  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • T tombox
    @bommel_030 es gibt jetzt zwei filter listen
    @clown007 ich habe nochmal logs hinzugefügt
    Clown007
    #181
    @tombox sagte in Test Adapter Garmin:
    2026-01-12 23:33:48.476  - debug: garmin.0 (397261) MFA Response title: Success
    2026-01-12 23:33:48.479  - info: garmin.0 (397261) MFA verification successful
    2026-01-12 23:33:48.479  - debug: garmin.0 (397261) Ticket: ST-281134-Xxm0wB32BcpLHh2g17lg-cas
    2026-01-12 23:33:48.479  - debug: garmin.0 (397261) Getting OAuth1 token...
    2026-01-12 23:33:48.997  - debug: garmin.0 (397261) Fetched OAuth consumer from S3
    2026-01-12 23:33:48.997  - debug: garmin.0 (397261) {"consumer_key":"fc3e99d2-118c-44b8-8ae3-03370dde24c0","consumer_secret":"E08WAR897WEy2knn7aFBrvegVAf0AFdWBBF"}
    2026-01-12 23:33:49.580  - debug: garmin.0 (397261) OAuth1 Status: 200
    2026-01-12 23:33:49.580  - debug: garmin.0 (397261) "oauth_token=a2d59379-a1e3-4a5d-b801-254e7610610b&oauth_token_secret=juIPzbGaeio0ria5HHiPlM32sNoo3nJm24Y&mfa_token=MFA-4166-q3IY01WZYBweJdrndrdGlfCXRWD1ZGt0avp04rB6lv5neXme1t-cas&mfa_expiration_timestamp=2027-01-12 22:33:48.000"
    2026-01-12 23:33:49.581  - debug: garmin.0 (397261) OAuth1 Token: OK
    2026-01-12 23:33:49.581  - debug: garmin.0 (397261) Exchanging for OAuth2 token...
    2026-01-12 23:33:49.581  - debug: garmin.0 (397261) oauth1Token: {"oauth_token":"a2d59379-a1e3-4a5d-b801-254e7610610b","oauth_token_secret":"juIPzbGaeio0ria5HHiPlM32sNoo3nJm24Y","mfa_token":"MFA-4166-q3IY01WZYBweJdrndrdGlfCXRWD1ZGt0avp04rB6lv5neXme1t-cas"}
    2026-01-12 23:33:49.581  - debug: garmin.0 (397261) authHeader: {"Authorization":"OAuth oauth_consumer_key=\"fc3e99d2-118c-44b8-8ae3-03370dde24c0\", oauth_nonce=\"WxShBZnGaUyc32QElolln2EqSHiqXWyA\", oauth_signature=\"ltG5oYAELBFPzDJpdF1LtEz43I0%3D\", oauth_signature_method=\"HMAC-SHA1\", oauth_timestamp=\"1768257229\", oauth_token=\"a2d59379-a1e3-4a5d-b801-254e7610610b\", oauth_version=\"1.0\""}
    2026-01-12 23:33:49.581  - debug: garmin.0 (397261) body: mfa_token=MFA-4166-q3IY01WZYBweJdrndrdGlfCXRWD1ZGt0avp04rB6lv5neXme1t-cas
    2026-01-12 23:33:49.725  - error: garmin.0 (397261) OAuth2 request failed: 401 Request failed with status code 401
    2026-01-12 23:33:49.725  - error: garmin.0 (397261) OAuth2 error response: "<!doctype html><html lang=\"en\"><head><title>HTTP Status 401 – Unauthorized</title><style type=\"text/css\">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 401 – Unauthorized</h1><hr class=\"line\" /><p><b>Type</b> Status Report</p><p><b>Message</b> Invalid signature for signature method HMAC-SHA1</p><p><b>Description</b> The request has not been applied to the target resource because it lacks valid authentication credentials for that resource.</p><hr class=\"line\" /><h3>Garmin Connect API Server</h3></body></html>"
    2026-01-12 23:33:49.725  - error: garmin.0 (397261) OAuth2 token exchange failed
    2026-01-12 23:33:49.725  - info: garmin.0 (397261) Clearing MFA session and token for fresh login...
