  4. [Aufruf] IKEA-Trådfri Adapter testen
471 Beiträge 49 Kommentatoren 175.9k Aufrufe 5 Beobachtet
    #41
    Auch nach versuch über die Konsole kein trådfri ordner
    linaro@linaro-alip:/opt/iobroker$ npm install https://github.com/AlCalzone/ioBroker.tradfri --production
    node-mbed-dtls@2.4.4 preinstall /opt/iobroker/node_modules/.staging/node-mbed-dtls-a5e9e04f
    node downloadDeps.js
    Cloning into 'mbedtls'...
    bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
    node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/bufferutil/build'
    CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
    In file included from ../node_modules/nan/nan.h:82:0,
    from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handlev8::integer) [with T = v8:
    :Int32; v8::Handle v8::integer= v8::Localv8::integer]:
    ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated
    (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarat
    ions]
    Tov8::int32(v8::Handle v8::integeri) { return i->ToInt32(); }
    :Uint32; v8::Handle v8::integer= v8::Localv8::integer]’:
    ../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local v8::uint32v8::Value::ToUint32() const’ is deprecat
    ed (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declar
    ations]
    Tov8::uint32(v8::Handle v8::integeri) { return i->ToUint32(); }
    In file included from ../node_modules/nan/nan_new.h:189:0,
    from ../node_modules/nan/nan.h:82,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :booleanobject="">::return_t NanIntern::Factoryv8::booleanobject::New(bool)’:
    ../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local v8::valuev8::BooleanObjec
    t::New(bool)’ is deprecated (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:4008): Pass an isola
    te [-Wdeprecated-declarations]
    return v8::BooleanObject::New(value).Asv8::booleanobject();
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :script="">::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string)’:
    ../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local v8::scriptv8::ScriptComp
    iler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (
    declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declaratio
    ns]
    return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :script="">::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local v8::scriptv8::ScriptComp
    ns]
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :string="">::return_t NanIntern::Factoryv8::string::New(const uint8_t*, int)’:
    ../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local v8::stringv8::String::Ne
    wFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated (declared at /home/
    linaro/.node-gyp/6.10.2/include/node/v8.h:2332): Use maybe version [-Wdeprecated-declarations]
    v8::String::kNormalString, length);
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :string="">::return_t NanIntern::Factoryv8::string::New(v8::String::ExternalStringResource*)’:
    ../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local v8::stringv8::String::Ne
    wExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated (declared at /home/linaro/.node-g
    yp/6.10.2/include/node/v8.h:2371): Use maybe version [-Wdeprecated-declarations]
    return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :unboundscript="">::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string)’:
    ../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local v8::unboundscriptv8::Scr
    iptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ i
    s deprecated (declared at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:1333): Use maybe version [-Wdepreca
    ted-declarations]
    return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8: :unboundscript="">::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string, const v8::ScriptO
    rigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local v8::unboundscriptv8::Scr
    ted-declarations]
    In file included from ../src/bufferutil.cc:16:0:
    ../node_modules/nan/nan.h: At global scope:
    ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::
    Local)’
    NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
    ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previ
    ously declared here
    NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
    ../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared
    at /home/linaro/.node-gyp/6.10.2/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declar
    ations]
    return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
    v8::Isolate::GCEpilogueCallback callback
    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
    , v8::GCType gc_type_filter = v8::kGCTypeAll) {
    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
    v8::Isolate::GCEpilogueCallback callback) {
    ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
    v8::Isolate::GCPrologueCallback callback
    ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
    v8::Isolate::GCPrologueCallback callback) {
    ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
    , node::smalloc::FreeCallback callback
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(char*, size_t, int)’:
    ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
    v8::Isolate::GetCurrent(), data, length, callback, hint);
    ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(const char*, uint32_t)’:
    ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
