  4. Errors nach einem Neustart
    5.2k
neustarterrornpm
15 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • H homecineplexx
    Hallo
    seit neuestem kommen nach dem Starten des ioBrokers folgende Fehler.
    kann ich das was tun, wenn ja was?
    npm version: 8.19.2
    nodejs: v16.18.1
    node: v16.18.1
    javascript.2
    2023-01-12 07:51:16.251	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.2
    2023-01-12 07:51:16.249	error	npm
    host.ioBroker
    2023-01-12 07:51:16.067	info	instance system.adapter.mqtt.0 started with pid 17310
    javascript.2
    2023-01-12 07:51:15.579	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.2
    2023-01-12 07:51:15.575	error	npm
    javascript.2
    2023-01-12 07:51:13.934	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.2
    2023-01-12 07:51:13.932	error	npm
    host.ioBroker
    2023-01-12 07:51:13.027	info	instance system.adapter.alexa2.0 started with pid 17294
    host.ioBroker
    2023-01-12 07:51:12.937	info	instance system.adapter.mihome.0 started with pid 17288
    javascript.1
    2023-01-12 07:51:12.773	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.1
    2023-01-12 07:51:12.771	error	npm WARN
    javascript.2
    2023-01-12 07:51:12.558	error	deprecated har-validator@5.1.5: this library is no longer supported
    javascript.2
    2023-01-12 07:51:12.556	error	WARN
    javascript.2
    2023-01-12 07:51:12.554	error
    javascript.2
    2023-01-12 07:51:12.551	error	npm
    javascript.1
    2023-01-12 07:51:12.355	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.1
    2023-01-12 07:51:12.353	error	npm WARN
    javascript.1
    2023-01-12 07:51:11.873	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.1
    2023-01-12 07:51:11.871	error	npm
    host.ioBroker
    2023-01-12 07:51:11.249	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    javascript.1
    2023-01-12 07:51:11.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/generated'
    javascript.1
    2023-01-12 07:51:11.426	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
    javascript.1
    2023-01-12 07:51:11.424	error	npm
    javascript.1
    2023-01-12 07:51:11.416	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
    javascript.1
    2023-01-12 07:51:11.414	error	npm
    javascript.1
    2023-01-12 07:51:11.410	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
    javascript.1
    2023-01-12 07:51:11.409	error	npm
    javascript.1
    2023-01-12 07:51:11.396	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/src'
    javascript.1
    2023-01-12 07:51:11.395	error	npm
    javascript.1
    2023-01-12 07:51:11.386	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/lib'
    javascript.1
    2023-01-12 07:51:11.384	error	npm
    javascript.1
    2023-01-12 07:51:11.374	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is/lib'
    javascript.1
    2023-01-12 07:51:11.372	error	npm WARN
    javascript.1
    2023-01-12 07:51:11.354	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/deps' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/plugins'
    javascript.1
    2023-01-12 07:51:11.345	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/test'
    javascript.1
    2023-01-12 07:51:11.338	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/test'
    javascript.1
    2023-01-12 07:51:11.332	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/test'
    javascript.1
    2023-01-12 07:51:11.323	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/locale'
    javascript.1
    2023-01-12 07:51:11.318	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/README.md'
    javascript.1
    2023-01-12 07:51:11.313	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/esm/helpers.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/esm/index.js'
    javascript.1
    2023-01-12 07:51:11.308	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/esm/node.js'
    javascript.1
    2023-01-12 07:51:11.303	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/esm/package.json'
    javascript.1
    2023-01-12 07:51:11.299	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data/lib/populate.js'
    javascript.1
    2023-01-12 07:51:11.293	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/pipe.js'
    javascript.1
    2023-01-12 07:51:11.292	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.eslintrc'
    javascript.1
    2023-01-12 07:51:11.287	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/package.json'
    javascript.1
    2023-01-12 07:51:11.283	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/test'
    javascript.1
    2023-01-12 07:51:11.279	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/package.json'
    javascript.1
    2023-01-12 07:51:11.273	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/cache.json'
    javascript.1
    2023-01-12 07:51:11.267	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:11.263	error	npm
    javascript.1
    2023-01-12 07:51:11.260	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/index.js'
    javascript.1
    2023-01-12 07:51:11.255	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib'
    javascript.1
    2023-01-12 07:51:11.250	error	npm
    javascript.1
    2023-01-12 07:51:11.246	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/esm/Parser.js'
    javascript.1
    2023-01-12 07:51:11.242	error
    javascript.1
    2023-01-12 07:51:11.240	error	npm
    javascript.1
    2023-01-12 07:51:11.235	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/example.html' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/.jshintrc'
    javascript.1