    2026-01-12 23:33:49.730  - error: garmin.0 (397261) Login failed
    Ich hatte beim ersten mal eine falsche MFA eingegeben das gab klar eine Fehlermeldung. Für mich sieht es so als ob der Hashing Algorithmus nicht akzeptiert wird: " Invalid signature for signature method HMAC-SHA1"
    Wenn Du mehr vom log benötiogst, gib mir einfach eine kurze Info
    • B bommel_030
      @tombox
      hm, das läuft auch noch nicht rund...
      Beim Filter exakter Datenpunkt wird
      hydration.valueInML
      nicht angenommen,
      valueInML
      hingegen schon.
      Dieser Datenpunkt ist noch eineindeutig. Bei
      dailysleep.dailySleepDTO.sleepScores.overall.value
      wird das dann schon schwieriger, da
      value
      sehr oft verwendet wird. Ich fände es besser wenn der "Pfad" des Datenpunktes mit verwendet wird.
      Leider werden weiterhin auch noch ca. 5.000 weitere Datenpunkte angelegt. Es dürften eigentlich nur die 2 im Screenshot dargestellten Punkte auftauchen(der Info Teil natürlich auch).
      Die unteren drei Ordner sind leer, die oberen sind voll.
      tombox
      schrieb am zuletzt editiert von tombox
      #182
      @bommel_030 @clown007
      wurde nochmal aktualisiert
      B C 2 Antworten Letzte Antwort
      • T tombox
        bommel_030
        #183
        @tombox
        1. Kann es sein, dass Groß-/Kleinschreibung interessant ist?
          Ich habe die exakten Datenpunkte aus dem alten Baum kopiert.
        weight.dateWeightList01.bmi, weight.dateWeightList01.bodyFat, weight.dateWeightList01.weight, weight.dateWeightList01.boneMass, weight.dateWeightList01.muscleMass,weight.dateWeightList01.bodyWater, usersummary.totalSteps, usersummary.dailyStepGoal, usersummary.floorsAscended, usersummary.totalDistanceMeters, usersummary.bodyBatteryMostRecentValue, usersummary.bodyBatteryChargedValue, usersummary.bodyBatteryDrainedValue, usersummary.maxHeartRate, usersummary.restingHeartRate, dailysleep.dailySleepDTO.sleepScores.overall.value, usersummary.latestSpo2, dailystress.avgStressLevel, trainingstatus.mostRecentVO2Max.generic.vo2MaxValue, hydration.valueInML, hydration.sweatLossInML, hydration.goalInML
        Im Log gibt er die alle komplett klein geschrieben aus.
        Exact allowlist active: weight.dateweightlist01.bmi, weight.dateweightlist01.bodyfat, weight.dateweightlist01.weight, weight.dateweightlist01.bonemass, weight.dateweightlist01.musclemass, weight.dateweightlist01.bodywater, usersummary.totalsteps, usersummary.dailystepgoal, usersummary.floorsascended, usersummary.totaldistancemeters, usersummary.bodybatterymostrecentvalue, usersummary.bodybatterychargedvalue, usersummary.bodybatterydrainedvalue, usersummary.maxheartrate, usersummary.restingheartrate, dailysleep.dailysleepdto.sleepscores.overall.value, usersummary.latestspo2, dailystress.avgstresslevel, trainingstatus.mostrecentvo2max.generic.vo2maxvalue, hydration.valueinml, hydration.sweatlossinml, hydration.goalinml
        Im Objektbaum taucht kein einziger Datenpunkt aus der allowlist auf.
        1. Die ersten 4 Ordner werden trotzdem angelegt obwohl sie das eigentlich nicht sollten. Sind allein schon über 2.500 Datenpunkte.
        Trotzdem nochmals danke für deine Arbeit. Mit der neuen LogIn übersteht die Instanz bei mir auch einen Neustart des ioBrokers.
