  4. Sonoff-Adapter: Frage zu einer Warnung
sonoff-adapter
12 Beiträge 6 Kommentatoren 1.6k Aufrufe 6 Beobachtet
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    bekomme vom Sonoff-Adapter für eine Komponente die u. g. Meldung. Wie kann ich das Secret anpassen/ändern?
    sonoff.0
    2022-09-07 04:55:52.863	warn	Old client Carport with secret 1662525906131_4270 sends publish. Ignore! Actual secret is 1662526547077_8383
    sonoff.0
    2022-09-07 04:55:52.861	warn	Old client Carport with secret 1662525906131_4270 sends publish. Ignore! Actual secret is 1662526547077_8383
    sonoff.0
    sonoff.0
    2022-09-07 04:55:52.861	warn	Old client Carport with secret 1662525906131_4270 sends pingreq. Ignore! Actual secret is 1662526547077_8383
    sonoff.0
    sonoff.0
    sonoff.0
    2022-09-07 04:55:47.078	info	Client [Carport] reconnected. Old secret 1662525906131_4270. New secret 1662526547077_8383
    sonoff.0
    2022-09-07 04:54:48.261	info	Client [Sonoff_3] reconnected. Old secret 1662470969672_8268. New secret 1662526488259_3125
    sonoff.0
    2022-09-07 04:45:06.131	info	Client [Carport] reconnected. Old secret 1662525561962_6919. New secret 1662525906131_4270
    sonoff.0
    2022-09-07 04:39:22.891	warn	Old client Carport with secret 1662525278104_6244 sends publish. Ignore! Actual secret is 1662525561962_6919
    sonoff.0
    2022-09-07 04:39:22.858	warn	Old client Carport with secret 1662525278104_6244 sends publish. Ignore! Actual secret is 1662525561962_6919
    sonoff.0
    sonoff.0
    2022-09-07 04:39:22.858	warn	Old client Carport with secret 1662525278104_6244 sends pingreq. Ignore! Actual secret is 1662525561962_6919
    sonoff.0
    sonoff.0
    sonoff.0
    2022-09-07 04:39:21.963	info	Client [Carport] reconnected. Old secret 1662525278104_6244. New secret 1662525561962_6919
    sonoff.0
    2022-09-07 04:35:34.308	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
    sonoff.0
    2022-09-07 04:35:34.305	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
    sonoff.0
    2022-09-07 04:35:34.304	warn	Old client Carport with secret 1662525059329_7760 sends publish. Ignore! Actual secret is 1662525278104_6244
    sonoff.0
    2022-09-07 04:35:34.304	warn	Old client Carport with secret 1662525059329_7760 sends pingreq. Ignore! Actual secret is 1662525278104_6244
    sonoff.0
    sonoff.0
    sonoff.0
    2022-09-07 04:34:38.104	info	Client [Carport] reconnected. Old secret 1662525059329_7760. New secret 1662525278104_6244
    liv-in-skyL SegwayS 2 Antworten Letzte Antwort
    • qqolliQ qqolli
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      @qqolli
      so genau weiß ich auch nicht, was die meldung bedeutet aber versuche mal:
      den sonoff vom strom zu nehmen - ein wenig warten und wieder einstecken
      evtl vorher die sonoff instanz pausieren - den sonoff ausstecken, den ordner dieses sonoffs löschen (im object tab), instanz starten und dann den sonoff erst einstecken (wieder an den strom)
      qqolliQ 2 Antworten Letzte Antwort
      • liv-in-skyL liv-in-sky
        @qqolli
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        @liv-in-sky
        Danke für die schnelle Antwort. Habe ich gemacht. Mal sehen, ob es das war :-)
          @qqolli
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          @liv-in-sky
          Hallo nochmal,
          leider hat es doch nichts gebracht :-(
          sonoff.0
          2022-09-07 06:13:51.121	warn	Old client Carport with secret 1662530490519_7131 sends publish. Ignore! Actual secret is 1662531224737_9385
          sonoff.0
          2022-09-07 06:13:51.119	warn	Old client Carport with secret 1662530490519_7131 sends publish. Ignore! Actual secret is 1662531224737_9385
          sonoff.0
          sonoff.0
          2022-09-07 06:13:51.119	warn	Old client Carport with secret 1662530490519_7131 sends pingreq. Ignore! Actual secret is 1662531224737_9385
          sonoff.0
          sonoff.0
          • qqolliQ qqolli
            @liv-in-sky
            Hallo nochmal,
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            Ralla66R Offline
            Ralla66R Offline
            Ralla66
            @qqolli
            Im Sonoff Adapter mal Carport löschen. Nach neustart vom Sonoff Adapter wird der Datenpunkt neu angelegt.