    return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
    In file included from ../src/bufferutil.cc:10:0:
    /home/linaro/.node-gyp/6.10.2/include/node/node_buffer.h:46:40: note: initializing argument 2 of ‘v8::MaybeLo
    cal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)’
    NODE_EXTERN v8::MaybeLocal v8::objectNew(v8::Isolate* isolate,
    ../node_modules/nan/nan.h:672:67: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((ch
    ar*)data), size)’ from ‘v8::MaybeLocalv8::object’ to ‘v8::Localv8::object’
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(uint32_t)’:
    ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size
    return node::Buffer::New(v8::Isolate::GetCurrent(), size);
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanBufferUse(char*, uint32_t)’:
    ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
    return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string, const v
    8::ScriptOrigin&)’:
    ../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isol
    ate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /home/lina
    ro/.node-gyp/6.10.2/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
    return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string)’:
    ../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isol
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handlev8::object)’:
    ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
    t char [7], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
    NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
    ../src/bufferutil.cc:30:52: note: candidates are:
    In file included from ../src/bufferutil.cc:8:0:
    /home/linaro/.node-gyp/6.10.2/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Local<v8::temp late="">, const char*, v8::FunctionCallback)
    inline void NODE_SET_METHOD(v8::Local v8::templaterecv,
    /home/linaro/.node-gyp/6.10.2/include/node/node.h:257:13: note: void node::NODE_SET_METHOD(v8::Local<v8::obje ct="">, const char*, v8::FunctionCallback)
    inline void NODE_SET_METHOD(v8::Local v8::objectrecv,
    ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
    t char [5], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
    NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
    ../src/bufferutil.cc:31:48: note: candidates are:
    ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, cons
    t char [6], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
    NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
    ../src/bufferutil.cc:32:50: note: candidates are:
    bufferutil.target.mk:94: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build'
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:2
    3)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    gyp ERR! System Linux 4.4.16
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild
    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
    gyp ERR! node -v v6.10.2
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    node-mbed-dtls@2.4.4 install /opt/iobroker/node_modules/node-mbed-dtls
    node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/node-mbed-dtls/build'
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/aes.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/aesni.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/arc4.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/asn1parse.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/asn1write.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/base64.o
    CC(target) Release/obj.target/mbedcrypto/mbedtls/library/bignum.o
    ../mbedtls/library/bignum.c: In function ‘mpi_mul_hlp’:
    ../mbedtls/library/bignum.c:1168:1: error: r7 cannot be used in asm here
    mbedcrypto.target.mk:144: recipe for target 'Release/obj.target/mbedcrypto/mbedtls/library/bignum.o' failed
    make: *** [Release/obj.target/mbedcrypto/mbedtls/library/bignum.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/node-mbed-dtls/build'
    3)
    gyp ERR! cwd /opt/iobroker/node_modules/node-mbed-dtls
    gyp ERR! not ok
    iobroker@1.0.0 /opt/iobroker
    ── (empty)
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! Linux 4.4.16
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/AlCalzone/ioBroker.tradfri" "--p
    roduction"
    npm ERR! node v6.10.2
    npm ERR! npm v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! node-mbed-dtls@2.4.4 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the node-mbed-dtls@2.4.4 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the node-mbed-dtls package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs node-mbed-dtls
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls node-mbed-dtls
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /opt/iobroker/npm-debug.log
    npm ERR! code 1</v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::obje></v8::template></v8::temp></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8:></v8::unboundscript></v8::string></v8::unboundscript></v8:></v8::string></v8::string></v8:></v8::string></v8::string></v8:></v8::script></v8::string></v8::script></v8:></v8::script></v8::string></v8::script></v8:></v8::booleanobject></v8::value></v8::booleanobject></v8:></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
    Rainer
    • H Offline
      han_swurst
      #42
      Hallo AlCalzone,
      ich hab den Pi nochmal frisch aufgesetzt um alles nochmal durchzuführen und meine Schritte zu dokumentieren.