        • B bommel_030
          @tombox
          tombox
          #184
          @bommel_030 KI hat eine dritte liste hinzugefügt und mehr debug logs weil wenn du die Ordner löscht sollten sie nicht mit Datenpunkt wieder angelegt werden
          B 1 Antwort Letzte Antwort
          • T tombox
            Clown007
            #185
            @tombox Danke, Danke.
            Jetzt hat es problemlos geklappt!
            Das ist ja ein super Support!
            • T tombox
              bommel_030
              #186
              Hab wieder über die Katze installiert, aber eine dritte Liste taucht nicht auf?!?
              Ergebnis der Datenpunkte wie gehabt. Die Ordner auth und info sind eigentlich verständlich. Mit dem ordner devices habe ich grundsätzlich auch kein Problem.
              Wenn ich mir das logfile ansehe filtert er nicht nach dem exakten Datenpunkt, sondern nur nach dem ersten Teil, also z.B. hydration. Damit kann er die Datenpunkte nicht parsen.
              Im Ordner dailystress sollte nach der allowlist 1 Datenpunkt auftauchen. Exakt dieser eine taucht nicht auf, hunderte andere trotzdem. Würde aber immerhin erklären warum er den Ordner anlegt.
              Warum er aber den Ordner activities anlegt verstehe ich nicht, das taucht in der allolist definitiv nicht auf.
              Gekürztes Log anbei (das komplette würde den Rahmen sprengen, aber für hydration und activities ist der interessante Teil dabei).
              garmin.0 2026-01-13 21:10:12.937	debug	Parsing activities with filtered data: [{"userRoles":["SCOPE_GOLF_API_READ","SCOPE_DI_OAUTH_2_DEVICE_REVOCATION_WRITE","SCOPE_DI_OAUTH_2_CREATE_DI_USER","SCOPE_ATP_READ","SCOPE_DIVE_API_WRITE","SCOPE_COMMUNITY_COURSE_ADMIN_READ","SCOPE_DIVE_API_READ","SCOPE_DI_OAUTH_2_CLIENT_READ","SCOPE_CONNECT_WRITE","SCOPE_COMMUNITY_COURSE_WRITE","SCOPE_CONNECT_MCT_DAILY_LOG_READ","SCOPE_CONNECT_API_CREATE_UPDATE_USER","SCOPE_MESSAGE_GENERATION_READ","SCOPE_DI_OAUTH_2_CLIENT_REVOCATION_ADMIN","SCOPE_CONNECT_WEB_TEMPLATE_RENDER","SCOPE_OMT_SUBSCRIP
              garmin.0 2026-01-13 21:10:12.936	debug	[{"activityId":21535275938,"activityName":"Berlin Gehen","startTimeLocal":"2026-01-13 17:28:04","startTimeGMT":"2026-01-13 16:28:04","activityType":{"typeId":9,"typeKey":"walking","parentTypeId":17,"isHidden":false,"restricted":false,"trimmable":true},"eventType":
              garmin.0 2026-01-13 20:55:08.666	debug	No data left after allowlist filter for hydration
              garmin.0 2026-01-13 20:55:08.666	debug	{"userId":2400759,"calendarDate":"2026-01-13","valueInML":0,"goalInML":3022,"dailyAverageinML":null,"lastEntryTimestampLocal":"2026-01-13T17:28:04.0","sweatLossInML":222,"activityIntakeInML":0}
              garmin.0 2026-01-13 20:55:08.157	info	Found 3 devices
              garmin.0 2026-01-13 20:55:07.469	info	Exact allowlist active: hydration.valueinml, hydration.sweatlossinml, hydration.goalinml, trainingstatus.mostrecentvo2max.generic.vo2maxvalue, dailystress.avgstresslevel, usersummary.latestspo2, dailysleep.dailysleepdto.sleepscores.overall.value, usersummary.restingheartrate, usersummary.maxheartrate, usersummary.bodybatterydrainedvalue, usersummary.bodybatterychargedvalue, usersummary.bodybatterymostrecentvalue, usersummary.totaldistancemeters, usersummary.floorsascended, usersummary.dailystepgoal, usersummary.totalsteps, weight.dateweightlist01.bodywater, weight.dateweightlist01.musclemass, weight.dateweightlist01.bonemass, weight.dateweightlist01.weight, weight.dateweightlist01.bodyfat, weight.dateweightlist01.bmi
              garmin.0 2026-01-13 20:55:07.461	info	starting. Version 0.2.1 (non-npm: TA2k/ioBroker.garmin) in /opt/iobroker/node_modules/iobroker.garmin, node: v22.21.0, js-controller: 7.1.0
              • B bommel_030
                tombox
                #187
                @bommel_030 ist jetzt drin
                • T tombox
                  bommel_030
                  #188
                  @tombox
                  Jetzt mit dritter Liste, aber leider gleichem Ergebnis. Diesmal nur mit hydration.goalinml in der allowlist.
