  5. Bitte um Sample Code für "sendToAsync"
javascript
4 Beiträge 2 Kommentatoren 616 Aufrufe 2 Beobachtet
    Marty56
    Hallo
    Ich möchte die neue Funktion "sendToAsync" nutzen, um eine InfluxDB query durchzuführen.
    So habe ich das bisher realisiert mit selbst gebautem promise.
    async function sum(id,timestart,timeend,db) {
        //workarround to adjust Timezone Differenz to UTC
        var end   =  new Date(timeend).getTime()*1000000
        var start =  new Date(timestart).getTime()*1000000
        var sum = 0
        var query = 'SELECT sum("value") FROM "autogen"."' + id +'" WHERE time >= ' + start + ' AND time <= ' + end
        const abfrage = new Promise(function(resolve, error) {
            sendTo(db, 'query', query,
                function (result) {
                    if (result.error) {console.error(result.error);
                    } else {
                        if (result.result[0][0] != undefined) sum = result.result[0][0].sum
                        resolve(true)
        await abfrage
        return sum;
    Dann habe ich versucht, die neue Funktion zu nutzen und bekomme einen Javascript "termination".
    async function sum2(id,timestart,timeend,db) {
        var sum = 0
        var result = {}
        result = await sendToAsync(db, 'query', query)
        } else {
            //log('Summme von DB:' + db + ' id:'+ id + " Summe: " + sum + " von: " + timestart + " bis: " + timeend)
        return sum;
    (async ()  => {
        log("" +  await sum2(path2db + 'Auto_Ex.Tag_Energie',firstdayofyear + seach_time_start,yesterday +seach_time_end ,endless))
    Der Javascript Adapter stürzt ab mit folgender Fehlermeldung
    	2022-11-23 10:30:27.581	error	undefined
    javascript.0
    2022-11-23 10:30:27.581	error	unhandled promise rejection: undefined
    javascript.0
    2022-11-23 10:30:27.581	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Was mache ich falsch?
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • M Marty56
      Hallo
          var sum = 0
                  function (result) {
                      } else {
                          resolve(true)
          await abfrage
          return sum;
          var sum = 0
          var result = {}
          } else {
          return sum;
      (async ()  => {
      javascript.0
      javascript.0
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @marty56
      die Funktion wirft einen Fehler.
      Die Async Versionen der Funktionen geben primär ein Promise zurück.
      Der Befehl await hilft dem Programmierer dabei, simpler mit dem promise umzugehen. Allerdings nur wenn alles gut verläuft. Wirft das promise ein reject (also ein Fehler ist im Befehl aufgetaucht, dann muss man den mit try/catch abfangen
      https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Promise?retiredLocale=de
      Version 1: Klassischer Umgang mit Promise
      sendToAsync(db, 'query', query).then({
        //Funktionsteil wenn ohne Fehler
        //Funktionsteil wenn mit Fehler
      Version 2: Fehler bei Promis mit Await mit try/catch Anweisung
      try {
        result = await sendToAsync(db, 'query', query);
        ... weitere Abarbeitung im Gutfall
      } catch(err) {
        //Im Fehlerfall
      Version 3: Fehler bei Promise mit Await und catch-Funktion
      result = await sendToAsync(db, 'query', query).catch((err=>{
          //Im Fehlerfall
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        @marty56
        try {
        } catch(err) {
          //Im Fehlerfall
            //Im Fehlerfall
        Marty56
        schrieb am zuletzt editiert von Marty56
        @oliverio Danke für die Antwort.
        Ich habe deinen Vorschlag ausprobiert und glaube jetzt, dass die Funktion "sendToAsync" noch buggy ist.
        Es wird nämlich immer einen Fehler ausgelöst, auch wenn ein korrektes Ergebnis vorliegt.
        Und wenn ich dann den Inhalt des Fehler anschaue, wird das korrekte Ergebnis als Fehlerursache angezeigt.
            var sum = 0
            var result ={}
            var return_value
            try {
                    return_value = await sendToAsync(db, 'query', query);
                    log("Return" + JSON.stringify(return_value))
            catch (error) {
                console.error(error)
            return sum;
        liefert im Log
        error	script.js.common.Energie: {'result':[[{'sum':1333.9444199999998,'ts':1640991600000}]],'ts':1669200179686,'error':null}
        Ich mache mal ein Issue auf.
        HW:NUC (16 GB Ram)
        • M Marty56
              var sum = 0
              var result ={}
              var return_value
              try {
              catch (error) {
              return sum;
          liefert im Log
          Marty56
          https://github.com/ioBroker/ioBroker.javascript/issues/1198
          Ich glaube, dass ich auch den Bug gefunden habe.
          HW:NUC (16 GB Ram)