      Also gestartet wird mit nem frischen Pi3, anschließend node und iobroker installieren:
      alten node Kram entfernen..
      sudo apt-get --purge remove node
      sudo apt-get --purge remove nodejs
      sudo apt-get autoremove
      sudo reboot
      Repos für node 6.x einrichten und node 6.10.3 installieren:
      curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
      sudo apt-get install -y build-essentials python nodejs
      reboot
      Verzeichnis für iobroker erstellen und iobroker installieren:
      sudo mkdir /opt/iobroker
      sudo chmod 777 /opt/iobroker
      cd /opt/iobroker
      sudo npm install iobroker --unsafe-perm
      Beim installieren traten Fehler bei iobroker.discovery auf.
      Keine Ahnung ob das für Dein Adapter relevant ist.
      Hier mal das Log für die Installation von iobroker
      log.txt
      git-core und anschließend Deinen Adapter installieren:
      sudo apt-get install git-core
      sudo npm install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master --production --unsafe-perm 2>&1 | tee tradfri_inst.log
      Hier das Log der Installation
      log.txt
      Adapter instanzieren…
      iobroker add tradfri
      Ausgabe:
       host.raspberrypi install adapter tradfri
       npm install –production (System call) in "/opt/iobroker/node_modules/iobroker.tradfri"
       got /opt/iobroker/node_modules/iobroker.tradfri/admin
       upload [2] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/words.js words.js application/javascript
       upload [1] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/tradfri.png tradfri.png image/png
       upload [0] tradfri.admin /opt/iobroker/node_modules/iobroker.tradfri/admin/index.html index.html text/html
       host.raspberrypi object system.adapter.tradfri created
       host.raspberrypi create instance tradfri
       host.raspberrypi object system.adapter.tradfri.0.outputCount created
       host.raspberrypi object system.adapter.tradfri.0.inputCount created
       host.raspberrypi object system.adapter.tradfri.0.uptime created
       host.raspberrypi object system.adapter.tradfri.0.memRss created
       host.raspberrypi object system.adapter.tradfri.0.memHeapTotal created
       host.raspberrypi object system.adapter.tradfri.0.memHeapUsed created
       host.raspberrypi object system.adapter.tradfri.0.connected created
       host.raspberrypi object system.adapter.tradfri.0.alive created
       host.raspberrypi object system.adapter.tradfri.0 created
      Eingabe von IP und SecurityCode…
      Und leider wieder derselbe Fehler im iobroker Log:
      host.raspberrypi	2017-05-11 22:11:28.803	info	Restart adapter system.adapter.tradfri.0 because enabled
      host.raspberrypi	2017-05-11 22:11:28.802	error	instance system.adapter.tradfri.0 terminated with code null ()
      host.raspberrypi	2017-05-11 22:11:28.802	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
      host.raspberrypi	2017-05-11 22:11:26.334	info	instance system.adapter.tradfri.0 started with pid 4488
      host.raspberrypi	2017-05-11 22:10:56.317	info	Restart adapter system.adapter.tradfri.0 because enabled
      host.raspberrypi	2017-05-11 22:10:56.316	error	instance system.adapter.tradfri.0 terminated with code null ()
      host.raspberrypi	2017-05-11 22:10:56.315	warn	instance system.adapter.tradfri.0 terminated due to SIGABRT
      host.raspberrypi	2017-05-11 22:10:53.745	info	instance system.adapter.tradfri.0 started with pid 4478
      host.raspberrypi	2017-05-11 22:10:51.290	info	instance system.adapter.tradfri.0 terminated with code 0 (OK)
      tradfri.0	2017-05-11 22:10:51.254	info	terminating
      host.raspberrypi	2017-05-11 22:10:51.223	info	stopInstance system.adapter.tradfri.0 killing pid 4467
      host.raspberrypi	2017-05-11 22:10:51.222	info	stopInstance system.adapter.tradfri.0
      host.raspberrypi	2017-05-11 22:10:51.217	info	object change system.adapter.tradfri.0
      tradfri.0	2017-05-11 22:06:41.889	info	requesting coap endpoint /15001
      tradfri.0	2017-05-11 22:06:41.837	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.10.3
      host.raspberrypi	2017-05-11 22:06:39.392	info	instance system.adapter.tradfri.0 started with pid 4467
      host.raspberrypi	2017-05-11 22:06:39.358	info	object change system.adapter.tradfri.0
      Was mir noch aufgefallen ist, die Instanz des Adapters terminiert sich sobald sie eine IP konfiguriert hat. Im unkonfiguriertem Zustand, oder wenn die IP gelöscht wird, bleibt die Instanz gestartet.