    2023-01-12 07:51:11.229	error	WARN
    javascript.1
    2023-01-12 07:51:11.226	error
    javascript.1
    2023-01-12 07:51:11.224	error	npm
    javascript.1
    2023-01-12 07:51:11.209	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/README.md'
    javascript.1
    2023-01-12 07:51:11.203	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/parse.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/test'
    javascript.1
    2023-01-12 07:51:11.197	error	npm
    javascript.1
    2023-01-12 07:51:11.193	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/readable_test.js'
    javascript.3
    2023-01-12 07:51:11.164	error	Cannot install exceljs: 217
    javascript.1
    2023-01-12 07:51:11.187	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/listenercount/test/test.js'
    javascript.1
    2023-01-12 07:51:11.176	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys/implementation.js'
    javascript.1
    2023-01-12 07:51:11.173	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/default_bool.js'
    javascript.1
    2023-01-12 07:51:11.168	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_converters_43_inl.h'
    javascript.1
    2023-01-12 07:51:11.166	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_repl.js'
    javascript.1
    2023-01-12 07:51:11.164	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js'
    javascript.1
    2023-01-12 07:51:11.141	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako/lib/utils'
    javascript.1
    2023-01-12 07:51:11.129	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5/dist/tree-adapters'
    javascript.1
    2023-01-12 07:51:11.120	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/license.txt'
    javascript.1
    2023-01-12 07:51:11.116	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/safer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js'
    javascript.1
    2023-01-12 07:51:11.107	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf/README.md'
    javascript.3
    2023-01-12 07:51:11.096	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2023-01-12T06_51_00_204Z-debug-0.log
    javascript.3
    2023-01-12 07:51:11.083	error	npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
    javascript.3
    2023-01-12 07:51:11.080	error	npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m npm ERR! errno -39
    javascript.3
    2023-01-12 07:51:11.073	error	npm ERR! code ENOTEMPTY
    javascript.1
    2023-01-12 07:51:11.070	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/lib'
    javascript.1
    2023-01-12 07:51:11.067	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver/classes/comparator.js'
    javascript.1
    2023-01-12 07:51:11.066	error	npm
    javascript.1
    2023-01-12 07:51:11.020	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/README.md'
    javascript.1
    2023-01-12 07:51:11.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/README.md'
    javascript.1
    2023-01-12 07:51:11.015	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/man/man1'
    javascript.1
    2023-01-12 07:51:11.013	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2/test.js'
    javascript.1
    2023-01-12 07:51:11.010	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/sandbox.js'
    javascript.1
    2023-01-12 07:51:11.000	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/examples'
    javascript.1
    2023-01-12 07:51:10.997	error	npm
    javascript.1
    2023-01-12 07:51:10.993	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unzipper/lib/Open/directory.js'
    javascript.1
    2023-01-12 07:51:10.964	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js'
    javascript.2
    2023-01-12 07:51:10.951	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/LICENSE'
    javascript.1
    2023-01-12 07:51:10.958	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node/buffer.d.ts'
    javascript.1
    2023-01-12 07:51:10.956	error	npm
    javascript.2
    2023-01-12 07:51:10.945	error	tar
    javascript.2
    2023-01-12 07:51:10.941	error	npm WARN
    javascript.1
    2023-01-12 07:51:10.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node/buffer.d.ts'
    javascript.1
    2023-01-12 07:51:10.930	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid/dist/esm-browser/index.js'
    javascript.2
    2023-01-12 07:51:10.921	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/package.json'
    javascript.1
    2023-01-12 07:51:10.927	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anySeries.js'
    javascript.1
    2023-01-12 07:51:10.918	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data/yarn.lock'
    javascript.1
    2023-01-12 07:51:10.917	error	npm
    javascript.2
    2023-01-12 07:51:10.916	error	WARN
    javascript.2
    2023-01-12 07:51:10.914	error
    javascript.2
    2023-01-12 07:51:10.912	error	npm
    javascript.1
    2023-01-12 07:51:10.914	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/package.json'
    javascript.1
    2023-01-12 07:51:10.912	error	npm WARN
    javascript.1
    2023-01-12 07:51:10.911	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/test'
    javascript.1
    2023-01-12 07:51:10.910	error	npm
    javascript.2
    2023-01-12 07:51:10.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist/LICENSE'
    javascript.2
    2023-01-12 07:51:10.893	error
    javascript.2
    2023-01-12 07:51:10.891	error	WARN
    javascript.2
    2023-01-12 07:51:10.889	error
    javascript.2
    2023-01-12 07:51:10.887	error	npm
    javascript.1
    2023-01-12 07:51:10.873	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/build/src/formatter'
    javascript.1
