  4. VIS echarts Widget
VIS echarts Widget
vis
26 Beiträge 3 Kommentatoren 4.3k Aufrufe 9 Beobachtet
    mike2712
    ist es möglich dem Echarts Widget die Echart ID mit einem String Tag zu übergeben?
    Die Idee war echart_oid":"echarts.0.Energy.Energie Verbrauch aktuell" durch "echart_oid":"0_userdata.0.echarts.echartsDP}"
    zu ersetzen, in diesem String würde dann der echartsDP stehen, das funktioniert leider nicht, es kommt folgender Fehler:
    Widget echarts
    [{"tpl":"tplEchartsChart","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","echart_oid":"echarts.0.Energy.Energie Verbrauch aktuell","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"noChartBackground":false},"style":{"left":"0px","top":"0px","width":"1260px","height":"600px"},"widgetSet":"echarts"}]
    Ich möchte das aus folgendem Grund machen, dieses wurde in diesem Thread von mir bereits diskutiert.
    Link iobroker Forum
    ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
    • M mike2712
      Widget echarts
      Link iobroker Forum
      M Online
      M Online
      MCU
      @mike2712 sagte in VIS echarts Widget:
      Eine Klammer vergessen
       "echart_oid":"{0_userdata.0.echarts.echartsDP}"
      M Agria4800A 2 Antworten Letzte Antwort
      • M MCU
        mike2712
        schrieb am zuletzt editiert von mike2712
        @mcu sagte in VIS echarts Widget:
        Wow, perfekt, so klappt es, zu mindestens sah es auf den ersten Blick so aus, ein paar Kleinigkeiten waren mir noch aufgefallen, aber habe das gerade nur nebenbei getestet, muss gleich auf Dienstreise und kann erst am Wochenende weitermachen. Danke wenn das so klappt wie ich es mir vorstelle ist das eine unendliche Erleichterung und spart mir unendliche viele views.
        @MCU wechselt man den echartDP nimmt er den Zeitrange des gewählten echart, er schaut beim ersten Aufruf nicht auf Deine Variable, erst man man sie aktualisiert, das hängt vermutlich mit dem Trigger Deines Script zusammen?
        • M mike2712
          M Online
          M Online
          MCU
          @mike2712 Ja. Das müsste man dort dann noch anpassen in dem Script. Bei Änderung von der Auswahl (echartDP) direkt die range anpassen.
          Ich hatte parallel schon ein anderes Programm geschrieben, bei dem werden die eChart-Objekte in ein Array geschrieben und sind dann auswählbar. Es wird dort nur ein eChart als View geben und diesem werden die Daten quasi reingesetzt. (-> das sieht man in dem GIF auf dem anderen Thread)
          Da war noch davon ausgegangen, dass die VIS es mit dem Binding nicht kann.
          Aber da du jetzt festgestellt hast, dass es geht, muss ich das 1. Programm nochmal anpassen.
          • M MCU
            mike2712
            ja keinen Stress, wenn Du da etwas gemacht hast wäre es gut wenn Du das aktuelle Script hier posten könntest, so ist es genau das was ich wollte. Ganz verstehe ich es nicht warum der Range nicht direkt mit aktualisiert wird, Dein Script wird durch durch Änderung einer der 3 Variablen an getriggert, richtig? Im Vis welchselt er bei echartsID direkt das echart, übernimmt aber nicht den Range aus Deiner Variable, erst wenn ich den Range erneut Trigger wird der richtige Zeitbereich dargestellt, es ist zunächst der vordefinierte Bereich aus den echart.
            • M mike2712
              M Online
              M Online
              MCU
              @mike2712 Angepasst. Jetzt kannst du fromRangeDP - true setzen -> Ausgewählte Kurve wird automatisch angepasst (rangeDP-Wert).
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./echartschange/javascript-echartschange
              • M MCU
                mike2712
                Super, danke, gerade mal kurzen Test gemacht, das klappt gut, jetzt muss ich mir noch was mit den Zeitachsen einfallen lassen, ich denke da kann man automatisch oder so was einstellen, da wird sich hoffentlich was finden lassen, und dann muss ich schauen wenn ich den echartDP an der VIS Button ändere eine Sinnvolle Zeit Achse vorgelegen, teilweise sind längere Bereiche sinnvoller, teilweise aber eben nicht weil er sich dann anhand der Datenmenge aufhängt. Dazu müsste ich an 1 Button irgendwie eine 2. Variable mit dran hängen oder irgendwie im Script abfangen wenn sich der echarts DP ändert die Range Variable eben überschreiben, da findet sich sicher auch eine Lösung.
                Ich denke das werde ich jetzt am Wochenende etwas basteln, Dir vielen Dank das hat mir wirklich enorm viel geholfen.