      MfG
      Chris
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #43
        @han_swurst:
        > mdns@2.3.3 install /opt/iobroker/node_modules/mdns
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/mdns/build'
        CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
        In file included from ../src/dns_sd.cpp:1:0:
        ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
        #include <dns_sd.h>
        compilation terminated.
        dns_sd_bindings.target.mk:149: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/mdns/build'</dns_sd.h>
        Da haben wir's doch! Ich schau, wie man das beheben/verhindern kann.
          AlCalzoneA Offline
          AlCalzone
          #44
          @Homoran:
          Die DTLS-Library scheint hier nicht kompatibel zu sein :( Muss ich mal schauen, ob ich ein anderes Paket finde.
            ACE76
            #45
            erst einmal vielen Dank an AlCalzone für die Entwicklung dieses Adapters!
            Nach stöbern im Thread habe ich es letztendlich geschafft den Tradfri Adapter zu installieren. Nun habe ich allerdings das Problem, dass sich der Adapter scheinbar nicht mit dem Gateway verbindet, obwohl die IP als auch Security Code stimmen. Ich finde einfach den Fehler nicht selbst.
            Das Log zeigt die folgende Schleife (IP anonymisiert):
            tradfri.0	2017-05-13 00:11:06.844	info	requesting coap endpoint 192.168.XXX.XX/15001
            tradfri.0	2017-05-13 00:11:06.820	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v4.8.1
            tradfri.0	2017-05-13 00:11:06.774	debug	statesDB connected
            tradfri.0	2017-05-13 00:11:06.699	debug	objectDB connected
            tradfri.0	2017-05-13 00:10:52.588	info	requesting coap endpoint 192.168.XXX.XX/15001
            tradfri.0	2017-05-13 00:10:52.564	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v4.8.1
            tradfri.0	2017-05-13 00:10:52.497	debug	statesDB connected
            tradfri.0	2017-05-13 00:10:52.423	debug	objectDB connected
            Unter den Objekten werden keine Datenpunkte für die Geräte angelegt. Lediglich eine Instanz.
            Hat jemand eine Idee woran dies liegen könnte? Falls ich noch etwas anderes beisteuern kann zur Fehlerfindung bitte ich um Hinweis.
            PS:
            @han_swurst:
            Was mir noch aufgefallen ist, die Instanz des Adapters terminiert sich sobald sie eine IP konfiguriert hat. Im unkonfiguriertem Zustand, oder wenn die IP gelöscht wird, bleibt die Instanz gestartet. `
            Gerade noch diesen Post gesehen und überprüft. Ist bei mir genau so. Ändert aber nichts daran, dass kein Ordner angelegt wird mit den Geräten.
            • H Offline
              han_swurst
              #46
              @AlCalzone:
              @han_swurst:
              > node-gyp rebuild
              #include <dns_sd.h>
              Da haben wir's doch! Ich schau, wie man das beheben/verhindern kann. `
              Das ist nicht das Problem. Da fehlen ein nur ein paar Abhängigkeiten für mdns.
              Ein apt-get install libavahi-compat-libdnssd-dev behebt den Fehler beim Installieren von mdns.
              Ich hab auch schon libcoap installiert bzw. kompiliert. Aber auch damit bringt der Adapter den bekannten Fehler.
              Nochwas:
              Ich weiß nicht obs Dir beim Fehler suchen hilft, aber der Adapter schmiert nur ab, wenn man die IP vom Ikea-Gateway eingibt.
