  4. VIS echarts Widget
VIS echarts Widget
vis
26 Beiträge 3 Kommentatoren 4.3k Aufrufe 9 Beobachtet
  • Agria4800A Agria4800
    @mcu sagte in VIS echarts Widget:
    @mike2712 sagte in VIS echarts Widget:
    "echart_oid":"0_userdata.0.echarts.echartsDP}"
    Eine Klammer vergessen
     "echart_oid":"{0_userdata.0.echarts.echartsDP}"
    Ich versuche mich auch gerade an der echart selection, soweit meine ich es auch verstanden zu haben, nur wo genau muss ich das eintragen?
    M Online
    M Online
    MCU
    @agria4800 Hab es auch mal versucht, es klappt aber nicht. Keine Ahnung warum er gesagt hat, dass es bei ihm klappt.
    Ist momentan auf Reise.
    [{"tpl":"tplEchartsChart","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","echart_oid":"{0_userdata.0.echarts.echartsDP}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"436px","top":"39px","width":"635px","height":"490px","position":""},"widgetSet":"echarts"}]
    Sehe nur ioBroker kreisen.
      M Online
      M Online
      MCU
      @agria4800 Es gibt jetzt eine andere Version von eChartsChange.
      eChartsChangeSelect
      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./echartschangeselect
      • M MCU
        mike2712
        Im Editor sehe ich zunächst auch nur kreisen, der TAG muss aktualisiert werden, also bei mir funktioniert das, passen die Verzeichnisse etc. ?
        ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
        • M MCU
          @mike2712 Was muss denn mit den Zeitachsen gemacht werden? Die Anzahl der angezeigten Werte anpassen.
          Schau ich mal heute Abend.
          Hab es nochmal aktualisiert. Nimm nochmal den Link von oben.
          Beispiel mit xticks
          mike2712
          Beispiel mit xticks
          ich denke das ist ein Problem weil ich die Zeitbereiche (Achsbeschriftung) fest gesetzt habe im originalen echartsDP, das ist nicht bei allen so, ich hoffe das ich am Wochenende dort weiter testen und experimentieren kann.
            mike2712
            @agria4800 sagte in VIS echarts Widget:
            ich habe das widget mit einem orignal echartDP exportiert und dann den DP durch diesen der durch das Script von @MCU in das Verzeichnis 0_userdata..... erzeugt wird ersetzt.
            • M Online
              M Online
              MCU
              @mike2712 Du hast Recht. Es funktioniert. Muss ich noch in der Doku beschreiben.
              Hab es hier einmal beschrieben:
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./echartschange/vis-definition
              Agria4800A 1 Antwort Letzte Antwort
              • M mike2712
                Beispiel mit xticks
                M Online
                M Online
                MCU
                @mike2712 Wenn du die feste Achsbeschriftung behalten willst, solltest du auf eChartChangeSelect wechseln, da dort die Originale nicht verändert werden.
                • M MCU
                  Agria4800A Offline
                  Agria4800A Offline
                  Agria4800
                  schrieb am zuletzt editiert von Agria4800
                  Danke für das update, das umschalten der verschiedenen echarts funktioniert gut. :-)
                  eider komme ich mit der Zeitachse Error vom Script her... bei manchen echarts geht es, bei manchen nicht, da das script diese nicht findet... z.b.: Heizungstaktung !
                  (EDIT: Eigenverschulden, Leerzeichen nach ";" war das Problem! Script funktioniert prima!!!)
                  ~~Bildschirmfoto 2022-12-01 um 20.11.18.png Bildschirmfoto 2022-12-01 um 20.12.04.png
                  0_userdata.0.echarts.fromRangeDP scheint bei mir auch nicht zu gehen.... false / true, keine Änderung... vielleicht habe ich auch auf die schnelle was falsch gemacht, gehe morgen nochmal mit etwas mehr Zeit dran. Achja, script Version ist die ChartsChange v1.0.2 .
                  Ansonsten mal ein großen Lob und Danke an euch @mcu, @mike2712, darauf habe ich schon lange gewartet.
                  Grüße Benny
                  M Agria4800A 2 Antworten Letzte Antwort
                    Grüße Benny
                    M Online
                    M Online
                    MCU
                    @agria4800 Einmal Objekte -> Expertenmodus an -> echarts.0 -> komplett anzeigen.
                    Du hast ein Leerzeichen eingegeben. Das darf nicht!
