  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 110.9k Aufrufe 49 Beobachtet
  • H Hadebe
    @djmarc75 ok, ich habe leider keine Ahnung wie ich den Output erzeugen soll. Du hast ihn ja offenbar "einfach" aus meiner Datei erzeugt - wie geht das bzw. wo finde ich wie es geht
    SegwayS Offline
    SegwayS Offline
    Segway
    #381
    @hadebe sagte in ZigBee neue Version 1.8.x:
    Datei aufrufen - alles kopieren - hierhin kopieren und CodeTags benutzen
    2024-01-03 20:00:05.549 - info: zigbee.0 (138145) Successfully interviewed '0x54ef441000aa11c5', device has successfully been paired
    2024-01-03 20:00:05.550 - info: zigbee.0 (138145) Device '0x54ef441000aa11c5' is supported, identified as: Xiaomi Aqara dual relay module T2 (LLKZMK12LM)
    2024-01-03 20:00:05.552 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:05.563 - warn: zigbee.0 (138145) download icon from https://www.zigbee2mqtt.io/images/devices/LLKZMK12LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LLKZMK12LM.png
    2024-01-03 20:00:05.708 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:11.994 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:12.084 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:21.940 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:22.086 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:22.736 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:22.851 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:23.944 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:24.017 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:34.930 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:35.019 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:35.792 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:35.865 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:39.438 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:39.509 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:44.100 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:44.175 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:00:48.853 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:00:48.952 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:01:02.354 - info: zigbee.0 (138145) Zigbee: stop joining
    2024-01-03 20:02:31.122 - info: zigbee.0 (138145) Device '0x00124b000905236c' announced itself
    2024-01-03 20:02:31.127 - info: zigbee.0 (138145) Device '0x00124b000ef97050' announced itself
    2024-01-03 20:05:23.986 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:05:24.061 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:05:57.744 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
    2024-01-03 20:05:58.070 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:05:58.135 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:03.549 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
    2024-01-03 20:06:03.914 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:03.990 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:04.099 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:04.173 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:10.586 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
    2024-01-03 20:06:10.921 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:11.002 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:17.061 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:17.187 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:29.500 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
    2024-01-03 20:06:29.826 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:29.963 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:30.056 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:06:30.121 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:06:34.609 - info: zigbee.0 (138145) Device '0xec1bbdfffeb7412f' announced itself
    2024-01-03 20:10:55.133 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:10:55.225 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:16:10.284 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:16:10.424 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:16:30.517 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:16:30.590 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:21:45.649 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:21:45.727 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:23:19.667 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:23:20.174 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:27:17.262 - warn: zigbee.0 (138145) DeviceAvailability:Stopping to ping 0x001fee0000009307 S2-R (5602) after 4 ping attempts
    2024-01-03 20:28:35.259 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:28:35.359 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:29:00.881 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:29:00.969 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:34:16.033 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:34:16.132 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    2024-01-03 20:34:44.169 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
    2024-01-03 20:34:44.327 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
    Gruß Dirk
    • H Hadebe
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #382
      @hadebe
      Texte aus LOG oder der Konsole kopieren und in die Codetags einfügen.
      Lehrling seit 1975 !!!
      H 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        @hadebe
        Hadebe
        #383
        @djmarc75 @Segway danke - ist so einfach, wenn man weiss wie es geht. Werde ich beim nächsten Mal beherzigen
        • arteckA arteck
          @hadebe es würde schon helfen wenn LOG nicht als Bild gepostet werden
          Hadebe
          schrieb am zuletzt editiert von Hadebe
          #384
          @arteck Habe um 18:01 GIT-Version installiert, nochmals Gerät entfernt, Adapter neu gestartet und Gerät gekoppelt. Jetzt trat nur einmal ein Error im Join-Zeitfenster auf. Danach nicht mehr. Auch durch Ein-/Ausschalten wurde keine Fehlermeldung provoziert. Habe das Protokoll angefügt. Bis jetzt (nach mehr als einer halben Stunde) sind keine weiteren Zigbee-Meldungen aufgelaufen. Super! Für mich ist das jetzt ok. Danke!
          2024-01-04 18:00:33.074 - info: zigbee.0 (158827) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2227875","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA10"}]
          2024-01-04 18:01:20.716 - info: zigbee.0 (158827) Zigbee: allowing new devices to join.
          2024-01-04 18:01:22.872 - info: zigbee.0 (158827) Starting interview of '0x54ef441000aa11c5'
          2024-01-04 18:01:23.542 - info: zigbee.0 (158827) Successfully interviewed '0x54ef441000aa11c5', device has successfully been paired
          2024-01-04 18:01:23.542 - info: zigbee.0 (158827) Device '0x54ef441000aa11c5' is supported, identified as: Xiaomi Aqara dual relay module T2 (LLKZMK12LM)
          2024-01-04 18:01:23.543 - info: zigbee.0 (158827) -> Configuring 0x54ef441000aa11c5 lumi.switch.acn047
          2024-01-04 18:01:23.649 - error: zigbee.0 (158827) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
          2024-01-04 18:02:21.904 - info: zigbee.0 (158827) Zigbee: stop joining
          2024-01-04 18:05:40.680 - info: zigbee.0 (158827) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2227875","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2227875-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA10"}]
          2024-01-04 18:05:48.172 - warn: zigbee.0 (158827) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
          2024-01-04 18:06:03.154 - warn: zigbee.0 (158827) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
          2024-01-04 18:06:14.278 - warn: zigbee.0 (158827) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
          2024-01-04 18:06:23.475 - warn: zigbee.0 (158827) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
          • S Skarpain
            @souly75 jup =) mqtt installieren zigbee2mqtt installieren und schon klappte es und er fand den "trvzb"
            hatte einfach Zigbee Coordinator gestoppt dann konnte ich z2m startet und ging ohne probleme nun wieder Zigbee Coordinator gestartet und meine alten mussten nicht repaired werden ( glück gehabt )
            werd wahrscheinlich aber komplett auf zigbee2mqtt umswitchen
            kBrausewK Offline
            kBrausewK Offline
            kBrausew
            #385
            @skarpain sagte in ZigBee neue Version 1.8.x:
            @souly75 jup =) mqtt installieren zigbee2mqtt installieren und schon klappte es und er fand den "trvzb" ...
            Geht bei dir alles? Bei mir wird local_temperature nicht aktualisiert
            Wo Reporte ich den Fehler? Is doch bestimmt Herdsman und nicht der ZigBee-Adapter???
            Pi 4/8GB + SSD + Docker \ DebMatic HM-IP + HM-RF \ ioBroker
            HikVision InterCom \ tedee SmartLook
            Wiegand - TCP/IP Door Access Controller \ MF-549 Fingerprint/Code/RFID \ FP100 Fingerprint/Code
            Fritz 7590 (ohne SmartHome)