              MfG
              Chris
                AlCalzoneA Offline
                AlCalzone
                #47
                Danke für die zahlreichen Infos. Ich kann noch nichts versprechen, da ich aktuell nicht viel Zeit habe, aber ich versuche im Laufe der Woche nachzuvollziehen, was da bei euch schief läuft.
                Dass keine Objekte angelegt werden, ist zu erwarten, da der Adapter keine Verbindung herstellt. Die Objekte sollten bei erfolgreicher Verbindung angelegt werden.
                Update: Ich kann euer Problem mittlerweile reproduzieren. Bei Ausführung über Konsole gibt es weitere Infos:
                io.tradfri.0: ../../nan/nan.h:704: Nan::MaybeLocal <v8::object>Nan::CopyBuffer(const char*, uint32_t): Assertion `size <= imp::kMaxLength && "too large buffer"' failed.</v8::object>
                Wenn ich jetzt noch wüsste, warum das vorher bei mir funktioniert hat…
                  AlCalzoneA Offline
                  AlCalzone
                  #48
                  Ich habe mal nach Alternativen geschaut:
                  • mbed-dtls (aktuelle Lösung, problematisch)
                  • tiny-dtls (in C geschrieben, schlecht bis nicht dokumentiert, muss ich irgendwie wrappen)
                  • node-dtls (nodeJS, aber kann nur RSA, kein PSK wie von Tradfri benötigt, Code ist etwas… äääh unübersichtlich)
                  • libcoap (kann kein DTLS, der beigelegte client erfordert pro überwachter Ressource [das sind einige] einen neuen Prozess)
                  Habe mich jetzt entschieden, DTLS und CoAP selbst zu implementieren, das wird aber noch ein bisschen dauern…
                    smartie
                    #49
                    Hallo!
                    "Update: Ich kann euer Problem mittlerweile reproduzieren. Bei Ausführung über Konsole gibt es weitere Infos:
                    Code:
                    io.tradfri.0: ../../nan/nan.h:704: Nan::MaybeLocal v8::objectNan::CopyBuffer(const char*, uint32_t): Assertion `size <= imp::kMaxLength && "too large buffer"' failed.
                    Wenn ich jetzt noch wüsste, warum das vorher bei mir funktioniert hat…"
                    Nun, ohne der große JS Experte zu sein:
                    Ich würde vermuten das wenn das auf RPi NICH läuft, auf anderen Umgebungen schon würde ich schlicht vermuten das es daran liegt, das der standardmäßig für JAVA bereitgestellte Speicher auf dem RPi schlicht kleiner ist als in anderen Umgebungen.
                    Das ist denke ich aber eher Symptom und nicht Ursache. Die Frage ist: Was braucht denn im tradfri Adapter so eine Menge an Speicher, denn offensichtlich ist die Größe, also der Wert des 1. Parameters zu groß ....
                    Ich bekomme diese start/crash schleife auch ohne eigegebene IP/Securitycode ....</v8::object>
                      smartie
                      #50
                      So, ich muss nun meinen Beitrag ergänzen - das Fehlerbild hat sich geändert.
                      Mein erstes Problem war: Die Prozedur zum Entfernen von node.js 4 hat wohl nicht funktioniert - und so hatte ich v4 und v7 parallel ( fieser weise hat die Command-line auf v7 zugegriffen, aber ioBroker auf v4).
                      Somit bin ich jetzt bei dem Status: Keine IP eingetragen –> Adapter läuft.
                      "Irgend eine IP - nur kein tradfri gate" --> Adapter sended coap request - und bekommt natürlich keine Antwort.
                      Sobald ich die IP vom Gate eingebe - auch ohne Securitycode crasht der Adapter mit
                      "host.csprint01 2017-05-30 16:43:38.925 error instance system.adapter.tradfri.0 terminated with code null ()
                      host.csprint01 2017-05-30 16:43:38.924 warn instance system.adapter.tradfri.0 terminated due to SIGABRT"
                      So ins Blaue geraten also dann wenn der client irgendwas antwortet ....
                        smartie
                        #51
                        Hallo zusammen!
