  4. ioBroker nichts geht mehr
    5.6k
43 Beiträge 4 Kommentatoren 5.6k Aufrufe 3 Beobachtet
  • I iKlaus
    t=0030, bcdDevice= 1.00
    [So Dez  4 19:14:58 2022] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [So Dez  4 19:14:58 2022] usb 1-2: Product: ConBee II
    [So Dez  4 19:14:58 2022] usb 1-2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [So Dez  4 19:14:58 2022] usb 1-2: SerialNumber: DE2219489
    [So Dez  4 19:14:58 2022] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
    [So Dez  4 19:15:02 2022] usb 1-2: USB disconnect, device number 17
    [So Dez  4 19:15:02 2022] usb 1-2: new full-speed USB device number 18 using xhci_hcd
    [So Dez  4 19:15:02 2022] usb 1-2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [So Dez  4 19:15:02 2022] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [So Dez  4 19:15:02 2022] usb 1-2: Product: ConBee II
    [So Dez  4 19:15:02 2022] usb 1-2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [So Dez  4 19:15:02 2022] usb 1-2: SerialNumber: DE2219489
    [So Dez  4 19:15:02 2022] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
    [So Dez  4 19:19:44 2022] perf: interrupt took too long (2513 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
    [So Dez  4 19:21:46 2022] perf: interrupt took too long (3153 > 3141), lowering kernel.perf_event_max_sample_rate to 63250
    [So Dez  4 19:24:52 2022] perf: interrupt took too long (3967 > 3941), lowering kernel.perf_event_max_sample_rate to 50250
    [So Dez  4 19:29:32 2022] perf: interrupt took too long (4962 > 4958), lowering kernel.perf_event_max_sample_rate to 40250
    [So Dez  4 19:37:11 2022] perf: interrupt took too long (6204 > 6202), lowering kernel.perf_event_max_sample_rate to 32000
    [So Dez  4 19:47:56 2022] FS-Cache: Loaded
    [So Dez  4 19:47:56 2022] FS-Cache: Netfs 'cifs' registered for caching
    [So Dez  4 19:47:56 2022] Key type cifs.spnego registered
    [So Dez  4 19:47:56 2022] Key type cifs.idmap registered
    [So Dez  4 19:47:56 2022] CIFS: Attempting to mount \\192.168.178.200\ioBrokerBackup
    [So Dez  4 19:48:00 2022] CIFS: VFS: Error connecting to socket. Aborting operation.
    [So Dez  4 19:48:00 2022] CIFS: VFS: cifs_mount failed w/return code = -113
    [So Dez  4 19:48:00 2022] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
    [So Dez  4 19:48:00 2022] CIFS: Attempting to mount \\192.168.178.200\ioBrokerBackup
    [So Dez  4 19:48:06 2022] CIFS: VFS: Error connecting to socket. Aborting operation.
    [So Dez  4 19:48:06 2022] CIFS: VFS: cifs_mount failed w/return code = -113
    [So Dez  4 20:13:38 2022] perf: interrupt took too long (7933 > 7755), lowering kernel.perf_event_max_sample_rate to 25000
    klaus@ioroker:~$
    #41
    @iklaus
    Das riecht nach Trouble. Ich hatte mal ähnliche Meldungen wie diese:
    Kurz darauf ist die SD-Karte abgeraucht.
    Höchste Eisenbahn da was frisches zu installieren, Backup mit intakten Daten einspielen.
    I 1 Antwort Letzte Antwort
      @iklaus
      I Offline
      I Offline
      iKlaus
      #42
      @thomas-braun ok das heisst neu machen alles !
      Das kann ich aber erst nächstes Wochenende machen bin Fernfahrer darf um 4 Uhr los fahren und bin dann erst Wochenende wieder da !
      Bräuchte dann noch mal hilfe wegen backup
      Danke dir erst einmal !
      Werde den Rechner aus machen geht so oder so nichts in mom!
      Habe ja noch einen mini PC hier stehen !
        @iklaus
        Bitte CodeTags verwenden.
        iob stop
        sudo apt install redis
        sudo reboot
        crunchipC Abwesend
        crunchipC Abwesend
        #43
        @thomas-braun sagte in ioBroker nichts geht mehr:
        verstehe ich aber nicht warum er redis installieren soll, wenn doch jsonl verwendet wird.
        es steht zwar
        @iklaus sagte in ioBroker nichts geht mehr:
        Error: States DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
        at processTicksAndRejections (node:internal/process/task_queues:96:5)
        aber der js-controller verwendet doch die die interne redis Datenbank, zu sehen an den Ports,
        das hat doch nichts mit redis in dem Sinn zu tun, redis installiert man doch nur wenn man redis anstatt jsonl verwendet
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 28966 644/iobroker.js-con
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 25437 644/iobroker.js-con
        redis läuft auf Port 6379, zu sehen, jetzt nach der Installation
        tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 120 3912 651/redis-server 12
        Doku Redis Datenbank
