors nach einem Neustart:
            warum nicht?
            eine Instanz die "sicher" laufen muss, für wichtige Dinge
            eine zweite, für andere Dinge
            und eventuell eine zum testen, wenn was schief geht, damit nicht alle Scripte abstürzen
              warum nicht?
              @crunchip
              Widerstrebt dem KISS-Prinzip.
              Kann man natürlich machen, mir wäre es zu unübersichtlich.
                @homecineplexx
                iob diag
                sagt?
                homecineplexx
                @thomas-braun said in Errors nach einem Neustart:
                @homecineplexx
                iob diag
                sagt?
                reicht dir das hier?
                		     v.2022-12-31
                Operatingsystem: 	Debian GNU/Linux 10 (buster)
                Installation: 		kvm
                Timezone: 		Europe/Vienna
                User-ID: 		1000
                X-Server: 		false
                Boot Target: 		graphical.target
                Pending OS-Updates: 	1
                Nodejs-Installation: 	/usr/bin/nodejs 	v16.18.1
                			/usr/bin/node 		v16.18.1
                			/usr/bin/npm 		8.19.2
                ioBroker Core: 		js-controller 		4.0.24
                			admin 			6.3.5
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: redis
                Status admin:
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                Pending iob updates: 	0
                Active repo(s): stable
                Objects: 		40829
                States: 		34235
                Size of iob-Database:
                37M	/opt/iobroker/iobroker-data/objects.jsonl
                15M	/opt/iobroker/iobroker-data/objects.json.migrated
                15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                81M	/opt/iobroker/iobroker-data/states.jsonl
                2.5M	/opt/iobroker/iobroker-data/states.json.migrated
                2.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                • H homecineplexx
                  @homecineplexx
                  iob diag
                  sagt?
                  		     v.2022-12-31
                  Installation: 		kvm
                  User-ID: 		1000
                  X-Server: 		false
                  			/usr/bin/npm 		8.19.2
                  			admin 			6.3.5
                  Objects type: jsonl
                  States  type: redis
                  Status admin:
                  Objects: 		40829
                  States: 		34235
                  @homecineplexx
                  Abgesehen davon dass Buster tot ist und durch das aktuelle Stable Release ersetzt werden muss soweit i.O.
                    @homecineplexx
                    homecineplexx
                    @thomas-braun ok, das weiß ich zwar, könnte ich aber wirklich mal ändern
                    • H homecineplexx
                      @homecineplexx sagte in Errors nach einem Neustart:
                      Das ist überfällig.
                        Das ist überfällig.
                        homecineplexx
                        Das ist überfällig.
                        was muss ich dafür in die /etc/apt/sources.list eintragen?
                        • H homecineplexx
                          Das ist überfällig.
                          @homecineplexx
                          Das ist doch irgendwas virtuelles, oder nicht?
                          Installation: 		kvm
                            @homecineplexx
                            Installation: 		kvm
                            homecineplexx
                            @homecineplexx
                            Installation: 		kvm
                            richtig, das ist ein proxmox und in einer vm läuft debian buster mit iobroker
                            ich muss ja die /etc/apt/sources.list in der VM ändern
                            • H homecineplexx
                              @homecineplexx
                              Installation: 		kvm
                              @homecineplexx
                              Hier hab ich das auf einem RPI3 mal durchexerziert:
                              https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                              Ob und wie das bei Proxmox funktioniert kann ich dir nicht sagen.
                                @homecineplexx
                                iob diag
                                sagt?
                                homecineplexx
                                @homecineplexx
                                iob diag
                                sagt?
                                so sieht es nun aus:
                                		     v.2022-12-31
                                Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                                Installation: 		kvm
                                User-ID: 		1000
                                X-Server: 		false
                                Pending OS-Updates: 	0
                                Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                                			/usr/bin/node 		v16.19.0
                                			/usr/bin/npm 		8.19.3
                                			admin 			6.3.5
                                Objects type: jsonl
                                States  type: redis
                                Status admin:
                                Objects: 		40838
                                States: 		34545
                                46M	/opt/iobroker/iobroker-data/objects.jsonl