            qqolliQ 1 Antwort Letzte Antwort
            • Ralla66R Ralla66
              @qqolli
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              @ralla66
              Genau das hatte ich ja nach Anweisung von @liv-in-sky gemacht :-)
              Ralla66R liv-in-skyL 3 Antworten Letzte Antwort
              • qqolliQ qqolli
                @ralla66
                Ralla66R Offline
                Ralla66R Offline
                Ralla66
                @qqolli
                Dann wurde der DP nicht richtig gelöscht.
                Lösche mal Carport im Adapter und benenne den Teilnehmer um in z.B. Carport0
                • qqolliQ qqolli
                  @ralla66
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @qqolli
                  was hat dieser sonoff für eine tasmota version - evtl updaten
                  • qqolliQ qqolli
                    @ralla66
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    @qqolli
                    da gibt es noch den thread - vielleicht hilft da was https://forum.iobroker.net/post/594581
                      @qqolli
                      RalfDr
                      Bei mir hat geholfen in der Tasmotakonsole "MqttKeepAlive 15" einzugeben, bei der Sonoff Zigbeebridge, weil da konnte ich keine ältere Tasmotaversion installieren, bei allen anderen habe ich keine höhere Tasmotaversion wie 6.4.2 mit Core 2.3 installiert, da ich bei den höheren Versionen auch das Problem hatte.
                      Gruß Ralf
                      • qqolliQ qqolli
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        SegwayS Offline
                        SegwayS Offline
                        Segway
                        @qqolli sagte in Sonoff-Adapter: Frage zu einer Warnung & @arteck :
                        Gibt es hier schon eine sagen wir mal offizielle Lösung um diese Meldungen wegzubekommen ?
                        manchmal kommen schon einige dieser meldungen ins Log - die bei mir auch zahlreich vorhanden sind.
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        sonoff.0
                        Gruß Dirk
                        AgrippinenserA 1 Antwort Letzte Antwort
                        • SegwayS Segway
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          sonoff.0
                          AgrippinenserA Offline
                          Agrippinenser
                          @segway sagte in Sonoff-Adapter: Frage zu einer Warnung:
                          ich hatte heute Morgen, mal wieder, jede Menge dieser Meldungen im Log und habe mal das Forum | Github nach Infos abgegrast. Einige Vorschläge kamen dabei zusammen aber eine "offizielle Lösung :-)" habe ich nicht gefunden.
                          (https://github.com/ioBroker/ioBroker.sonoff/issues/273#issuecomment-1146838710)
                          Nachricht ignorieren bzw. Device überprüfen.
                          (https://github.com/ioBroker/ioBroker.sonoff/issues/71#issuecomment-544563395)
                          zwei Clients mit identischer ID
                          (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/30?_=1707195614667)
                          Tasmota-Console: WifiPower 15
                          (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/24?_=1707195614667)
                          Fritzbox Funkkanal wechseln
                          (https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq/13?_=1707195614667)
                          Adapter Loglevel reduzieren
                          (https://forum.iobroker.net/topic/57770/sonoff-adapter-frage-zu-einer-warnung/10)
                          Console: MqttKeepAlive 15
                          (https://forum.iobroker.net/topic/57770/sonoff-adapter-frage-zu-einer-warnung/6)
                          Datenpunkt löschen und durch restart Sonoff-Adapter neu aufbauen.
                          Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