    2023-01-12 07:51:10.872	error	npm
    javascript.1
    2023-01-12 07:51:10.843	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnParser.js'
    javascript.1
    2023-01-12 07:51:10.839	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib'
    javascript.1
    2023-01-12 07:51:10.837	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/index.js'
    javascript.1
    2023-01-12 07:51:10.836	error	npm
    javascript.1
    2023-01-12 07:51:10.832	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib'
    javascript.1
    2023-01-12 07:51:10.814	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer/BigInteger.min.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/README.md'
    javascript.1
    2023-01-12 07:51:10.804	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/parallel.js'
    javascript.1
    2023-01-12 07:51:10.800	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/README.md'
    javascript.1
    2023-01-12 07:51:10.788	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/test' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird/js/browser/bluebird.core.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf/CONTRIBUTING.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/buf.js'
    javascript.1
    2023-01-12 07:51:10.764	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind/test/callBound.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer/package.json'
    javascript.1
    2023-01-12 07:51:10.741	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/README.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map/example/map.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/bin/cake' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/prompt.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/dist/es5' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cheerio-select/lib/helpers.js'
    javascript.1
    2023-01-12 07:51:10.713	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tslint.json'
    javascript.1
    2023-01-12 07:51:10.711	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.709	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/package.json'
    javascript.1
    2023-01-12 07:51:10.696	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.687	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile.targ'
    javascript.1
    2023-01-12 07:51:10.685	error	npm
    host.ioBroker
    2023-01-12 07:51:10.676	info	stopInstance system.adapter.alexa2.0 killing pid 17223
    javascript.1
    2023-01-12 07:51:10.674	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash/etc/dashdash.bash_completion.in' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn/lib/LICENSE-jsbn' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/lib/date.js'
    javascript.1
    2023-01-12 07:51:10.655	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-what/lib/es'
    javascript.1
    2023-01-12 07:51:10.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler/lib/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils/lib/feeds.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream/lib/delayed_stream.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/lib/foreignNames.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dayjs/esm/locale/af.js'
    javascript.1
    2023-01-12 07:51:10.616	error	npm
    javascript.2
    2023-01-12 07:51:10.604	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async'
    javascript.1
    2023-01-12 07:51:10.603	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/component.json'
    javascript.1
    2023-01-12 07:51:10.598	error
    javascript.2
    2023-01-12 07:51:10.599	error	WARN
    javascript.2
    2023-01-12 07:51:10.596	error
    javascript.1
    2023-01-12 07:51:10.594	error	WARN
    javascript.1
    2023-01-12 07:51:10.592	error
    javascript.1
    2023-01-12 07:51:10.591	error	npm
    javascript.1
    2023-01-12 07:51:10.588	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has/test/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/entities/lib/esm/generated/decode-data-html.js'
    javascript.2
    2023-01-12 07:51:10.586	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format/node_modules/@types/node' npm
    javascript.1
    2023-01-12 07:51:10.577	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/example'
    javascript.2
    2023-01-12 07:51:10.578	error	WARN
    javascript.2
    2023-01-12 07:51:10.576	error
    javascript.1
    2023-01-12 07:51:10.574	error
    javascript.2
    2023-01-12 07:51:10.574	error	npm
    javascript.1
    2023-01-12 07:51:10.572	error	npm
    javascript.1
    2023-01-12 07:51:10.567	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/examples/filter-pipe.js'
    javascript.2
    2023-01-12 07:51:10.565	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/node_modules/@types/node'
    javascript.1
    2023-01-12 07:51:10.560	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/.travis.yml'
    javascript.2
    2023-01-12 07:51:10.558	error
    javascript.1
    2023-01-12 07:51:10.558	error	npm
    javascript.2
    2023-01-12 07:51:10.556	error	WARN
    javascript.2
    2023-01-12 07:51:10.554	error
    javascript.2
    2023-01-12 07:51:10.552	error	npm
    javascript.1
    2023-01-12 07:51:10.552	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/.travis.yml'
    javascript.1
    2023-01-12 07:51:10.549	error	npm
    javascript.2
    2023-01-12 07:51:10.548	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.546	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/index.js'
    javascript.1
    2023-01-12 07:51:10.541	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/README.md'
