  4. Vis nach Backup nicht mehr aufrufbar
11 Beiträge 3 Kommentatoren 873 Aufrufe 3 Beobachtet
  • L Offline
    lustig29
    Ich habe bei meinen Eltern ein Backup des Iobrokers einspielen müssen. Seitdem geht die Visualisierung nicht mehr. Ich kann den Adapter weder löschen, noch kann ich ihn erneut installieren. Anbei ein Auszug aus dem Log:
    host.raspberrypi
    2022-11-23 17:59:20.483	error	iobroker host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
    host.raspberrypi
    2022-11-23 17:59:20.449	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-11-23T16_59_09_617Z-debug-0.log
    host.raspberrypi
    2022-11-23 17:59:20.442	info	iobroker npm ERR! command sh -c -- node main.js --install
    host.raspberrypi
    2022-11-23 17:59:20.440	info	iobroker npm ERR! command failed
    host.raspberrypi
    2022-11-23 17:59:20.433	info	iobroker npm ERR! path /opt/iobroker/node_modules/iobroker.vis
    host.raspberrypi
    2022-11-23 17:59:20.429	info	iobroker npm ERR! code 6
    vis.0
    2022-11-23 17:59:19.584	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    2022-11-23 17:59:19.582	info	terminating
    vis.0
    2022-11-23 17:59:19.078	error	Not exists
    vis.0
    2022-11-23 17:59:19.076	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
    vis.0
    2022-11-23 17:59:19.074	error	unhandled promise rejection: Not exists
    vis.0
    2022-11-23 17:59:19.072	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    • L lustig29
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      @lustig29 sagte in Vis nach Backup nicht mehr aufrufbar:
      Und was steht da drin?
      L 1 Antwort Letzte Antwort
        lustig29
        schrieb am zuletzt editiert von lustig29
        Meinst du das hier,
        2022-11-23 18:13:39.277 - info: host.raspberrypi iobroker npm ERR! code 6
        2022-11-23 18:13:39.278 - info: host.raspberrypi iobroker npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        2022-11-23 18:13:39.282 - info: host.raspberrypi iobroker npm ERR! command failed
        2022-11-23 18:13:39.286 - info: host.raspberrypi iobroker npm ERR! command sh -c -- node main.js --install
        2022-11-23 18:13:39.295 - info: host.raspberrypi iobroker
        2022-11-23 18:13:39.299 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:
        2022-11-23 18:13:39.303 - info: host.raspberrypi iobroker npm ERR! /home/iobroker/.npm/_logs/2022-11-23T17_12_35_641Z-debug-0.log
        2022-11-23 18:13:39.338 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker/ioBroker.vis: 6
        2022-11-23 18:13:40.380 - info: host.raspberrypi iobroker exit 25
        Oder kann ich mir das Log irgendwie anders anschauen?
        • L lustig29
          Meinst du das hier,
          Diese Datei.
          Mit
          less -R /home/iobroker/.npm/_logs/2022-11-23T17_12_35_641Z-debug-0.log
          geht's u. a.
            Diese Datei.
            Mit
            geht's u. a.
            lustig29
            bug-0.log
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@8.19.2
            2 info using node@v16.18.1
            3 timing npm:load:whichnode Completed in 1ms
            4 timing config:load:defaults Completed in 5ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
            6 timing config:load:builtin Completed in 3ms
            7 timing config:load:cli Completed in 10ms
            8 timing config:load:env Completed in 0ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
            10 timing config:load:project Completed in 25ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:validate Completed in 2ms
            16 timing config:load:credentials Completed in 3ms
            17 timing config:load:setEnvs Completed in 3ms
            18 timing config:load Completed in 55ms
            19 timing npm:load:configload Completed in 56ms
            20 timing npm:load:mkdirpcache Completed in 2ms
            21 timing npm:load:mkdirplogs Completed in 1ms
            22 verbose title npm install iobroker/ioBroker.vis
            23 verbose argv "install" "iobroker/ioBroker.vis"
            24 timing npm:load:setTitle Completed in 4ms
            25 timing config:load:flatten Completed in 9ms
            26 timing npm:load:display Completed in 11ms
            27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
            28 verbose logfile /home/iobroker/.npm/_logs/2022-11-23T17_12_35_641Z-debug-0.log
            29 timing npm:load:logFile Completed in 15ms
            30 timing npm:load:timers Completed in 0ms
            31 timing npm:load:configScope Completed in 0ms
            32 timing npm:load Completed in 92ms
            33 timing arborist:ctor Completed in 2ms
            34 silly logfile start cleaning logs, removing 2 files
            35 silly logfile done cleaning log files
            36 timing idealTree:init Completed in 2884ms
            37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            38 timing idealTree:userRequests Completed in 5233ms
            39 silly idealTree buildDeps
            40 silly fetch manifest iobroker.vis@iobroker/ioBroker.vis
