  4. Backitup kein JavaScript Restore möglich!
103 Beiträge 7 Kommentatoren 11.2k Aufrufe 7 Beobachtet
  • B BenjaminCz
    @benjamincz
    Started iobroker ...
    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
    [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
    [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
    #61
    @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
    Das muss wohl
    192.168.178.58:/IOBroker-Backup
    lauten.
    B 1 Antwort Letzte Antwort
      Das muss wohl
      lauten.
      BenjaminCz
      #62
      jetzt kommt der Fehler:
      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups"
      [ERROR] [mount] - [undefined mount: bad usage
      Try 'mount --help' for more information.
      [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
      mount: bad usage
      • B BenjaminCz
        mount: bad usage
        simatecS Offline
        simatecS Offline
        simatec
        schrieb am zuletzt editiert von simatec
        #63
        @benjamincz
        Installiere mal die nfs-common
        sudo apt install nfs-common
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @benjamincz
          BenjaminCz
          schrieb am zuletzt editiert von BenjaminCz
          #64
          @simatec said in Backitup kein JavaScript Restore möglich!:
          sudo apt install nfs-commons
          pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt install nfs-commons
          Reading package lists... Done
          Building dependency tree... Done
          E: Unable to locate package nfs-commons
          pi@raspberrypi:~ $
          -bash: pi@raspberrypi:~: command not found
          -bash: Reading: command not found
          -bash: Building: command not found
          -bash: E:: command not found
          nfs-common is already the newest version (1:1.3.4-6).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $
          simatecS Thomas BraunT 2 Antworten Letzte Antwort
          • B BenjaminCz
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            simatecS Offline
            simatecS Offline
            simatec
            #65
            @benjamincz
            Sorry verschrieben
            nfs-common
            • B BenjaminCz
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              #66
              @benjamincz
              Zu viele Leerzeichen und die Freigabe doppelt. Vermutlich sollte es
              sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
              lauten.
              Und bitte verwende CodeTags, dann sieht man sowas auch viel schneller.
                @benjamincz
                lauten.
                BenjaminCz
                #67
                [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups"
                [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/:/IOBroker-Backup
                [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups
                • B BenjaminCz
                  #68
                  Immer noch ein falscher Pfad...
                  muss das.
                    muss das.
                    BenjaminCz
                    #69
                    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups"
                    [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/IOBroker-Backup
                    [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                    • simatecS simatec
                      @legro Entweder ihr überprüft die Userrechte auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                      Grundsätzlich ist es aber kein Problem von Backitup sondern ein Problem eurer NAS Konfiguration
                      legro
                      #70
                      Vielen Dank für deine Rückmeldung
                      @legro .. auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner ..
                      Das ist definitiv nicht der Fall. Der verwendete User ioBroker hat auf den in der Fritz!Box 7590 volle Zugriffsrechte. So kann er beispielsweise problemlos die verschiedenen Unterordner für die getrennte Speicherung der Backup-Dateien anlegen. Daran sollte es also in meinem Falle nicht liegen.
                      .. oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                      Hierzu muss ich die Dateien von ZigBee und YAHKA in das Verzeichnis "/opt/iobroker/backups" kopieren. Verstehe ich das richtig?
                      Das werde ich morgen früh einmal probieren.
                      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                      • B BenjaminCz
                        #71
                        @benjamincz
                        Und die Rechte an der Freigabe sehen wie aus?
                        Bei NFS sollte es (im einfachsten Fall) die gleiche uid/gid wie der user 'iobroker' sein.
                        • L legro
                          #72
                          @legro sagte in Backitup kein JavaScript Restore möglich!:
                          Der interne CIFS? Muss mit 'noserverino' und SMB Protokoll 3.1.1 gemountet werden.
                          L 1 Antwort Letzte Antwort
                            @benjamincz
                            BenjaminCz
                            #73
                            @thomas-braun da ist alles beim alten Geblieben. Muss der ordner öffentlich sein weil da ist ein Passwort drin.
                            im Nas steht die Freigabe so:
                            Bereitstellungspunkt: nfs://192.168.178.58/nfs/test
                            nicht wundern ich habe einen neuen ordner erstellt wo leer ist. Evtl. habe ich die einstelllungen falsch im Backitup ?
                              legro
                              schrieb am zuletzt editiert von legro
                              #74
                              @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                              Aber klar doch. Ich habe mir hierzu sogar eine eigene Anleitung geschrieben, als ich mich - damals noch vergeblich - an den Umstieg von Buster 32bit auf Bullseye 64bit wagte. Mittlerweile sind viele Ungereimtheiten (YAHKA pam-devil, ZigBee, Vis, ..) beseitigt, die mich damals zur Aufgabe trieben. Mittlerweile reicht's offenbar, Vis und Webserver in eine leere ioBroker Installation einzupflegen, um anschließend mittels BackItUp erfolgreich eine Backup aus Buster einzuspielen.
                              Daran liegt's offenbar auch nicht.
                              Bitte mir jetzt nicht auch den Rat geben, CIFS in die Tonne zu klopfen. Ich benötige die Fritz!Box für die Zugriffe von Windows PCs.
                              • B BenjaminCz
                                #75
                                Der Ordner muss dem gleichen user wie auf dem Raspberry gehören.
                                Meist ist das
                                echad@chet:~ $ sudo -u iobroker id
                                uid=1001(iobroker) gid=1001(iobroker)
                                • L legro
                                  #76
                                  Würde ich tun, wenn die FritzBox denn NFS spräche. Tut sie aber nicht.
                                  Im übrigen schnurrt meine FritzBox ganz okay mit CIFS, auch was javaskript-Restore angeht.
                                    legro
                                    #77
                                    Das macht mir Hoffnung, dass das Problem doch noch gelöst werden kann. Denn bei mir funktioniert die Fritz!Box ebenso vortrefflich, sodass ich keinen Grund sehe, auf FTP umzusteigen.
                                    Aber was machst du anders als ich?🙄
                                    • L legro
                                      #78
                                      Vielleicht mal in einem eigenen Thread? Das geht hier zu sehr kreuz und quer.
                                      B L 2 Antworten Letzte Antwort
                                        BenjaminCz
                                        #79
                                        Also. Habe etliches versucht leider kein Erfolg.
                                        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/test:/ /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/test:/
                                        [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/test:/ /opt/iobroker/backups
                                        Immer der gleiche Fehler....
                                        • B BenjaminCz
                                          #80
                                          test:
                                          test hat keinen Doppelpunkt im Namen.