    javascript.2
    2023-01-12 07:51:10.537	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.536	error	npm
    javascript.2
    2023-01-12 07:51:10.532	error	tar
    javascript.1
    2023-01-12 07:51:10.532	error	npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/browser.json'
    javascript.2
    2023-01-12 07:51:10.531	error
    javascript.1
    2023-01-12 07:51:10.525	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/README.md'
    javascript.2
    2023-01-12 07:51:10.529	error	WARN
    javascript.2
    2023-01-12 07:51:10.527	error
    javascript.2
    2023-01-12 07:51:10.525	error	npm
    javascript.1
    2023-01-12 07:51:10.521	error	npm
    javascript.2
    2023-01-12 07:51:10.521	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.517	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/package.json'
    javascript.1
    2023-01-12 07:51:10.514	error	npm
    javascript.2
    2023-01-12 07:51:10.510	error	tar
    javascript.1
    2023-01-12 07:51:10.509	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/get-own-property-symbols.js'
    javascript.2
    2023-01-12 07:51:10.508	error
    javascript.2
    2023-01-12 07:51:10.507	error	WARN
    javascript.1
    2023-01-12 07:51:10.506	error	npm
    javascript.2
    2023-01-12 07:51:10.505	error
    javascript.1
    2023-01-12 07:51:10.503	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/lib/index.js'
    javascript.2
    javascript.2
    2023-01-12 07:51:10.501	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/uuid' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.496	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/Readme.md'
    javascript.1
    2023-01-12 07:51:10.494	error	npm
    javascript.1
    2023-01-12 07:51:10.489	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/lib'
    javascript.2
    2023-01-12 07:51:10.489	error	tar
    javascript.2
    2023-01-12 07:51:10.487	error
    javascript.1
    2023-01-12 07:51:10.486	error	npm
    javascript.2
    2023-01-12 07:51:10.485	error	WARN
    javascript.2
    2023-01-12 07:51:10.484	error
    javascript.2
    2023-01-12 07:51:10.482	error	npm
    javascript.1
    2023-01-12 07:51:10.477	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema/package.json'
    javascript.2
    2023-01-12 07:51:10.477	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir/node_modules/semver' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fstream/node_modules/rimraf'
    javascript.1
    2023-01-12 07:51:10.471	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/spec'
    javascript.1
    2023-01-12 07:51:10.469	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/CHANGES.md'
    javascript.2
    2023-01-12 07:51:10.467	error
    javascript.2
    2023-01-12 07:51:10.465	error	WARN
    javascript.1
    2023-01-12 07:51:10.464	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/index.js'
    javascript.2
    2023-01-12 07:51:10.463	error
    javascript.2
    2023-01-12 07:51:10.462	error	npm
    javascript.1
    2023-01-12 07:51:10.460	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream/test/pipe_test.js'
    javascript.2
    2023-01-12 07:51:10.457	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion'
    javascript.1
    2023-01-12 07:51:10.450	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types/README.md'
    javascript.1
    2023-01-12 07:51:10.448	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp/bin/usage.txt'
    javascript.1
    2023-01-12 07:51:10.446	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan/nan_callbacks.h' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist/test/dash.js'
    javascript.1
    2023-01-12 07:51:10.441	error	npm
    javascript.2
    2023-01-12 07:51:10.443	error
    javascript.2
    2023-01-12 07:51:10.440	error	npm
    javascript.1
    2023-01-12 07:51:10.439	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect/lib/internal/inspect_client.js'
    javascript.1
    2023-01-12 07:51:10.435	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-ssh/LICENSE.md'
    javascript.2
    2023-01-12 07:51:10.433	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data'
    javascript.1
    2023-01-12 07:51:10.431	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5-htmlparser2-tree-adapter/dist/index.js'
    javascript.1
    2023-01-12 07:51:10.429	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now/.tm_properties'
    javascript.1
    2023-01-12 07:51:10.426	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors/types.ts'
    javascript.1
    2023-01-12 07:51:10.424	error	npm WARN tar
    javascript.2
    2023-01-12 07:51:10.424	error	WARN
    javascript.1
    2023-01-12 07:51:10.422	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode/README.md'
    javascript.2
    2023-01-12 07:51:10.423	error
    javascript.1
    2023-01-12 07:51:10.421	error	npm WARN
    javascript.2
    2023-01-12 07:51:10.420	error	npm
    javascript.1
    2023-01-12 07:51:10.419	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/getProxyFromURI.js'
    javascript.1
    2023-01-12 07:51:10.418	error	npm
    javascript.2
    2023-01-12 07:51:10.417	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs'
    javascript.2
    2023-01-12 07:51:10.410	error	tar
    javascript.2
    2023-01-12 07:51:10.409	error
    javascript.2
    2023-01-12 07:51:10.407	error	WARN
    javascript.2
    2023-01-12 07:51:10.405	error
    javascript.1
    2023-01-12 07:51:10.401	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer/Readme.md'
    javascript.1
    2023-01-12 07:51:10.398	error