            41 silly placeDep ROOT iobroker.vis@1.4.15 OK for: iobroker.inst@3.0.0 want: iobroker/ioBroker.vis
            42 silly fetch manifest axios@^1.1.3
            43 http fetch GET 200 https://registry.npmjs.org/axios 240ms (cache revalidated)
            44 timing idealTree:#root Completed in 3313ms
            45 silly placeDep node_modules/iobroker.vis axios@1.2.0 OK for: iobroker.vis@1.4.15 want: ^1.1.3
            46 timing idealTree:node_modules/iobroker.vis Completed in 9ms
            47 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
            48 timing idealTree:buildDeps Completed in 3326ms
            49 timing idealTree:fixDepFlags Completed in 28ms
            50 timing idealTree Completed in 11517ms
            51 timing reify:loadTrees Completed in 11520ms
            52 timing reify:diffTrees Completed in 99ms
            53 silly reify moves {}
            54 timing reify:retireShallow Completed in 4ms
            55 timing reify:createSparse Completed in 8ms
            56 timing reify:loadBundles Completed in 0ms
            57 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
            58 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
            59 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
            60 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
            61 timing reifyNode:node_modules/osx-temperature-sensor Completed in 14ms
            • L lustig29
              bug-0.log
              @lustig29
              Die Datei ist mit Sicherheit viel länger.
                @lustig29
                lustig29
                62 timing reifyNode:node_modules/fsevents Completed in 14ms
                63 silly tarball no local data for axios@https://registry.npmjs.org/axios/-/axios-1.2.0.tgz. Extracting by manifest.
                64 http fetch GET 200 https://registry.npmjs.org/axios/-/axios-1.2.0.tgz 500ms (cache miss)
                65 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 536ms
                66 http fetch GET 200 https://codeload.github.com/iobroker/ioBroker.vis/tar.gz/8d82d060c10d465201ad02099ea8846d10b53048 1945ms (cache miss)
                67 timing reifyNode:node_modules/iobroker.vis Completed in 47558ms
                68 timing reify:unpack Completed in 47560ms
                69 timing reify:unretire Completed in 1ms
                70 timing build:queue Completed in 99ms
                71 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
                72 info run iobroker.vis@1.4.15 install { code: 6, signal: null }
                73 timing reify:rollback:createSparse Completed in 264ms
                74 timing reify:rollback:retireShallow Completed in 1ms
                75 timing command:install Completed in 63312ms
                76 verbose stack Error: command failed
                76 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                76 verbose stack     at ChildProcess.emit (node:events:513:28)
                76 verbose stack     at maybeClose (node:internal/child_process:1100:16)
                76 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                77 verbose pkgid iobroker.vis@1.4.15
                78 verbose cwd /opt/iobroker
                79 verbose Linux 5.15.76-v8+
                80 verbose node v16.18.1
                81 verbose npm  v8.19.2
                82 error code 6
                83 error path /opt/iobroker/node_modules/iobroker.vis
                84 error command failed
                85 error command sh -c -- node main.js --install
                86 verbose exit 6
                87 timing npm Completed in 63646ms
                88 verbose unfinished npm timer reify 1669223555960
                89 verbose unfinished npm timer reify:build 1669223615169
                90 verbose unfinished npm timer build 1669223615172
                91 verbose unfinished npm timer build:deps 1669223615173
                92 verbose unfinished npm timer build:run:install 1669223615273
                93 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1669223615274
                94 verbose code 6
                95 error A complete log of this run can be found in:
                95 error     /home/iobroker/.npm/_logs/2022-11-23T17_12_35_641Z-debug-0.log
                • L lustig29
                  82 error code 6
                  86 verbose exit 6
                  94 verbose code 6
                  @lustig29
                  Installier eine Vorversion von vis und update die dann.
                    @lustig29
                    lustig29
                    Wie mache ich das?
                    • L lustig29
                      Wie mache ich das?
                      crunchipC Offline
                      crunchipC Offline
                      @lustig29
                      iobroker upgrade vis@1.4.0
                        @lustig29
                        lustig29
                        @crunchip said in Vis nach Backup nicht mehr aufrufbar:
                        Super, vielen Dank. Hat geklappt.