                      Grüße Benny
                      Agria4800A Offline
                      Agria4800A Offline
                      Agria4800
                      @agria4800 : ist schon interessant, wie schnell man sich mit einem leerzeichen einen fehler einbaut, ohne es zu merken...
                      achtet beim ausfüllen auf die korrekte Schreibweise, so hatte ich es Bildschirmfoto 2022-12-01 um 20.21.09.png und das ist nicht gut, lasst also nach der Trennung mit dem ";" keine Leerzeichen !!!
                        M Online
                        M Online
                        MCU
                        @agria4800 Läuft es jetzt auch mit rangeDP?
                        • M MCU
                          Agria4800A Offline
                          Agria4800A Offline
                          Agria4800
                          ja.... :-) habe schon meinen Beitrag kommentiert 😁
                          • M MCU
                            mike2712
                            Nein, möchte ich ja nicht, muss das in meinen originalen echarts auf automatisch stellen, macht ja keinen Sinn feste Achsbeschriftung für die Zeit zu haben wenn man sie umschalten möchte, wie gesagt ich hoffe ich komme dieses Wochenende dazu dann fliegen bestimmt 20 views aus dem VIS, alles wird wesentlich übersichtlicher.
                              mike2712
                              @MCU vielen Dank nochmal für das Script und die Unterstützung
                              ich habe jetzt ein paar Test gemacht und bekomme alles so hin wie ich es haben möchte. Habe das Script kopiert und benutze es Gruppenweise. Jetzt folgt Fleißarbeit, alle Float auf echart umstellen und in VIS alles anpassen, für die Zukunft ist es nach dem neuem System wesentlich einfacher und sehr pflegeleicht. Danke !
                              Dann ein zusätzliches Script wenn ich die Echarts umschalte das ein sinnvoller Range voreingestellt wird.
                              • M MCU
                                Agria4800A Offline
                                Agria4800A Offline
                                Agria4800
                                Ja, das manuelle verstellen der Zeitachse mit range funktioniert wunderbar, leider nicht das umschalten mit 0_userdata.0.echarts.fromRangeDP. Bei mir werden nicht die original Werte aus dem gespeicherten echart gezogen...
                                Er überschreibt die Werte aus dem rangeDB in die Objektdaten des echart; gepeichert sind im echart 1440, sobald ich einmal die Zeitachse mit range ändere, z.b. 10080, dann ist der neue Wert gespeichert... War so nicht geplant, oder ?
                                Bildschirmfoto 2022-12-02 um 20.19.48.png Bildschirmfoto 2022-12-02 um 20.20.20.png
                                Funktioniert das bei dir ?
                                  M Online
                                  M Online
                                  MCU
                                  @agria4800 Ja das ist so, wenn der fromRangeDP true ist.
                                  Deswegen, sagte ich ja, wenn man die originale behalten will muss man das andere Programm nutzen.
                                  eChartChange -> es wird immer im Original überschrieben!
                                  Wenn er immer den gespeicherten Wert von range aus dem Orig holen soll, muss fromRangeDP->false sein.
                                  Da man aber schon vorher fromRangeDP auf true, sind die orig range-Daten natürlcih überschrieben.
                                    mike2712
                                    schrieb am zuletzt editiert von mike2712
                                    @MCU
                                    [gelöst] Ich lasse das mal stehen, vielleicht hilft es anderen oder mir selbst wenn ich nächste mal vor dem Problem stehe.
                                    Ich bin gerade wieder an diesem Punkt, wollte den Rest meiner unzähligen Trends auf das neue System umstellen, dabei ist mir aufgefallen das sich das Script, trotz gleicher Version 1.02 massiv geändert hat, hab das neue genommen, alle meine alten Sachen funktionieren auch soweit, aber wenn ich jetzt neue Sachen erstelle funktioniert das nicht mehr, Ursache ist vermutlich (hier ist ein Unterschied in den DPs) das hier nichts mehr drin steht, wie werden diese Daten befüllt?
                                    Die Ordnerstruktur Definition war im alten Script nicht vorhanden.
                                    Beleuchtung ist neu
                                    Energy z.B. ist zuvor erstellt
                                    Okay, wer lesen kann ist klar im Vorteil, das sind 2 unterschiedliche paar Schuhe, echartschange und echartschangeselect, wieder auf das alte umgestellt, trotzdem funktioniert es leider nicht, jetzt kann ich keinen Fehler Unterschied entdecken.
                                    ToDo`s waren
                                    • Script kopieren und DP umbennen im Script
                                    • in vis den echarts DP, sowie den Range beschreiben
                                    Das sieht eigentlich gut aus, aber in vis wird die Kurve aus Beleuchtung nicht angezeigt-
                                    Lösung
                                    ToDo`s
                                    • Umbennung im Kurven Widget