    javascript.1
    2023-01-12 07:51:10.395	error	npm
    javascript.2
    2023-01-12 07:51:10.391	error	npm
    javascript.1
    2023-01-12 07:51:10.391	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/saxes/saxes.js.map'
    javascript.1
    2023-01-12 07:51:10.383	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-promise-queue/README.md'
    javascript.2
    2023-01-12 07:51:10.381	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/node_modules/readable-stream' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv'
    javascript.1
    2023-01-12 07:51:10.381	error	npm
    javascript.1
    2023-01-12 07:51:10.378	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sb-scandir/README.md'
    javascript.1
    2023-01-12 07:51:10.374	error
    javascript.2
    2023-01-12 07:51:10.373	error
    javascript.1
    2023-01-12 07:51:10.372	error	npm
    javascript.2
    2023-01-12 07:51:10.371	error	npm
    javascript.1
    2023-01-12 07:51:10.368	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/shell-escape/test/simple.js'
    javascript.1
    2023-01-12 07:51:10.358	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions/package.json'
    javascript.1
    2023-01-12 07:51:10.354	error	npm
    javascript.1
    2023-01-12 07:51:10.351	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/LICENSE'
    javascript.1
    2023-01-12 07:51:10.348	error	npm
    javascript.1
    2023-01-12 07:51:10.343	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream/pack.js'
    javascript.1
    2023-01-12 07:51:10.337	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tmp/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:10.330	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie/lib/cookie.js'
    javascript.1
    2023-01-12 07:51:10.327	error	npm
    javascript.1
    2023-01-12 07:51:10.322	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/traverse/LICENSE'
    javascript.1
    2023-01-12 07:51:10.320	error	WARN tar
    javascript.1
    2023-01-12 07:51:10.318	error
    javascript.2
    2023-01-12 07:51:10.316	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is'
    javascript.1
    2023-01-12 07:51:10.316	error	npm
    javascript.1
    2023-01-12 07:51:10.312	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl/nacl-fast.js'
    javascript.2
    2023-01-12 07:51:10.311	error
    javascript.2
    2023-01-12 07:51:10.309	error	WARN
    javascript.2
    2023-01-12 07:51:10.307	error
    javascript.1
    2023-01-12 07:51:10.306	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js/dist'
    javascript.2
    javascript.1
    2023-01-12 07:51:10.298	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid/lib/md5-browser.js'
    javascript.2
    2023-01-12 07:51:10.298	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/zip-stream/node_modules/readable-stream'
    javascript.1
    2023-01-12 07:51:10.295	error
    javascript.1
    2023-01-12 07:51:10.293	error	WARN
    javascript.1
    2023-01-12 07:51:10.291	error	npm
    javascript.2
    2023-01-12 07:51:10.290	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils'
    javascript.2
    2023-01-12 07:51:10.287	error	WARN
    javascript.1
    2023-01-12 07:51:10.286	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/CHANGES.md'
    javascript.2
    2023-01-12 07:51:10.285	error
    javascript.1
    2023-01-12 07:51:10.283	error
    javascript.2
    2023-01-12 07:51:10.283	error	npm
    javascript.1
    2023-01-12 07:51:10.282	error	npm
    javascript.1
    2023-01-12 07:51:10.278	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend/test.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlchars/xmlns/1.0/ed3.js'
    javascript.2
    2023-01-12 07:51:10.277	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
    javascript.2
    2023-01-12 07:51:10.273	error
    javascript.1
    2023-01-12 07:51:10.272	error
    javascript.2
    2023-01-12 07:51:10.271	error	npm
    javascript.1
    2023-01-12 07:51:10.270	error	npm
    javascript.2
    2023-01-12 07:51:10.265	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
    javascript.1
    2023-01-12 07:51:10.262	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/node_modules/async/anyLimit.js'
    javascript.2
    2023-01-12 07:51:10.261	error
    javascript.1
    2023-01-12 07:51:10.259	error
    javascript.2
    2023-01-12 07:51:10.259	error	WARN
    javascript.1
    2023-01-12 07:51:10.257	error	WARN
    javascript.2
    javascript.1
    2023-01-12 07:51:10.255	error
    javascript.2
    2023-01-12 07:51:10.255	error	npm
    javascript.1
    2023-01-12 07:51:10.253	error	npm
    javascript.2
    2023-01-12 07:51:10.250	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
    javascript.2
    2023-01-12 07:51:10.241	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
    javascript.1
    2023-01-12 07:51:10.239	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/brace-expansion/.github/FUNDING.yml'
    javascript.2
    2023-01-12 07:51:10.237	error
    javascript.2
    2023-01-12 07:51:10.235	error	WARN
    javascript.2
    2023-01-12 07:51:10.233	error
    javascript.1
    2023-01-12 07:51:10.229	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readdir-glob/node_modules/minimatch/lib/path.js'
    javascript.2
    2023-01-12 07:51:10.231	error	npm
    javascript.1
    2023-01-12 07:51:10.226	error
    javascript.1
    2023-01-12 07:51:10.224	error	npm WARN
    javascript.2
    2023-01-12 07:51:10.218	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/format'
    javascript.2
    2023-01-12 07:51:10.209	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse'
    javascript.1