                        Ich habe mal ein bischen angefangen zu debuggen- um einzugrenzen wo der crash passiert:
                        Es liegt an coapClient.js
                        Line 147 - 172
                        Mehr Details habe ich noch nicht, aber vielleicht hilft's ja ….
                          AlCalzoneA Offline
                          AlCalzone
                          #52
                          Danke für den Input. Mir ist bewusst, dass es an den 3rd-party libs liegt - irgendwas mit fehlerhafter Buffer-Größe. Hatte weiter oben auch schon mal einen Log gepostet mit dem exakten Fehler.
                          Was mich nur wundert:
                          Ich habe die erste Version auf einem Raspi 2 entwickelt, auf dem vorher schon einiges anderes installiert war. Da hats einwandfrei funktioniert. Die CI-Tests ebenfalls.
                          Dann kamen die ersten Nutzer, die es auf diversen Systemen nicht ausführen konnten. Auf einem frisch aufgesetzten Raspi (2 oder 3, weiß ich gerade nicht) ging es dann plötzlich auch bei mir nicht mehr. Irgendwas scheint also zu fehlen, nur was…?
                          Naja, ich werde die COAP und DTLS-Libraries demnächst durch eigenen Code ersetzen - ist nicht so schrecklich umfangreich auf der Client-Seite. Bin nur gerade im Umzugsstress, da ist keine Zeit für so Spielchen.
                            smartie
                            #53
                            Das ist sicher eine gute Idee.
                            Ich bin auch noch einen Schritt weiter:
                            Das Problem liegt in coap-dtls/index.js , bei der Instantiierung des Agent ab Zeile 41 - 52.
                              AlCalzoneA Offline
                              AlCalzone
                              #54
                              Das Problem müsste eigentlich im Paket mbed-dtls liegen, da hier die Bindings zum nativen C-Code liegen.
                              https://github.com/AlCalzone/node-mbed- … master/src
                              Wenn du die exakte Stelle finden solltest, lass es mich wissen. Ansonsten werde ich (sobald ich Zeit habe) die Libraries durch selbstgeschriebenen Code (reines JS) ersetzen.
                                smartie
                                #55
                                Damit kann ich dienen:
                                in node-mbed-dstl\client_socket.js
                                Zeile 52: Bei der Instantiierung von mbed.DtlsClientSocket kracht's …..
                                Smartie
                                  smartie
                                  #56
                                  @smartie:
                                  Smartie `
                                  … ich nehm alles zurück und behaupte das Gegenteil ....
                                  Dar Aufruf
                                  const data = this.mbedSocket.receiveData(msg);
                                  in client_socket.js macht das Problem. (So um Zeilennummer 85).
                                    sunny999999
                                    #57
                                    Gibts in dieser Richtung was neues ?
                                    Häng auch da und warte auf ne Lösung oder nen workaround…...
                                    Thx
                                    Sunny
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #58
                                      Bin dran, dauert leider noch etwas. Die Implementierung von (D)TLS ist recht aufwändig und ich war die letzten Wochen nur unterwegs. Bin auf jeden Fall dran, da ich den Adapter in meiner Wohnung auch brauche.
                                        sirtwist672
                                        #59
                                        Hallo AlCalzone,
                                        ohne hetzen zu wollen,
                                        gibts was neues?
                                        SirTwist
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #60
                                          Habe letzte Woche die ersten Kommunikationsversuche per DTLS unternommen und einige Fehler ausgebaut. Prinzipiell funktioniert der Handshake (Austausch der Verschlüsselungsinformationen).
                                          Allerdings habe ich dabei gemerkt, dass das Gateway nur AEAD-Verschlüsselungsmethoden unterstützt, die ich noch nicht implementiert hatte. Da komme ich frühestens Donnerstag dazu… habe leider momentan fast jede Minute neben der Arbeit verplant. Dann kann ich endlich testen, ob der reguläre Datenaustausch auch funktioniert.
                                          CoAP steht dann auch noch an. Das scheint zumindest in einer rudimentären Variante nicht besonders viel zu werden.