                • M mike2712
                  M Online
                  M Online
                  MCU
                  @mike2712 Was muss denn mit den Zeitachsen gemacht werden? Die Anzahl der angezeigten Werte anpassen.
                  Schau ich mal heute Abend.
                  Hab es nochmal aktualisiert. Nimm nochmal den Link von oben.
                  Beispiel mit xticks
                  • M MCU
                    Agria4800A Offline
                    Agria4800A Offline
                    Agria4800
                    Ich versuche mich auch gerade an der echart selection, soweit meine ich es auch verstanden zu haben, nur wo genau muss ich das eintragen?
                    M M 3 Antworten Letzte Antwort
                    • Agria4800A Agria4800
                      M Online
                      M Online
                      MCU
                      @agria4800 Hab es auch mal versucht, es klappt aber nicht. Keine Ahnung warum er gesagt hat, dass es bei ihm klappt.
                      Ist momentan auf Reise.
                      [{"tpl":"tplEchartsChart","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","echart_oid":"{0_userdata.0.echarts.echartsDP}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"436px","top":"39px","width":"635px","height":"490px","position":""},"widgetSet":"echarts"}]
                      Sehe nur ioBroker kreisen.
                        M Online
                        M Online
                        MCU
                        @agria4800 Es gibt jetzt eine andere Version von eChartsChange.
                        eChartsChangeSelect
                        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./echartschangeselect
                        • M MCU
                          mike2712
                          Im Editor sehe ich zunächst auch nur kreisen, der TAG muss aktualisiert werden, also bei mir funktioniert das, passen die Verzeichnisse etc. ?
                          • M MCU
                            Beispiel mit xticks
                            mike2712
                            Beispiel mit xticks
                            ich denke das ist ein Problem weil ich die Zeitbereiche (Achsbeschriftung) fest gesetzt habe im originalen echartsDP, das ist nicht bei allen so, ich hoffe das ich am Wochenende dort weiter testen und experimentieren kann.
                              mike2712
                              @agria4800 sagte in VIS echarts Widget:
                              ich habe das widget mit einem orignal echartDP exportiert und dann den DP durch diesen der durch das Script von @MCU in das Verzeichnis 0_userdata..... erzeugt wird ersetzt.
                              • M Online
                                M Online
                                MCU
                                @mike2712 Du hast Recht. Es funktioniert. Muss ich noch in der Doku beschreiben.
                                Hab es hier einmal beschrieben:
                                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./echartschange/vis-definition
                                Agria4800A 1 Antwort Letzte Antwort
                                • M mike2712
                                  Beispiel mit xticks
                                  M Online
                                  M Online
                                  MCU
                                  @mike2712 Wenn du die feste Achsbeschriftung behalten willst, solltest du auf eChartChangeSelect wechseln, da dort die Originale nicht verändert werden.
                                  • M MCU
                                    Agria4800A Offline
                                    Agria4800A Offline
                                    Agria4800
                                    schrieb am zuletzt editiert von Agria4800
                                    Danke für das update, das umschalten der verschiedenen echarts funktioniert gut. :-)
                                    eider komme ich mit der Zeitachse Error vom Script her... bei manchen echarts geht es, bei manchen nicht, da das script diese nicht findet... z.b.: Heizungstaktung !
                                    (EDIT: Eigenverschulden, Leerzeichen nach ";" war das Problem! Script funktioniert prima!!!)
                                    ~~Bildschirmfoto 2022-12-01 um 20.11.18.png Bildschirmfoto 2022-12-01 um 20.12.04.png
                                    0_userdata.0.echarts.fromRangeDP scheint bei mir auch nicht zu gehen.... false / true, keine Änderung... vielleicht habe ich auch auf die schnelle was falsch gemacht, gehe morgen nochmal mit etwas mehr Zeit dran. Achja, script Version ist die ChartsChange v1.0.2 .
                                    Ansonsten mal ein großen Lob und Danke an euch @mcu, @mike2712, darauf habe ich schon lange gewartet.
                                    Grüße Benny
                                      Grüße Benny
                                      M Online
                                      M Online
                                      MCU
                                      @agria4800 Einmal Objekte -> Expertenmodus an -> echarts.0 -> komplett anzeigen.
                                      Du hast ein Leerzeichen eingegeben. Das darf nicht!
                                        Grüße Benny
                                        Agria4800A Offline
                                        Agria4800A Offline
                                        Agria4800
                                        @agria4800 : ist schon interessant, wie schnell man sich mit einem leerzeichen einen fehler einbaut, ohne es zu merken...
                                        achtet beim ausfüllen auf die korrekte Schreibweise, so hatte ich es Bildschirmfoto 2022-12-01 um 20.21.09.png und das ist nicht gut, lasst also nach der Trennung mit dem ";" keine Leerzeichen !!!
                                          M Online
                                          M Online
                                          MCU
                                          @agria4800 Läuft es jetzt auch mit rangeDP?