    2023-01-12 07:51:10.214	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/qs/lib/index.js'
    javascript.2
    2023-01-12 07:51:10.205	error
    javascript.1
    2023-01-12 07:51:10.199	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@fast-csv/parse/build/src/parser/column/ColumnFormatter.js'
    javascript.2
    2023-01-12 07:51:10.203	error	WARN
    javascript.2
    2023-01-12 07:51:10.201	error
    javascript.2
    2023-01-12 07:51:10.199	error	npm
    javascript.1
    2023-01-12 07:51:10.182	error	npm
    javascript.2
    2023-01-12 07:51:10.193	error	ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver'
    javascript.2
    2023-01-12 07:51:10.182	error	tar
    javascript.2
    2023-01-12 07:51:10.181	error
    javascript.2
    2023-01-12 07:51:10.179	error	WARN
    javascript.2
    2023-01-12 07:51:10.177	error
    javascript.2
    2023-01-12 07:51:10.175	error	npm
    javascript.1
    2023-01-12 07:51:10.167	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/scripts/travis-gh-pages'
    javascript.1
    2023-01-12 07:51:10.163	error	npm
    javascript.2
    2023-01-12 07:51:10.162	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
    javascript.2
    2023-01-12 07:51:10.161	error	npm
    javascript.2
    2023-01-12 07:51:10.155	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
    javascript.2
    2023-01-12 07:51:10.154	error	npm
    javascript.1
    2023-01-12 07:51:10.154	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver/lib/error.js'
    javascript.1
    2023-01-12 07:51:10.151	error
    javascript.1
    2023-01-12 07:51:10.149	error	npm
    javascript.1
    2023-01-12 07:51:10.143	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1/lib/ber/index.js'
    javascript.1
    2023-01-12 07:51:10.140	error	tar
    javascript.1
    2023-01-12 07:51:10.139	error
    javascript.1
    2023-01-12 07:51:10.136	error	WARN
    javascript.1
    2023-01-12 07:51:10.134	error
    javascript.2
    2023-01-12 07:51:10.134	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
    javascript.2
    2023-01-12 07:51:10.132	error	npm
    javascript.1
    javascript.2
    2023-01-12 07:51:10.125	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4'
    javascript.2
    2023-01-12 07:51:10.123	error	npm
    javascript.1
    2023-01-12 07:51:10.113	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck/LICENSE'
    javascript.1
    2023-01-12 07:51:10.105	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archiver-utils/README.md'
    javascript.2
    2023-01-12 07:51:10.097	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
    javascript.2
    2023-01-12 07:51:10.096	error	npm
    javascript.1
    2023-01-12 07:51:10.101	error
    javascript.1
    2023-01-12 07:51:10.099	error	WARN
    javascript.1
    javascript.1
    javascript.2
    2023-01-12 07:51:10.091	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
    javascript.2
    2023-01-12 07:51:10.090	error	npm
    javascript.1
    2023-01-12 07:51:10.079	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit/stream.js'
    javascript.1
    2023-01-12 07:51:10.078	error	npm
    javascript.1
    2023-01-12 07:51:10.020	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4/package.json'
    javascript.1
    2023-01-12 07:51:10.019	error	npm
    javascript.1
    2023-01-12 07:51:10.017	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match/.github/FUNDING.yml' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js/index.d.ts'
    javascript.2
    2023-01-12 07:51:10.013	error	tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
    javascript.2
    2023-01-12 07:51:10.012	error	WARN
    javascript.1
    2023-01-12 07:51:10.009	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary/example/parse.js'
    javascript.1
    2023-01-12 07:51:10.007	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/exceljs/LICENSE' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill/init-buffer.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers/examples/splice.js'
    javascript.1
    2023-01-12 07:51:09.986	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw/examples/add_do.js'
    javascript.2
    2023-01-12 07:51:09.990	error	npm
    javascript.2
    2023-01-12 07:51:09.987	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/big-integer'
    javascript.1
    2023-01-12 07:51:09.985	error	npm
    javascript.2
    2023-01-12 07:51:09.980	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/binary'
    javascript.1
    2023-01-12 07:51:09.981	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/compress-commons/lib'
    javascript.1
    2023-01-12 07:51:09.979	error	npm
    javascript.2
    2023-01-12 07:51:09.965	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluebird'
    javascript.1
    2023-01-12 07:51:09.973	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream/lib/combined_stream.js'
    javascript.1
    2023-01-12 07:51:09.971	error	npm
    javascript.2
    2023-01-12 07:51:09.956	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/boolbase'
    javascript.2
    2023-01-12 07:51:09.945	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
    javascript.1
    2023-01-12 07:51:09.935	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc-32/types/tsconfig.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/LICENSE'
    javascript.2
    2023-01-12 07:51:09.930	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv'
    javascript.2
    2023-01-12 07:51:09.921	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-indexof-polyfill' npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