                  Die grünen Ordner sind ok, der gelbe sollte nicht da sein, stört aber nicht, die beiden magenta sollten nicht auftauchen.
                  Der erlaubte hydration taucht leider gar nicht auf.
                  debug.log
                  • B bommel_030
                    @tombox
                    debug.log
                    tombox
                    #189
                    @bommel_030 nochmal testen
                    • T tombox
                      bommel_030
                      #190
                      @tombox
                      Sobald ich einen Filter eingebe Werte kommen keine Daten an.
                      Die Ordner activities und dailystress erscheinen jetzt aber nicht mehr.
                      Wenn ich den Filter rausnehme kommen wieder Daten rein....
                      • B bommel_030
                        @tombox
                        tombox
                        #191
                        @bommel_030 bräuchte den log
                        • C Offline
                          chris299
                          #192
                          @tombox funktioniert einwandfrei bei mir. aber gibt es irgendwo eine liste mit allen möglichen Datenpunkten? idealerweise mit beschreibung, was das jeweils genau ist?
                          • T tombox
                            bommel_030
                            #193
                            @tombox
                            Der Hinweis mit dem Array hat geholfen. Danke, alle Daten kommen jetzt rein.
                            Wenn es nach mir ginge reicht im Array die 01 als Datenpunkt, da stehen die aktuellen Werte drin. Der zusätzlichen Ordner 02 müsste nicht erscheinen.
                            • MassiveAttackM Offline
                              MassiveAttack
                              #194
                              ganz verstehe ich noch nicht, welche elemente ich wo eintragen muss. kann mir da bitte jemand einen tipp geben?
                              • MassiveAttackM MassiveAttack
                                bommel_030
                                #195
                                @MassiveAttack
                                Kommt drauf an was du genau haben willst. Wenn du dir explizit Datenpunkte aussuchst die du haben möchtest, kopiere den Pfad (doppeltes Blatt neben dem value in der markierten Zeile von deinem Screenshot) und trage ihn "Exakte Pfade (komma-separiert)" in der Instanz ein. Den Teil "garmin.0." musst du dann noch entfernen. Weitere Datenpunkte nach gleichem Schema komma separiert hinten dran. Wichtig, bei Arrays die Zahl entfernen.
                                hydration.valueInML, hydration.sweatLossInML, hydration.goalInML, trainingstatus.mostRecentVO2Max.generic.vo2MaxValue, dailystress.avgStressLevel, usersummary.latestSpo2, dailysleep.dailySleepDTO.sleepScores.overall.value, usersummary.restingHeartRate, usersummary.maxHeartRate, usersummary.bodyBatteryDrainedValue, usersummary.bodyBatteryChargedValue, usersummary.bodyBatteryMostRecentValue, usersummary.totalDistanceMeters, usersummary.floorsAscended, usersummary.dailyStepGoal, usersummary.totalSteps, weight.dateWeightList.bodyWater, weight.dateWeightList.muscleMass, weight.dateWeightList.boneMass, weight.dateWeightList.weight, weight.dateWeightList.bodyFat, weight.dateWeightList.bmi
                                MassiveAttackM 1 Antwort Letzte Antwort
                                • B bommel_030
                                  @MassiveAttack
                                  MassiveAttack
                                  #196
                                  @bommel_030
                                  Besten Dank :)