    javascript.1
    2023-01-12 07:51:09.926	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/crc32-stream/package.json'
    javascript.1
    2023-01-12 07:51:09.921	error	TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal/react.js'
    javascript.2
    2023-01-12 07:51:09.915	error	npm WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffers'
    javascript.1
    2023-01-12 07:51:09.915	error	tar
    javascript.1
    2023-01-12 07:51:09.913	error
    javascript.1
    2023-01-12 07:51:09.911	error	WARN
    javascript.1
    2023-01-12 07:51:09.910	error
    javascript.1
    2023-01-12 07:51:09.908	error	npm
    javascript.2
    2023-01-12 07:51:09.906	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
    javascript.2
    2023-01-12 07:51:09.905	error	npm
    javascript.1
    2023-01-12 07:51:09.901	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.javascript/node_modules/css-select/lib' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf/Makefile' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-csv/build/src/index.js.map'
    javascript.1
    2023-01-12 07:51:09.891	error
    javascript.2
    2023-01-12 07:51:09.890	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buildcheck'
    javascript.1
    2023-01-12 07:51:09.889	error	WARN
    javascript.2
    2023-01-12 07:51:09.887	error	npm
    javascript.1
    javascript.1
    2023-01-12 07:51:09.884	error	npm
    javascript.2
    2023-01-12 07:51:09.883	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
    javascript.2
    2023-01-12 07:51:09.881	error	npm
    javascript.1
    2023-01-12 07:51:09.881	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug/src/node.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties/package.json'
    javascript.1
    2023-01-12 07:51:09.870	error
    javascript.1
    2023-01-12 07:51:09.867	error	WARN
    javascript.2
    2023-01-12 07:51:09.864	error	WARN tar ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.javascript/node_modules/chainsaw'
    javascript.1
    2023-01-12 07:51:09.865	error
    javascript.1
    2023-01-12 07:51:09.863	error	npm
    javascript.2
    2023-01-12 07:51:09.858	error	npm
    javascript.1
    2023-01-12 07:51:09.853	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend/CHANGELOG.md'
    javascript.1
    2023-01-12 07:51:09.844	error
    javascript.1
    2023-01-12 07:51:09.841	error	WARN
    javascript.1
    2023-01-12 07:51:09.839	error
    javascript.1
    2023-01-12 07:51:09.837	error	npm
    javascript.1
    2023-01-12 07:51:09.830	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic/index.js' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind/index.js'
    javascript.1
    2023-01-12 07:51:09.823	error	npm
    javascript.1
    2023-01-12 07:51:09.817	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass/lib/index.js'
    javascript.1
    2023-01-12 07:51:09.815	error	npm
    javascript.1
    2023-01-12 07:51:09.807	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan/implementation.js'
    javascript.1
    2023-01-12 07:51:09.801	error	npm
    javascript.1
    2023-01-12 07:51:09.796	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/glob/sync.js'
    javascript.1
    2023-01-12 07:51:09.783	error
    javascript.1
    2023-01-12 07:51:09.781	error	WARN
    javascript.1
    2023-01-12 07:51:09.778	error
    javascript.1
    2023-01-12 07:51:09.776	error	npm
    javascript.1
    2023-01-12 07:51:09.773	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/package.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/header.json' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs/package.json'
    javascript.1
    2023-01-12 07:51:09.762	error	npm
    javascript.1
    2023-01-12 07:51:09.758	error	tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors/test/index.js'
    javascript.1
    2023-01-12 07:51:09.752	error	WARN
    javascript.1
    2023-01-12 07:51:09.749	error
    javascript.1
    2023-01-12 07:51:09.746	error	npm
    javascript.1
    2023-01-12 07:51:09.741	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols/test/shams/core-js.js'
    javascript.1
    2023-01-12 07:51:09.739	error	npm
    javascript.1
    2023-01-12 07:51:09.700	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/http_signing.md'
    javascript.1
    2023-01-12 07:51:09.699	error	npm
    javascript.1
    2023-01-12 07:51:09.672	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/hashmap/LICENSE'
    javascript.1
    2023-01-12 07:51:09.670	error	npm
    javascript.1
    2023-01-12 07:51:09.650	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate/dist/immediate.min.js'
    javascript.1
    2023-01-12 07:51:09.648	error	npm
    javascript.1
    2023-01-12 07:51:09.620	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream/LICENSE.md'
    javascript.1
    2023-01-12 07:51:09.608	error	npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe/CHANGELOG.md' npm WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn/index.js'
    javascript.1
    2023-01-12 07:51:09.594	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse/README.md'
    javascript.1
    2023-01-12 07:51:09.592	error	npm
    javascript.1
    2023-01-12 07:51:09.582	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim/package.json'
    javascript.1
    2023-01-12 07:51:09.580	error	npm
    javascript.1
    2023-01-12 07:51:09.573	error	WARN tar TAR_ENTRY_ERROR ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nth-check/lib/esm/index.js'
    javascript.1
    2023-01-12 07:51:09.569	error	npm
    @homecineplexx
    Du könntest bei den Instanzen schon mal aufräumen.
    Warum laufen da drei Instanzen?
    H 1 Antwort Letzte Antwort
      @homecineplexx
      homecineplexx
      @thomas-braun du meinst bei javascript?
      weil ich da unterschiedliche dinge am laufen habe
      • H homecineplexx
        @homecineplexx
        Würde ich nicht machen.
        iob diag
        sagt?
        crunchipC H 3 Antworten Letzte Antwort
          @homecineplexx
          iob diag
          sagt?
          crunchipC Offline
          crunchipC Offline
          @thomas-braun sagte in Errors nach einem Neustart:
          warum nicht?
          eine Instanz die "sicher" laufen muss, für wichtige Dinge
          eine zweite, für andere Dinge
          und eventuell eine zum testen, wenn was schief geht, damit nicht alle Scripte abstürzen
            warum nicht?
            @crunchip
            Widerstrebt dem KISS-Prinzip.
            Kann man natürlich machen, mir wäre es zu unübersichtlich.
              @homecineplexx
              iob diag
              sagt?
              homecineplexx
              @thomas-braun said in Errors nach einem Neustart:
              @homecineplexx
              iob diag
              sagt?
              reicht dir das hier?
              		     v.2022-12-31
              Operatingsystem: 	Debian GNU/Linux 10 (buster)
              Installation: 		kvm
              Timezone: 		Europe/Vienna
              User-ID: 		1000
              X-Server: 		false
              Boot Target: 		graphical.target
              Pending OS-Updates: 	1
              Nodejs-Installation: 	/usr/bin/nodejs 	v16.18.1
              			/usr/bin/node 		v16.18.1
              			/usr/bin/npm 		8.19.2
              ioBroker Core: 		js-controller 		4.0.24
              			admin 			6.3.5
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: redis
              Status admin:
              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
              Pending iob updates: 	0
              Active repo(s): stable
              Objects: 		40829
              States: 		34235
              Size of iob-Database:
              37M	/opt/iobroker/iobroker-data/objects.jsonl
              15M	/opt/iobroker/iobroker-data/objects.json.migrated
              15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              81M	/opt/iobroker/iobroker-data/states.jsonl
              2.5M	/opt/iobroker/iobroker-data/states.json.migrated
              2.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
              • H homecineplexx
                @homecineplexx
                iob diag
                sagt?
                		     v.2022-12-31
                Installation: 		kvm
                User-ID: 		1000
                X-Server: 		false
                			/usr/bin/npm 		8.19.2
                			admin 			6.3.5
                Objects type: jsonl
                States  type: redis
                Status admin:
                Objects: 		40829
                States: 		34235
                @homecineplexx
                Abgesehen davon dass Buster tot ist und durch das aktuelle Stable Release ersetzt werden muss soweit i.O.
                  @homecineplexx
                  homecineplexx
                  @thomas-braun ok, das weiß ich zwar, könnte ich aber wirklich mal ändern
                  • H homecineplexx
                    @homecineplexx sagte in Errors nach einem Neustart:
                    Das ist überfällig.
                      Das ist überfällig.
                      homecineplexx
                      Das ist überfällig.
                      was muss ich dafür in die /etc/apt/sources.list eintragen?
                      • H homecineplexx
                        Das ist überfällig.
                        @homecineplexx
                        Das ist doch irgendwas virtuelles, oder nicht?
                        Installation: 		kvm
                          @homecineplexx
                          Installation: 		kvm
                          homecineplexx
                          @homecineplexx
                          Installation: 		kvm
                          richtig, das ist ein proxmox und in einer vm läuft debian buster mit iobroker
                          ich muss ja die /etc/apt/sources.list in der VM ändern
                          • H homecineplexx
                            @homecineplexx
                            Installation: 		kvm
                            @homecineplexx
                            Hier hab ich das auf einem RPI3 mal durchexerziert:
                            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                            Ob und wie das bei Proxmox funktioniert kann ich dir nicht sagen.
                              @homecineplexx
                              iob diag
                              sagt?
                              homecineplexx
                              @homecineplexx
                              iob diag
                              sagt?
                              so sieht es nun aus:
                              		     v.2022-12-31
                              Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                              Installation: 		kvm
                              User-ID: 		1000
                              X-Server: 		false
                              Pending OS-Updates: 	0
                              Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                              			/usr/bin/node 		v16.19.0
                              			/usr/bin/npm 		8.19.3
                              			admin 			6.3.5
                              Objects type: jsonl
                              States  type: redis
                              Status admin:
                              Objects: 		40838
                              States: 		34545
                              46M	/opt/iobroker/iobroker-data/objects.jsonl
